thatman84 Posted June 11, 2016 Posted June 11, 2016 Not on play store. ok, so not compatible. did you want to try the apk anyway? Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
Henderson33 Posted June 11, 2016 Posted June 11, 2016 Have you tried it yet thatman84?? Its wierd because the default special art works even tho its animated and a swf file
thatman84 Posted June 11, 2016 Posted June 11, 2016 yeah just trying now works in my pc setup but just blank on shield tv going to try another .png make sure and one of the other potts43 swf for xbox Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
Henderson33 Posted June 11, 2016 Posted June 11, 2016 yes worked on my bartop set up also, most of my themes have png files in so its a mystery
thatman84 Posted June 11, 2016 Posted June 11, 2016 sorry potts43, doesnt look like the .png files work as special!! My mistake but i tried the custom xbox .swf from post #80 and that works if you get a chance just try doing them as swf im not sure how all the special A1 B1 stuff works. It looks to me like my system menus read the special art from Main menu just puts it in a different place depending on the ini, dont know if thats normal Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
Henderson33 Posted June 11, 2016 Posted June 11, 2016 sorry potts43, doesnt look like the .png files work as special!! My mistake but i tried the custom xbox .swf from post #80 and that works if you get a chance just try doing them as swf im not sure how all the special A1 B1 stuff works. It looks to me like my system menus read the special art from Main menu just puts it in a different place depending on the ini, dont know if thats normal Sorry potts i previously said that the xbox.swf files made my hyperspin crash, after thatman84 said they worked on his i went back and tried again...Again it crashed so i deleted specialA1.swf file (frame) and the xbox controls seemed to work fine. Does the specialA1.swf file make your hyperspin crash thatman84? Thanks
thatman84 Posted June 11, 2016 Posted June 11, 2016 Sorry potts i previously said that the xbox.swf files made my hyperspin crash, after thatman84 said they worked on his i went back and tried again...Again it crashed so i deleted specialA1.swf file (frame) and the xbox controls seemed to work fine. Does the specialA1.swf file make your hyperspin crash thatman84? Thanks Um I have switched off tonight now. Possible as I was only messing with SpecialB1. I'll try tomorrow. BTW Potts43 the system buttons look amazing for Shield but I think for my setup I will have to double the size as I think they will be to small (from testing on my laptop) I'm going to track down a flash program next week so I can have a go at this animation stuff. Looks like fun!! Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
potts43 Posted June 12, 2016 Posted June 12, 2016 I may see the issue here. The original custom swf file had embedded action script to have the current date and time show. For kicks I'll do a frame without action script to try. It's possible that your shield TV doesn't like pngs so not showing.
potts43 Posted June 12, 2016 Posted June 12, 2016 Can you try this. They are unanimated png converted to swf. It may point us in the direction to completely solve this issue. I also need to know if these work if the original SpecialB1,2 and 3 work but the SpecialA doesn't. This will highlight the Actionscript is the issue. Cheers HyperSpin.zip
Henderson33 Posted June 12, 2016 Posted June 12, 2016 Can you try this. They are unanimated png converted to swf. It may point us in the direction to completely solve this issue. I also need to know if these work if the original SpecialB1,2 and 3 work but the SpecialA doesn't. This will highlight the Actionscript is the issue. Cheers Hi potts, the frame shown up just got to try get the correct x and y coordinates, im assuming the buttons are just wrong x an y coordinates as they dont show. Anyway here is a clip again https://youtu.be/o1WRcazRLRU Thanks for this potts
thatman84 Posted June 12, 2016 Posted June 12, 2016 So done some testing Files from post #80 Customised special art.zip A1 = Crashes my Shield TV hyperspin B1,2,3 display fine but are fairly small (I did not change my x and y) Latest Shield Buttons.swf test A1 shows up but does not scale up to fit the screen on the Shield TV (scales ok on my laptop) B1 has something weird going on both on Shield TV and my Laptop Hope this helps diagnose Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
potts43 Posted June 12, 2016 Posted June 12, 2016 Ok chaps thanks for testing. It appears that shield TV doesn't upscale like expected which probably means that I need to create the SpecialA at the intended resolution- probably 1920x1080? Is that what you are displaying? Clearly the action script in the original SpecialA that displayed the current date is the issue as my latest one didn't crash your system. Therefore that issue appears to have been resolved! The button icons were created to match the original SpecialA and fitted well with its design. The bottom had a transparent bar and they were sized to match. However on the PC they had to fit 1024x768 which was a HS thing/issue. This may be the issue you are seeing as there's no resizing going on. I'm thinking if you get me your screen resolution I can provide several files that should produce the best fit for android based systems.
thatman84 Posted June 12, 2016 Posted June 12, 2016 Yeah mines a full HD TV, 1920x1080 Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
potts43 Posted June 12, 2016 Posted June 12, 2016 Ok. Will be able to hopefully sort a test on Tuesday
potts43 Posted June 13, 2016 Posted June 13, 2016 Ok I have redone the artwork for you at 1080p. Normally the SpecialArt is made up from A and B...background and buttons. I have created them as separates and combined so you can choose how it works best for you. It might be easy to just choose the combined and rename to SpecialA. I have created pngs and swfs. NO Action scripts for you lot! The template at 1080p inc buttons is included so that you can edit the text for your individual systems if you wish to. Hopefully by now you see what is required to get these positioned correctly once you get your correct x and y positions. I have made the buttons larger as requested! I hope you can now get these to work pain free! 1080P.zip
potts43 Posted June 14, 2016 Posted June 14, 2016 Ninja here are your animated special swfs Hope they are ok for you! arcade main and system SpecialB artwork.zip
gigapig Posted June 14, 2016 Posted June 14, 2016 Ninja here are your animated special swfs Hope they are ok for you! Just tried the Main Menu one here. Looks great.
ninja2bceen Posted June 14, 2016 Author Posted June 14, 2016 looking through the browser its hard to tell in IE as its a little blurry but it looks amazing at first glance. will add to the system tonight and let you know. Top quality! Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
thatman84 Posted June 14, 2016 Posted June 14, 2016 Ok I have redone the artwork for you at 1080p. Normally the SpecialArt is made up from A and B...background and buttons. I have created them as separates and combined so you can choose how it works best for you. It might be easy to just choose the combined and rename to SpecialA. I have created pngs and swfs. NO Action scripts for you lot! The template at 1080p inc buttons is included so that you can edit the text for your individual systems if you wish to. Hopefully by now you see what is required to get these positioned correctly once you get your correct x and y positions. I have made the buttons larger as requested! I hope you can now get these to work pain free! Thanks for all the work on this, beat your own deadline! Had a very quick test before work and not sure if it's going to work Tried the main menu combined, Png didn't load as expected The swf looked like it was zoomed in but didn't have time to change x and y Viewing the png normally the buttons looked great. I'll test them all tonight properly Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted June 14, 2016 Posted June 14, 2016 Weird I know maybe it scales at an odd size. I'll try and see, what resolution images where the ones that displayed ok but slightly small? If only I had a way to create swf without spending tons of cash! Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
Henderson33 Posted June 14, 2016 Posted June 14, 2016 I don't understand any of it. How come the default swf special art that comes with HyperSpin works on Android but custom made ones don't display?
