Sir Cyrano Posted January 8, 2014 Posted January 8, 2014 Some games these platforms are unplayable with MESS Emulator, but I set all the buttons do not respond, anyone know if there is any emulator that emulates all games perfectly ???
jvlk Posted January 8, 2014 Posted January 8, 2014 2600 = Stella 5200 = Kat 5200 7800 = Prosystem Console Fade Project 4:3 Resolutions compatible fix
richardbmw Posted January 8, 2014 Posted January 8, 2014 2600 = Stella5200 = Kat 5200 7800 = Prosystem +1
Trnzaddict Posted January 8, 2014 Posted January 8, 2014 Use emu7800 for the lightgun games in Atari 7800 but the other emus are what I use spot on as well. I am......Machine
rfancella Posted January 8, 2014 Posted January 8, 2014 Stella for the 2600 will allow you to emulate the paddle with your mouse/spinner. I don't think any other emu can do that.?? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Dime333 Posted April 5, 2014 Posted April 5, 2014 I tried a few games with prosystem. Among them were Double Dragon and Basketbrawl. None of them worked. Are they not compatible? Is that still the best emulator out there? Should I use an alternate emulator for those? I don't Think it's a very good sign that about 50% of the games I tried won't run. Any help on this would be appreciated.
craiganderson Posted January 15, 2015 Posted January 15, 2015 regarding 5200 any updates? still need two emulators? if so, can somebody share their list of which game for which emulator? your file is in hyperlaunch > settings > atari 5200 > games.ini http://craigandersonthemes.weebly.com/
Styphelus Posted January 15, 2015 Posted January 15, 2015 Atari 2600 - Retroarch (with Stella Core) Atari 5200 - Atari800. I could not get the bezel to work with Kat5200. Atari800 runs everything perfectly fine. Haven't found any issues yet. Atari 7800 - Retroarch (using the Prosystem core) and Mess. Retroarch has problems with some games so I have Mess setup as an alternate emulator. I'm running Mess 0.151 which is really old. I've heard the new Mess 0.157 has very good 7800 emulation but I haven't tried yet. If true I'll replace Retroarch with Mess. Will try it this weekend.
craiganderson Posted January 15, 2015 Posted January 15, 2015 Atari 2600 - Retroarch (with Stella Core)Atari 5200 - Atari800. I could not get the bezel to work with Kat5200. Atari800 runs everything perfectly fine. Haven't found any issues yet. Atari 7800 - Retroarch (using the Prosystem core) and Mess. Retroarch has problems with some games so I have Mess setup as an alternate emulator. I'm running Mess 0.151 which is really old. I've heard the new Mess 0.157 has very good 7800 emulation but I haven't tried yet. If true I'll replace Retroarch with Mess. Will try it this weekend. regardin 5200 thanks weird..i tried 800 and had several games not work (didnt note which ones sorry..) so i switched back to MESS as main and KAT for alt emulator had to mess with kat bezel setting in module a little bit now to check all controls..... http://craigandersonthemes.weebly.com/
craiganderson Posted January 15, 2015 Posted January 15, 2015 regarding bezels is there a way to name the .png/.ini combos SUCH that a user can have one bezel for the main emulator and a different bezel for the alt emulator? thanks edit'--answer is no i have been told http://craigandersonthemes.weebly.com/
Styphelus Posted January 16, 2015 Posted January 16, 2015 regardin 5200thanks weird..i tried 800 and had several games not work (didnt note which ones sorry..) so i switched back to MESS as main and KAT for alt emulator had to mess with kat bezel setting in module a little bit now to check all controls..... Do you think you can post your setup for the Atari 5200 and your KAT bezel and module? This is one system that has been giving me headaches. You are right about the 800. I started trying out all the games and there are quite a few that don't run.
craiganderson Posted January 16, 2015 Posted January 16, 2015 sure. but to be clear the bezel "works" but the bezel shows the titlebar still i think i could get rid of that as well but working on something else right now let me know if u still want it? see pic below. its ok if u dont....no biggie :) i know that the module normally does that but in order to center it i tweaked it to not do that make sense? dont want any of the PURISTS (lol) to get mad at my doing things my own weird way... :) :) http://craigandersonthemes.weebly.com/
craiganderson Posted January 16, 2015 Posted January 16, 2015 hold on fixed the title bar as well MEmu = Kat5200 MEmuV = v0.6.2 MURL = http://kat5200.jillybunch.com/ MAuthor = djvj MVersion = 2.0.1 MCRC = 3FDEE537 MID = 635038268901251702 MSystem = "Atari 5200" ;---------------------------------------------------------------------------- ; Notes: ; In you emu dir, create a subdir named bios and place the 5200.rom there extracted. ; When you first start kat5200, you will be presented with a Wizard. Set the bios folder you created as your "Atari 8-bit ; Image Directory" and leave Scan for BIOS? checked. ; While in the wizard, check the Fullscreen box to enable it and set Video Zoom to 2x. ; CLI is supported but doesn't seem to work. So for now, set your video options from the GUI. ; Settings are stored in the kat5200.db3 file. ; Roms must be extracted, zip is not supported ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() 7z(romPath, romName, romExtension, 7zExtractPath) If romExtension in %7zFormats% ScriptError("Kat5200 only supports extracted roms. Please extract your roms or turn on 7z for this system as the emu is being sent this extension: """ . romExtension . """") settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) [b][color="#FF0000"]disableHideTitleBar := true disableHideToggleMenu := true disableHideBorder := true BezelStart("fixResMode")[/color][/b] Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinActivate, ahk_class ConsoleWindowClass WinMinimize, ahk_class ConsoleWindowClass WinActivate, kat5200 ahk_class SDL_app WinWait("kat5200 ahk_class SDL_app") WinWaitActive("kat5200 ahk_class SDL_app") WinActivate, kat5200 ahk_class SDL_app BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("kat5200 ahk_class SDL_app") Return (the bezel png and ini are one of grizz's) bezel png and ini.zip http://craigandersonthemes.weebly.com/
craiganderson Posted January 16, 2015 Posted January 16, 2015 Work? http://craigandersonthemes.weebly.com/
dsync89 Posted June 4, 2015 Posted June 4, 2015 It seems like only a few lines of code (just 3) is needed to enable the bezel and hiding the title bar. The following code provided by @craig is not necessary. In fact, enabling them will still show the title bar. disableHideTitleBar := true disableHideToggleMenu := true disableHideBorder := true BezelStart("fixResMode") Here is the config that I've modified. Tested on HyperSpin 1.3.x MEmu = Kat5200 MEmuV = v0.6.2 MURL = http://kat5200.jillybunch.com/ MAuthor = djvj MVersion = 2.0.1 MCRC = 3FDEE537 MID = 635038268901251702 MSystem = "Atari 5200" ;---------------------------------------------------------------------------- ; Notes: ; In you emu dir, create a subdir named bios and place the 5200.rom there extracted. ; When you first start kat5200, you will be presented with a Wizard. Set the bios folder you created as your "Atari 8-bit Image Directory" and leave Scan for BIOS? checked. ; While in the wizard, check the Fullscreen box to enable it and set Video Zoom to 2x. ; CLI is supported but doesn't seem to work. So for now, set your video options from the GUI. ; Settings are stored in the kat5200.db3 file. ; Roms must be extracted, zip is not supported ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() 7z(romPath, romName, romExtension, 7zExtractPath) If romExtension in %7zFormats% ScriptError("Kat5200 only supports extracted roms. Please extract your roms or turn on 7z for this system as the emu is being sent this extension: """ . romExtension . """") BezelStart("fixResMode") Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("kat5200 ahk_class SDL_app") WinWaitActive("kat5200 ahk_class SDL_app") BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("kat5200 ahk_class SDL_app") Return
kenshutt97 Posted July 12, 2015 Posted July 12, 2015 I still can't get the bezel to work with either of code snippets posted in this forum. Are there settings beyond what are in the notes needed to make this work? Note: I'm a 1080p display. Could that be causing the issue?
patricknn Posted April 24, 2016 Posted April 24, 2016 For those who still having this issue on 1080p after use @dsync89 config file, go to kat video options: Uncheck Full Screen box Check Specify WindowSet the resolution 1400x1080Then your bezel will look fine
newoski Posted June 14, 2016 Posted June 14, 2016 Atari 2600 - Retroarch (with Stella Core) Atari 5200 - Atari800. I could not get the bezel to work with Kat5200. Atari800 runs everything perfectly fine. Haven't found any issues yet. Atari 7800 - Retroarch (using the Prosystem core) and Mess. Retroarch has problems with some games so I have Mess setup as an alternate emulator. I'm running Mess 0.151 which is really old. I've heard the new Mess 0.157 has very good 7800 emulation but I haven't tried yet. If true I'll replace Retroarch with Mess. Will try it this weekend. Which 7800 games do you use MESS for?
Styphelus Posted June 14, 2016 Posted June 14, 2016 Mess (Mame) supposedly has really good 7800 emulation. I haven't run into any issues with it so far. I have yet to encounter a game that doesn't run with it. I haven't tried all of them however.
Caci Posted July 8, 2019 Posted July 8, 2019 I have one question for the readers who are still reading this old post. Is it possible to use the same emulators from Atari 7800 Emulators to play the games of Atari 5200 and 2600? I had boring with 7800 games and I want to switch to another console so do I need to delete the emulator?
