Sir Cheddar Posted May 11, 2013 Posted May 11, 2013 I posted an mod for running Pinball FX2 over at VPForums. Blur, if anything of it is of use to you feel free to rip it out.
blur Posted May 15, 2013 Posted May 15, 2013 great tnx! will check it out My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Sir Cheddar Posted May 17, 2013 Posted May 17, 2013 (edited) Zen has announced an in-game setting for portrait mode soonish. I think it's best to wait, then we can drop this Display Changer/iRotate mess Edit: Said option has been integrated a few days ago. I've updated the mod. Edit2: Updated again to v1.2 Edited May 29, 2013 by Sir Cheddar
Darkmeteor Posted May 25, 2013 Posted May 25, 2013 Well, BAM is able to run different executables, I don't know since which version though. Here's my modification to the fplaunch.ahk (1.295 wip 10) to make this happen : At lines 562 & 564 I replaced the following : "%emupath%\%executable%" with : %emupath%BAM\FPLoaderNew.exe /FPEXE:"%executable%" After this, just specify which other than the default settings.ini exe you want to run in the settings/fpexetables.txt (tablename[enter]fpexe.exe[enter]...)
flynt Posted June 10, 2013 Posted June 10, 2013 (edited) Well, BAM is able to run different executables, I don't know since which version though. Here's my modification to the fplaunch.ahk (1.295 wip 10) to make this happen :At lines 562 & 564 I replaced the following : "%emupath%\%executable%" with : %emupath%BAM\FPLoaderNew.exe /FPEXE:"%executable%" After this, just specify which other than the default settings.ini exe you want to run in the settings/fpexetables.txt (tablename[enter]fpexe.exe[enter]...) When using FPLaunch.exe the BAM Mod is working properly. But if starting Hyperpin and launching a FP-Table, the cam isnt working anymore. In BAM menu there is simply a black preview-window. Edited June 10, 2013 by flynt
zeenon Posted June 15, 2013 Posted June 15, 2013 Can anyone provide some guidance as to the settings for the new virtuapin plunger/encoder. The encoder is set to joy8 for exit. I've had the keyboard working with no issues in VP/FP for the last month while waiting on the plunger kit. The only thing that I can't get working is exiting tables using the kit (keyboard 'e' works). I have tried replacing the exit settings in the settings.ini with Joy8, but hitting the exit button on the front of the cab brings up the hyperpin exit and the VP exit menu. Any help would greatly be appreciated, as I'm so close to finishing the cab. Z
Clark Kent Posted June 18, 2013 Posted June 18, 2013 (edited) Problem solved - it was the new focus preferences. Just saw this in the version history but not described on page 1! Edited June 18, 2013 by Clark Kent
Clark Kent Posted June 21, 2013 Posted June 21, 2013 Can somebody explain what the menu "More Games" does and if I can start other games than FP and VP how to integrate them into HP?
rockyrocket Posted July 22, 2013 Posted July 22, 2013 Hi blur, So I have started running PinballFX2 with LEDBlinky for lighting effects see here. And I am thinking that I shall also use it for FP, however that is an issue with the LEDwiz enabled tables. Now I know there are only a handfull at the moment, so they could have a subsection each in FPlaunch but how hard would it be to parse a list like fpexetables.txt?. I may be the only one who is interested in doing this so do not expect it added into the mainstream build, just wondering about your thoughts on this?. Starwars build Tron build Tempest build
studmuff Posted August 16, 2013 Posted August 16, 2013 (edited) I just downloaded and get an rror when trying to run a table: Must be in th sam directory as Hyprpin.ex Not sure what this means???? I had to change hyperpin.exe to VirtualPin.exe Edited August 16, 2013 by studmuff Tom.
Sir Cheddar Posted August 17, 2013 Posted August 17, 2013 Added support for BAM and Future DMD to my Pinball FX2 mod. VPUniverse: link VPForums: link
snjspiteri Posted August 21, 2013 Posted August 21, 2013 I am having trouble with viewing my instruction cards since upgrading to this wip10 which used to work fine in earlier versions. I get an error with the ActiveX n shock wave line in the script. I updated to the latest version adobe flash but still get the errors. I also was getting an error when launching a table with the pwb.color movie but I ; them out n now table launch. Can anyone help to fix these errors please? Thx Joe
snjspiteri Posted September 16, 2013 Posted September 16, 2013 All fixed it seems I was using the wrong version of autohotkey. Must use the anci 32 version not Unicode.
skewba98z28 Posted September 22, 2013 Posted September 22, 2013 Thought I would link this here as it seems to be a FPLaunch issue http://www.hyperspin-fe.com/forum/showthread.php?28624-Exit-Sound-Sound-Playing-3-Times&p=271936#post271936
Gilrock Posted October 5, 2013 Posted October 5, 2013 I worked out most of my FPLaunch WIP 10 issues today except for one. I can't get FP tables to Pause/Exit. I have FP configured to pause with the right mouse button and that is working. While playing an FP table in Hyperpin using FPLaunch my 'e' and 'p' keys do nothing, a right mouse button will pause the table and show high scores, and ESC is the only way I can exit the table back to the Hyperpin wheel. In VP the 'e' and 'p' keys are working fine. They bring up the exit menu with a short press and exit the table 3,2,1 with a long press. Any ideas?
Les73gtx Posted November 5, 2013 Posted November 5, 2013 I would like a couple things fixed please ... Only using VP so first is the multiple instruction card error ... I found a post that says it doesn't work right now. And the annoying multiple flipper or clicking sound when exiting from VP table back to HP. I thought I read how to fix that or turn it off but now I can't find it. Sorry I would love to see the focus issue fixed that still exists randomly when going back to HP from VP. It requires a mouse click to fix it but no mouse in my cab and the wife and kids need it to be as error free as possible. I don't feel that running a script that clicks the mouse during my game is a fix, sorry. Thanks for your time and hard work Cheers Sent from my iPad using Tapatalk
Sir Cheddar Posted November 16, 2013 Posted November 16, 2013 Added support for FarSight's Pinball Arcade. VPUniverse: link VPForums: link
OzStick Posted December 11, 2013 Posted December 11, 2013 (edited) Help, I've hit a snag! I've been running WIP9 for ages as I use a slightly modded version that I compiled for myself that disables access to the Service Menu. It works perfectly well, however not with Direct B2S tables! Every time I close a dB2S table in HyperPin it appears to "freeze", however it is simply due to the active backglass not being shut down. If I hold down my Pause/Quit button I get the 3,2,1... screens which THEN closes the backglass, sends focus back to HyperPin and allows proper functionality to resume. But if I rename the table file so it has B2s at the end of it (eg ACDC-B2S.vpt) I end up with an error message when trying to run the table: I'm pretty sure this is due to using an old version of FPLaunch which has the routine from Rosve for handling the older type of B2S tables. So after all that, is there a way I can contiue to use my modded WIP9 FPlaunch file or do I need to bite the bullet and use WIP10? Am I supposed to name the tables XXXX-B2S.vpt and XXXX-B2S.directb2s for them to work correctly in HyperPin with WIP10? I'm apprehensive about updating FPLaunch as this machine is running 285 tables without issue and it's at my sporting club with a lot of different people using it, so I don't want to get caught up with too many problems as a result of trying to add a few new tables! Edited December 11, 2013 by OzStick
blur Posted January 1, 2014 Posted January 1, 2014 (edited) If i remember correctly my policy is this (i haven't been on forums for half a year so i might be forgeting something): if i open b2s exe from fplaunch script i will close it, if table opens b2s exe from the table script - table script should close it - not the fplaunch. how do you control this: - if you want me to start and close b2s - give table and b2s exe same name that ends with b2s, and set launch b2s in table script to false - if you want table to launch b2s exe set table name that doesn't end with b2s and set launch to true in table script and put closing of b2s somewhere in the script - i think there were many examples on how to close exe on table close on forums Edited January 1, 2014 by blur My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
blur Posted January 3, 2014 Posted January 3, 2014 So about your problem Oz - directb2s is a bit different - you can run it in controller mode or exe mode, whichever mode you run it - table script should start and close db2s. when you put table name that ends with b2s run is searching for exe with same name as table and you probably don't have it - you could probably put db2s to exe mode, set launch to false in script and run it and close it from fplaunch My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
ICPjuggla Posted June 30, 2014 Posted June 30, 2014 I just got around to installing wip 10 having a bit of a problem The tables load fine but on exit a box pops up: FPLaunch.exe You are missing ledcontrole file. Refer to the documentation text to fix this. Not sure where I should go from here. Please help. :-) also, where is the documentation text? In the folder there is a hyperpin-help-file but it says nothing about ledcontrole. A side note I have an ledcontrole file in my tables folder not sure if that's what it's talking about... sigh I wish it was all just plug and play.. lol
spaceship Posted July 27, 2014 Posted July 27, 2014 I downloaded and it is working nicely except that when I launch any table with a dB2S backglass setup i get this error message: "File 'C:\Program Files\Visual Pinball\Tables\Notepad.directb2s not found. Please rename or download the matching directb2s backglass files" the backglass loads fine outside of hyperpin and this just happened after updating to this FPlaunch
reko19 Posted February 27, 2015 Posted February 27, 2015 (edited) Thought I would link this here as it seems to be a FPLaunch issuehttp://www.hyperspin-fe.com/forum/showthread.php?28624-Exit-Sound-Sound-Playing-3-Times&p=271936#post271936 anybody was able to resolve the exit click sound being played 3 times instead of just once when you exit back to hyperpin Edited February 27, 2015 by reko19
Les73gtx Posted March 2, 2015 Posted March 2, 2015 anybody was able to resolve the exit click sound being played 3 times instead of just once when you exit back to hyperpin . . I never did solve it and I know why it happens ... the frontend is doing what it needs to trying grab focus. What I did do was find the .wav file and change it to something less annoying, and low volume. Shortly after this issue I abandoned the HP frontend all together in favor of one that is supported and updated regularly. That was over a year ago and I can say I am completely satisfied with the new frontend
bill55 Posted March 2, 2015 Posted March 2, 2015 .. I never did solve it and I know why it happens ... the frontend is doing what it needs to trying grab focus. What I did do was find the .wav file and change it to something less annoying, and low volume. Shortly after this issue I abandoned the HP frontend all together in favor of one that is supported and updated regularly. That was over a year ago and I can say I am completely satisfied with the new frontend Which frontend? My Pinball Build: Indiana Jones and the Pinball Crusade
Create an account
Register a new accountSign in
Sign In Now
