HyperSearch
pietie
In HyperHQ you can choose the location of your Videos. That location gets saved into your SYSTEMNAME.ini file in the C:\HyperSpin\Settings folder. My files are in my EmuMovies FTP folder where I dumped every single 480p file on the server into. :)
  • Replies 485
Bravo, this program is amazing!
But I have a little trouble getting it to work right. No video... Games don't start... Is it because I'm under Hyperlanch 2.
Thanks a lot.
Thanks a lot.
For launching, I assume you have RocketLauncher.0, yes. It uses the HyperLaunch path configured in Settings.ini. It then launches "HyperLaunch.exe [system name] [rom name]". So if you can configure HL2.0 in the same way it should work.
As for the videos, that's only dependent on your HyperSpin config. Do you use alternative video paths perhaps? It was an issue but has been fixed in the latest version.
Can you post your log?
My tools
Steam wheel creator - Generate xml list from Steam profile with artwork and videos
HyperSearch - Integrates search functionality with HyperSpin
If that's the case all HyperLaunch 1 and 2 users need to do is add the HyperLaunch Path to your HyperSpin settings file. You don't necessarily need to update to RocketLauncher until/if HyperSearch uses HyperLaunch specific files, like for statistics, most played, media, etc.
The command line options has not changed at all ever since HL started, and it probably will not change until HyperSpin changes. Although there is always the possibility of adding the support for more HL parameters (the first two paramters won't change), but that is up to djvj and his cronies.
Indeed, with hyperlaunch 2, we must add a line:
hyperlaunch_path = D: \ Hyperspin
in theHyperSpin settings file. With this addition, it is possible to launch games ... Great!!!
However, I still have no video. (I also use png, flv as mp4, paths by default and specific paths).
I still make some test before sending my log.
Again thank you for this wonderful search engine.
Great application.
I've played with it a few minutes and it works great. It's a really nice tool.
I've run into 2 problems though :
1- In my settings.ini, I use relative path (..\Hyperlauch) instead of full path (C:\Hyperpause). The games won't lauch when it's like that. If I user the full path, game are lauched perfectly.
I also have a problem if I use relative path to my hyperspin directory in HyperSearch.exe.config. The initialisation of the search is not able to finish and I can't search after that (an error getting a malformed URI...)
I use this because I sync my 2 hyperspin on multiple computers.
2- Video doesn't seem to show when the list has only 1 entry. And in the list with more entries, I have to move to another to get the video.
But it's totally fine if it works this way these are just nice to have and I would understand and these are not corrected.
Thanks again for this great software.
1. As others have said, relative paths are not supported but I'll add it to my list
2. I'll look into this thanks.
My tools
Still no videos...
Here's my log :
08:18:32  Trigger key from config: P
08:18:32  Hyperspin path: d:\Hyperspin
08:18:32  SearchTriggerDelayInMilliseconds=0
08:18:32  Hook installed succesfully
08:18:32  Hyperspin settings loaded from: d:\Hyperspin\Settings\Settings.ini
08:18:32  HL path: D:\Hyperspin
08:18:32  	SearchDB: Parsing d:\Hyperspin\Databases\Main Menu\Main Menu.xml...
08:18:33  	SearchDB: Found 69 entries in [Main Menu.xml]
08:18:33  	SearchDB: Processing d:\Hyperspin\Databases\MAME\MAME.xml
08:18:33  		Found 8034 entries
08:18:33  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:33  	SearchDB: Processing d:\Hyperspin\Databases\ggpo\ggpo.xml
08:18:33  		Found 1 entries
08:18:33  	SearchDB: Processing d:\Hyperspin\Databases\Dice\Dice.xml
08:18:33  		Found 14 entries
08:18:33  	SearchDB: Processing d:\Hyperspin\Databases\AAE\AAE.xml
08:18:34  		Found 37 entries
08:18:34  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:34  	SearchDB: Processing d:\Hyperspin\Databases\Actionmax\Actionmax.xml
08:18:34  		Found 5 entries
08:18:34  	SearchDB: Processing d:\Hyperspin\Databases\ShmupMame\ShmupMame.xml
08:18:34  		Found 75 entries
08:18:34  	SearchDB: Processing d:\Hyperspin\Databases\Cave\Cave.xml
08:18:34  		Found 21 entries
08:18:35  		Removed: 1 (wheel filter), 0 (theme filter)
08:18:35  	SearchDB: Processing d:\Hyperspin\Databases\Touhou Project\Touhou Project.xml
08:18:35  		Found 15 entries
08:18:35  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:35  	SearchDB: Processing d:\Hyperspin\Databases\Nintendo Arcade Systems\Nintendo Arcade Systems.xml
08:18:35  		Found 105 entries
08:18:35  	SearchDB: Processing d:\Hyperspin\Databases\CPS\CPS.xml
08:18:35  		Found 21 entries
08:18:35  	SearchDB: Processing d:\Hyperspin\Databases\CPS2\CPS2.xml
08:18:36  		Found 34 entries
08:18:36  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:36  	SearchDB: Processing d:\Hyperspin\Databases\CPS3\CPS3.xml
08:18:36  		Found 6 entries
08:18:36  	SearchDB: Processing d:\Hyperspin\Databases\NeoGeo MVS\NeoGeo MVS.xml
08:18:36  		Found 140 entries
08:18:36  	SearchDB: Processing d:\Hyperspin\Databases\Zinc\Zinc.xml
08:18:36  		Found 38 entries
08:18:37  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:37  	SearchDB: Processing d:\Hyperspin\Databases\Sega ST-V\Sega ST-V.xml
08:18:37  		Found 61 entries
08:18:37  	SearchDB: Processing d:\Hyperspin\Databases\Sega Model 2\Sega Model 2.xml
08:18:37  		Found 56 entries
08:18:37  		Removed: 0 (wheel filter), 9 (theme filter)
08:18:37  	SearchDB: Processing d:\Hyperspin\Databases\Taito Type X2\Taito Type X2.xml
08:18:38  		Found 19 entries
08:18:38  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:38  	SearchDB: Processing d:\Hyperspin\Databases\[vide]\[vide].xml
08:18:38  		Found 1 entries
08:18:38  	SearchDB: Processing d:\Hyperspin\Databases\NeoGeo AES\NeoGeo AES.xml
08:18:39  		Found 140 entries
08:18:39  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:39  	SearchDB: Processing d:\Hyperspin\Databases\NeoGeo CD\NeoGeo CD.xml
08:18:39  		Found 71 entries
08:18:39  	SearchDB: Processing d:\Hyperspin\Databases\SNK Neo Geo Pocket\SNK Neo Geo Pocket.xml
08:18:40  		Found 10 entries
08:18:40  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:40  	SearchDB: Processing d:\Hyperspin\Databases\SNK Neo Geo Pocket Color\SNK Neo Geo Pocket Color.xml
08:18:40  		Found 40 entries
08:18:40  	SearchDB: Processing d:\Hyperspin\Databases\Nes\Nes.xml
08:18:40  		Found 791 entries
08:18:40  	SearchDB: Processing d:\Hyperspin\Databases\Nintendo Famicom Disk System\Nintendo Famicom Disk System.xml
08:18:41  		Found 91 entries
08:18:41  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:41  	SearchDB: Processing d:\Hyperspin\Databases\Super Nintendo\Super Nintendo.xml
08:18:41  		Found 787 entries
08:18:41  	SearchDB: Processing d:\Hyperspin\Databases\Nintendo 64\Nintendo 64.xml
08:18:42  		Found 303 entries
08:18:42  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:42  	SearchDB: Processing d:\Hyperspin\Databases\Game Boy\Game Boy.xml
08:18:42  		Found 565 entries
08:18:42  	SearchDB: Processing d:\Hyperspin\Databases\Nintendo Game Boy Color\Nintendo Game Boy Color.xml
08:18:42  		Found 535 entries
08:18:43  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:43  	SearchDB: Processing d:\Hyperspin\Databases\Game Boy Advance\Game Boy Advance.xml
08:18:43  		Found 1129 entries
08:18:43  	SearchDB: Processing d:\Hyperspin\Databases\Virtual Boy\Virtual Boy.xml
08:18:44  		Found 20 entries
08:18:44  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:44  	SearchDB: Processing d:\Hyperspin\Databases\Nintendo Pokemon Mini\Nintendo Pokemon Mini.xml
08:18:44  		Found 11 entries
08:18:46  		Removed: 5 (wheel filter), 0 (theme filter)
08:18:46  	SearchDB: Processing d:\Hyperspin\Databases\SG1000\SG1000.xml
08:18:46  		Found 68 entries
08:18:46  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:46  	SearchDB: Processing d:\Hyperspin\Databases\Master System\Master System.xml
08:18:46  		Found 278 entries
08:18:46  	SearchDB: Processing d:\Hyperspin\Databases\Megadrive\Megadrive.xml
08:18:46  		Found 781 entries
08:18:46  	SearchDB: Processing d:\Hyperspin\Databases\Sega CD\Sega CD.xml
08:18:47  		Found 171 entries
08:18:47  		Removed: 166 (wheel filter), 0 (theme filter)
08:18:47  	SearchDB: Processing d:\Hyperspin\Databases\32X\32X.xml
08:18:48  		Found 37 entries
08:18:48  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:48  	SearchDB: Processing d:\Hyperspin\Databases\Sega Saturn\Sega Saturn.xml
08:18:48  		Found 273 entries
08:18:48  	SearchDB: Processing d:\Hyperspin\Databases\Sega Game Gear\Sega Game Gear.xml
08:18:48  		Found 259 entries
08:18:48  	SearchDB: Processing d:\Hyperspin\Databases\PC Engine\PC Engine.xml
08:18:49  		Found 289 entries
08:18:49  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:49  	SearchDB: Processing d:\Hyperspin\Databases\NEC PC Engine-CD\NEC PC Engine-CD.xml
08:18:49  		Found 118 entries
08:18:49  	SearchDB: Processing d:\Hyperspin\Databases\NEC TurboGrafx-16\NEC TurboGrafx-16.xml
08:18:49  		Found 94 entries
08:18:49  	SearchDB: Processing d:\Hyperspin\Databases\NEC TurboGrafx CD\NEC TurboGrafx CD.xml
08:18:50  		Found 48 entries
08:18:50  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:50  	SearchDB: Processing d:\Hyperspin\Databases\SuperGrafx\SuperGrafx.xml
08:18:50  		Found 5 entries
08:18:50  	SearchDB: Processing d:\Hyperspin\Databases\Sony Playstation\Sony Playstation.xml
08:18:51  		Found 1713 entries
08:18:51  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:51  	SearchDB: Processing d:\Hyperspin\Databases\Atari 2600\Atari 2600.xml
08:18:51  		Found 648 entries
08:18:51  	SearchDB: Processing d:\Hyperspin\Databases\Atari 5200\Atari 5200.xml
08:18:51  		Found 72 entries
08:18:51  	SearchDB: Processing d:\Hyperspin\Databases\Atari Lynx\Atari Lynx.xml
08:18:51  		Found 75 entries
08:18:51  	SearchDB: Processing d:\Hyperspin\Databases\Atari Jaguar\Atari Jaguar.xml
08:18:52  		Found 31 entries
08:18:52  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:52  	SearchDB: Processing d:\Hyperspin\Databases\Commodore Amiga\Commodore Amiga.xml
08:18:52  		Found 1808 entries
08:18:52  	SearchDB: Processing d:\Hyperspin\Databases\Commodore Amiga CD32\Commodore Amiga CD32.xml
08:18:53  		Found 86 entries
08:18:53  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:53  	SearchDB: Processing d:\Hyperspin\Databases\Commodore CDTV\Commodore CDTV.xml
08:18:53  		Found 10 entries
08:18:53  	SearchDB: Processing d:\Hyperspin\Databases\Adventurevision\Adventurevision.xml
08:18:53  		Found 4 entries
08:18:53  	SearchDB: Processing d:\Hyperspin\Databases\Astrocade\Astrocade.xml
08:18:53  		Found 38 entries
08:18:54  	SearchDB: Processing d:\Hyperspin\Databases\Arcadia 2001\Arcadia 2001.xml
08:18:54  		Found 48 entries
08:18:54  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:54  	SearchDB: Processing d:\Hyperspin\Databases\Casio PV-1000\Casio PV-1000.xml
08:18:54  		Found 4 entries
08:18:54  	SearchDB: Processing d:\Hyperspin\Databases\Channel F\Channel F.xml
08:18:54  		Found 28 entries
08:18:54  	SearchDB: Processing d:\Hyperspin\Databases\Colecovision\Colecovision.xml
08:18:54  		Found 140 entries
08:18:55  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:55  	SearchDB: Processing d:\Hyperspin\Databases\Epoch Super Cassette Vision\Epoch Super Cassette Vision.xml
08:18:55  		Found 30 entries
08:18:55  	SearchDB: Processing d:\Hyperspin\Databases\GX4000\GX4000.xml
08:18:55  		Found 22 entries
08:18:55  	SearchDB: Processing d:\Hyperspin\Databases\GCE Vectrex\GCE Vectrex.xml
08:18:55  		Found 24 entries
08:18:56  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:56  	SearchDB: Processing d:\Hyperspin\Databases\Wonderswan Mono\Wonderswan Mono.xml
08:18:56  		Found 109 entries
08:18:56  	SearchDB: Processing d:\Hyperspin\Databases\Wonderswan Color\Wonderswan Color.xml
08:18:56  		Found 91 entries
08:18:56  	SearchDB: Processing d:\Hyperspin\Databases\PC Games\PC Games.xml
08:18:57  		Found 9 entries
08:18:57  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:57  	SearchDB: Processing d:\Hyperspin\Databases\ScummVM\ScummVM.xml
08:18:57  		Found 37 entries
08:18:57  	SearchDB: Processing d:\Hyperspin\Databases\PopCap\PopCap.xml
08:18:57  		Found 71 entries
08:18:57  	SearchDB: Processing d:\Hyperspin\Databases\Mugen\Mugen.xml
08:18:58  		Found 10 entries
08:18:58  		Removed: 0 (wheel filter), 0 (theme filter)
08:18:58  	SearchDB: Processing d:\Hyperspin\Databases\Future Pinball\Future Pinball.xml
08:18:58  		Found 101 entries
08:18:58  	SearchDB: Processing d:\Hyperspin\Databases\JukeBox\JukeBox.xml
08:18:58  		Found 0 entries
08:18:58  	SearchDB: Processing d:\Hyperspin\Databases\Favoritegames\Favoritegames.xml
08:18:59  		Found 3 entries
08:18:59  		Removed: 0 (wheel filter), 0 (theme filter)
08:19:12  Search: full game list loaded in 39422ms. Game count: 16249
08:20:33  Video failed to open: System.Windows.Controls.MediaElement, with error: System.IO.FileNotFoundException: Media file download failed. ---> System.Runtime.InteropServices.COMException (0xC00D0FEA): Exception from HRESULT: 0xC00D0FEA
08:20:41  Video failed to open: System.Windows.Controls.MediaElement, with error: System.IO.FileNotFoundException: Media file download failed. ---> System.Runtime.InteropServices.COMException (0xC00D0FEA): Exception from HRESULT: 0xC00D0FEA
08:20:49  Launching: D:\Hyperspin\Hyperlaunch.exe "Nes" "Silent Service (USA) (Rev A)"
And one more time : GREAT JOB!
Cool, learned something new, but dang I have the default path and no vids in hypersearch.
Sent from my SM-N900V using Tapatalk
I personally don't have an answer for the no vids issue. :)
But yeah Alt paths rock.
so hypersync/hyperbase knows to update to your alt path? looks like i needs to do some movings...
Think I may just give up since I tried to turn it off <add key="EnableGameVideos" value="false"/>, and the video border still pops up...meh. still cool tool though!
:o whoops. I'll have to fix that
My tools
Lol. Just a temporary giving up. I know I'm doing something wrong, I'll test more this evening.
when i try to find "Spider-man" games y can´t type "-" character, please add support to more keys, (yes i can find it typing "spider" and "spiderman" or "spider man" don´t work), thanks it´s an awesome app.
pietie, i figured that one out... it was i saved the config while it was still running.
Sending from iPhone...
Installed latest version. Searched for Rambo and I got the list. Then as I scrolled through them the videos popped up but then I got a pop up saying can't load Rambo.xml in database folder. Any ideas? I will rerun search if no success to generate the log when I'm at my pc.
Thanks
First, thanks a lot for the app, it is a brilliant idea for any HS install :)
I have a little problem though.
I tried redefining the key from F3 to q (I did set a button to that key with xpadder), but Hypersearch defaults it back to F3.
In the log :
12:05:33  Failed to convert trigger key from key, default to: F3
In the .config :
<add key="TriggerKey" value="q"/>
Any idea why it doesn't work? Thanks in advance !
I have no idea why the videos started showing up, but I noticed it happening when I started clicking with the mouse around where the videos where. I got a video to show then accidentally launched the game. I had no idea why, but prior to that my log was not showing any activity, other then it saying it was searching and found my databases. Finally an error! I noticed my mame media was off (cause I had just changed it) Anywho, I corrected that then magically they all started showing up... cept a custom wheel for Gun Games, but I expected that! So if that rambling helped anyone horrah! If not, just keep at it!
pietie, as your demanding testers I have one more request (you know you don't have to listen to us, right? :laugh:) How about ability to change the exit commands? I have a cab, and ideally would not like to pull out the keyboard, if I decide to close out of HyperSearch. Which is an awesome app by thr way!!
In the log :
In the .config :
If you switch it back to F3, does it work?
