Mame Compiler 100% Automated
Rain
Are you sure your using the correct Mame version for your computer?
314 members have voted
  1. 1. Are you sure your using the correct Mame version for your computer?
    • Yes
      117
    • No
      62
    • Not sure?
      177
Software used: QuickMame v2.1.0.9 only
Processor Options
Processor Type: native - 64-bit
Core Options: Dual
General Options
Selected: Enable Direct Input, Enable High Score, Disable Warnings, Clean Compile
Build Version: 3
Base Build: unselected
Status:
Mame ini: Automatically created
"hi" folder: Automatically created
skip_gameinfo: Automatically = 1
Nag Screen: First play only
Mame compiled & running successfully!!
Problems:
Build Mame UI selected: Not created
  • Replies 589
Yeah, MameUI requires additional source files that are not as of yet handled by QuickMame. I will add these into the next build after a little bit of testing. Thanks!
Got this error =(
src/osd/windows/video.c:257:6: error: redefinition of 'void windows_osd_interface::update_hi(bool)'
src/osd/windows/video.c:235:6: error: 'virtual void windows_osd_interface::update_hi(bool)' previously defined here
make: *** [obj/windows64/osd/windows/video.o] Error 1
make: *** Waiting for unfinished jobs....
Processor Options
Core Options: quad
General Options
Build Version: 3
Base Build: selected
Status:
Problems:
Mame.exe not created
Hey Rain,
So I gave QuickMame a spin and ran into what I believe is an error, but I could be wrong. I am running Windows 7 followed all the instructions per your guide, but when the compiling get's to linking mame64 the status bar goes idle and nothing happens. The reason I believe I am doing something wrong is because the status bar stays idle and only gives me the option to cancel, which is leading me to believe it's still working. I let it sit for awhile, but nothing happens. The settings I applied when compiling were native 64 bit, core options quad, selected Enable direct Input, Enable High Score. disable warnings, build version 3 base build unselected. Oh by they way, not that this major, but wanted to bring to your attention that you have "Enale DirectInput" insted of "Enable DirectInput" that's to the extent I can help you out at the moment haha. Anyways, as always thank you for your contributions and hard work.
When it says "linking mame64" I always check the folder to see if the executable has been created. It always is, so I just click "cancel". I move the executable and the ini to my Mame folder and done. I've mentioned the "Enale" part before but there's not much room to work with in that space anyway.
Excellent! Thank you.
I don't get it. I never get the MAMEui? Where does it say "linking MAME64"? Could you post a pic/video, so I know what to do? I've tried it 4 times now, but nothing :)
Build your cabinet, conquer the codes, become a King of Chaos!
Hi Rain,
Using QuickMAME 2.1.0.9, I just did a compile for a 32bit core2, dual core MAME 0.147u3 with Direct input, No-Nag, and Hi-Score support and everything worked fine except the dat file required for saving the high scores was named highscore.dat instead of hiscore.dat
I renamed it and everything works fine.
Thanks for a cool app.
i already tried 10 times so far and it did not work, I use win 7 :(
QuickMame [2.1.0.9]
http://www.hyperspin-fe.com/
Patch: O sistema não pode encontrar o arquivo especificado
Disabling warnings as errors.
Enabling DirectInput in Mame source code.
QuickMame [2.1.0.9]
Parameters = OSD=winui TARGETOS=win32 -j3 ARCHOPTS=-march=native
CompileMame: O sistema não pode encontrar o arquivo especificado
Ok, trying this out again instead of MC64 that I'm already use to. Question about source update patches. Do they need to be applied one at a time under the "Source Patches" tab? Also, I'm confused as to what the "Versioning Information" is used for? It only goes to 3, but I want to update to u4.
Gonna give this a try. For the processor selection, which one would I choose for:
AMD A10-5800K APU 3.8Ghz Processor
Thanks!
dont work for me
First HyperSync, now this? I am seriously thinking there is something wrong with the framework on your PC. Either Jon or I would be glad to take a look at it for you and get your machine running properly and out of its current state.
lol i did manage to compile it with mr dos way, but when i ran mame with easymame as front end i only had 38 roms showing and with mame 143u9 i had over 2000. im running xp 32bit.
Well I have been trying to compile 147u4 and 147u3 with no luck and I even tried 147 base and I still end up with the error..
c1.exe: internal compiler error:
Illegal instruction Please submit a full bug report, with preprocessed source if appropriate
make: *** [obj/windows/osd/windows/vconv.o] Error 1
I dont know what to do?
Windows xp pro 32bit
Pentium 4 2.4ghz
1gb ram
I gave it a shot. I received no errors, just no .exe after it's compiled?
I'm a total noob, so maybe I'll try unchecking base build and give it another go.
i was gonna post up an error i got but see it still using 0.147 and i was trying to get it to do 0.148 as released on 11th i'll wait for rain to release /update to new version
[sIGPIC][/sIGPIC]
I'm trying to use this with mamui but not getting an executable. I'm running windows 7. Does anyone know if its because mameui is not supported?
Thought I would give some feedback here.
I have never attempted to do a compile before, although I have been reading up on it lately I just thought it was tedious. I used Rain's software with 100% success!
Quick Mame 2.1.0.9
WinXP Service Pack 3
Intel Celeron Single Core 450 @ 2.20GHz
2GB of RAM
MAME v 0.145
Checked Off Clean Compile, Enable High Score, Disable Warnings
Total Time was about 25-30 minutes
Thanks for this simple program Rain!!
