ersatz Posted March 9, 2014 Posted March 9, 2014 Thanks for this great tool, Hyperspin needs a search engine. I've run Hypersearch at startup via HyperHQ and everything's fine but now I don't know how to kill the process at exit. When I close Hyperspin, Hypersearch is still active as a process.
Sir Cyrano Posted March 9, 2014 Posted March 9, 2014 HyperSearch can capture inputs from Joystick and Buttons ?? HL can do it.
pietie Posted March 10, 2014 Author Posted March 10, 2014 Thanks for this great tool, Hyperspin needs a search engine. I've run Hypersearch at startup via HyperHQ and everything's fine but now I don't know how to kill the process at exit. When I close Hyperspin, Hypersearch is still active as a process. Create a batch (.bat) file, put the line below in there and set it to run on exit. taskkill /f /fi "IMAGENAME eq HyperSearch.exe" My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
pietie Posted March 10, 2014 Author Posted March 10, 2014 Actually I'd prefer a QWERTY keyboard myself but dunno how much work that is to implement? Actually not much work at all! It's really just a visual reordering, the functionality stays exactly the same. Do you have a touchscreen or does it just make it easier to find the right letter? I did a quick test of it and it works okay but due to the way listviews work moving between buttons can be a bit....weird. But please give it a try in the next version and let me know how it works for you... My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
Polemicist Posted March 10, 2014 Posted March 10, 2014 Actually not much work at all! It's really just a visual reordering, the functionality stays exactly the same. Do you have a touchscreen or does it just make it easier to find the right letter? I did a quick test of it and it works okay but due to the way listviews work moving between buttons can be a bit....weird. But please give it a try in the next version and let me know how it works for you... The QWERTY keyboard has been shown to be easier to find buttons on for most people due to it being the most common keyboard layout. Also a few of the common characters found in names for searching would be helpful eg. Pac-man is hard to search for with a "-"
AxelTerizaki Posted March 10, 2014 Posted March 10, 2014 French people use AZERTY though. Would it be ok if there was a setting to set which keyboard we prefer ? Envoyé de mon Nexus 5 en utilisant Tapatalk
Polemicist Posted March 10, 2014 Posted March 10, 2014 French people use AZERTY though. Would it be ok if there was a setting to set which keyboard we prefer ? Envoyé de mon Nexus 5 en utilisant Tapatalk That is like a difference of two keys. At least you don't use this. http://en.wikipedia.org/wiki/File:Telegraph_Keyboard.jpg But QWERTY is still the most common. http://en.wikipedia.org/wiki/Keyboard_layout and with QWERTZ being the next most common and only having the two keys swapped I'm sure the Zaxxon players in France and Germany won't mind looking for their Z...
pietie Posted March 11, 2014 Author Posted March 11, 2014 Installed latest version. Searched for Rambo and I got the list. Then as I scrolled through them the videos popped up but then I got a pop up saying can't load Rambo.xml in database folder. Any ideas? I will rerun search if no success to generate the log when I'm at my pc. Have you been able to reproduce this? My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
relic Posted March 11, 2014 Posted March 11, 2014 would it be possible to set search button for enter on keyboard so once you press enter it will auto click search cause as i say its perfect the way you can type stuff in but still needs search to be set to enter key auto well thats a suprise for me you press ctrl + enter to make auto land on search 100%
potts43 Posted March 11, 2014 Posted March 11, 2014 Have you been able to reproduce this? I haven't tried but will try this morning. Thanks for replying. Videos are great btw
pietie Posted March 11, 2014 Author Posted March 11, 2014 Anywho, I corrected that then magically they all started showing up... cept a custom wheel for Gun Games, but I expected that! So if that rambling helped anyone horrah! If not, just keep at it! What is different about your Gun Games wheel? Is it not part of your Main Menu.xml? If HyperSpin can browse it then I would also like to. pietie, as your demanding testers I have one more request (you know you don't have to listen to us, right? ) How about ability to change the exit commands? I have a cab, and ideally would not like to pull out the keyboard, if I decide to close out of HyperSearch. Which is an awesome app by thr way!! Heh I don't have a problem with requests such as these 'cause my mine aim was to make it work for cab users. What key do you have configured in HyperSpin as your exit key? The app already looks at the HyperSpin input settings but there are a couple of issues. If you use a key found on the OSK then the OSK intercepts it. I also don't support combo keys yet... My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
klizine Posted March 11, 2014 Posted March 11, 2014 Ok I might have been going crazy. I'll double check when I get home. Sent from my SM-N900V using Tapatalk
Dime333 Posted March 11, 2014 Posted March 11, 2014 If you use a key found on the OSK then the OSK intercepts it I haven't tried this yet, but it sounds like a wonderful piece of software. I was thinking maby there could be an option to reverse this setting. I'm using "m" as my player 2 start button. This is also my "back/exit" button in HS. It would be great to be able to us that to exit hypersearch too. As I'm using a cab, I don't ever intend to use the keyboard to type in what I'm searching for. This is of course the complete opposite of what someone that doesn't use a cab would want. Maby we can get the best of two Worlds here. Thanks for making this app. It will be a great addition to my cab.
pietie Posted March 12, 2014 Author Posted March 12, 2014 I was thinking maby there could be an option to reverse this setting. I'm using "m" as my player 2 start button. This is also my "back/exit" button in HS. It would be great to be able to us that to exit hypersearch too. Yeah I tried to make the two modes work together as best I can but it really is just not feasible. So I agree, a hard switch will work better. Thanks! My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
pietie Posted March 12, 2014 Author Posted March 12, 2014 New version is out! Check the first post for detail but some highlights are a new favourites and genre search & new keyboard layouts. My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
horseyhorsey Posted March 12, 2014 Posted March 12, 2014 Customise look and feel. If you really don't like my yellow video border and you're familiar with XAML or you can figure it out, you can change the Styling in Styles.xaml. It even contains some of the core control templates. If there is any interested I might add even more more of the templates and styling into this file. Cool! Hope you can add the HyperStats in this somewhere with the games sometime... Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
klizine Posted March 12, 2014 Posted March 12, 2014 Pietie, awesome new features!!!! I love the exit via esc and being able to move right/left during a search! This thing rocks!.... I just can't get videos to show up. It's the white mesh looking screen no sound, no image... no error. My videos are in the default location. I'm completely fine with turning them off, your app is great enough on it's on... I just don't like when computers get the best of me... so I will fight this...to the end...hopefully with help Here is the seemingly uneventful log: 10:39:31 Search trigger key from config: F3 10:39:31 Favourites trigger key from config: F4 10:39:31 Genre trigger key from config: F5 10:39:31 Hyperspin path: C:\Hyperspin 10:39:31 Hook installed succesfully 10:39:31 Hyperspin settings loaded from: C:\Hyperspin\Settings\Settings.ini 10:39:31 HL path: C:\Hyperspin\HyperLaunch\ 10:39:31 CabMode: True 10:39:31 SearchDB: Parsing C:\Hyperspin\Databases\Main Menu\Main Menu.xml... 10:39:31 SearchDB: Found 53 entries in [Main Menu.xml] 10:39:31 SearchDB: Processing C:\Hyperspin\Databases\AAE\AAE.xml 10:39:31 Found 35 entries 10:39:31 Removed: 0 (wheel filter), 0 (theme filter) 10:39:31 SearchDB: Processing C:\Hyperspin\Databases\American Laser Games\American Laser Games.xml 10:39:31 Found 11 entries 10:39:31 Removed: 0 (wheel filter), 0 (theme filter) 10:39:31 SearchDB: Processing C:\Hyperspin\Databases\Atari 2600\Atari 2600.xml 10:39:31 Found 648 entries 10:39:31 Removed: 0 (wheel filter), 0 (theme filter) 10:39:31 SearchDB: Processing C:\Hyperspin\Databases\Atari 5200\Atari 5200.xml 10:39:31 Found 72 entries 10:39:31 Removed: 0 (wheel filter), 0 (theme filter) 10:39:31 SearchDB: Processing C:\Hyperspin\Databases\Atari 7800\Atari 7800.xml 10:39:32 Found 53 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Atari Jaguar\Atari Jaguar.xml 10:39:32 Found 54 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Atari Lynx\Atari Lynx.xml 10:39:32 Found 75 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Capcom Play System 3\Capcom Play System 3.xml 10:39:32 Found 6 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\ColecoVision\ColecoVision.xml 10:39:32 Found 140 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Commodore 64\Commodore 64.xml 10:39:32 Found 527 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Daphne\Daphne.xml 10:39:32 Found 17 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Gun Games\Gun Games.xml 10:39:32 Found 181 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\MAME\MAME.xml 10:39:32 Found 8710 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Mattel Intellivision\Mattel Intellivision.xml 10:39:32 Found 138 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\MUGEN\MUGEN.xml 10:39:32 Found 45 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\NEC TurboGrafx-16\NEC TurboGrafx-16.xml 10:39:32 Found 94 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo 64\Nintendo 64.xml 10:39:32 Found 303 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo DS\Nintendo DS.xml 10:39:32 Found 12 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo Entertainment System\Nintendo Entertainment System.xml 10:39:32 Found 791 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo Game Boy\Nintendo Game Boy.xml 10:39:32 Found 565 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo Game Boy Advance\Nintendo Game Boy Advance.xml 10:39:32 Found 1129 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo Game Boy Color\Nintendo Game Boy Color.xml 10:39:32 Found 535 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo GameCube\Nintendo GameCube.xml 10:39:32 Found 5 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo Super Game Boy\Nintendo Super Game Boy.xml 10:39:32 Found 145 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo Virtual Boy\Nintendo Virtual Boy.xml 10:39:32 Found 20 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Nintendo Wii\Nintendo Wii.xml 10:39:32 Found 6 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\OpenBOR\OpenBOR.xml 10:39:32 Found 60 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\PC Games\PC Games.xml 10:39:32 Found 3 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sammy Atomiswave\Sammy Atomiswave.xml 10:39:32 Found 24 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\ScummVM\ScummVM.xml 10:39:32 Found 208 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega 32X\Sega 32X.xml 10:39:32 Found 33 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega CD\Sega CD.xml 10:39:32 Found 171 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega Dreamcast\Sega Dreamcast.xml 10:39:32 Found 142 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega Game Gear\Sega Game Gear.xml 10:39:32 Found 259 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega Genesis\Sega Genesis.xml 10:39:32 Found 781 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega Master System\Sega Master System.xml 10:39:32 Found 278 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega Model 2\Sega Model 2.xml 10:39:32 Found 56 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega Model 3\Sega Model 3.xml 10:39:32 Found 23 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega Naomi\Sega Naomi.xml 10:39:32 Found 117 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega SG-1000\Sega SG-1000.xml 10:39:32 Found 73 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sega Triforce\Sega Triforce.xml 10:39:32 Found 5 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\SNK Neo Geo\SNK Neo Geo.xml 10:39:32 Found 213 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\SNK Neo Geo CD\SNK Neo Geo CD.xml 10:39:32 Found 87 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\SNK Neo Geo Pocket Color\SNK Neo Geo Pocket Color.xml 10:39:32 Found 40 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sony Playstation\Sony Playstation.xml 10:39:32 Found 33 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Sony Playstation 2\Sony Playstation 2.xml 10:39:32 Found 14 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Steam Big Picture\Steam Big Picture.xml 10:39:32 Found 14 entries 10:39:32 Removed: 0 (wheel filter), 0 (theme filter) 10:39:32 SearchDB: Processing C:\Hyperspin\Databases\Super Nintendo Entertainment System\Super Nintendo Entertainment System.xml 10:39:33 Found 787 entries 10:39:33 Removed: 0 (wheel filter), 0 (theme filter) 10:39:33 SearchDB: Processing C:\Hyperspin\Databases\Taito Type X\Taito Type X.xml 10:39:33 Found 35 entries 10:39:33 Removed: 0 (wheel filter), 0 (theme filter) 10:39:33 SearchDB: Processing C:\Hyperspin\Databases\Tiger Game.com\Tiger Game.com.xml 10:39:33 Found 20 entries 10:39:33 Removed: 0 (wheel filter), 0 (theme filter) 10:39:33 SearchDB: Processing C:\Hyperspin\Databases\Touhou Project\Touhou Project.xml 10:39:33 Found 25 entries 10:39:33 Removed: 0 (wheel filter), 0 (theme filter) 10:39:33 SearchDB: Processing C:\Hyperspin\Databases\VM Labs Nuon\VM Labs Nuon.xml 10:39:33 Found 7 entries 10:39:33 Removed: 0 (wheel filter), 0 (theme filter) 10:39:33 SearchDB: Processing C:\Hyperspin\Databases\WoW Action Max\WoW Action Max.xml 10:39:33 Found 5 entries 10:39:33 Removed: 0 (wheel filter), 0 (theme filter) 10:39:34 Search: full game list loaded in 2824ms. Game count: 17830 10:39:34 Favourites: Found 3 file(s). 10:39:34 Search: Favourites list loaded in 0ms. Entry count: 0 10:39:34 Processing C:\Hyperspin\Databases\NEC TurboGrafx-16\favorites.txt... 10:39:34 Found 0 item(s) 10:39:34 Processing C:\Hyperspin\Databases\Nintendo Wii\favorites.txt... 10:39:34 Found 0 item(s) 10:39:34 Processing C:\Hyperspin\Databases\Sega Master System\favorites.txt... 10:39:34 Found 0 item(s) 10:39:34 Search: Genere list loaded in 62ms. Genre count: 87 10:41:33 Using list: Normal 10:41:47 SearchMode: Contains 10:42:30 SearchMode: Contains 10:42:38 Using list: Normal 10:42:45 SearchMode: Contains 10:43:28 Using list: Normal 10:43:48 SearchMode: Contains 10:44:28 SearchMode: Contains 10:44:37 Launching: C:\Hyperspin\HyperLaunch\Hyperlaunch.exe "MAME" "pc_miket" 10:45:07 Using list: Normal 10:45:21 SearchMode: Contains 10:45:33 Launching: C:\Hyperspin\HyperLaunch\Hyperlaunch.exe "MAME" "sonicp"
pietie Posted March 12, 2014 Author Posted March 12, 2014 Pietie, awesome new features!!!! I love the exit via esc and being able to move right/left during a search! This thing rocks!.... I just can't get videos to show up. It's the white mesh looking screen no sound, no image... no error. My videos are in the default location. I'm completely fine with turning them off, your app is great enough on it's on... I just don't like when computers get the best of me... so I will fight this...to the end...hopefully with help Here is the seemingly uneventful log: Were you the one that had this issue and then it just went away by itself? What OS are you using? My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
klizine Posted March 12, 2014 Posted March 12, 2014 Were you the one that had this issue and then it just went away by itself?What OS are you using? That was me. I am on Win 7 Pro 64bit.
pietie Posted March 12, 2014 Author Posted March 12, 2014 I think you're the only one that has reported this problem. I also use Win7 64-bit on two system and no issue. Do you perhaps have a bunch of weird codec packs installed? I'm really not sure what to make of this. If the problem persists I'll look at putting together some small test app and we can take it from there... My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
klizine Posted March 12, 2014 Posted March 12, 2014 I think you're the only one that has reported this problem. I also use Win7 64-bit on two system and no issue. Do you perhaps have a bunch of weird codec packs installed? I'm really not sure what to make of this. If the problem persists I'll look at putting together some small test app and we can take it from there... No codecs installed because they make things like this impossible to troubleshoot. What is it using to play the videos? What is it using to "play the videos"?
pietie Posted March 12, 2014 Author Posted March 12, 2014 It uses the Window Media Player components. It uses the "Window Media Player components". Haha, I'll have what you're having! My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
Dime333 Posted March 12, 2014 Posted March 12, 2014 I tried this out today. WOW! It's fantastic. An absolute must-have for hyperspin users. I have a couple more requests/suggestions. How about a setting for keeping the mouse pointer hidden if hyperlaunch has been configured that way. For cab users like myself, the mouse pointer is best kept hidden. Would it be possible to completely disable letter typing with keyboard on the OSK? I thought the latest update would do this but I can't use my "back/exit" key (M) to back out of the OSK. Using it to go back to OSK from search results works great, but when on OSK the M key types "M". I couldn't see any diference when using true or false on cabmode setting. Actually I couldn't exit the OSK in any other way than pressing ALT+f4. Esc did nothing. I hope you will consider making these Changes. Again , thanks a million for this great app. Disregard request no. 2. It's working great now.
klizine Posted March 12, 2014 Posted March 12, 2014 I tried this out today. WOW! It's fantastic. An absolute must-have for hyperspin users. I have a couple more requests/suggestions.How about a setting for keeping the mouse pointer hidden if hyperlaunch has been configured that way. For cab users like myself, the mouse pointer is best kept hidden. Would it be possible to completely disable letter typing with keyboard on the OSK? I thought the latest update would do this but I can't use my "back/exit" key (M) to back out of the OSK. Using it to go back to OSK from search results works great, but when on OSK the M key types "M". I couldn't see any diference when using true or false on cabmode setting. Actually I couldn't exit the OSK in any other way than pressing ALT+f4. Esc did nothing. I hope you will consider making these Changes. Again , thanks a million for this great app. you can disable keyboard typing is disabled if you set <add key="CabMode" value="true"/> *Edit. Just saw you said it didn't do anything... which doesn't sound right. I know I was stoopid and tried updating the config whilst it was running... and thought it wasn't working.
