blur Posted January 28, 2012 Posted January 28, 2012 maybe bogie can upload it again i have one but without vuk fixed (don't know even what is it ) My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
boogies2 Posted January 28, 2012 Posted January 28, 2012 I am working on a new cabinet, so I cannot test that it's working, but I can get access to the drive - no problem. Any suggestions as to where?
chinzman93 Posted January 28, 2012 Posted January 28, 2012 I am working on a new cabinet, so I cannot test that it's working, but I can get access to the drive - no problem.Any suggestions as to where? Mediafire or Rapidshare maybe?
blur Posted January 28, 2012 Posted January 28, 2012 i'm on media fire for now if it goes down we still have vp forum and hs forum for uploads My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
boogies2 Posted January 29, 2012 Posted January 29, 2012 Untested, from backup files - so please let me know if this is out-of-date (if launch doesn't go behind the wall) http://www.mediafire.com/?rtjpc4h7w5k4pil
chinzman93 Posted January 29, 2012 Posted January 29, 2012 Looks good with the launch. Many thanks for uploading this!
blur Posted January 29, 2012 Posted January 29, 2012 Untested, from backup files - so please let me know if this is out-of-date (if launch doesn't go behind the wall)http://www.mediafire.com/?rtjpc4h7w5k4pil Ball goes behind the wall so it's ok. But layback is not set on this table, don't know about that VUK fixing? My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
luvthatapex Posted February 17, 2012 Posted February 17, 2012 I can't get this to work. The ball gets stuck at the top rollovers. Looks like the plastic is in the way? If I force another ball out (press , it does the same thing. Does it work for you?
boogies2 Posted March 21, 2012 Posted March 21, 2012 I got my cabinet up and running. I designed it with keyboard external - only for installation of tables. When running my T3, it just got stuck, when I edit it worked. Long story short, after about 20 tries - I am sure that for me, if I have the Keyboard plugged in T3 will launch the ball out the VUK. Without the USB keyboard plugged in, it will be stuck. This is frustating, but if someone else can verify, it would help resolve. I ended up buying a slim USB keyboard and throwing it inside, just tyo play this game. Thanks
boogies2 Posted April 25, 2012 Posted April 25, 2012 The mediafire file that I uploaded is now "Invalid or Deleted File".... Is there a moderator from the VPForums that can upload the file to VPforums so the file doesn't get deleted due to inactivity?
Wahreez Posted May 7, 2012 Posted May 7, 2012 I'd also appreciate it if you could upload this file to VPForums or whatever. I never got a chance to grab this way back in the day. For getting it on VPForums I'd suggest you PM Destruk as I know he is a mod and he is very active over there. Thx for your work on this and look forward to snagging a copy when you find a permanent home for it!
boogies2 Posted May 9, 2012 Posted May 9, 2012 Here we are again: http://www.2shared.com/file/JJTfjIeI/Terminator_3.html If the VUK doesn't work for you, plug in a keyboard before starting the game, and that should fix
Wahreez Posted May 9, 2012 Posted May 9, 2012 Thanks a ton man! I'll see if I can get it uploaded to VPForums.org if that is OK with you? I'll of course make sure the proper people are listed with credits pending your approval.
boogies2 Posted May 9, 2012 Posted May 9, 2012 It's Groni's table, and he gave me prior permission to upload it..... If you want to upload it, he probably wouldn't mind, but you would have to contact him. I only did a small mod, not worth mentioning. Thanks - It would be geat if it could get uploaded to VPforums, I think that's where it should be.
pezima77 Posted May 10, 2012 Posted May 10, 2012 Thank you boogies for the link and for the very nice mod !!
Numiah Posted May 10, 2012 Posted May 10, 2012 Thanks for all your hard work **Each pinball machine is a tiny universe... that we control** My Build Overview My Computer Specifications
luvthatapex Posted May 12, 2012 Posted May 12, 2012 Not sure if others are having problems with the ball lock, but I had to move the following components to the left about an inch in the editor to get the locks to work. sw52 - position x=551 Launch1a - position x=628 Launch1 - position x=693 Now I have no problem with the ball lock and I can get through all of the modes. Hope this helps someone else too.
boogies2 Posted May 12, 2012 Posted May 12, 2012 Not sure if others are having problems with the ball lock, but I had to move the following components to the left about an inch in the editor to get the locks to work.sw52 - position x=551 Launch1a - position x=628 Launch1 - position x=693 Now I have no problem with the ball lock and I can get through all of the modes. Hope this helps someone else too. Thanks luvthatapex. I will give that a shot in my cab too. I had some issues when I redeisgned my current cab without a keyboard. The VUK didn't work unless I had a keyboard plugged in, then I got a different version, and worked from there.... Excuses, excuses, lol. I know that there were a few times I made it up the orbits, and it registered, but too late, and didn't get the "award", but it did launch the vuk.
boogies2 Posted May 26, 2012 Posted May 26, 2012 Quick update - I changed the Min Slope & Max Slope from 10.5 to 8, and the RPG is still working great. The table seems to be working slower and smoother. Would love to have someone try and verify - THANKS!!!
SORHP Posted May 31, 2012 Posted May 31, 2012 Sounds Great! Any chance to add a link to the updated working table? My Arcade Machines...
Ralf Posted November 26, 2012 Posted November 26, 2012 Thanks to all the people creating all the tables and and and.... I could have never built my cab without you. So now there is the first problem with Terminator 3. When I start the table in VP with an USB keyboard plugged in it works fine, but if I start via Hyperpin the ball gets lost in the upper right corner, even if I let the keyboard plugged in. I moved the kickerholes like luvthatapex suggested but it wont work with the Mot Ion kit in my cab.Are there any sulotions, or do I better wait until there is a FS version on VP forums ? Thanks again to all of you!!!!!
PeeKay Posted November 29, 2012 Posted November 29, 2012 When I start the table in VP with an USB keyboard plugged in it works fine, but if I start via Hyperpin the ball gets lost in the upper right corner, even if I let the keyboard plugged in. Hi Ralf, is it possible that you have another Terminator 3 vpt file in your VP table folder, and your Hyperpin game list is directing it to start that other version without the fixes?
Ralf Posted December 5, 2012 Posted December 5, 2012 Thank s that was a good tip.I redownloaded from the link on page 9 and it worked.Must have made a mistake while renaming the wrong table. Ordered a mini USB keyboard now to put it in the cab.
