Taito Type X Files
gigapig
  superrama said:
NOTE TO MODS: This does not contain the hacked exe or copyright material. this is only the preconfiguration for an xbox controller or wheel for the emulator
NOTE TO SUPERRAMA: But I want them. :(
Thanks... :)
  • Replies 369
Look at theme announcements thread! ^^
Ah, crap, got bg4 running once. Second time it just hangs in start up. Anyone know of this problem or is it just me
UPDATE: It runs fine from D: partition but not from my R: partition
superrama, all your configs no longer work as the latest loader changes the controls and fixes support for a lot more.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
all i could think of for the longest time was that I remember downloading an mp3 off napster in my teenage years that was called 70s porno music, and it's your 1st background track in this video haha!
What version loader are we on now?
Latest update is 8, bg4_7, Looks like it fixes audio. Previously I had to set mine to spdif as hdmi and speakers didn't work.
Oh I'm well out of date!
That maybe my fault? I've just check the latest bg4_7 and some files are missing. You may also need bg4_3 also as that has the loader. If you already had the loader maybe it won't matter, depends on what's getting updated I suppose.
  urbangangsta101 said:
Can't seem to get BG4 to run, just freezes. Did someone mention a .dll file that needed to be moved into the folder? Using Windows 8.1 x64
Taken from gamer9347's post.
Take These files from the C: \ Windows \ SysWOW64 folder:
msvcp110_clr0400.dll
msvcr110_clr0400.dll
Copy into BG4T folder and rename to Them:
rename msvcp110_clr0400.dll msvcp110.dll
rename msvcr110_clr0400.dll msvcr110.dll
Just tested the update, which as Dj said breaks Superramas control config.
The game now has audio and background music over HDMI, but I can't get this bloody Citroen off the starting grid :)
Make sure you run the loader with the exe, not the game.exe directly.
Make a batch file, should be something like this in it:
ttx_loader game.exe
Run the bat to start the game.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
ttx_loader game.exe
Yeah I have done that, still unable to run the game although it gets further. I now get asked to press the accelerator and hit start then the brake and start, then it saves and gives a "handle error"
Wouldn't do anything until I ran it from drive R:\ (suggested in an earlier post)
About to give up on this one....
Agree, but maybe just see how things develop, there have been changes over the last few days, so hopefully things will get sorted.
The main thing for me is fixing the config to accept 360 inputs, not just on this game, but most, if not all the others. But this game particularly as it needs analogue, I also tried my G27 and that had the same issue, and now I've said that it's obviously not exclusive to the 360 controller.
Did you try a different audio setting, and have you also tried Superramas config etc from here?
they still work. im on version 8 of the loader. i was playing it earlier today and I didnt have to reconfigure. Only copy over the monitor_input, monitor_misc, monitor log and use the latest loader and config2.0 The xbox ones are working. I think you might be right about the steering wheel one since it was using the older definitions of buttons. ill update the wheel one later
I got deathsmiles 2 working by setting it to run in windows 7 compatibility and run as administrator, but I still get the music cutting out in daemon bride and arcana heart 3, anyone else had this problem?
Finally got Battle Gear 4 Working.
To summarise:
- It's fussy about what drive it runs from. Doesn't seem to work from G:\ or Z:\ but runs fine on H:\
If you having trouble running it, 'Share' the folder (set permissions so that 'Everyone' has Read/Write access) and then map to it via 'Computer' (My Computer) as drive H:\. It will load fine when run from there.
- If you are getting a .dll error during launch, or when running the button config application - Install the Microsoft Visual C++ 2012 Redists (x86 and x64) as you are missing important files. (NOTE: Do NOT use the .dll files that have been posted before or the ones that people suggest to copy from the Windows folder and renamed - they don't work with BG4 and you will have problems like the "I/O Error")
- The game looks much better (Less jagged edges) with added FXAA. If you have a GeForce card go into your NVIDIA Control Panel and add it to the list of applications. Force FXAA and also 16x AF (Helps with blurry textures)
- Superramas configs still work with the latest loader (Update 8), you just need the 'monitor_input.bin' from whatever set of controls you want to use and copy it into your BG4 folder.
- The Test Menu on Superramas config is Keyboard "P" - be sure to go into there and do the "Adjustment" setting
- Menus are controlled by Shift Up/Down (LB,RB) and Start (Start Button)
- Difficulty can be increased during the track/course selection, press the hazard button (X Button) to increase (See indicator in the bottom right hand of the screen)
- Full screen can be enabled by running the game via the following command:
game4.exe _MTS_FULL_SCREEN_
- There is a config file floating around that can unlock hidden tracks
All working fine here. Would like to make my own controller config but there appears to be a problem setting the controls in ttx_config2.0.exe as the Xbox 360 Analog sticks take over any button I try to set!
Hey guys, i try to setup Contra now but there is no files provided for this game in the ftp, someone made this launch and exit correctly through HS?
nevermind i used this prelaunch script and it exits correctly :)
~Esc::
 Process, Close, AMContra_full.exe
 ExitAPP
return
