EyMannMachHin Posted May 30, 2017 Share Posted May 30, 2017 @DubaiShark yes, they are, I opened a ticket for that already And you can open a ticket, by klicking on the "Support" menu on top of this page Link to comment Share on other sites More sharing options...
sr.lucas Posted June 1, 2017 Share Posted June 1, 2017 Hi All, This is my first time here. I've been struggling to get hypersync cloud to work with no luck. It logs into my emumovies account, but it throws an error every time I want to log into the hypersinc account. Any ideas why? Link to comment Share on other sites More sharing options...
Accorsi Posted June 1, 2017 Share Posted June 1, 2017 6 minutes ago, sr.lucas said: Hi All, This is my first time here. I've been struggling to get hypersync cloud to work with no luck. It logs into my emumovies account, but it throws an error every time I want to log into the hypersinc account. Any ideas why? you need to be a platinum member Link to comment Share on other sites More sharing options...
sr.lucas Posted June 1, 2017 Share Posted June 1, 2017 18 minutes ago, Accorsi said: you need to be a platinum member I thought I was. How do I become one? Link to comment Share on other sites More sharing options...
Accorsi Posted June 1, 2017 Share Posted June 1, 2017 http://www.hyperspin-fe.com/store/category/1-subscriptions/ Link to comment Share on other sites More sharing options...
sr.lucas Posted June 2, 2017 Share Posted June 2, 2017 22 hours ago, Accorsi said: http://www.hyperspin-fe.com/store/category/1-subscriptions/ Thanks. I got my platinum membership but I am still not able to access.... same error 1 Link to comment Share on other sites More sharing options...
Accorsi Posted June 2, 2017 Share Posted June 2, 2017 i don't know it's working here http://www.hyperspin-fe.com/forums/forum/342-hypersync-support/ or contact adm Link to comment Share on other sites More sharing options...
alex2005 Posted December 10, 2017 Share Posted December 10, 2017 Hello! I use this excellent tool to sync my artwork and works perfectly, however would it be possible to make the user interface adjustable or to fit on a 640x480 screen? Reason for asking is that I use it on an arcade cabinet that does not support higher resolutions, and the current UI is too big to make it usabel on a low resolution monitor, making it depenedant to have an alternative computer to sync the media, which is not very ideal... Thank so much!! Link to comment Share on other sites More sharing options...
gigapig Posted December 10, 2017 Share Posted December 10, 2017 2 minutes ago, alex2005 said: Hello! I use this excellent tool to sync my artwork and works perfectly, however would it be possible to make the user interface adjustable or to fit on a 640x480 screen? Reason for asking is that I use it on an arcade cabinet that does not support higher resolutions, and the current UI is too big to make it usabel on a low resolution monitor, making it depenedant to have an alternative computer to sync the media, which is not very ideal... Thank so much!! This software is no longer in development so I guess it won't happen. A new version currently called HyperAI is in development which may support low resolution but won't support windows XP if you use that. Link to comment Share on other sites More sharing options...
alex2005 Posted December 10, 2017 Share Posted December 10, 2017 2 hours ago, gigapig said: This software is no longer in development so I guess it won't happen. A new version currently called HyperAI is in development which may support low resolution but won't support windows XP if you use that. thanks for the heads up on this So if I understand correctly, currently there is no tool to sync these? I just tried HyperSync 3.5 again (it has been a while since then) and its no longer syncing Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted December 10, 2017 Share Posted December 10, 2017 I'm not designing the new app specifically to work with such a low res. I believe the lowest tested res is 800*600. However, Technically it should still work.Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
alex2005 Posted December 10, 2017 Share Posted December 10, 2017 (edited) thanks for the reply. it used to work for me a couple of months ago but now by some reason i always get a message saying there are no new themes to download (but havent run it for about a year) . is there a specific path where the settings are stored? maybe i could try to reset them and see if this makes a difference. edit: found the setting file a few pages back, ill give it a try Edited December 10, 2017 by alex2005 1 Link to comment Share on other sites More sharing options...
alex2005 Posted December 11, 2017 Share Posted December 11, 2017 editing the ini file with default values sorted the issue somehow, it seems that there are not so many artworks updated lately, or maybe I already have the majority of them I could even set the sync button "on" editing the settings file, and there was no need to change resolutions on my arcade monitor for it! great workaround Link to comment Share on other sites More sharing options...
uronito Posted October 14, 2020 Share Posted October 14, 2020 Thanks!!!!!!! Link to comment Share on other sites More sharing options...
juicelee Posted January 21, 2021 Share Posted January 21, 2021 is hyper sync upto date with all the latest themes videos artwork. do i get the best video snaps from here looking for the best resolution(hq) and at 60fps, thanks Link to comment Share on other sites More sharing options...
Marcoqwerty Posted July 9, 2022 Share Posted July 9, 2022 (edited) On 12/6/2014 at 10:37 AM, Sledge said: Ok, I've got an issue... My cab has a limited screen resolution, so i can't turn 'sync system' on.. It's below the bottom of the screen at the highest resolution i can go... Does Hypsersync not support low resolutions at all? (ie: windows bars that we can drag.. not sure what it's called) highest i can go is 768x576.. Ok i see this is a common question sorry for the post 🥲 Edited July 9, 2022 by Marcoqwerty Try one of the workaround Link to comment Share on other sites More sharing options...
Marcoqwerty Posted July 9, 2022 Share Posted July 9, 2022 On 12/11/2017 at 7:29 PM, alex2005 said: editing the ini file with default values sorted the issue somehow, it seems that there are not so many artworks updated lately, or maybe I already have the majority of them I could even set the sync button "on" editing the settings file, and there was no need to change resolutions on my arcade monitor for it! great workaround Could you explain me where i could find the ini files? Thank you! Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
