mikekim Posted August 10, 2012 Posted August 10, 2012 Right here goes.... After months of reading and head scratching I feel its time to start my own cabinet build. Many thanks to all of the fantastic people on this site who have figured out so much on how these things go together. you guys all deserve a medal or something Let the Build commence... After seeing Mamemans fantasitic Tron P2K build, I thought about doing something similar, but decided against it, and plumped for a standard body cab (Freezy's detailed plans helped to a certain degree), and the detailed threads from Chriz99 and Deegor. I have decided to theme the cabinet on artwork from the Watchmen Series, as I thought that it would look good on the Cabinet. I might also look at lightning parts of the artwork from the inside (probably the back box clocks) Cabinet this will be a standard body cabinet, with sunken playfield, I have ordered the following items (links included - where items purchased new) Ultimate Cab-Builder's Kit - standard body Mirror-polished Lockdown Bar Mirror-polished Side Rails Williams/Bally Chrome coin door Blue pincab leg protectors cab builders button kit Red, White, Green and Blue Starpoint 44mm Illuminated Arcade Button White, Red, Yellow and Blue 5v leds Yellow Launch Ball Button power switch Black slotted trunking Spiral cable wrap - Yellow Spiral cable wrap - Black Cable tie mounting pads drawer runners Door locks hinges Cablesson HDMI Wall Plate Single molex connectors (pk of 5) Flange fixing chassis plug, IEC Male Flange fixing chassis plug, IEC Female audio connectors cam lock Dowel (pack of 50) cam lock 18mm (pack of 50) 4x 1200x650x18MM Plywood Sheet 1x 1200x650x3mm Hardboard Sheet A4 Transparent Sticky Back Self Adhesive PVC Film 5 sht This cab will have 10x flashers (probably the lower lumen led's - not crees) and 2x strobes 10x Clear Flasher Cap 5pcs 1W Watt LED Aluminium Heatsink 1pcs 3W High Power RGB Led 5m RGB LED strip Airflow will be augmented by the following: 2x Silverstone SST-AP181 Air Penetrator 180mm FAN 700/1200rpm(for air inlet at the front underside of the cab) 4x NZXT FS-200 Enthusiast Silent Case Fan - 200mm(for both rear of main box and back box) 3x Akasa AK-191-SM Smoke Ultra Quiet 120mm Fan(for triple radiator) Cabinet Audio the pc will soundcard I'm using is the excellent Asus Xonar DX2 7.1 Harmin Kardon Speakers Asus Xonar Dx2 7.1 Soundcard Electrics I'm still finalising the list of parts required for this build. I'm currently working thorough this with one of my friends who is an electrician, so hopefully this shouldn't be too much of a problem, However I'm also undecided on what system to use for nudging, some different ideas and feedback from the community would be helpful here... iPac32 keyboard controller LEdWiz Controller Zebulons High Power Booster Boards PSU 5V 40A PSU 12V 16.7A PSU 24V 8.4A 8x Siemens Contactors 3RT10161BB41 Diodes 1N4007 (pk 20) 27ohm 5watt resistors (pk 10) 10x 3.9 ohm 1 watt resistors 5x 6.8 ohm 1 watt resistors 24AWG wire various colours x10 30m rolls 20AWG wire various choice of 11 colours 10m rolls MS Sidewinder Pro Screens I have opted for the Samsung ES6300 40" screen for the main play field and a Samsung T27A300 27 inch Widescreen LED for the back glass. I have ordered a Vishay Orange from Virtuapin for the DMD Samsung UE40ES6300 LED 200hz (Play field 1920x1080) Samsung T27A300 27 inch Widescreen LED Monitor (Backglass 1280x1024) Vishay Orange 5v LED DMD PinDMD controller PC the PC i'm using is probably a bit overkill for a cabinet, (I7 980X) but it was a spare machine I've had sitting around that is no longer used for gaming. I've had to purchase a couple of items to make it viable as a machine for this purpose (this machine originally had an OCZ IBIS drive, but that is far to temperamental for a machine that needs to run without issues, so it was replaced with an OCZ Agility 4 120GB SSD). this machine is fully Watercooled, so I will be changing the coolant to sunburst yellow which will match the theme of the cabinet artwork, when installed in the cab. I have some ideas about positioning the radiator externally on the underside of the cab, with some form of removable base for the PC and radiator to be installed on. This machine has a GTX 580 for the mainscreen and a GTX 480 for the back glass. I have installed Hyperspin, VP IVP has the 4GB patch applied) and FP on a clean windows 7 build using 301.42 WHQL drivers, after many days of figuring things out i have a system up and running with 50 tables using the 301.42 drivers I have no slowdown (or stutter) on any of the tables installed (even Monoploly runs at turbo speed). i still haven't installed UVP yet but can't see that being a problem. As I have a 6 core system, I have set the luxury of spreading out the processor affinity so that each main program gets its own pair of cores. currently it is set for the following: VP and FP to run on cores 4-5, Hyperspin to run on 2-3 and the rest to run on 0-1. I might have to adjust this later on (i have also disabled Hyperthreading) I will probably assign a single core to each application when tuning later on (when i get LEDWIZ and UVP playing together) Motherboard Tray PC Specs Intel Core i7 980X 3.33GHz, Extreme Edition (Socket LGA1366) (O/C'd to 4.2Ghz) Asus Rampage III Extreme,X58, S1366, DDR3 Motherboard Corsair Vengeance 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Enermax Galaxy EGX850EWL 850W Modular PSU Asus GTX 580, 40nm, 4008MHz, GPU 782MHz, 1536MB Graphics Card EVGA GTX 480, 40nm, 3696MHz, GPU 700MHz, 1536MB Graphics Card OCZ Vertex 4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive Akasa SATA-III 50cm Rounded Data Cable Asus Xonar D2X 7.1 PCI-E Sound Card Microsoft Windows 7 Home Premium 64-Bit XSPC X2O 750 Dual 5.25” Bay Reservoir Pump HK CPU Backplate LGA 1366 HK CPU LGA1366 Waterblock EK CoolStream Triple Radiator XT 360 (360mm) EK-FC580GTX VGA cooler AquagraFX GTX 480 VGA cooler 6m XSPC HighFlex Hose 1/2" ID, 3/4" OD, Clear/UV 2L Mayhems Pastel - Sunset Yellow Coolant cooling fluid 3x Bitspower right angle connectors 4x Bitspower 45 degree connectors 10x Bitspower compression fittings 4x EK-PSC Adapter Rotary 90° G1/4 Black 4x EK-PSC Adapter Rotary 45° G1/4 Black Artwork here is the current design that I'm thinking about for the cabinet: Side Front Backbox A quick Photoshop mockup using Freezy's cab build picture: Any questions / comments would be most welcome.
njay Posted August 10, 2012 Posted August 10, 2012 Wicked man !! , good luck with your build. Are you going the vishay plasma 12v route? should work like a charm on a pc psu My Mini Pin Build: http://www.hyperspin-fe.com/forum/showthread.php?t=5622 My Arcade Bartop Build: http://www.hyperspin-fe.com/forum/showthread.php?t=14570
mameman Posted August 10, 2012 Posted August 10, 2012 Nice artwork PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
DeeGor Posted August 10, 2012 Posted August 10, 2012 Great theme! I'm a big Watchmen fan, so I'll be looking forward to seeing this build.
jeepguy81 Posted August 10, 2012 Posted August 10, 2012 That artwork is killer, gives a great feel to the cab! - Vertical-Cocktail Cab Theme Project
maxxsinner Posted August 10, 2012 Posted August 10, 2012 Love the Watchman theme. Think the backbox needs a bit of colour in the background? Look forward to seeing your build Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
chriz99 Posted August 11, 2012 Posted August 11, 2012 great start and welcome aboard cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
mikekim Posted August 14, 2012 Author Posted August 14, 2012 Love the Watchman theme. Think the backbox needs a bit of colour in the background?Look forward to seeing your build i've taken your advice on the back box, how about this design.
monkeychunkuk Posted August 14, 2012 Posted August 14, 2012 Wow Mike I can't keep up with your amazing builds I can't wait to see the finished machine
mameman Posted August 14, 2012 Posted August 14, 2012 agreed, the black backbox black artwork was not fitting with the colorful side art. The new backbox art i'm not as keen on, don't personally like the watchmen down the side, breaks it up too much. I would much perfer the who thing as the blue artwork streached out on the side of the head. between these 2 i would stick with the first. if you really wanted to get the watchmen name on the cab, perhaps ghost it into the cabinet sideart? just my 2 cents. PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
DeeGor Posted August 14, 2012 Posted August 14, 2012 I like the new art a lot. That look pays homage to the original comic books. It would be awesome if you could get a picture of Alan Moore playing it when you're all done.
mikekim Posted August 14, 2012 Author Posted August 14, 2012 I like the new art a lot. That look pays homage to the original comic books.[ATTACH=CONFIG]19633[/ATTACH] It would be awesome if you could get a picture of Alan Moore playing it when you're all done. You never know.... I actually met him at an independent local cinema screening of watchmen ( got a signed copy of the graphic novel). I could ask the cinema if they would pass on a message.. Sent from my GT-I9100 using Tapatalk 2
DeeGor Posted August 14, 2012 Posted August 14, 2012 You never know....I actually met him at an independent local cinema screening of watchmen ( got a signed copy of the graphic novel). I could ask the cinema if they would pass on a message.. You have a new mission in life. Anything short of this = failure.
Hyperion Posted August 14, 2012 Posted August 14, 2012 Wow! I love Watchmen! Perfect choice for a pinball theme and you got to meet Alan Moore! I'm not sure how he'd feel about the movie artwork though. From what I've read he's pretty sore about his book been adapted to a movie. I personally think the movie was great. A perfect fit for Zack Snyder's style (let's see if he does a good job on Man of Steel and not screw it up like SuckerPunch). Man I'd love to have a spare i7 machine like that lying around! It makes me wonder what your current gaming machine specs are. My first cocktail cab: The Hyper Arcade Entertainment System Win 7 64bit | i5 3570K Overclocked to 4.2GHz | 16GB 1600MHz DDR3 | GTX 970 Strix | Samsung 250GB 840 Evo SSD + 8x4TB green drives in RAID 5 for XBMC/KODI
mameman Posted August 15, 2012 Posted August 15, 2012 now what you need is to build a Watchmen table to go with the cabinet. then get Alan to sign the cab. Ca-ching!!!!! incidently my wife has a signed watchmen book by dave gibbons (the illustrator), apprently he frequented a book store in St Albans UK where we used to work, she was told if she left it there he often comes in and they would get him to sign it. One day they called and she went up there, low and behold one signed book. nice!! PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
mikekim Posted August 15, 2012 Author Posted August 15, 2012 now what you need is to build a Watchmen table to go with the cabinet. then get Alan to sign the cab. Ca-ching!!!!!incidently my wife has a signed watchmen book by dave gibbons (the illustrator), apprently he frequented a book store in St Albans UK where we used to work, she was told if she left it there he often comes in and they would get him to sign it. One day they called and she went up there, low and behold one signed book. nice!! Very nice, I live in Hemel Hempstead (5 miles form St. Albans). Small world sometimes..
scott.gullicks Posted August 16, 2012 Posted August 16, 2012 Awesome cab theme. Would make a sweet pinball table too.
mameman Posted August 16, 2012 Posted August 16, 2012 Very nice, I live in Hemel Hempstead (5 miles form St. Albans).Small world sometimes.. haha, cool yeah we lived in kings langley (ovaltine complex) for sometime, watford also till i took a transfer with the company to the head office over here in southfield (outside Detroit). was in hemel for week just before the olympics on a trip back since we had not been back in 2 years. What theater did you meet him at? The Rex in berko? Or when he did the London conference? keep up the good work. PM me for any custom CNC needs. Find me on Facebook.. Xtreme Pinball or www.xtremepinball.com Ipad pinball cabinet iFlipper Here: See the Doctor Who build Here.... / See the Tron build Here.... / See the BattleStar Galactica build Here.... See the Big Bang Bar build Here.... / See the Twilight Zone build Here.... CNC Work Here.....
mikekim Posted August 16, 2012 Author Posted August 16, 2012 yes, it was at the Rex screening of Watchmen
mikekim Posted August 19, 2012 Author Posted August 19, 2012 bit of an update... after extensive testing of the pc (in other words playing lots of pinball on it!!) wasn't happy with the level of heat produced by the Dell monitor for the back glass, so i have just placed an order for a Samsung T27A300 27 inch Widescreen LED Monitor, the Dell will go back up in the loft waiting to be used at a later date. Also my Virtuapin standard body kit and coin door turned up this weekend (after the joy of paying £90 in import Taxes ) I will be starting work on the cabinet shortly, just about to order the wood for the job. I'm also looking for a UK supplier of invisiglass or similar for the screens, as i want to minimise reflections on the cab. also if anyone wants heat sinks for leds let me know, as I slightly over ordered. should have read the seller description on ebay better (they where being sold in packs of five)... so instead of 10 heat sinks , I have 50!!
monkeychunkuk Posted August 20, 2012 Posted August 20, 2012 Cant wait to see your progress ,were do you build your projects?
mikekim Posted August 22, 2012 Author Posted August 22, 2012 had a play with some custom inserts today. printed on adhesive transparent gloss film photoshop template: coin door: extra ball button:
