Section Admin
    3,621
    9
Everything posted by thatman84
  1. For 2. Validate override media in hq settings
  2. Can you open HyperHQ? do you mean the new game system wizard or the actual installation wizard?
  3. When legends return
  4. Non-merged support has been worked on this week so should see improvement in the next release
  5. Did it ever complete?
  6. The joys of beta testing your welcome to add some more detail to the post. Maybe set the log to verbose and attach the zip export. The devs may be able to spot the bugs
  7. Have you tried the cache clearing options in the HQ settings? Also roms refresh in the system settings?
  8. Delete and add the system again. double check your Rom extension is in the list when adding the system
  9. Give the latest build a try and reconfigure the controls in HyperHQ. been a bunch of updates on input for this release. See if the problem persists
  10. You can still download media from this forum. It’s in the Hyperspin 1.x section of the forum
  11. Once you have clicked the edit pencil on a game and saved OR cancelled you must exit the game page before using the edit function again
  12. SNK Neo Geo AES Main Menu Theme by: Unknown Preview Description SNK Neo Geo AES Main Menu. Graphics by Baddeolv! Details Type: Main Menu Theme Tags: neo,geo,aes,neo geo,snk,main,main menu,baddeolv Created: Mar 16, 2025 Download View on HyperTheme Credits tron38 (Animator)
  13. Out of interest how many of those 600+ are unique systems and how many are collections? Drop you Main Menu xml in here if you get a chance
  14. Would be nice to add a total games count to the systems list, and as i'm thinking maybe systems counter to. Please see my shakey mouse snip edit example.
  15. also happening for me on HQ.54 & HS.36
  16. For multi system emulators like RetroArch the ability to import multiple systems for that emulator in one hit would be awesome. Add System -> Select Retroarch -> Tick all supported systems -> Tick RomPaths OR auto scan for System folder names Similar to mame import & filtering
  17. Still happens for me, didnt realised this was fixed .53-beta UPDATE:- Updated my beta version to .54 and hit reinstall on the plugin and HS extracted/installed ok
  18. On the sounds settings the music instead of video snap video should say video snap audio
  19. When the new build is out you should def start fresh without the overrides for just a couple of systems before adding in overrides 1 at a time to see what or if your speeds get killed again. i tested last night and had much quicker performance but I don’t have collections of your size.
  20. There in the HS1 forum. Click community/forums in you side bar menu. At the bottom of the page
  21. I don’t think this setup has been looked at yet so the current method would probably be to split out the roms into separate folders. it does need looking into imo
  22. I just done some testing with Frosty and he has fixed an installer issue to rectify it on my system. I expect this will get into the next update the way around it is to let the update download and manual grab the exe file from the hyperHQ-updater folder in Users/AppData. Then manually run it in your custom location. Or grab the download exe from the forum and run it manually as above
  23. Please post your issue in the bug tracker. It needs looking into and that's the best place to keep track of it
