Sony PSP Theme and Media
I did mine some days ago too... just a little simpler... I may include some other images on the wheel theme (not the sub-wheel one)
  • Replies 56
this is my PSP image
http://jbensch.deviantart.com/art/PSP-psd-template-95443724
this is my box template,
http://www.neogaf.com/forum/showpost.php?p=30253645&postcount=862
I got the action to work but I do not like the front glare,
I modified it so that you would just see the crease and
I created a new set of actions to generate the box automatically.
Only problem is that I can only create one at a time, I cannot run a batch process.
if you rather have that I will have it in my folder when I finish uploading my 3d boxes.
I have over 100 done so far, they look pretty good except this one
this is the original image
http://www.covergalaxy.com/forum/sony-psp/12054-3rd-birthday-cover-ntsc.html
I tried to make it look like this one. but I did not like the end result, so I just left it alone.
http://www.gamefaqs.com/psp/951987-the-3rd-birthday/images/box-172037
I've noticed there's a lot of noise in my videos. I'll have to encode them again (audio encoding was set to the minimum quality...).
its up, Make sure your image covers the entire canvas, The vertical guides show you where the spine edges are and the script saves to desktop; PSP 3D Box Template.png.
Unfortunately it will overwrite the current file you do not rename your file before doing a second image.
I also updated this box. I rebuilt the spine and used the front cover from gamefaqs
  • 4 weeks later...
Some how my folder is always ends up in the "100+ PC Games Themes" folder. This is at least the 4th time it has happened, that's why I no longer have ps2 wheels in my folder, thankfully someone moved it back,
I like to make more ps2, gamecube and PSP boxes but the full 2d box scans are getting hard to find. I download PiraHC wheels and put them against a white and black background and cleaned the imperfections, wheel count is at over 50, I will upload them when I'm done.
  • 4 weeks later...
  • 2 months later...
I found out JPCSP is optimized to work with Nvidia graphics. When using Ati cards it produces many glitches, bad texture loading, etc. (Due to the shaders) so hopefully...
I haven't tried the jpcsp emu, is there an advantage over this one.
http://www.ppsspp.org/
It works with Android as well and is from the Dolphin developer i think.
I tested 2 Wipeout games and apart from there being no music, they both ran really sweet.
Nice theme btw.
  • 1 month later...
I wrote a small program that reads files in a directory and creates a Hyperspin XML file for the wheel. I was tired of having a ton of games listed that I did not have. It currently only makes a basic wheel and doesn't have any other info in the XML other than the game name but I'll add other info soon.
Filters off of file extension which is .cso for my psp roms. I'm planning to add the other systems.
