ninja2bceen Posted July 24, 2014 Posted July 24, 2014 Extra note running as admin on windows 7 64 bit doesnt allow fav search either. Does fav search work for anyone? Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted July 25, 2014 Posted July 25, 2014 The only way for me to get fav to work is if I first run as admin. I had this auto start in hyperspin but I can't run as admin from the auto start from hyperhq and run as admin even though I have it set too run as admin at the file level. Why must I run as admin to search for fav and how can I get it to auto load as admin (I already have the file compatibility marked as run as admin) and it only physically does this if I click the file Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
NeoID Posted July 30, 2014 Posted July 30, 2014 Love it! Could you please make the keys used for navigation configurable as well? As I use a horizontal theme, my up/down/left/right are not in the direction they are supposed to be... On a side-note... would it be possible to release the source code? Would love to help on further development.
ninja2bceen Posted July 31, 2014 Posted July 31, 2014 Neo, do you have any idea why my fav search works rarely and only sometimes works when I run as admin? I. 64 bit, windows 7, fresh install, log gives no error when run outside of hyperspin, when I search fav in hyperspin, it just loads and loads and I doña alt tab to run the error log. Do you know what this means? 01:04:51 ERROR: System.NullReferenceException: Object reference not set to an instance of an object. at HyperSearch.Windows.GameSearchWindow.PerformSearch Task.<>c__DisplayClass61.<Run>b__3f(GameXmlDatabas e g) at System.Linq.Enumerable.WhereListIterator`1.MoveNex t() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.OrderedEnumerable`1.<GetEnumerator>d__ 0.MoveNext() at System.Linq.Enumerable.WhereSelectEnumerableIterat or`2.MoveNext() at System.Linq.Enumerable.<DistinctIterator>d__81`1.M oveNext() at System.Collections.Generic.List`1..ctor(IEnumerabl e`1 collection) at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at HyperSearch.Windows.GameSearchWindow.PerformSearch Task.Run(Object data) Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
pietie Posted July 31, 2014 Author Posted July 31, 2014 Neo, do you have any idea why my fav search works rarely and only sometimes works when I run as admin? I. 64 bit, windows 7, fresh install, log gives no error when run outside of hyperspin, when I search fav in hyperspin, it just loads and loads and I doña alt tab to run the error log. Do you know what this means?01:04:51 ERROR: System.NullReferenceException: Object reference not set to an instance of an object. NullRef exceptions usually means the programmer stuffed up. Download this zip and extract into your HyperSearch folder: https://dl.dropboxusercontent.com/u/59583314/HSDebug.7z Let it fail again and send me the log...it should include more info. You may also need to send me your full Game Xml + Favourites but let's just see if the log produces anything first. My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
ninja2bceen Posted July 31, 2014 Posted July 31, 2014 k downloaded and extracted in the hypersearch folder. I ran the app and clicked log and I get this (this looks the same to me)I'll post the log after hyperspin fires up in just a moment 03:27:58 Search trigger key from config: F3 03:27:58 Favourites trigger key from config: F4 03:27:58 Genre trigger key from config: F5 03:27:58 Hyperspin path: E:\X-PC\Hyperspin 03:27:58 Hook installed succesfully 03:27:58 Hyperspin settings loaded from: E:\X-PC\Hyperspin\Settings\Settings.ini 03:27:58 HL path: E:\X-PC\Hyperspin\HyperLaunch\ 03:27:58 CabMode: False 03:27:58 SearchDB: Parsing E:\X-PC\Hyperspin\Databases\Main Menu\Main Menu.xml... 03:27:58 SearchDB: Found 42 entries in [Main Menu.xml] 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\XBMC\XBMC.xml 03:27:58 Found 1 entries 03:27:58 Removed: 0 (wheel filter), 0 (theme filter) 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\MAME\MAME.xml 03:27:58 Found 1362 entries 03:27:58 Removed: 0 (wheel filter), 0 (theme filter) 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\PopCap\PopCap.xml 03:27:58 Found 65 entries 03:27:58 Removed: 0 (wheel filter), 0 (theme filter) 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Visual Pinball\Visual Pinball.xml 03:27:58 Found 157 entries 03:27:58 Removed: 0 (wheel filter), 0 (theme filter) 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Future Pinball\Future Pinball.xml 03:27:58 Found 78 entries 03:27:58 Removed: 0 (wheel filter), 0 (theme filter) 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\DICE\DICE.xml 03:27:58 Found 7 entries 03:27:58 Removed: 0 (wheel filter), 0 (theme filter) 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Microsoft MS-DOS\Microsoft MS-DOS.xml 03:27:58 Found 14 entries 03:27:58 Removed: 0 (wheel filter), 0 (theme filter) 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\ScummVM\ScummVM.xml 03:27:58 Found 11 entries 03:27:58 Removed: 0 (wheel filter), 0 (theme filter) 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\PC Games\PC Games.xml 03:27:58 Found 26 entries 03:27:58 Removed: 0 (wheel filter), 0 (theme filter) 03:27:58 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Mattel Intellivision\Mattel Intellivision.xml 03:27:58 Found 127 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari 2600\Atari 2600.xml 03:27:59 Found 362 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari 5200\Atari 5200.xml 03:27:59 Found 70 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari 7800\Atari 7800.xml 03:27:59 Found 58 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Colecovision\Colecovision.xml 03:27:59 Found 141 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari Jaguar\Atari Jaguar.xml 03:27:59 Found 26 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari Lynx\Atari Lynx.xml 03:27:59 Found 74 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Entertainment System\Nintendo Entertainment System.xml 03:27:59 Found 791 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Super Nintendo Entertainment System\Super Nintendo Entertainment System.xml 03:27:59 Found 789 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo 64\Nintendo 64.xml 03:27:59 Found 302 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy\Nintendo Game Boy.xml 03:27:59 Found 543 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy Color\Nintendo Game Boy Color.xml 03:27:59 Found 533 entries 03:27:59 Removed: 0 (wheel filter), 0 (theme filter) 03:27:59 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy Advance\Nintendo Game Boy Advance.xml 03:28:00 Found 987 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo DS\Nintendo DS.xml 03:28:00 Found 547 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Virtual Boy\Nintendo Virtual Boy.xml 03:28:00 Found 16 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Master System\Sega Master System.xml 03:28:00 Found 278 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Genesis\Sega Genesis.xml 03:28:00 Found 780 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega CD\Sega CD.xml 03:28:00 Found 42 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega 32X\Sega 32X.xml 03:28:00 Found 33 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Dreamcast\Sega Dreamcast.xml 03:28:00 Found 10 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Game Gear\Sega Game Gear.xml 03:28:00 Found 259 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Model 2\Sega Model 2.xml 03:28:00 Found 32 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\NEC TurboGrafx-16\NEC TurboGrafx-16.xml 03:28:00 Found 94 entries 03:28:00 Removed: 0 (wheel filter), 0 (theme filter) 03:28:00 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Mugen\Mugen.xml 03:28:01 Found 1 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:01 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Capcom Play System\Capcom Play System.xml 03:28:01 Found 63 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:01 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Capcom CPS3\Capcom CPS3.xml 03:28:01 Found 6 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:01 SearchDB: Processing E:\X-PC\Hyperspin\Databases\SNK Neo Geo MVS\SNK Neo Geo MVS.xml 03:28:01 Found 139 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:01 SearchDB: Processing E:\X-PC\Hyperspin\Databases\SNK Neo Geo Pocket Color\SNK Neo Geo Pocket Color.xml 03:28:01 Found 40 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:01 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Zinc\Zinc.xml 03:28:01 Found 28 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:01 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Bandai Wonderswan Color\Bandai Wonderswan Color.xml 03:28:01 Found 93 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:01 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Panasonic 3DO\Panasonic 3DO.xml 03:28:01 Found 27 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:01 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sony Playstation\Sony Playstation.xml 03:28:01 Found 48 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:01 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Daphne\Daphne.xml 03:28:01 Found 12 entries 03:28:01 Removed: 0 (wheel filter), 0 (theme filter) 03:28:13 Search: full game list loaded in 15195ms. Game count: 9072 03:28:13 Favourites: Found 41 file(s). 03:28:13 Processing E:\X-PC\Hyperspin\Databases\Atari 2600\favorites.txt... 03:28:13 Found 63 item(s) 03:28:13 Processing E:\X-PC\Hyperspin\Databases\Atari 5200\favorites.txt... 03:28:14 Found 21 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Atari 7800\favorites.txt... 03:28:14 Found 21 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Atari Jaguar\favorites.txt... 03:28:14 Found 13 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Atari Lynx\favorites.txt... 03:28:14 Found 14 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Bandai Wonderswan Color\favorites.txt... 03:28:14 Found 16 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Capcom CPS3\favorites.txt... 03:28:14 Found 3 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Capcom Play System\favorites.txt... 03:28:14 Found 29 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Colecovision\favorites.txt... 03:28:14 Found 40 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Daphne\favorites.txt... 03:28:14 Found 6 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Dice\favorites.txt... 03:28:14 Found 4 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Future Pinball\favorites.txt... 03:28:14 Found 23 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\MAME\favorites.txt... 03:28:14 Found 284 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Mattel Intellivision\favorites.txt... 03:28:14 Found 35 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Microsoft MS-DOS\favorites.txt... 03:28:14 Found 4 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Mugen\favorites.txt... 03:28:14 Found 1 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\NEC TurboGrafx-16\favorites.txt... 03:28:14 Found 21 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Nintendo 64\favorites.txt... 03:28:14 Found 84 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Nintendo DS\favorites.txt... 03:28:14 Found 100 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Nintendo Entertainment System\favorites.txt... 03:28:14 Found 168 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy\favorites.txt... 03:28:14 Found 129 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy Advance\favorites.txt... 03:28:14 Found 175 item(s) 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy Color\favorites.txt... 03:28:15 Found 89 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Nintendo Virtual Boy\favorites.txt... 03:28:15 Found 12 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Panasonic 3DO\favorites.txt... 03:28:15 Found 19 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\PC Games\favorites.txt... 03:28:15 Found 14 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\PopCap\favorites.txt... 03:28:15 Found 12 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\ScummVM\favorites.txt... 03:28:15 Found 6 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Sega 32X\favorites.txt... 03:28:15 Found 8 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Sega CD\favorites.txt... 03:28:15 Found 22 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Sega Dreamcast\favorites.txt... 03:28:15 Found 7 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Sega Game Gear\favorites.txt... 03:28:15 Found 72 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Sega Genesis\favorites.txt... 03:28:15 Found 180 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Sega Master System\favorites.txt... 03:28:15 Found 69 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Sega Model 2\favorites.txt... 03:28:15 Found 15 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\SNK Neo Geo MVS\favorites.txt... 03:28:15 Found 42 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\SNK Neo Geo Pocket Color\favorites.txt... 03:28:15 Found 8 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Sony PlayStation\favorites.txt... 03:28:15 Found 36 item(s) 03:28:15 Processing E:\X-PC\Hyperspin\Databases\Super Nintendo Entertainment System\favorites.txt... 03:28:16 Found 226 item(s) 03:28:16 Processing E:\X-PC\Hyperspin\Databases\Visual Pinball\favorites.txt... 03:28:16 Found 85 item(s) 03:28:16 Processing E:\X-PC\Hyperspin\Databases\Zinc\Favorites.txt... 03:28:16 Found 12 item(s) 03:28:16 Search: Favourites list loaded in 2886ms. Entry count: 2175 03:28:16 Search: Genere list loaded in 405ms. Genre count: 100 Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted July 31, 2014 Posted July 31, 2014 something that I notice in the original log is this...you see how the colecovision favorites has txt. <space> .. I notice all the other favorites don't have a space and with 3 ... all together. Just a guess but probably not right. Here is the log file when hyperspin attempts to search favorites. Note that searching genre is great, searching by game is great, but fav searching fails. The search is instant until the fav search. I wait 30 seconds and say this isn't working, I alt tab to the desktop while its still searching and check the log and boom here is what I see 03:28:14 Processing E:\X-PC\Hyperspin\Databases\Colecovision\favorites.txt. .. (this was taken from above) 03:34:04 Search trigger key from config: F3 03:34:04 Favourites trigger key from config: F4 03:34:04 Genre trigger key from config: F5 03:34:04 Hyperspin path: E:\X-PC\Hyperspin 03:34:05 Hook installed succesfully 03:34:05 Hyperspin settings loaded from: E:\X-PC\Hyperspin\Settings\Settings.ini 03:34:05 HL path: E:\X-PC\Hyperspin\HyperLaunch\ 03:34:05 CabMode: False 03:34:05 SearchDB: Parsing E:\X-PC\Hyperspin\Databases\Main Menu\Main Menu.xml... 03:34:05 SearchDB: Found 42 entries in [Main Menu.xml] 03:34:05 SearchDB: Processing E:\X-PC\Hyperspin\Databases\XBMC\XBMC.xml 03:34:05 Found 1 entries 03:34:05 Removed: 0 (wheel filter), 0 (theme filter) 03:34:05 SearchDB: Processing E:\X-PC\Hyperspin\Databases\MAME\MAME.xml 03:34:05 Found 1362 entries 03:34:05 Removed: 0 (wheel filter), 0 (theme filter) 03:34:05 SearchDB: Processing E:\X-PC\Hyperspin\Databases\PopCap\PopCap.xml 03:34:05 Found 65 entries 03:34:05 Removed: 0 (wheel filter), 0 (theme filter) 03:34:05 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Visual Pinball\Visual Pinball.xml 03:34:05 Found 157 entries 03:34:05 Removed: 0 (wheel filter), 0 (theme filter) 03:34:05 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Future Pinball\Future Pinball.xml 03:34:05 Found 78 entries 03:34:06 Removed: 0 (wheel filter), 0 (theme filter) 03:34:06 SearchDB: Processing E:\X-PC\Hyperspin\Databases\DICE\DICE.xml 03:34:06 Found 7 entries 03:34:06 Removed: 0 (wheel filter), 0 (theme filter) 03:34:06 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Microsoft MS-DOS\Microsoft MS-DOS.xml 03:34:07 Found 14 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\ScummVM\ScummVM.xml 03:34:07 Found 11 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\PC Games\PC Games.xml 03:34:07 Found 26 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Mattel Intellivision\Mattel Intellivision.xml 03:34:07 Found 127 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari 2600\Atari 2600.xml 03:34:07 Found 362 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari 5200\Atari 5200.xml 03:34:07 Found 70 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari 7800\Atari 7800.xml 03:34:07 Found 58 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Colecovision\Colecovision.xml 03:34:07 Found 141 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari Jaguar\Atari Jaguar.xml 03:34:07 Found 26 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Atari Lynx\Atari Lynx.xml 03:34:07 Found 74 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Entertainment System\Nintendo Entertainment System.xml 03:34:07 Found 791 entries 03:34:07 Removed: 0 (wheel filter), 0 (theme filter) 03:34:07 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Super Nintendo Entertainment System\Super Nintendo Entertainment System.xml 03:34:08 Found 789 entries 03:34:08 Removed: 0 (wheel filter), 0 (theme filter) 03:34:08 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo 64\Nintendo 64.xml 03:34:08 Found 302 entries 03:34:08 Removed: 0 (wheel filter), 0 (theme filter) 03:34:08 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy\Nintendo Game Boy.xml 03:34:08 Found 543 entries 03:34:08 Removed: 0 (wheel filter), 0 (theme filter) 03:34:08 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy Color\Nintendo Game Boy Color.xml 03:34:08 Found 533 entries 03:34:08 Removed: 0 (wheel filter), 0 (theme filter) 03:34:08 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy Advance\Nintendo Game Boy Advance.xml 03:34:08 Found 987 entries 03:34:08 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo DS\Nintendo DS.xml 03:34:09 Found 547 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Nintendo Virtual Boy\Nintendo Virtual Boy.xml 03:34:09 Found 16 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Master System\Sega Master System.xml 03:34:09 Found 278 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Genesis\Sega Genesis.xml 03:34:09 Found 780 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega CD\Sega CD.xml 03:34:09 Found 42 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega 32X\Sega 32X.xml 03:34:09 Found 33 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Dreamcast\Sega Dreamcast.xml 03:34:09 Found 10 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Game Gear\Sega Game Gear.xml 03:34:09 Found 259 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sega Model 2\Sega Model 2.xml 03:34:09 Found 32 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\NEC TurboGrafx-16\NEC TurboGrafx-16.xml 03:34:09 Found 94 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Mugen\Mugen.xml 03:34:09 Found 1 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Capcom Play System\Capcom Play System.xml 03:34:09 Search: full game list loaded in 3993ms. Game count: 9072 03:34:09 Found 63 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Capcom CPS3\Capcom CPS3.xml 03:34:09 Found 6 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\SNK Neo Geo MVS\SNK Neo Geo MVS.xml 03:34:09 Found 139 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\SNK Neo Geo Pocket Color\SNK Neo Geo Pocket Color.xml 03:34:09 Found 40 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Zinc\Zinc.xml 03:34:09 Found 28 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Bandai Wonderswan Color\Bandai Wonderswan Color.xml 03:34:09 Found 93 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Panasonic 3DO\Panasonic 3DO.xml 03:34:09 Found 27 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Sony Playstation\Sony Playstation.xml 03:34:09 Found 48 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 SearchDB: Processing E:\X-PC\Hyperspin\Databases\Daphne\Daphne.xml 03:34:09 Found 12 entries 03:34:09 Removed: 0 (wheel filter), 0 (theme filter) 03:34:09 Favourites: Found 41 file(s). 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Atari 2600\favorites.txt... 03:34:09 Found 63 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Atari 5200\favorites.txt... 03:34:09 Found 21 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Atari 7800\favorites.txt... 03:34:09 Found 21 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Atari Jaguar\favorites.txt... 03:34:09 Found 13 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Atari Lynx\favorites.txt... 03:34:09 Found 14 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Bandai Wonderswan Color\favorites.txt... 03:34:09 Found 16 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Capcom CPS3\favorites.txt... 03:34:09 Found 3 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Capcom Play System\favorites.txt... 03:34:09 Found 29 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Colecovision\favorites.txt... 03:34:09 Found 40 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Daphne\favorites.txt... 03:34:09 Found 6 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Dice\favorites.txt... 03:34:09 Found 4 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Future Pinball\favorites.txt... 03:34:09 Found 23 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\MAME\favorites.txt... 03:34:09 Found 284 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Mattel Intellivision\favorites.txt... 03:34:09 Found 35 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Microsoft MS-DOS\favorites.txt... 03:34:09 Found 4 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Mugen\favorites.txt... 03:34:09 Found 1 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\NEC TurboGrafx-16\favorites.txt... 03:34:09 Found 21 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Nintendo 64\favorites.txt... 03:34:09 Found 84 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Nintendo DS\favorites.txt... 03:34:09 Found 100 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Nintendo Entertainment System\favorites.txt... 03:34:09 Found 168 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy\favorites.txt... 03:34:09 Found 129 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy Advance\favorites.txt... 03:34:09 Found 175 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Nintendo Game Boy Color\favorites.txt... 03:34:09 Found 89 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Nintendo Virtual Boy\favorites.txt... 03:34:09 Found 12 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Panasonic 3DO\favorites.txt... 03:34:09 Found 19 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\PC Games\favorites.txt... 03:34:09 Found 14 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\PopCap\favorites.txt... 03:34:09 Found 12 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\ScummVM\favorites.txt... 03:34:09 Found 6 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Sega 32X\favorites.txt... 03:34:09 Found 8 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Sega CD\favorites.txt... 03:34:09 Found 22 item(s) 03:34:09 Processing E:\X-PC\Hyperspin\Databases\Sega Dreamcast\favorites.txt... 03:34:10 Found 7 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\Sega Game Gear\favorites.txt... 03:34:10 Found 72 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\Sega Genesis\favorites.txt... 03:34:10 Found 180 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\Sega Master System\favorites.txt... 03:34:10 Found 69 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\Sega Model 2\favorites.txt... 03:34:10 Found 15 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\SNK Neo Geo MVS\favorites.txt... 03:34:10 Found 42 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\SNK Neo Geo Pocket Color\favorites.txt... 03:34:10 Found 8 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\Sony PlayStation\favorites.txt... 03:34:10 Found 36 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\Super Nintendo Entertainment System\favorites.txt... 03:34:10 Found 226 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\Visual Pinball\favorites.txt... 03:34:10 Found 85 item(s) 03:34:10 Processing E:\X-PC\Hyperspin\Databases\Zinc\Favorites.txt... 03:34:10 Found 12 item(s) 03:34:10 Search: Favourites list loaded in 1482ms. Entry count: 2175 03:34:10 Search: Genere list loaded in 94ms. Genre count: 100 03:34:17 Using list: Favourites 03:34:33 SearchMode: Contains 03:34:34 ERROR: System.NullReferenceException: Object reference not set to an instance of an object. at HyperSearch.Windows.GameSearchWindow.PerformSearchTask.<>c__DisplayClass61.<Run>b__3f(GameXmlDatabase g) in c:\00-Work\Projects\HyperSpinClone\HyperSearch\Windows\GameSearchWindow.xaml.cs:line 1289 at System.Linq.Enumerable.WhereListIterator`1.MoveNext() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.OrderedEnumerable`1.<GetEnumerator>d__0.MoveNext() at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext() at System.Linq.Enumerable.<DistinctIterator>d__81`1.MoveNext() at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection) at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at HyperSearch.Windows.GameSearchWindow.PerformSearchTask.Run(Object data) in c:\00-Work\Projects\HyperSpinClone\HyperSearch\Windows\GameSearchWindow.xaml.cs:line 1307 Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
pietie Posted July 31, 2014 Author Posted July 31, 2014 Thanks for the log. It now includes line numbers which help a lot. When you do post such long logs please use a service such as http://pastebin.com/ I'm not sure what's going on with your Colecovision. Why is there a space for the XML file as well? Perhaps try removing it's favourites file and test without it. I think I may have found a potential problem. Please download and try again: https://dl.dropboxusercontent.com/u/59583314/HSDebug.7z If it does work please post your log anyway there is something I'd like to see... My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
NeoID Posted July 31, 2014 Posted July 31, 2014 @pietie: In order to get my controls to work I tried to copy the settings.ini (I thought it read the controls from it) and made a mklink to my database folder, but that did not seem to work. If I use my keyboard I'm able to choose what letter to enter, but not with my joystick (still configured at a keyboard in HS). Is there any way to fix that? As mentioned before, I would really like to a copy of the source code to continue to improve and further customize the look and feel. Would that be possible? All credits will of cause go to you! We need more open source projects here at Hyperspin in order to get development going!
pietie Posted July 31, 2014 Author Posted July 31, 2014 @pietie:In order to get my controls to work I tried to copy the settings.ini (I thought it read the controls from it) and made a mklink to my database folder, but that did not seem to work. If I use my keyboard I'm able to choose what letter to enter, but not with my joystick (still configured at a keyboard in HS). Is there any way to fix that? Hmmm it does read from your HyperSpin Settings.ini. Only keyboards are supported. Do you use one of those Joystick 2 Keyboard mapper things? @pietie:As mentioned before, I would really like to a copy of the source code to continue to improve and further customize the look and feel. Would that be possible? All credits will of cause go to you! We need more open source projects here at Hyperspin in order to get development going! I have considered releasing the code before. The code actually forms part of a bigger project I've been working on so I wanted to rather release it as part of that. But I haven't touched most of my side projects in months so open source would help I'm sure. Lemme think about what I want to do... My tools Steam wheel creator - Generate xml list from Steam profile with artwork and videos HyperSearch - Integrates search functionality with HyperSpin
NeoID Posted July 31, 2014 Posted July 31, 2014 Hmmm it does read from your HyperSpin Settings.ini. Only keyboards are supported. Do you use one of those Joystick 2 Keyboard mapper things? Hmm.. vJoy or what it's called might actually be running in the background, I'll check that later today... But that shouldn't do anything (if it does it's kind of a bug imo as it would be in use by HyperLaunch)... Edit: With or without vJoy... doesn't work using my X-Arcade. I have considered releasing the code before. The code actually forms part of a bigger project I've been working on so I wanted to rather release it as part of that. But I haven't touched most of my side projects in months so open source would help I'm sure. Lemme think about what I want to do... The problem with "bigger project" is, as you say yourself, finishing them. Also, user might not even need the other functionality and the risk of the application never to become stable is also greater. In my opinion it would be great if you intend to release the code as open source. That way user (me included) would help out and add new features that you can implement in your version/bigger project later. I think the high number of third party closed source projects for HyperSpin is bad. Most of the tools are really awesome, but the fact that you cannot alter or fix any bugs yourself is kind of frustrating. HyperSpin is probably the best example in that matter as I'm currently trying to make a keyboard hack/driver that would resolve the problem of the wheel spinning the wrong way when hold down on horizontal themes. If HyperSpin would have been open source it would have been fixed in a day, but now we are stuck with an awesome project that is not actively maintained anymore and every bugfix has to be implemented as a hack.
ninja2bceen Posted August 1, 2014 Posted August 1, 2014 very interesting... a couple of warnings in the log now... note that I created favorites within hyperspin, I didn't do any renaming. The favorite title does differ from the xml but I can run the fav from hyperspin just fine normally, I just tested the error ones in the log. Anyhow, I fired hyperspin up, tried searching by genre, fav, and all games and they ALL work! You rock dude! If I could say myself, this app is amazing. Now if only you could add two things to this app it would be perfect in my eyes. #1 support png preview too (you support the video preview but I have complete sets where if there aren't video, there is at least a .png pic in its place) #2 support a different close feature. (right now if you search any of the genre, fav or all games, to close you have to hit back (my o) a couple times very fast OR press alt f4. I'd like to close the search using 0 in general since the o on the keyboard and emulated ps3 controller is my back button. Everything ran great my friend. Here is my log http://pastebin.com/Kj50R2Ch Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
gooch Posted August 3, 2014 Posted August 3, 2014 Thanks for the log. It now includes line numbers which help a lot. When you do post such long logs please use a service such as http://pastebin.com/I'm not sure what's going on with your Colecovision. Why is there a space for the XML file as well? Perhaps try removing it's favourites file and test without it. I think I may have found a potential problem. Please download and try again: https://dl.dropboxusercontent.com/u/59583314/HSDebug.7z If it does work please post your log anyway there is something I'd like to see... This version makes favorites work for me, thanks! Two requests: - Video previews are very choppy, but they're not choppy within HyperSpin itself. Is there a setting within Windows I might have set wrong that would help with performance? - Any chance there could be better integration with LEDBlinky? It would be cool if when it scrolled to a game it changed my button LEDs to match like it does within HyperSpin. I also use Antos's EDS and HyperMarquee which trigger off LEDBlinky in order to display marquees. I also got my touchscreen to work with the onscreen keyboard with a simple AHK: ~LButton:: IfWinActive, GameSearchWindow { Sleep, 400 Send, {Enter} } Return
underthesky00 Posted August 9, 2014 Posted August 9, 2014 Hopefully I'm not being a complete noob here (I probably am though) but I have two questions. 1. How can I make the program stay up at all times? I know how to make it run on Startup but it seems that once it's running it closes itself after I close out of Hyperspin. So if I go back into Hyperspin I have to click the icon to get it running again. 2. I'm having an issue with it not picking up all systems. It picks most of them up but a few throw back this error: 15:05:08 SearchDB: Processing C:\Hyperspin\Databases\Nintendo Game Boy Advance\Nintendo Game Boy Advance.xml 15:05:08 ERROR: System.InvalidOperationException: There is an error in XML document (387, 22). ---> System.Xml.XmlException: An error occurred while parsing EntityName. Line 387, position 22. at System.Xml.XmlTextReaderImpl.Throw(String res, Int32 lineNo, Int32 linePos) at System.Xml.XmlTextReaderImpl.HandleEntityReference(Boolean isInAttributeValue, EntityExpandType expandType, Int32& charRefEndPos) at System.Xml.XmlTextReaderImpl.ParseAttributeValueSlow(Int32 curPos, Char quoteChar, NodeData attr) at System.Xml.XmlTextReaderImpl.ParseAttributes() at System.Xml.XmlTextReaderImpl.ParseElement() at System.Xml.XmlTextReaderImpl.ParseElementContent() at System.Xml.XmlReader.ReadEndElement() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMenuXmlDatabase.Read2_GameXmlDatabase(Boolean isNullable, Boolean checkType) at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMenuXmlDatabase.Read4_MenuXmlDatabase(Boolean isNullable, Boolean checkType) at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMenuXmlDatabase.Read5_menu() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle) at HyperSpinClone.Classes.MenuXmlDatabase.LoadFromFile(String filePath) at HyperSearch.Windows.GameSearchWindow.PerformSearchTask.LoadFullGameList() I decided to go to the XML and see what is causing the error and oddly enough it an "&" sign in a game name. I had this happen with PlayStation and PSP too. I pulled the PlayStation XML and the error occurred at another "&" sign in a game name. Any fix for this or am I doing something wrong? AWESOME system by the way. This is a HUGE help when you have a large database of games. Thanks for the time and effort you put into this!
underthesky00 Posted August 10, 2014 Posted August 10, 2014 1. How can I make the program stay up at all times? I know how to make it run on Startup but it seems that once it's running it closes itself after I close out of Hyperspin. So if I go back into Hyperspin I have to click the icon to get it running again. I think I figured this part out. Looks like I didn't minimize the log after viewing it but instead I closed it hence the program wasn't running. I've been careful to make sure to minimize it instead since and no issues with it closing. Now I just need some help with issue number 2.
ninja2bceen Posted August 10, 2014 Posted August 10, 2014 Did u download this version? Are u on framework 4.5 .net? If yes to both, sounds like the owner will have to make another tweak to accept &'s. Give it a whirl, adds more logging too https://dl.dropboxusercontent.com/u/59583314/HSDebug.7z Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
underthesky00 Posted August 10, 2014 Posted August 10, 2014 Did u download this version? Are u on framework 4.5 .net? If yes to both, sounds like the owner will have to make another tweak to accept &'s. Give it a whirl, adds more logging toohttps://dl.dropboxusercontent.com/u/59583314/HSDebug.7z I downloaded the version that was in the first post. I just tried yours and it does seem to bring back a different log. There are so many errors though that it only posts 250 lines or so. This time I only see a bunch of fav list errors...I don't know what's above that since the list can apparently only be so long. Here's what one of the lines looks like: 14:50:53 WARNING: FAV failed to match up: Final Fantasy IX (USA) (Disc 1). System: Sony PlayStation It's just line after that of that. It only fired back Playstation and PSP faves. Those two systems just so happened to be two of the three that weren't working beforehand. Not sure if that has anything to do with it. Right after the last PSP error it shows SNES FAV list loading right: 14:50:53 Processing C:\Hyperspin\Databases\Super Nintendo Entertainment System\favorites.txt... So I'm guessing that it's not loading the PS and PSP fave list b/c it can't find the PS and PSP games at all due to the XML error. As for as Framework...I didn't know anything about how to figure out what version I'm on so I followed the instructions here: http://msdn.microsoft.com/en-us/library/hh925568(v=vs.110).aspx According to that I'm on .NET Framework 4.5.1 installed on Windows 8, Windows 7 SP1, or Windows Vista SP2 Any other ideas? I did notice that the search keyboard only has A-Z, 0-9, hyphen, space, comma, backspace, and clear. There's no & sign on the keyboard which I'm wondering if that means the app doesn't support & signs. Seems like someone else would have reported this before now though? Hopefully the Dev will see this and chime in.
ninja2bceen Posted August 11, 2014 Posted August 11, 2014 Pietie owns the code and will likely have to fix it. Fav weren't running at all for me until the link I gave u. It didn't like favs either for me. I think ' threw it off. Thing is hyperspin creates the favs. I don't have commas in my xml I believe. Whatevs. I have ps favs and working fine. I do know I don't have & though. I bet dev will have to fix but that new link I bet will get u gimping at least more than the first post right Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
potts43 Posted August 11, 2014 Posted August 11, 2014 Anyone have an exit routine that closes HS when hyperspin shuts down? I've had no success with this.
Min2001 Posted August 11, 2014 Posted August 11, 2014 potts try adding this to a txt file. save it as exit.bat and add it to HyperHQ's exit bar. @ECHO off taskkill /f /fi "IMAGENAME eq HyperSearch.exe" I have found that killing the task is a bit buggy though as I always have to hover over the icon on my startbar to get the icon off after closing HyperSpin but that could be due to UAC settings as im using it with Windows 7. Maybe there's a better way of closing this somewhere that someone else can help on?
Min2001 Posted August 11, 2014 Posted August 11, 2014 Mn... well I have a Win 7 64 bit too and closes fine on mine (with the exception of the taskbar bug). You tried adding a start.bat file for it too? try adding both start and exit commands to both batch files. Also check the HyperSearch.exe.config file too to see if you missed anything that may prevent closing. Try setting this part to false. <!-- Set to true if you wish to run HyperSearch without HyperSpin --> <add key="StandaloneMode" value="false"/> Both my start and exit batch files look like this: start.bat @ECHO off cd\ start E:\HyperSpin\Utilities\Xpadder\Xpadder.exe start E:\HyperSpin\HyperSearch.exe exit.bat @ECHO off taskkill /f /fi "IMAGENAME eq Xpadder.exe" taskkill /f /fi "IMAGENAME eq HyperSearch.exe"
penduzecat Posted August 12, 2014 Posted August 12, 2014 Hi, Thank you for you great program ! Could you add some features like : Enable/Disable favorites Enable/Disable genre Enable/Disable the message that say that the program is already launched (not really important) If possible generate a "static database" instead of parsing every xml at start for people who never change games
potts43 Posted August 12, 2014 Posted August 12, 2014 Mn... well I have a Win 7 64 bit too and closes fine on mine (with the exception of the taskbar bug). You tried adding a start.bat file for it too? try adding both start and exit commands to both batch files. Also check the HyperSearch.exe.config file too to see if you missed anything that may prevent closing.Try setting this part to false. <!-- Set to true if you wish to run HyperSearch without HyperSpin --> <add key="StandaloneMode" value="false"/> Both my start and exit batch files look like this: start.bat @ECHO off cd\ start E:\HyperSpin\Utilities\Xpadder\Xpadder.exe start E:\HyperSpin\HyperSearch.exe exit.bat @ECHO off taskkill /f /fi "IMAGENAME eq Xpadder.exe" taskkill /f /fi "IMAGENAME eq HyperSearch.exe" Will take a look thanks for your help!
underthesky00 Posted August 15, 2014 Posted August 15, 2014 I'm having an issue with it not picking up all systems. It picks most of them up but a few throw back this error: 15:05:08 SearchDB: Processing C:\Hyperspin\Databases\Nintendo Game Boy Advance\Nintendo Game Boy Advance.xml 15:05:08 ERROR: System.InvalidOperationException: There is an error in XML document (387, 22). ---> System.Xml.XmlException: An error occurred while parsing EntityName. Line 387, position 22. at System.Xml.XmlTextReaderImpl.Throw(String res, Int32 lineNo, Int32 linePos) at System.Xml.XmlTextReaderImpl.HandleEntityReference(Boolean isInAttributeValue, EntityExpandType expandType, Int32& charRefEndPos) at System.Xml.XmlTextReaderImpl.ParseAttributeValueSlow(Int32 curPos, Char quoteChar, NodeData attr) at System.Xml.XmlTextReaderImpl.ParseAttributes() at System.Xml.XmlTextReaderImpl.ParseElement() at System.Xml.XmlTextReaderImpl.ParseElementContent() at System.Xml.XmlReader.ReadEndElement() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMenuXmlDatabase.Read2_GameXmlDatabase(Boolean isNullable, Boolean checkType) at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMenuXmlDatabase.Read4_MenuXmlDatabase(Boolean isNullable, Boolean checkType) at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMenuXmlDatabase.Read5_menu() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle) at HyperSpinClone.Classes.MenuXmlDatabase.LoadFromFile(String filePath) at HyperSearch.Windows.GameSearchWindow.PerformSearchTask.LoadFullGameList() I decided to go to the XML and see what is causing the error and oddly enough it an "&" sign in a game name. I had this happen with PlayStation and PSP too. I pulled the PlayStation XML and the error occurred at another "&" sign in a game name. Any fix for this or am I doing something wrong? Anyone have any ideas here? I haven't heard from pietie yet. Hoping there's an easy fix somewhere. I guess worse case I could always try and change all my ROM names and XML files from using the & sign since it seems unsupported.
