sanchezmike01 Posted February 27, 2019 Posted February 27, 2019 Ok usually I dont ask for help for android but this is a 1st for me....as I scroll thru the Sega mega drive wheel I added, once it gets to the 1st game starting with letter "O", hyperspin crashes ...even if i navigate using the letters option when i get to letter "O" again it crashes....i use a default theme i made and have cart art, boxart,and wheel for all the games ...will upload a log as I'm clueless to what happening...thanks
dougan78 Posted February 27, 2019 Posted February 27, 2019 Maybe start with removing images to see if it’s a bad image causing it to crash.Remove cartsRemove boxesRemove wheelsMaybe letter o has a bad image?Or review the letter o images to ensure no corrupt ones.Just an idea. Good luck.
sanchezmike01 Posted February 27, 2019 Author Posted February 27, 2019 Will do...thanks...crazy because I've done many hyperspin android systems and a simple console is kicking my azz....lmaoooo....smh
thatman84 Posted February 27, 2019 Posted February 27, 2019 @sanchezmike01 post your xml please Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Creezz67 Posted February 27, 2019 Posted February 27, 2019 You have a corrupt database. Thats why it's starting from letter O Either change it or fix it and you should be good to go.
sanchezmike01 Posted February 27, 2019 Author Posted February 27, 2019 At work but I'll try with teamviewer from my phone to upload xml...lol
sanchezmike01 Posted February 27, 2019 Author Posted February 27, 2019 Ok this the xml...I changed the name to just mega drive and deleted the 1st game that starts with "O"...now it crashed with the normys game...its really weird like it's a glitch or something but just on this 1 system Mega Drive.xml
sanchezmike01 Posted February 27, 2019 Author Posted February 27, 2019 Sega genesis works with no issues...damn near the same names except they have (usa) tag and mega drive has (europe) at the end ....I may start this 1 literally from the bottom up to see what's going on...also uninstalled hyperspin and reinstalled from the playstore....I didnt deleted any files though which possibly I should have like obb folder contents for hyperspin....tomorrow I'll skip work and may have time 2 work on it
mikty Posted February 27, 2019 Posted February 27, 2019 one time my android setup crash suddenly. a default theme become corrupt. so you could try to delete your theme and test to know if it's the problem
thatman84 Posted February 27, 2019 Posted February 27, 2019 Try this one. Mega Drive.xml Removed the apostrophes. Im in bed sick right now, just on my phone so cant test it Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Bungles Posted February 27, 2019 Posted February 27, 2019 Also make sure your settings are ok. I found that when I had a special art set where length=0 it crashed the entire application. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
sanchezmike01 Posted February 28, 2019 Author Posted February 28, 2019 Finally figured it out and fixed it...smh....took everyone's suggestions and went thru everything 1by1 line by line....2 bad images was the cause of the crash..these 2 images I will post would not open in android causing it to immediately crash....thanks everyone for the inputs and advice
