or8ital's HyperSpin Helper Software - 2nd / 3rd Display Controller
Would you be interested in software like this?
124 members have voted
  1. 1. Would you be interested in software like this?
  • Replies 606
  • 4 weeks later...
Having Experimented with this program i found it to be extremely easy to set up. CP Wizard and Marquee Magician have never worked for me outside of Mame(CP Wizard).
I have it set to change the image with the wheel & On NES for instance i have created a marquee folder and loaded it with flyer art, box and cartridge art.
A few issues i've ran into with my Windows 8 setup:
1. Haven't been able to load this program on start up yet, strangely it opens the notepad telling me it's started but that's it.
2. CP Wizard is causing it to loose focus (2 Monitor Setup) & also because i haven't figured out how to Open&Close CP wizard upon Launch of Mame and close
That's really all i can think of right now, but this program has so much potential and so far it's run flawlessly on normal conditions.
No longer working with latest demul 0.582 :(
Any chance of taking a look at this Or8ital?
Loving this app in my setup, seems a shame for it not to work with my Naomi/Atomiswave wheels.
Sent from my SM-N9005 using Tapatalk
Edit
Doesn't work with commodore amiga either
sig2.png?raw=1sig.jpg?raw=1
He posted a script a few pages back. I no longer am using my cab or second monitor at the moment, but I may mess with this again in the future. So I cant tell you if it works or not!!
A boy stuck in a mans body
Well i'm back with a small update:
Upon system startup this program is still only opening the .txt file for it (back out of HS to launch it,atleast for me)
Also the emulator that's giving me trouble is Daphne, which works fine on it's own, so after trying various settings nothing worked right unless i close Hyperspin Helper.
Any thoughts?
Well i'm back with a small update: Upon system startup this program is still only opening the .txt file for it (back out of HS to launch it' date='atleast for me) Also the emulator that's giving me trouble is Daphne, which works fine on it's own, so after trying various settings nothing worked right unless i close Hyperspin Helper. Any thoughts?[/quote']
Daphne should work fine. Just make sure each game is setup with the correct resolution for your monitor.
Not sure what you mean about opening the .txt file for it? Somewhere on this thread I have a .bat file that can be used to open it on startup.
Info on HyperspinHelper Software: http://hyperspinhelper.wordpress.com. Allows you to enable two additional displays as a Marquee and a controls help screen as well as map UltraStik 360 controls. Works exclusively with Hyperspin.
So I'm having a weird issue. After installing hyperspin helper, HS starts fine and it shows "Retro Arcade" on my 2nd monitor, but when I scroll to a system I want to play and click it to enter the game wheel it kicks me back out to the main system wheel back to the first system. It's doing this for every system.
I don't think this is Hyperspin Helper related. Was you doing something else between all this? Post you Hyperlaunch log set to troubleshooting.
Add a HSH shortcut to the windows startup folder that's how I have it set.
That's the last thing I just tried. HSH crashes when windows starts. IDK, maybe its an issue with my system.
***EDIT***
"Shortcut"..... lol I put a copy of the exe in the Startup folder, not a shortcut. I replaced it with a shortcut, now it works!
***EDIT***
Glad it's working for you :)
Is there a way to use an animated file format for the default marquee image like Gif or Apng?
Just posing this question again in case there's already a way to do it that I'm over looking. I'd really like the default marquee on my cab to have a simple GIF-like animation.
Thanks man. BTW - I greatly improved the reliability on my rig by having a short Windows login script delete debug.log then recreate a blank one. It very well is just something wrong with my setup but I thought I'd share.
  • 3 weeks later...
Thanks.
By the way I started to look at animated gif support today but found my video card driver isn't working and despite my best efforts I've not been able to repair it.
Thanks.
Thanks or8ital, much appreciated. I've got ambitions to animate the below. Let me know if there's anything I can contribute or test.
Thanks.
What kind of graphics card you using?
Radeon 7700. It's giving me a code 43 which is a driver error. I've uninstalled the drive and catalyst software and tried reloading it will no luck. I can either get the driver not loaded and a single screen or both monitors working with just a black screen and cursor.
Ok, ya I was checking because if you had a cheap one, I was willing to send you my old Radeon HD5750, I just upgraded to the Nivida GTX760.
Good news - I got the video card working again
Bad news - it took most of the day and reinstalling windows to do it. Gonna have to look at the animated gif option some other time. It will take me a while to get visual studio installed and everything I need to work on it.
Sorry for the delays guys. Any other features that folks want while I'm in the code?
