Hi , hyperXMLspin is updated :
Version 1.8.0.4
+03/12/2018 - Added --> Theme "Dark" by FernandoCaldas
+03/12/2018 - Added--> Theme "Bungles" from Bungles idea with artworks by FernandoCaldas
+01/20/2018 - Fixed --> Better search engine for keywords containing spaces (Mario Kart and Kart Mario give same results)
+01/20/2018 - Fixed --> Bugg when launching video preview on quicksearch after differents searchs (error message from player)
+01/20/2018 - Added --> Setting transparency and background color act directly on visible windows.
+01/20/2018 - Added --> Parameters window available (with shortcut) from any window
+19/19/2018 - Added --> Full interface customization for each hyperxmlspin windows (Transparency,Background color,...)
+01/18/2018 - Added --> Option inside ini file : SystemArtworkDir (allow to set another system artworks directory) (Thanks to Bungles)
+01/17/2018 - Added --> All hyperxmlspin windows are movable , their positions are saved in ini file
+01/17/2018 - Fixed --> Waiting picture have been removed (problem of compatibility)
+12/28/2017 - Fixed --> Flashing screen when loading artwork instead of video in Quicksearch & Multisearch.
+12/12/2017 - Fixed --> "HyperXMLspin Hide/Show" Keyboard Hotkey wasn't updated into parameters window.
+12/12/2017 - Fixed --> Mouse left click emulation was not working on Quicksearch results view.
some screenshots with "bungles" theme attached...
r0man0
  • Replies 463
Version 1.8.0.4
r0man0
Looks great
Sent from my SM-G935F using Tapatalk
hi, I cant get the latest version of hyperxmlspin to load from within hyperspin. I have version 1.7.2 that was installed for a long time now, and it works great in hyperspin. So I put the new version in my folder and told hyperhq where the new exe file is and it wont launch it from hyperspin. outside of hyperspin it launches just fine. When I try to launch it from within the wheel, hyperspin just freezes up until I alt-tab or ctrl-alt-del and come back to it. when I launch in hyperspin and go to task manager its not listed as running, but when i launch it outside hyperspin it shows up in task manager.
Just to see what would happen i told hyperhq to use the old exe again and it works inside hyperspin. But the new version still won't run. I've double checked the read me file, I just can't seem to get it to load up.
Running win7 x64
Also, no antivirus running
Thanks for the great program, and the help.
Running win7 x64
Hi , sorcerer86 , that was a bugg , now fixed. New version is uploaded on hyperspin server.
Thanks for report.:good:
r0man0
So I started using HyperXMLspin recently, setup took all of two minutes, pointed to RL, then pointed to HS. I did nothing else, and it seemed to work great!!
I just noticed (for example) it will not pull results for my N64 roms. If I pull the System to N64 and search 'a' I get 0 results. Other systems seem to work fine, especially MAME.
Trying to troubleshoot, any suggestions what I can look at?
Update: Figured this out for anyone else having this issue. Turns out some of the XML files were not formatted correctly, believe it or not if the xml had the below (note the cloneof lines)
  <game name="007 - GoldenEye (USA)" index="true" image="0">
    <description>007 - GoldenEye (USA)</description>
    <cloneof>
    </cloneof>
    <crc>
    </crc>
    <manufacturer>Nintendo</manufacturer>
    <year>1997</year>
    <genre>Shooter</genre>
    <rating>ESRB - T (Teen)</rating>
    <enabled>Yes</enabled>
  </game>
OR
    <cloneof> </cloneof>
    <crc> </crc>
It would not pull the results into hyperxmlspin. Reformatting to the below works great!!!
    <cloneof></cloneof>
    <crc></crc>
    <cloneof />
    <crc />
Z
Howdy
I found a few bugs that i'd like you to fix if possible. I created a view with the search  "Zelda" and exported it to my main menu wheel. The media transferred over fine via link but when I launch a game it says it doesn't recognize the extension for the rom. The ones specifically are .zip roms. Is my INI set up correctly? Maybe I've done something wrong. I've noticed that some games will run but most don't. They run fine outside of the app, I use rocketlauncher for all my games. Note that if I change the ini file to use hyperlaunch=yes it will say that the game name (note it has @'s in the name) hasn't been set up in rocketlaunch and it doesn't know the exe, fade, or title screen to run the game.
How do you launch the games in the new version? looking forward to using this app to create a playlist wheel
here is my log
OS Version = 10.0.16299
OS Version 64b = 1
HyperXmlspin Path = E:\Arcade-PC\hyperspin\HyperXMLspin.exe
20180403011322 : #00000 Start HyperXMLspin
20180403011322 : #00001 Parameter1 : Legend(_-_)of(_-_)Zelda,(_-_)The(_-_)-(_-_)Link's(_-_)Awakening(_-_)(USA,(_-_)Europe)+++Nintendo@@@Game@@@Boy+++.
20180403011322 : #00002 Parameter2 :
20180403011322 : #00003 Parameter3 :
20180403011322 : #00279 HyperspinDirectoryPath = E:\Arcade-PC\hyperspin
20180403011328 : #00169 HyperXMLspin Exit
here is my Zelda.ini
[exe info]
path=E:\Arcade-PC\hyperspin\
rompath=
userompath=false
exe=HyperXMLspin.exe
romextension=
parameters=
searchsubfolders=false
pcgame=false
winstate=MAXIMIZED
hyperlaunch=false
[filters]
parents_only=false
themes_only=false
wheels_only=false
roms_only=false
[themes]
use_parent_vids=true
use_parent_themes=true
animate_out_default=true
reload_backgrounds=true
[wheel]
alpha=.15
small_alpha=1
style=normal
speed=high
pin_center_width=500
horz_wheel_y=512
vert_wheel_position=right
y_rotation=center
norm_large=360
norm_small=230
vert_large=400
vert_small=240
pin_large=500
pin_small=200
horz_large=240
horz_small=150
letter_wheel_x=800
letter_wheel_y=384
text_width=700
text_font=Style4
small_text_width=260
large_text_width=400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_color=0x000000
shadow_alpha=1
shadow_blur=0
[pointer]
animated=true
x=975
y=384
[video defaults]
path=
[sounds]
game_sounds=true
wheel_click=true
[navigation]
game_jump=50
use_indexes=true
jump_timer=400
remove_info_wheel=false
remove_info_text=false
use_last_game=false
last_game=Legend(_-_)of(_-_)Zelda(_-_)(MSU-1)+++Hacked@@@Games+++
random_game=false
start_on_favorites=false
[Special Art A]
default=false
active=true
x=512
y=720
in=0.4
out=0.4
length=3
delay=0
type=normal
start=bottom
[Special Art B]
default=true
active=true
x=512
y=740
in=0.4
out=0.4
length=3
delay=0
type=fade
start=none
[Special Art C]
active=true
x=512
y=384
in=0
out=0
length=3
delay=10
type=fade
start=none
[Game Text]
game_text_active=true
show_year=true
show_manf=true
show_description=true
text_color1=0xffffff
text_color2=0x0099cc
text_font=Style1
text1_textsize=26
text1_strokesize=7
text1_x=32
text1_y=610
text2_textsize=36
text2_strokesize=8
text2_x=30
text2_y=640
It was determine that the setting for not launching from RocketLauncher are truest correct and I needed to add the extensions in the system name Inis to launch outside of RocketLauncher however I’d really like to run thinks through RocketLauncher from the main menu. What settings do I need to have for it to launch via RocketLauncher so that I get the bezels and all through the RocketLauncher set up that runs when running a normal game? When I update the settings system name ini to hyperlaunch=yes it errors out at the system isn’t set up under pclauncher which is confusing since it would be a console game
I've uploaded a new version that don't need anymore to be launched through hyperxmlspin : with tag system : <exe>%system%<exe>
i've found a solution for games that have the same name across multiples systems they will be renamed with a space before game name.
Your HyperXMLspin XML will be more cleaned for sure !
To use this version you have to convert your old Hyperxmlspin lists into params/update/scan medias.
Version 1.8.0.5
+04/12/2018 - Info --> Launch games through Hyperspin with a non-converted HyperXMLspin list is possible.
+04/12/2018 - Added --> Update old HyperXMLspin lists (<exe></exe>)--> Into parameters/Update/scan medias.
             Old lists will be saved (with extention .bak). Old artworks , themes and videos will not be deleted or renamed.
             You have to do that yourself if you do not want to keep them on your HDD.(That is not compulsory , but your directory will be more cleaned  :-) )
+04/10/2018 - Added --> Xml lists are created with game tag <exe></exe> : no need anymore hyperxmlspin to decode game name before launch.
Version 1.8.0.4beta4
+04/08/2018 - Fixed --> Bugg : Variable not cleared after first search , cause sometimes no results .(Thanks to ninja2bceen)
Version 1.8.0.4beta3
+04/07/2018 - Fixed --> Bugg : Full launch of hyperxmlspin instead of just game launcher from a game from hyperxmlspin wheel.(Thanks to ninja2bceen)
I'm having a problem.
I created a "Tetris" wheel and it found roughly 75 games across many systems.
Well, when I go to launch a game, most of the games from most of the systems won't launch.  Sega Naomi, Philips CD-i, NDS, 3DS, etc, and they just sit there.  I press enter over and over and it just sits there on the theme and doesn't launch.  Other Tetris wheels from other systems, such as Mame, Nintendo, Sega Genesis, etc, launch fine.
It's about 50/50 right now.
This is happening no matter which wheel I create.  Tetris is just an example.
If I go to the actual game on the actual wheel, it loads fine, with no problems.  They just won't load from the XMLSpin wheel for whatever reason.
Where should I look?
Can you post your hyperxmlspin log after selecting on that doesn’t work? My bet is your system ini setting file is not correct. I think you were saying mame system was working, be sure every system ini looks similar
Below is the log.
I upgraded to the latest version, then did a media update.  It converted my XML files to the new format and now I can launch from all systems, but again, about half of the systems give a new error.  Mame, for instance, worked before the update, but now, it gives a "rom not found" error.  I can launch it directly from the Mame wheel in HS, though.  Several other systems are the same way, but some work fine.
So it's either this, where half the systems say the rom isn't found, but do "attempt" to load, or go back to the previous version and have half the systems just not respond and not even try to load.  It's different systems that work on each version, though.
LOG:
OS Version 64b = 1
HyperXmlspin Path = F:\HyperSpin\HyperXMLspin.exe
20180423074429 : #00000 Start HyperXMLspin
20180423074429 : #00001 Parameter1 :
20180423074429 : #00002 Parameter2 :
20180423074429 : #00003 Parameter3 :
20180423074429 : #00010 HyperSpin.exe not detected
20180423074429 : #00012 HyperXMLspin.ini detected . Checking ...
20180423074429 : #00279 HyperspinDirectoryPath = F:\HyperSpin
20180423074429 : #00280 HyperXMLspinItemName =
20180423074429 : #00281 Fullscreen = 0
20180423074429 : #00282 resolution = 3
20180423074429 : #00283 FullPathLauncherExecutable = F:\RocketLauncher\RocketLauncher.exe
20180423074429 : #00284 HyperXMLspinLanguage = English
20180423074429 : #00285 VirtualKeyboard = 1
20180423074429 : #00286 Joy2MouseForJoy1 = 0
20180423074429 : #00287 OnStartExecutable =
20180423074429 : #00288 OnStartParameters =
20180423074429 : #00289 OnExitExecutable =
20180423074429 : #00290 OnExitParameters =
20180423074429 : #00295 Theme = Bungles
20180423074429 : #00291 BackgroundColor#1 = 0xd3d3d3
20180423074429 : #00291 BackgroundColor#2 = 0xd3d3d3
20180423074429 : #00291 BackgroundColor#3 = 0xd3d3d3
20180423074429 : #00291 BackgroundColor#4 = 0xd3d3d3
20180423074429 : #00291 BackgroundColor#5 = 0xd3d3d3
20180423074429 : #00292 PoliceColor#1 = 0x8f8f8f
20180423074429 : #00292 PoliceColor#2 = 0x8f8f8f
20180423074429 : #00292 PoliceColor#3 = 0x8f8f8f
20180423074429 : #00292 PoliceColor#4 = 0x8f8f8f
20180423074429 : #00292 PoliceStyle#1 = Verdana
20180423074429 : #00292 PoliceStyle#2 = Verdana
20180423074429 : #00292 PoliceStyle#3 = Verdana
20180423074429 : #00292 PoliceStyle#4 = Verdana
20180423074429 : #00293 BackgroundImage =
20180423074429 : #00294 Transparency#1 = 255
20180423074429 : #00294 Transparency#2 = 255
20180423074429 : #00294 Transparency#3 = 255
20180423074429 : #00294 Transparency#4 = 255
20180423074429 : #00294 Transparency#5 = 255
20180423074429 : #00295 Theme Position X = -104
20180423074429 : #00295 Theme Position Y = -75
20180423074429 : #00295 MultiSearch Position X = -4
20180423074429 : #00295 MultiSearch Position Y = -40
20180423074429 : #00295 MultiSearch Position X = 0
20180423074429 : #00295 MultiSearch Position Y = 0
20180423074429 : #00296 ExitKeyNumber = 2
20180423074429 : #00297 OptionsKeyNumber = 22
20180423074429 : #00298 HyperXMLspinKeyNumber = 23
20180423074429 : #00300 MouseClickButtonNumber = 2
20180423074429 : #00301 DeleteButtonNumber = 3
20180423074429 : #00302 SearchButtonNumber = 9
20180423074429 : #00303 controlMouseClickButtonNumber = 4
20180423074429 : #00304 ShiftMouseClickButtonNumber = 5
20180423074429 : #00305 ExitButtonNumber = 8
20180423074429 : #00306 OptionsButtonNumber = 6
20180423074429 : #00307 HyperXMLspinButtonNumber = 10
20180423074429 : #00308 ParentalPINCode =
20180423074429 : #00309 JoystickNumber = 1
20180423074429 : #00310 ParentalFilter = 0
20180423074429 : #00311 StartupHidden = 1
20180423074429 : #00312 UseNTFSSymlinks = 1
20180423074429 : #00313 VideoArtworkPreview = 1
20180423074429 : #00314 ConfirmExit = 0
20180423074429 : #00314 SystemArtworkDir = F:\HyperSpin\Media\Main Menu\Images\Wheel\
20180423074429 : #00563 HyperSpin HDD Partition is NTFS
20180423074429 : #00415 Routine
20180423074429 : #00019 Set Hotkey "enter"
20180423074429 : #00020 Set Hotkey "ESC"
20180423074429 : #00021 Set Hotkey "F2"
20180423074429 : #00022 Set Hotkey "F5"
20180423074429 : #00033 F:\HyperSpin\HyperXMLspin.ini found
20180423074429 : #00160 Hyperxmlspin Scan databases systems...
20180423074430 : #00505 Hyperxmlspin database...Reading Filters
20180423074430 : #00034 Hyperxmlspin gui creating...
20180423074430 : #00036 Hyperxmlspin gui creating...
20180423074430 : #00040 Hyperxmlspin gui creating...
20180423074430 : #00041 Hyperxmlspin gui settings...#1=#2=#3=1#5
20180423074430 : #00273 Hyperxmlspin Hide/Show Hotkey #0=1
20180423074441 : #00001 Parameter1 :
20180423074441 : #00002 Parameter2 :
20180423074441 : #00003 Parameter3 :
20180423074441 : #00010a HyperXMLspin already running
20180423074441 : #00010b HyperXMLspin Multiple Instance Not allowed
20180423074441 : #00010c HyperXMLspin (#2) Exit20180423075133 : #00001 Parameter1 :
20180423075133 : #00002 Parameter2 :
20180423075133 : #00003 Parameter3 :
20180423075133 : #00010a HyperXMLspin already running
20180423075133 : #00010b HyperXMLspin Multiple Instance Not allowed
20180423075133 : #00010c HyperXMLspin (#2) Exit
Ninja, remember, I was on this version before switching to your version, and we had this problem and tried "Everything" to get it to work and couldn't figure it out.
If I convert the databases back to the old version and reinstall your version (I don't know which version you're using, but apparently it's not the newest) then Mame will work, but other systems will just sit there and not attempt to load.
It's a catch 22. :(
Here's another log.
This time I just deleted the Tetris DB that was converted and created a new one.
Now about 75% of the systems will load, but again, the other 25% give a no rom found in any rom path with any valid extension error.
Here's the funny thing.  Mame doesn't work, but "Favorite" which is a DB I created of my favorite Mame Games DOES work!  They're the same games!  Weird.
Anyway, here's the latest log...
OS Version 64b = 1
20180423080317 : #00000 Start HyperXMLspin
20180423080317 : #00001 Parameter1 :
20180423080317 : #00002 Parameter2 :
20180423080317 : #00003 Parameter3 :
20180423080317 : #00010 HyperSpin.exe not detected
20180423080317 : #00012 HyperXMLspin.ini detected . Checking ...
20180423080317 : #00279 HyperspinDirectoryPath = F:\HyperSpin
20180423080317 : #00280 HyperXMLspinItemName =
20180423080317 : #00281 Fullscreen = 0
20180423080317 : #00282 resolution = 3
20180423080317 : #00283 FullPathLauncherExecutable = F:\RocketLauncher\RocketLauncher.exe
20180423080317 : #00284 HyperXMLspinLanguage = English
20180423080317 : #00285 VirtualKeyboard = 1
20180423080317 : #00286 Joy2MouseForJoy1 = 0
20180423080317 : #00287 OnStartExecutable =
20180423080317 : #00288 OnStartParameters =
20180423080317 : #00289 OnExitExecutable =
20180423080317 : #00290 OnExitParameters =
20180423080317 : #00295 Theme = Bungles
20180423080317 : #00291 BackgroundColor#1 = 0xd3d3d3
20180423080317 : #00291 BackgroundColor#2 = 0xd3d3d3
20180423080317 : #00291 BackgroundColor#3 = 0xd3d3d3
20180423080317 : #00291 BackgroundColor#4 = 0xd3d3d3
20180423080317 : #00291 BackgroundColor#5 = 0xd3d3d3
20180423080317 : #00292 PoliceColor#1 = 0x8f8f8f
20180423080317 : #00292 PoliceColor#2 = 0x8f8f8f
20180423080317 : #00292 PoliceColor#3 = 0x8f8f8f
20180423080317 : #00292 PoliceColor#4 = 0x8f8f8f
20180423080317 : #00292 PoliceStyle#1 = Verdana
20180423080317 : #00292 PoliceStyle#2 = Verdana
20180423080317 : #00292 PoliceStyle#3 = Verdana
20180423080317 : #00292 PoliceStyle#4 = Verdana
20180423080317 : #00293 BackgroundImage =
20180423080317 : #00294 Transparency#1 = 255
20180423080317 : #00294 Transparency#2 = 255
20180423080317 : #00294 Transparency#3 = 255
20180423080317 : #00294 Transparency#4 = 255
20180423080317 : #00294 Transparency#5 = 255
20180423080317 : #00295 Theme Position X = -104
20180423080317 : #00295 Theme Position Y = -75
20180423080317 : #00295 MultiSearch Position X = -4
20180423080317 : #00295 MultiSearch Position Y = -40
20180423080317 : #00295 MultiSearch Position X = 0
20180423080317 : #00295 MultiSearch Position Y = 0
20180423080317 : #00296 ExitKeyNumber = 2
20180423080317 : #00297 OptionsKeyNumber = 22
20180423080317 : #00298 HyperXMLspinKeyNumber = 23
20180423080317 : #00300 MouseClickButtonNumber = 2
20180423080317 : #00301 DeleteButtonNumber = 3
20180423080317 : #00302 SearchButtonNumber = 9
20180423080317 : #00303 controlMouseClickButtonNumber = 4
20180423080317 : #00304 ShiftMouseClickButtonNumber = 5
20180423080317 : #00305 ExitButtonNumber = 8
20180423080317 : #00306 OptionsButtonNumber = 6
20180423080317 : #00307 HyperXMLspinButtonNumber = 10
20180423080317 : #00308 ParentalPINCode =
20180423080317 : #00309 JoystickNumber = 1
20180423080317 : #00310 ParentalFilter = 0
20180423080317 : #00311 StartupHidden = 1
20180423080317 : #00312 UseNTFSSymlinks = 1
20180423080317 : #00313 VideoArtworkPreview = 1
20180423080317 : #00314 ConfirmExit = 0
20180423080317 : #00314 SystemArtworkDir = F:\HyperSpin\Media\Main Menu\Images\Wheel\
20180423080317 : #00563 HyperSpin HDD Partition is NTFS
20180423080317 : #00415 Routine
20180423080317 : #00019 Set Hotkey "enter"
20180423080317 : #00020 Set Hotkey "ESC"
20180423080317 : #00021 Set Hotkey "F2"
20180423080317 : #00022 Set Hotkey "F5"
20180423080317 : #00033 F:\HyperSpin\HyperXMLspin.ini found
20180423080317 : #00160 Hyperxmlspin Scan databases systems...
20180423080317 : #00505 Hyperxmlspin database...Reading Filters
20180423080317 : #00034 Hyperxmlspin gui creating...
20180423080317 : #00036 Hyperxmlspin gui creating...
20180423080317 : #00040 Hyperxmlspin gui creating...
20180423080317 : #00041 Hyperxmlspin gui settings...#1=#2=#3=1#5
20180423080317 : #00273 Hyperxmlspin Hide/Show Hotkey #0=1
20180423080326 : #00001 Parameter1 :
20180423080326 : #00002 Parameter2 :
20180423080326 : #00003 Parameter3 :
20180423080326 : #00010a HyperXMLspin already running
20180423080326 : #00010b HyperXMLspin Multiple Instance Not allowed
20180423080326 : #00010c HyperXMLspin (#2) Exit
Several systems don't work.  They all give the same error.  Mame is one example of a system that doesn't work.  It says something to the effect of Rom not found, no valid rom path found in any extensions, then lists all the extensions...
Cannot find rom in any rom path provided with any rom extension...That's the exact message.  Then it lists the path to my roms, which is correct, and also lists all the extensions.  That's the exact error message, BTW.
Some of your tetris games come from a wheel called "favorite" , i think that your wheel favorite is not a dedicated emulator but an hyperxmlspin wheel, so it's not recognized by hyperspin/rocketlauncher all the games with tag <exe>favorites</exe> will have an error ...that's because your tetris search results have included your favorite wheel games....
No, the favorite games actually work!  They work fine!  It's not a HyperXMLspin wheel, btw.  It's a wheel I created manually.
ok you have created a favorite wheel yourself with game tag <exe> ? so results have been added to your previous old search because old hyperxmlspin doesn't recognize this game tag and add this wheel as an emulator , that is not an emulator but an hyperxmlspin extension that allows lists across multiple systems.
for exemple : If you made search again for tetris games , with the new hyperxmlspin app , you will not have favorite wheel games added to results. because new hyperxmlspin skip lists with game tag <exe>, to prevent doubles
No, I didn't do that.  I made a wheel in HyperSpin called "Favorite."  It's just like any other wheel.  It doesn't have any thing to do with XMLspin.  It's just a regular wheel like any other, called Favorite.
BTW, favorite works in all three versions of the XML.  Again, though, Favorite was created a year ago or so as a regular wheel and has nothing to do with XMLspin.
