r0man0 Posted September 8, 2016 Author Posted September 8, 2016 Hi , i ve added a log file function to hyperxmlspin , i m not sure that it can solve the background bug from wheel. Just launch it from the wheel and share me your hyperxmlspin.log file that is on same folder as hyperxmlspin.exe. New exe is attached to this post r0man0
ninja2bceen Posted September 9, 2016 Posted September 9, 2016 OS Version = WIN_7 OS Version 64b = 1 HyperXmlspin Path = E:\Arcade-PC\hyperspin\HyperXMLspin.exe 20160909011618 : #00001 Start HyperXMLspin 20160909011618 : #00001 Parameter1 : Help. 20160909011618 : #00002 Parameter2 : 20160909011618 : #00003 Parameter3 : 20160909011618 : #00009 HyperSpin.exe detected 20160909011618 : #00012 HyperXMLspin.ini detected . Checking ... 20160909011618 : #00279 HyperspinDirectoryPath = E:\Arcade-PC\Hyperspin 20160909011618 : #00280 HyperXMLspinItemName = Help 20160909011618 : #00281 Fullscreen = 1 20160909011618 : #00282 resolution = 1 20160909011618 : #00283 FullPathLauncherExecutable = E:\Arcade-PC\Hyperspin\RocketLauncher\RocketLauncher.exe 20160909011618 : #00284 HyperXMLspinLanguage = English 20160909011618 : #00285 HyperXMLspinMode = 1 20160909011618 : #00286 VirtualKeyboard = 1 20160909011618 : #00287 Joy2MouseForJoy1 = 1 20160909011618 : #00288 OnStartExecutable = E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe 20160909011618 : #00289 OnStartParameters = E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\Help\Help.cfg 20160909011618 : #00290 OnExitExecutable = E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe 20160909011618 : #00291 OnExitParameters = E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\HyperSpin\HyperSpin.cfg 20160909011618 : #00292 BackgroundColor = 0x0 20160909011618 : #00293 PoliceColor = 0x41E4D4 20160909011618 : #00294 BackgroundImage = E:\Arcade-PC\Hyperspin\Media\Help\Images\Backgrounds\Background.png 20160909011618 : #00295 Transparency = 106 20160909011618 : #00296 ExitKeyNumber = 2 20160909011618 : #00297 OptionsKeyNumber = 8 20160909011618 : #00298 MultiSearchKeyNumber = 9 20160909011618 : #00299 QuickSearchKeyNumber = 7 20160909011618 : #00300 MouseClickButtonNumber = 2 20160909011618 : #00301 DeleteButtonNumber = 3 20160909011618 : #00302 SearchButtonNumber = 9 20160909011618 : #00303 controlMouseClickButtonNumber = 4 20160909011618 : #00304 ShiftMouseClickButtonNumber = 5 20160909011618 : #00305 ExitButtonNumber = 8 20160909011618 : #00306 OptionsButtonNumber = 6 20160909011618 : #00307 MultiSearchButtonNumber = 10 20160909011618 : #00308 QuickSearchButtonNumber = 11 20160909011618 : #00309 ParentalPINCode = 20160909011618 : #00310 JoystickNumber = 1 20160909011618 : #00311 ParentalFilter = 0 20160909011618 : #00312 StartupHidden = 1 20160909011618 : #00313 VideoArtworkPreview = 1 20160909011618 : #00415 Routine 20160909011619 : #00099 ValidatePCM#1: 20160909011619 : #00013 Checking E:\Arcade-PC\Hyperspin\Databases\Help\Help.xml 20160909011619 : #00018 run "E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe" "E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\Help\Help.cfg" 20160909011619 : #00019 Set Hotkey "enter" 20160909011619 : #00020 Set Hotkey "ESC" 20160909011619 : #00021 Set Hotkey "PGUP" 20160909011619 : #00022 Set Hotkey "PGDN" 20160909011619 : #00023 Set Hotkey "HOME" 20160909011619 : #00024 Set Hotkey "1Joy1" 20160909011619 : #00025 Set Hotkey "1Joy4" 20160909011619 : #00026 Set Hotkey "1Joy3" 20160909011619 : #00027 Set Hotkey "1Joy2" 20160909011619 : #00028 Set Hotkey "1Joy8" 20160909011619 : #00029 Set Hotkey "1Joy5" 20160909011619 : #00030 Set Hotkey "1Joy7" 20160909011619 : #00031 Set Hotkey "1Joy9" 20160909011619 : #00032 Set Hotkey "1Joy10" 20160909011619 : #00033 E:\Arcade-PC\hyperspin\HyperXMLspin.ini found 20160909011619 : #00160 Hyperxmlspin database 20160909011620 : #00161 Hyperxmlspin database 20160909012041 : #00271 Hyperxmlspin Hotkey #0= #1=1 #2=1 #3= 20160909012256 : #00266 Hyperxmlspin Hotkey #0= it still happens. note the white screen doesn't appear now and closes properly now. the only think I see in the log that is wrong is it says my os is win 7 Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 9, 2016 Posted September 9, 2016 i'm not sure that the video folder gets cleared out correctly. For instance I have 2 K wheels but 4 K videos there. I would think that the video folder and wheel folder are the same volume? Same with the theme folder, I see 3 K themes in the hyperxmlspin folder. I'll bet this is all from all time. can we get it where if you check media its only what is currently in the xmls and not previously? Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 9, 2016 Posted September 9, 2016 Ah I see. The new exe works for the media but I have to manually delete what was in there historically. Moving forward it will work as intended. Just need the launch on wheel and it's perfect. Working on clean up now for greatest games Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted September 9, 2016 Author Posted September 9, 2016 Ah I see. The new exe works for the media but I have to manually delete what was in there historically. Moving forward it will work as intended. Just need the launch on wheel and it's perfect. Working on clean up now for greatest games Ok , if you want to clean properly your hyperxmlspin medias folder , just delete all content of each folders of \medias\hyperxmlspin\... then do an "scan medias" to get all of necessary medias. I will check your log file soon , for launching from wheel. r0man0
r0man0 Posted September 9, 2016 Author Posted September 9, 2016 Ok ninja , i've check the logfile , seems to be the database that is not loaded properly. That could be for example because you have not enouth memory , to load both app : hyperspin & hyperxmlspin. So i've optimize database creation and loading , and also searching. Now the only thing that takes memory is video preview & artworks. Usually part of log file must be like that : 20160909115844 : #00033 Z:\EMULATEURS\HyperSearch\HyperXMLspin.ini found20160909115844 : #00160 Hyperxmlspin database20160909115844 : #00161 Hyperxmlspin database20160909115844 : #00162 Hyperxmlspin database...end20160909115844 : #00034 Hyperxmlspin gui creating...20160909115844 : #00036 Hyperxmlspin gui creating...20160909115844 : #00037 Hyperxmlspin gui creating...20160909115844 : #00038 Hyperxmlspin gui creating... Take the new exe attached at this post , i've rewrite an optimized script. Try again and If that didn't works again , post me again logfile.
r0man0 Posted September 9, 2016 Author Posted September 9, 2016 Oups you need also to recreate database !
ninja2bceen Posted September 9, 2016 Posted September 9, 2016 Can I just copy the one I have? The last time took about 30 min Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 9, 2016 Posted September 9, 2016 I assume all the exports will still work? Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted September 9, 2016 Author Posted September 9, 2016 I assume all the exports will still work? ;-) of course ! Can I just copy the one I have? The last time took about 30 min ok i 've made another executable fully compatible with old databases Take it on attach : HyperXMLspin_v1_6_9(2016-09-09)2.7z
ninja2bceen Posted September 9, 2016 Posted September 9, 2016 Thanks will test tonight. Being compatible with the previous versions database is a huge help. I'm basically done with the best games of all time wheel and all the genres I added that are dedicated character wheels! Hoping for the best then I'll send you my xml, pointer and main menu pack Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 9, 2016 Posted September 9, 2016 actually just tested.. here is my log... same story with the focus thi OS Version = WIN_7 OS Version 64b = 1 HyperXmlspin Path = E:\Arcade-PC\hyperspin\HyperXMLspin.exe 20160909131134 : #00001 Start HyperXMLspin 20160909131134 : #00001 Parameter1 : Help. 20160909131134 : #00002 Parameter2 : 20160909131134 : #00003 Parameter3 : 20160909131134 : #00009 HyperSpin.exe detected 20160909131134 : #00012 HyperXMLspin.ini detected . Checking ... 20160909131134 : #00279 HyperspinDirectoryPath = E:\Arcade-PC\Hyperspin 20160909131134 : #00280 HyperXMLspinItemName = Help 20160909131134 : #00281 Fullscreen = 1 20160909131134 : #00282 resolution = 1 20160909131134 : #00283 FullPathLauncherExecutable = E:\Arcade-PC\Hyperspin\RocketLauncher\RocketLauncher.exe 20160909131134 : #00284 HyperXMLspinLanguage = English 20160909131135 : #00285 HyperXMLspinMode = 1 20160909131135 : #00286 VirtualKeyboard = 1 20160909131135 : #00287 Joy2MouseForJoy1 = 1 20160909131135 : #00288 OnStartExecutable = E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe 20160909131135 : #00289 OnStartParameters = E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\Help\Help.cfg 20160909131135 : #00290 OnExitExecutable = E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe 20160909131135 : #00291 OnExitParameters = E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\HyperSpin\HyperSpin.cfg 20160909131135 : #00292 BackgroundColor = 0x0 20160909131135 : #00293 PoliceColor = 0x41E4D4 20160909131135 : #00294 BackgroundImage = E:\Arcade-PC\Hyperspin\Media\Help\Images\Backgrounds\Background.png 20160909131135 : #00295 Transparency = 106 20160909131135 : #00296 ExitKeyNumber = 2 20160909131135 : #00297 OptionsKeyNumber = 8 20160909131135 : #00298 MultiSearchKeyNumber = 9 20160909131135 : #00299 QuickSearchKeyNumber = 7 20160909131135 : #00300 MouseClickButtonNumber = 2 20160909131135 : #00301 DeleteButtonNumber = 3 20160909131135 : #00302 SearchButtonNumber = 9 20160909131135 : #00303 controlMouseClickButtonNumber = 4 20160909131135 : #00304 ShiftMouseClickButtonNumber = 5 20160909131135 : #00305 ExitButtonNumber = 8 20160909131135 : #00306 OptionsButtonNumber = 6 20160909131135 : #00307 MultiSearchButtonNumber = 10 20160909131135 : #00308 QuickSearchButtonNumber = 11 20160909131135 : #00309 ParentalPINCode = 20160909131135 : #00310 JoystickNumber = 1 20160909131135 : #00311 ParentalFilter = 0 20160909131135 : #00312 StartupHidden = 1 20160909131135 : #00313 VideoArtworkPreview = 1 20160909131135 : #00415 Routine 20160909131135 : #00099 ValidatePCM#1: 20160909131141 : #00013 Checking E:\Arcade-PC\Hyperspin\Databases\Help\Help.xml 20160909131141 : #00018 run "E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe" "E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\Help\Help.cfg" 20160909131141 : #00019 Set Hotkey "enter" 20160909131141 : #00020 Set Hotkey "ESC" 20160909131141 : #00021 Set Hotkey "PGUP" 20160909131141 : #00022 Set Hotkey "PGDN" 20160909131141 : #00023 Set Hotkey "HOME" 20160909131141 : #00024 Set Hotkey "1Joy1" 20160909131141 : #00025 Set Hotkey "1Joy4" 20160909131141 : #00026 Set Hotkey "1Joy3" 20160909131141 : #00027 Set Hotkey "1Joy2" 20160909131141 : #00028 Set Hotkey "1Joy8" 20160909131141 : #00029 Set Hotkey "1Joy5" 20160909131141 : #00030 Set Hotkey "1Joy7" 20160909131141 : #00031 Set Hotkey "1Joy9" 20160909131141 : #00032 Set Hotkey "1Joy10" 20160909131142 : #00033 E:\Arcade-PC\hyperspin\HyperXMLspin.ini found 20160909131142 : #00160 Hyperxmlspin database 20160909131142 : #00161 Hyperxmlspin database 20160909131209 : #00271 Hyperxmlspin Hotkey #0= #1=1 #2=1 #3= 20160909131209 : #00274 Hyperxmlspin Exit #0= #1= #2=1 #3=1 20160909131236 : #00267 Hyperxmlspin Hotkey #0= #1=1 #2=1 #3= ng Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 9, 2016 Posted September 9, 2016 this version actually crashes outside of hyperspin when trying to pull up the search screen. I can only get the parameter screen up if I right click the icon Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 10, 2016 Posted September 10, 2016 In the second most recent version I tried to launch donkey kong from mame and it said that I needed a default emulator ini to launch the game? Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
r0man0 Posted September 10, 2016 Author Posted September 10, 2016 Hi again , I've checked again script , rewrite some parts and optimize it , now list of years , list of genres , list of systems will be stored inside hyperxmlspin.ini. Old database are still compatible , but at first launch old database will be checked to store thoses elements inside ini file. I've spend a lot of time in order to understand why all exported games doesn't launch from wheel... And the issue come from HyperSpin , When setting up the new exported system , ini file from Hyperspin\settings\hyperxmlspin.ini if copiyed as to be the same for new exported system.... And the error from hyperspin is that when setting up the hyperxmlspin wheel in hyperHQ , when you let the radio buttons on "disabled " for "Use full path to roms" & "Search Subfolders" , it leave the variables rompath & searchsubfolders empty from Hyperspin\settings\hyperxmlspin.ini file instead of "False". So 2 solutions : edit manually Hyperspin\settings\hyperxmlspin.ini & others hyperxmlspin exported systems or in hyperhq hyperxmlspin & others exported systems wheels set the radio buttons to enabled then to disabled. After this game launch from wheel is ok. Fixed the problem from ini files then test the new executable attached. r0man0 HyperXMLspin_v1_6_9(2016-09-10).7z
ninja2bceen Posted September 11, 2016 Posted September 11, 2016 thanks for keeping at this..when I launch for the first time outside of hyperspin, my log looks like this...working as intended OS Version = 10.0.10586 OS Version 64b = 1 HyperXmlspin Path = E:\Arcade-PC\hyperspin\HyperXMLspin.exe 20160911010613 : #00000 Start HyperXMLspin 20160911010613 : #00001 Parameter1 : 20160911010613 : #00002 Parameter2 : 20160911010613 : #00003 Parameter3 : 20160911010613 : #00009 HyperSpin.exe detected 20160911010613 : #00012 HyperXMLspin.ini detected . Checking ... 20160911010613 : #00279 HyperspinDirectoryPath = E:\Arcade-PC\Hyperspin 20160911010613 : #00280 HyperXMLspinItemName = Help 20160911010613 : #00281 Fullscreen = 1 20160911010613 : #00282 resolution = 1 20160911010613 : #00283 FullPathLauncherExecutable = E:\Arcade-PC\Hyperspin\RocketLauncher\RocketLauncher.exe 20160911010613 : #00284 HyperXMLspinLanguage = English 20160911010613 : #00285 HyperXMLspinMode = 1 20160911010613 : #00286 VirtualKeyboard = 1 20160911010613 : #00287 Joy2MouseForJoy1 = 1 20160911010613 : #00288 OnStartExecutable = E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe 20160911010613 : #00289 OnStartParameters = E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\Help\Help.cfg 20160911010613 : #00290 OnExitExecutable = E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe 20160911010613 : #00291 OnExitParameters = E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\HyperSpin\HyperSpin.cfg 20160911010613 : #00292 BackgroundColor = 0x0 20160911010613 : #00293 PoliceColor = 0x41E4D4 20160911010613 : #00294 BackgroundImage = E:\Arcade-PC\Hyperspin\Media\Help\Images\Backgrounds\Background.png 20160911010613 : #00295 Transparency = 106 20160911010613 : #00296 ExitKeyNumber = 2 20160911010613 : #00297 OptionsKeyNumber = 8 20160911010614 : #00298 MultiSearchKeyNumber = 9 20160911010614 : #00299 QuickSearchKeyNumber = 7 20160911010614 : #00300 MouseClickButtonNumber = 2 20160911010614 : #00301 DeleteButtonNumber = 3 20160911010614 : #00302 SearchButtonNumber = 9 20160911010614 : #00303 controlMouseClickButtonNumber = 4 20160911010614 : #00304 ShiftMouseClickButtonNumber = 5 20160911010614 : #00305 ExitButtonNumber = 8 20160911010614 : #00306 OptionsButtonNumber = 6 20160911010614 : #00307 MultiSearchButtonNumber = 10 20160911010614 : #00308 QuickSearchButtonNumber = 11 20160911010614 : #00309 ParentalPINCode = 20160911010614 : #00310 JoystickNumber = 1 20160911010614 : #00311 ParentalFilter = 0 20160911010614 : #00312 StartupHidden = 0 20160911010614 : #00313 VideoArtworkPreview = 1 20160911010614 : #00415 Routine 20160911010614 : #00099 ValidatePCM#1: 20160911010614 : #00013 Checking E:\Arcade-PC\Hyperspin\Databases\Help\Help.xml 20160911010614 : #00018 run "E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe" "E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\Help\Help.cfg" 20160911010614 : #00019 Set Hotkey "enter" 20160911010614 : #00020 Set Hotkey "ESC" 20160911010614 : #00021 Set Hotkey "PGUP" 20160911010614 : #00022 Set Hotkey "PGDN" 20160911010614 : #00023 Set Hotkey "HOME" 20160911010614 : #00024 Set Hotkey "1Joy1" 20160911010614 : #00025 Set Hotkey "1Joy4" 20160911010614 : #00026 Set Hotkey "1Joy3" 20160911010615 : #00027 Set Hotkey "1Joy2" 20160911010615 : #00028 Set Hotkey "1Joy8" 20160911010615 : #00029 Set Hotkey "1Joy5" 20160911010615 : #00030 Set Hotkey "1Joy7" 20160911010615 : #00031 Set Hotkey "1Joy9" 20160911010615 : #00032 Set Hotkey "1Joy10" 20160911010615 : #00033 E:\Arcade-PC\hyperspin\HyperXMLspin.ini found 20160911010615 : #00160 Hyperxmlspin database 20160911010615 : #00505 Hyperxmlspin database...Reading Filters 20160911010615 : #00162 Hyperxmlspin database...end 20160911010617 : #00034 Hyperxmlspin gui creating... Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 11, 2016 Posted September 11, 2016 when launching from hyperspin wheel, it never appears still but here is my log. The wheel background just freezes and nothing happens until I press windows m to minimize all. Then I see hyperspin background move again and I have to push window m again in order to see my desktop which is why I still think its a focus problem OS Version = WIN_7 OS Version 64b = 1 HyperXmlspin Path = E:\Arcade-PC\hyperspin\HyperXMLspin.exe 20160911010722 : #00000 Start HyperXMLspin 20160911010722 : #00001 Parameter1 : Help. 20160911010722 : #00002 Parameter2 : 20160911010722 : #00003 Parameter3 : 20160911010722 : #00009 HyperSpin.exe detected 20160911010722 : #00012 HyperXMLspin.ini detected . Checking ... 20160911010722 : #00279 HyperspinDirectoryPath = E:\Arcade-PC\Hyperspin 20160911010722 : #00280 HyperXMLspinItemName = Help 20160911010722 : #00281 Fullscreen = 1 20160911010722 : #00282 resolution = 1 20160911010722 : #00283 FullPathLauncherExecutable = E:\Arcade-PC\Hyperspin\RocketLauncher\RocketLauncher.exe 20160911010722 : #00284 HyperXMLspinLanguage = English 20160911010722 : #00285 HyperXMLspinMode = 1 20160911010722 : #00286 VirtualKeyboard = 1 20160911010722 : #00287 Joy2MouseForJoy1 = 1 20160911010722 : #00288 OnStartExecutable = E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe 20160911010722 : #00289 OnStartParameters = E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\Help\Help.cfg 20160911010722 : #00290 OnExitExecutable = E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe 20160911010722 : #00291 OnExitParameters = E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\HyperSpin\HyperSpin.cfg 20160911010722 : #00292 BackgroundColor = 0x0 20160911010722 : #00293 PoliceColor = 0x41E4D4 20160911010722 : #00294 BackgroundImage = E:\Arcade-PC\Hyperspin\Media\Help\Images\Backgrounds\Background.png 20160911010722 : #00295 Transparency = 106 20160911010722 : #00296 ExitKeyNumber = 2 20160911010722 : #00297 OptionsKeyNumber = 8 20160911010722 : #00298 MultiSearchKeyNumber = 9 20160911010722 : #00299 QuickSearchKeyNumber = 7 20160911010722 : #00300 MouseClickButtonNumber = 2 20160911010722 : #00301 DeleteButtonNumber = 3 20160911010722 : #00302 SearchButtonNumber = 9 20160911010722 : #00303 controlMouseClickButtonNumber = 4 20160911010722 : #00304 ShiftMouseClickButtonNumber = 5 20160911010722 : #00305 ExitButtonNumber = 8 20160911010722 : #00306 OptionsButtonNumber = 6 20160911010722 : #00307 MultiSearchButtonNumber = 10 20160911010722 : #00308 QuickSearchButtonNumber = 11 20160911010722 : #00309 ParentalPINCode = 20160911010722 : #00310 JoystickNumber = 1 20160911010722 : #00311 ParentalFilter = 0 20160911010722 : #00312 StartupHidden = 0 20160911010722 : #00313 VideoArtworkPreview = 1 20160911010722 : #00415 Routine 20160911010722 : #00099 ValidatePCM#1: 20160911010723 : #00013 Checking E:\Arcade-PC\Hyperspin\Databases\Help\Help.xml 20160911010723 : #00018 run "E:\Arcade-PC\hyperspin\zips\tools\JoyToKey_en\JoyToKey.exe" "E:\Arcade-PC\hyperspin\RocketLauncher\Profiles\JoyToKey\Help\Help.cfg" 20160911010723 : #00019 Set Hotkey "enter" 20160911010723 : #00020 Set Hotkey "ESC" 20160911010723 : #00021 Set Hotkey "PGUP" 20160911010723 : #00022 Set Hotkey "PGDN" 20160911010723 : #00023 Set Hotkey "HOME" 20160911010723 : #00024 Set Hotkey "1Joy1" 20160911010723 : #00025 Set Hotkey "1Joy4" 20160911010723 : #00026 Set Hotkey "1Joy3" 20160911010723 : #00027 Set Hotkey "1Joy2" 20160911010723 : #00028 Set Hotkey "1Joy8" 20160911010723 : #00029 Set Hotkey "1Joy5" 20160911010723 : #00030 Set Hotkey "1Joy7" 20160911010723 : #00031 Set Hotkey "1Joy9" 20160911010723 : #00032 Set Hotkey "1Joy10" 20160911010723 : #00033 E:\Arcade-PC\hyperspin\HyperXMLspin.ini found Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 11, 2016 Posted September 11, 2016 for the launch issue, this is the error I get. The exported wheel seems to want a specific setting within Rocket Launcher.Did I set that up wrong? 01:12:45:951 | RL | ERROR | +8016 | No Default_Emulator found in "E:\Arcade-PC\hyperspin\RocketLauncher\Settings\Top Games\Emulators.ini" Please set one so RocketLauncher knows what module to use. Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 11, 2016 Posted September 11, 2016 [themes] reload_backgrounds=true use_parent_vids=true use_parent_themes=true [navigation] use_last_game=true start_on_favorites=false last_game=dkong+++MAME+++ use_indexes=true [wheel] text_color1=0xFFFFFF text_color2=0x0099CC text_color3=0x000NAN text_stroke_color=0x000000 shadow_color=0x000NAN alpha=0.15 horz_wheel_y=512 [Special Art A] default=false active=true x = 512 y = 384 in = .4 out = .4 length = 3 delay = .1 type =normal start =none [Special Art B] default=false active=true x = 290 y=750 in = .4 out = .4 length = 10 delay = .1 type =fade start =none [Special Art C] active=true x=974 y=13 in=0 out=0 length=3 delay=0 type=fade start=none [Game Text] game_text_active=true show_year=true show_manf=true show_description=true text_color1=0xffffff text_color2=0x0099cc stroke_color=0x000000 text_font=Style1 text1_textsize=16 text1_strokesize=7 text1_x=32 text1_y=665 text2_textsize=26 text2_strokesize=8 text2_x=30 text2_y=695 [video defaults] path= [exe info] romextension= parameters= rompath= path=E:\Arcade-PC\hyperspin\Emulators\PC Launcher\ exe=PCLauncher.exe pcgame=true searchsubfolders=false userompath=false hyperlaunch=true winstate=MAXIMIZED [filters] wheels_only=true exported wheel settings Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 11, 2016 Posted September 11, 2016 hyperxmlspin settings [exe info] romextension= parameters= rompath= path=E:\Arcade-PC\hyperspin\ exe=HyperXMLspin.exe pcgame=false searchsubfolders=false userompath=false hyperlaunch=false winstate=HIDDEN [themes] reload_backgrounds=true use_parent_vids=true use_parent_themes=true [navigation] use_last_game=true start_on_favorites=false last_game=Help use_indexes=true [wheel] text_color1=0xffffff text_color2=0x0099cc text_color3=0x000NAN text_stroke_color=0x000000 shadow_color=0x000NAN alpha=0.15 [Special Art A] default=false active=true x = 512 y = 384 in = .4 out = .4 length = 3 delay = .1 type =normal start =none [Special Art B] default=false active=true x = 290 y=750 in = .4 out = .4 length = 10 delay = .1 type =fade start =none [Special Art C] active=true x=974 y=13 in=0 out=0 length=3 delay=0 type=fade start=none [Game Text] game_text_active=true show_year=true show_manf=true show_description=true text_color1=0xffffff text_color2=0x0099cc stroke_color=0x000000 text_font=Style1 text1_textsize=16 text1_strokesize=7 text1_x=32 text1_y=665 text2_textsize=26 text2_strokesize=8 text2_x=30 text2_y=695 [video defaults] path=E:\Arcade-PC\hyperspin\Media\Help\Video\ Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted September 11, 2016 Posted September 11, 2016 ah my exported wheel needed hyper hq settings set to hyperxmlspin, duh! So the launching problem is no more however the gui doesn't display through the hyperspin wheel. here is my exported wheel and genres that i think would be awesome to include in your pack once the official release happens with hyperxmlspin when its called final Top Games.zip Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
psmiraglia Posted September 17, 2016 Posted September 17, 2016 Hi, I'm playing with the latest version from this thread (2016-09-10) and I'm hitting a snag. I was able to create a "Soccer games" wheel and export it. I was also able to create an "All favorites" one and export it. I cannot though create a "Donkey Kong" or "Star Trek" (which are lists matching those strings on game names across all my systems), though I'm able to create and export a "Lego" one (again, matching string across all systems). If I try to access "Donkey Kong" or "Star Trek" from the hyperxmlgenre list, I get "HyperXMLspin.xml is invalid" and HS exits. It seems like there is an issue when these lists are created (bad character ?). I'm sending pastebin links for both XMLs for your review. Let me know if there are other troubleshooting steps I should take. http://pastebin.com/N9WeMXZ2 http://pastebin.com/MrdXqTDt thanks, pablo.
r0man0 Posted September 18, 2016 Author Posted September 18, 2016 Hi, I'm playing with the latest version from this thread (2016-09-10) and I'm hitting a snag. I was able to create a "Soccer games" wheel and export it. I was also able to create an "All favorites" one and export it. I cannot though create a "Donkey Kong" or "Star Trek" (which are lists matching those strings on game names across all my systems), though I'm able to create and export a "Lego" one (again, matching string across all systems). If I try to access "Donkey Kong" or "Star Trek" from the hyperxmlgenre list, I get "HyperXMLspin.xml is invalid" and HS exits. It seems like there is an issue when these lists are created (bad character ?). I'm sending pastebin links for both XMLs for your review. Let me know if there are other troubleshooting steps I should take. http://pastebin.com/N9WeMXZ2 http://pastebin.com/MrdXqTDt thanks, pablo. Hi pablo , there is an error for donkey kong list on line 283 : <game name=""(_-_)index=+++Atari@@@2600+++" Index="False" Image="" > and for startrek line 643 <game name=""(_-_)index=+++Atari@@@2600+++" Index="False" Image="" > Both have bad game name , and both on atari 2600 Maybe hyperxmlspin atari 2600 database creation have encounted a problem , could you share me your atari 2600 original database , in order to fix that ? Thanks r0man0
psmiraglia Posted September 18, 2016 Posted September 18, 2016 sure. here it is: http://pastebin.com/FtELEdp5 cheers.
ninja2bceen Posted September 18, 2016 Posted September 18, 2016 Get a newer one, he's done a lot of work since then:) He is releasing a final version in the coming days. It's cool right? Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
