thatman84 Posted February 8, 2017 Posted February 8, 2017 57 minutes ago, cataclysm67 said: Also my MAME romset is 0.182 and works fine I will have to make do with bezels on the MAME4DROID set Are you using the same rom and artwork sets for BOTH mame4droid and retroarch? mame4droid is based on MAME .139 and the are hundreds/thousands of name changes between that and .182 as I tried to match a wheel set and hardly any match. romname should match artwork name and also be of the same version of the emulator. .182 or .139 Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
sanchezmike01 Posted February 8, 2017 Posted February 8, 2017 Open ur bezel zip and make sure it's correct ...it should be a png image with a lay file
Creezz67 Posted February 9, 2017 Posted February 9, 2017 yes i have checked, they are correct bezels example 1941 1941_inst_2.png 1941_inst_3.png default.lay 1941_inst_1.png
Creezz67 Posted February 9, 2017 Posted February 9, 2017 @thatman84 - yes I am using 0.182 romset + chd's for MAME RetroArch and MAME 0.139u romset for MAME4DROID As I say, everything works fine for each system just no bezels showing for RetroArch despite doing everything you have all stated
Creezz67 Posted February 9, 2017 Posted February 9, 2017 This is my setup: MAME 0.182 ROMSET + CHDS located on 3tb external hard drive : H:/Hyperspin/Emulators/MAME/roms Artwork now located on external hard drive : Android\data\com.retroarch\files\system\mame\Artwork (I have used the mame folder Badheim posted) Also tried putting it on internal drive : Internal shared storage\RetroArch\System\mame\Artwork Also tried putting artwork in : H:/Hyperspin/Emulators/MAME/artwork Settings for MAME are pointing to : H:/Hyperspin/Emulators/MAME/roms I have gone into RetroArch and to quick menu, then turned on read and write options and then saved. Both systems for MAME on RetroArch and MAME4DROID work perfectly on NVIDIA SHIELD TV 2017 version on Hyperspin Bezels work perfectly on MAME4DROID for MAME Bezels are correct as they work on MAME4DROID and PC version of MAME Only thing NOT working are the bezels on RetroArch for MAME 0.182 using MAME core. The games play fine, just no bezel when game starts Thanks
thatman84 Posted February 9, 2017 Posted February 9, 2017 Can you drop me that 1941 art zip so I can test the same thing. I'll try test pc RA tonight then Shield RA after Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted February 9, 2017 Posted February 9, 2017 10 hours ago, cataclysm67 said: @thatman84 - yes I am using 0.182 romset + chd's for MAME RetroArch and MAME 0.139u romset for MAME4DROID As I say, everything works fine for each system just no bezels showing for RetroArch despite doing everything you have all stated What artwork sets are you using ? Same for both or version specific. It only matters for games that have changed 10 hours ago, cataclysm67 said: yes i have checked, they are correct bezels example 1941 1941_inst_2.png 1941_inst_3.png default.lay 1941_inst_1.png This is a BAD example as there is no bezel for this game in your above files. They are instructional cards I tested 1943.zip rom with 1943.zip artwork on PC and Shield & with system folder on my network hard drive. I didnt have time to pull my shield out and connect a hard drive but I dont see any reason for it not to work. I also did not test this from launching via Hyperspin because I have mine pointed to mame4droid. Can you test the below please place empty folders Anywhere on your external harddrive system/mame/artwork place the 1943.zip artwork from Mr Do's site (http://mrdo.mameworld.info/mame_artwork_ingame.php) in the system/mame/artwork folder Load RA. Go to settings->directory change your system/bios directory to the above system/ folder on you hard drive. run the 1943 rom from within RA. The bezel should load. I had read and write config enable in retroarch core options but that should not make any difference. If it dont load open up the MAME UI in retroarch and check in Video settings that all the artworks are enabled Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Creezz67 Posted February 10, 2017 Posted February 10, 2017 @THATMAN84 Finally got it working, thanks for all your help. I uninstalled RetroArch completely from NVS and re-installed with todays latest nightly version of RetroArch, pointed to system directory and now all bezels are showing Is there a way to point MAME4DROID to this same folder of artwork or does that need to stay on the internal drive on NVS ? Only reason is because I only have 16gb version and have no space left, artwork is over 7gb Thanks again
thatman84 Posted February 10, 2017 Posted February 10, 2017 I'm not sure about mame4droid sorry Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted February 10, 2017 Posted February 10, 2017 2 hours ago, cataclysm67 said: @THATMAN84 Finally got it working, thanks for all your help. I uninstalled RetroArch completely from NVS and re-installed with todays latest nightly version of RetroArch, pointed to system directory and now all bezels are showing Is there a way to point MAME4DROID to this same folder of artwork or does that need to stay on the internal drive on NVS ? Only reason is because I only have 16gb version and have no space left, artwork is over 7gb Thanks again Mame 4 droid needs artwork in it system folder . Damn 7 gigs of artwork. Mines only 2.5
badhemi Posted February 10, 2017 Posted February 10, 2017 Just now, badhemi said: Mame 4 droid needs artwork in it system folder . Damn 7 gigs of artwork. Mines only 2.5 Put in sdcard
sonkun Posted February 10, 2017 Posted February 10, 2017 Speaking of Mame help, for some reason I can't move in any direction with the d-pad on any games, instead I can only move using the left analog stick only, all other buttons work though. Retroarch Mame doesn't have it's own in-core controller options so I tried to go to the regular main input options to config but that didn't do anything. I'm on rooted Shield TV 3.3 using an official ps3 sixaxis pad if that counts for anything. Using Mame 0.182 on Retroarch 1.4.1 as well. Edit: Configuring a d-pad direction to a action button seems to work for some strange reason but still won't work when I go back and try any of the actual 4 direction buttons. Every other Mame core plus all other cores I try the direction pad works, 0.182 is the only one that doesn't. Edit again: Just read on the Retroarch forums that this is some kind of known issue
