MAME Artwork Bezel Project
About the parents and clones, sometime in the future I will add the option to search on parents folders for all games that do not have a bezel or instruction card on their own folders.
So it would be a good practice to keep the bezels on the parent folders whenever possible.
When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS!
Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher).
Ass. Bleasby - RocketLauncher Development Team.
  • Replies 137
That, for sure, sounds like the best option. But I do have a question. How will you differentiate between the parent and clone bezel if they are both in the same directory?? Same with the IC's?
Thanks,
Ron
No, they will no be on the same folder.
For example, if you run the game 25pacmano. Right now I search for the bezels and instruction cards on the folders:
hyperlaunch\media\bezels\mame\25pacmano
hyperlaunch\media\bezels\mame\_default
hyperlaunch\media\bezels\_default
When I add the parent support, I will search on this order instead if you enable to use parent contents for clones
I think I understand. It's not going to search the parent folder for a clone bezel. It will search for a clone directory and try to find a bezel. How about if you launch a clone and there is no bezel? Can it search for a parent folder and bezel?
So, we carry on with this. I'll figure out which bezels are for the clones and which are for the parents and separate them out.
Thanks,
Ron
The only rule that you must follow is to have the bezels on the parent folder. Nothing more.
So all clones will use the parent bezels if no specific clone bezel was found.
If you want a clone with a different bezel than the parent game, you just need to use its specific game folder anyway.
Got it. Very cool and great job!!!
Thanks,
Ron
Here's a Neo bezel, as well as a few for 4:3. I'm sure Ron will work out the best way to distribute them, if they any good of course.
  • 1 month later...
Hello all,
So, I am looking for a little guidance from someone out there that is fluent with PhotoShop. The images described in this post: http://www.hyperspin-fe.com/forum/showthread.php?32580-New-Bezel-Art-Location-And-Approval&p=334373&viewfull=1#post334373 are very big. 60+ meg! I knew they were going to be when I created them. But I am not very good with PS at this point. The images are 4000x4000px at 8bit color. I really do not want to shrink the resolution much, this is what the original file was, but I don't understand why this image is so much larger than the others.
Take a look at the file on the ftp: /Upload Here/_MAME Artwork Bezel Project/samsho/Bezel - ASA samsho with IC (rfancella).png
I would take any advice I can get.
Thanks,
Ron
I can help you with that Sir.
When you or I saved it we forgot to select this, smallest. The size after saving is reduced from 61mb to 1.37.
Are there many like this?
Wow... Wonder why? It's allways defaulted that way before. I'll do a scan and see how many big files I did.
Thanks,
Ron
Thanks,
Ron
Gig,
Yea, quite a few of mine are big. 34 that are over 50gb and 31 that are over 10gb.
I'll start working on this ASAP.
Thanks,
Ron
yes its like gigapig says if you save or export them once more the have only 1.0 mb-1.8 mb
its not a big thing to do i have made it yesterday
[sIGPIC][/sIGPIC]
Ok, I have adjusted all the big files and they are now much smaller. I will get them uploaded today sometime.
Thank you both for the input!!
Thanks,
Ron
  • 4 months later...
/Upload Here/_MAME Artwork Bezel Project seems to no longer exist.
Where has it been moved to?
It's definitely still there.
Disregard. Thanks for the quick reply BTW.
Was connecting with my emumovies account rather than my hyperspin account.... DOH! Found It!
Give this a try.
Open up HLHQ.
Select MAME on the left.
Select Modules on the top.
Click once on MAME and hit the "Edit Global Module Settings" button.
On the Settings tab, make sure your BezelMode is set to "normal".
Click on the MAME tab right next to Settings.
Change the following all to "false": Artwork_Crop, Use_Bezels, Use_Overlays, Use_Backdrops, Use_Cpanels & Use_Marquees.
Close out that window.
Click the Settings tab on top.
Click the Bezel sub-tab and make sure Bezel - Enabled is set to true.
If that doesn't work, post your HyperLaunch log using code tags as described here:
http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm
Let me know how it goes.
Thanks,
Ron
Does this work for all Mame versions? I have mame .148 and I don't have all these options "Artwork_Crop, Use_Bezels, Use_Overlays, Use_Backdrops, Use_Cpanels & Use_Marquees" I only has Use_bezels, Use_Overlays and Use_Backdrops. Don't know if that's why I cant make them appear.
Thanks.
Thanks.
If you followed what Ron said and have put the artwork files in the correct place then yes it should work. But I would recommend you grab a new build from Jumpstiles folder and also upgrade your Rom Set to match.
Yes I followed what Ron said but it still didn't work that's why I was asking if it mattered that I had .148. I was googling to c how I can update my rom set to play on mame .156 hopefully I can update it.
Your not a member of pleasure Dome then?
Or try this which is slightly newer than what you have. I would imagine most of your Roms will work with 0.156, I always update mine so I can't be sure.
Can you post your Hyperlaunch log set to troubleshooting.
Idk if this is what u mean.
16:25:26:004 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.0.9
16:25:26:004 | HL |     INFO  | +0     | Main - System Specs:
				HyperLaunch Dir: C:\Hyperspin\HyperLaunch
				OS: WIN_7
				Architecture: 64-bit (might not be accurate)
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1032 work)
				AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe
				AHK Version: 1.1.09.04
				Unicode: No
16:25:26:004 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
16:25:26:004 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\HyperLaunch.exe exists
16:25:26:004 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	3.0.0.9
				File Size:			899072 bytes
				Created:			5/2/2014 - 8:38:55 PM
				Modified:			4/25/2014 - 6:16:34 PM
16:25:26:004 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\gdip.ahk exists
16:25:26:067 | HL |   DEBUG1  | +63    | CRC Check - CRC matches, this is an official unedited Extension.
16:25:26:067 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			88789 bytes
				Created:			5/2/2014 - 8:39:04 PM
16:25:26:067 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\RIni.ahk exists
16:25:26:098 | HL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Extension.
16:25:26:098 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			67561 bytes
16:25:26:098 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\CLR.ahk exists
16:25:26:098 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
				File Size:			10586 bytes
				Created:			5/2/2014 - 8:39:03 PM
16:25:26:098 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\COM.ahk exists
16:25:26:114 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
16:25:26:114 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26342 bytes
16:25:26:114 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\JSON.ahk exists
16:25:26:145 | HL |   DEBUG1  | +32    | CRC Check - CRC matches, this is an official unedited Extension.
16:25:26:145 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9203 bytes
16:25:26:145 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Fade Init.ahk exists
16:25:26:145 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
				File Size:			1145 bytes
				Created:			5/2/2014 - 8:39:00 PM
16:25:26:145 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\HyperPause Init.ahk exists
16:25:26:160 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			691 bytes
16:25:26:160 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Keymapper Init.ahk exists
16:25:26:160 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
16:25:26:160 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			2485 bytes
16:25:26:160 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\MultiGame Init.ahk exists
				File Size:			161 bytes
16:25:26:160 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Statistics Init.ahk exists
				File Size:			167 bytes
16:25:26:160 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Fade.ahk exists
16:25:26:176 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			26644 bytes
16:25:26:176 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\HyperPause.ahk exists
16:25:26:270 | HL |   DEBUG1  | +93    | CRC Check - CRC matches, this is an official unedited Library.
16:25:26:270 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			326352 bytes
16:25:26:270 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Keymapper.ahk exists
16:25:26:285 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
16:25:26:285 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			27844 bytes
16:25:26:285 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\MultiGame.ahk exists
16:25:26:285 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
				File Size:			28070 bytes
16:25:26:285 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Bezel.ahk exists
16:25:26:301 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			21407 bytes
16:25:26:301 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Statistics.ahk exists
16:25:26:301 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
16:25:26:301 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26089 bytes
16:25:26:301 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists
				File Size:			63798 bytes
16:25:26:301 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Shared.ahk exists
16:25:26:316 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
16:25:26:316 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			65137 bytes
16:25:26:316 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\XHotkey.ahk exists
16:25:26:316 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
				File Size:			28659 bytes
16:25:26:316 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk exists
				File Size:			48181 bytes
16:25:26:316 | HL |     INFO  | +0     | Main - HyperLaunch received "MAME" and "1941"
16:25:26:332 | HL |     INFO  | +16    | Main - 1941 is using the default emulator: MAME
16:25:26:332 | HL |     INFO  | +0     | Main - Checking for a [MAME] section in C:\Hyperspin\HyperLaunch\Settings\MAME\Emulators.ini
16:25:26:332 | HL |     INFO  | +0     | Main - Found [MAME] in C:\Hyperspin\HyperLaunch\Settings\MAME\Emulators.ini
16:25:26:348 | HL |     INFO  | +15    | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Modules\MAME\MAME.ahk exists
16:25:26:348 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9871 bytes
				Created:			5/2/2014 - 8:39:05 PM
16:25:26:348 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
16:25:26:348 | HL |     INFO  | +0     | Main - 1941 will use module: C:\Hyperspin\HyperLaunch\Modules\MAME\MAME.ahk
16:25:26:363 | HL |     INFO  | +16    | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks.
16:25:26:379 | HL |     INFO  | +16    | Main - INI Keys read
16:25:26:379 | HL |     INFO  | +0     | CheckFile - Checking if C:\Program Files\7-Zip\7zG.exe exists
16:25:26:379 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	7-Zip GUI
				FileVersion             	9.20
				InternalName            	7zg
				OriginalFilename        	7zg.exe
				ProductVersion          	9.20
				File Size:			387072 bytes
				Created:			11/18/2010 - 8:11:38 PM
				Modified:			11/18/2010 - 8:11:38 PM
16:25:26:379 | HL |     INFO  | +0     | CheckFile - Checking if C:\Program Files\7-Zip\7z.dll exists
16:25:26:394 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7za
				ProductVersion          	9.20
				File Size:			1422336 bytes
				Created:			11/18/2010 - 8:24:20 PM
				Modified:			11/18/2010 - 8:24:20 PM
16:25:26:410 | HL |     INFO  | +16    | CheckPaths - Started
16:25:26:410 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Hyperspin\Emulators\Mame\roms\1941.zip
16:25:26:410 | HL |     INFO  | +0     | CheckPaths - Found rom: C:\Hyperspin\Emulators\Mame\roms\1941.zip
16:25:26:410 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\Emulators\Mame\mame.exe exists
16:25:26:410 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	Multiple Arcade Machine Emulator
				FileVersion             	0, 148, 0, 0
				InternalName            	MAME
				LegalCopyright          	Copyright Nicola Salmoria and the MAME team
				OriginalFilename        	MAME
				ProductName             	MAME
				ProductVersion          	0.148
				CompanyName             	MAME Team
				File Size:			76524544 bytes
				Created:			5/7/2014 - 8:21:06 PM
				Modified:			1/11/2013 - 12:26:51 AM
16:25:26:410 | HL |     INFO  | +0     | CheckPaths - Ended
16:25:26:426 | HL |     INFO  | +15    | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 2
				frontendPID = 0
				frontendPath = C:\Hyperspin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = C:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				emuFullPath = C:\Hyperspin\Emulators\Mame\mame.exe
				emuPath = C:\Hyperspin\Emulators\Mame
				emuName = MAME
				emuExt = exe
				romPath = C:\Hyperspin\Emulators\Mame\roms
				romPathFromIni = C:\Hyperspin\Emulators\Mame\roms
				romExtension = .zip
				romExtensionOrig = .zip
				romExtensions = zip
				executable = mame.exe
				systemName = MAME
				dbName = 1941
				romName =
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = true
				logFile = C:\Hyperspin\HyperLaunch\HyperLaunch.log
				logLevel = 10
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				navUpKey = 2joy7
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter|2joy3
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1920
				originalHeight = 1080
				dtEnabled = true
				dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = C:\Hyperspin\Media\Fade
				HLDataPath = C:\Hyperspin\HyperLaunch\Data
				HLMediaPath = C:\Hyperspin\Media
				HLErrSoundPath = C:\Hyperspin\Media\Sounds\Error
				modulesPath = C:\Hyperspin\HyperLaunch\Modules
				moduleFullName = C:\Hyperspin\HyperLaunch\Modules\MAME\MAME.ahk
				moduleName = MAME
				modulePath = C:\Hyperspin\HyperLaunch\Modules\MAME
				moduleExtension = ahk
				moduleExtensionsPath = C:\Hyperspin\HyperLaunch\Module Extensions
				libPath = C:\Hyperspin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = C:\Program Files\7-Zip\7zG.exe
				7zDllPath = C:\Program Files\7-Zip\7z.dll
				7zExtractPath = C:\Program Files\7-Zip
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 0
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = C:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes =
				hpLoadStateKeyCodes =
				keymapperEnabled = false
				keymapper =
				xpadderFullPath = C:\Hyperspin\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = C:\Hyperspin\HyperLaunch\Profiles\JoyToKey\_Default\Dual Joystick.cfg
				keymapperProfilePath = C:\Hyperspin\HyperLaunch\Profiles\
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = Xin-Mo Dual Arcade
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				FEProfile = C:\Hyperspin\HyperLaunch\Profiles\\HyperSpin
				defaultProfile = C:\Hyperspin\HyperLaunch\Profiles\\_Default
				systemProfile = C:\Hyperspin\HyperLaunch\Profiles\\MAME
				xPadderSystemProfile = C:\Hyperspin\HyperLaunch\Profiles\\MAME\_Default
				emuProfile = C:\Hyperspin\HyperLaunch\Profiles\\MAME\MAME
				romProfile = C:\Hyperspin\HyperLaunch\Profiles\\MAME\1941
				blankProfile = C:\Hyperspin\HyperLaunch\Profiles\\blank
				HyperLaunchProfile = C:\Hyperspin\HyperLaunch\Profiles\\HyperLaunch
				bezelEnabled = true
				statisticsEnabled = true
16:25:26:426 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
16:25:26:426 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
16:25:26:426 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
16:25:26:426 | HL |   DEBUG1  | +0     | BuildScript - Module starts on line: 285
16:25:26:426 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = MAME
				MEmuV =  v0.148
				MURL = http://www.mame.net/
				MAuthor = djvj
				MVersion = 2.0.6
				MCRC = D558F163
				iCRC = CD775A90
				MID = 635038268903403479
				MSystem = "AAE","Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES"
				; Notes:
				; No need to edit mame.ini and set your rom folder, module sends the rompath for you.
				; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html
				; High Scores DO NOT SAVE when cheats are enabled!
				; HLSL Documentation: http://mamedev.org/source/docs/hlsl.txt.html
				; MAME 149 is currently bugged and HyperPause support is broken. Emu does not let you alt-tab out. This is a mamedev issue, not an HL one.
				; If you use MAME for AAE, create a vector.ini in mame's ini subfolder and paste these HLSL settings in there: http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=309968&page=&view=&sb=5&o=&vc=1
				StartModule()
				FadeInStart()
				settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini")
				Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1)
				hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1)	; Hides console window from view if it shows up
				pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1)	; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers
				bezelMode := IniReadCheck(settingsFile, "Settings", "BezelMode","layout",,1)	; "layout" or "normal"
				cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1)
				cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1)	; user defined key to be held down before launching a mame rom.
				sysParams := IniReadCheck(settingsFile, systemName, "Params", A_Space,,1)
				romParams := IniReadCheck(settingsFile, romName, "Params", A_Space,,1)
				mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1)
				Use_Bezels := IniReadCheck(settingsFile, "Settings", "Use_Bezels", "true",,1)
				Use_Bezels := IniReadCheck(settingsFile, romName, "Use_Bezels", Use_Bezels,,1)	; default is the system's current setting
				Use_Overlays := IniReadCheck(settingsFile, "Settings", "Use_Overlays", "true",,1)
				Use_Overlays := IniReadCheck(settingsFile, romName, "Use_Overlays", Use_Overlays,,1)	; default is the system's current setting
				Use_Backdrops := IniReadCheck(settingsFile, "Settings", "Use_Backdrops", "true",,1)
				Use_Backdrops := IniReadCheck(settingsFile, romName, "Use_Backdrops", Use_Backdrops,,1)	; default is the system's current setting
				If bezelEnabled = true
				{	ListXMLtable := []
					ListXMLtable := ListXMLInfo(romName)
					If bezelMode = layout
						useBezels := If (Use_Bezels = "true") ? "-use_bezels" : "-nouse_bezels"
						useOverlays := If (Use_Overlays = "true") ? "-use_overlays" : "-nouse_overlays"
						useBackdrops := If (Use_Backdrops = "true") ? "-use_backdrops" : "-nouse_backdrops"
						BezelStart(romName,ListXMLtable[1],ListXMLtable[2],ListXMLtable[3],ListXMLtable[4])
					} Else {
						useBezels := "-nouse_bezels"
						useOverlays := "-nouse_overlays"
						useBackdrops := "-nouse_backdrops"
						BezelStart(,,ListXMLtable[2])
				; -romload part of 147u2 that shows what roms were checked when missing roms
				winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel"
				fullscreen := If (Fullscreen = "true") ? "-nowindow" : "-window"
				videomode := If (Videomode != "" ) ? "-video " . videomode : ""
				sysParams := If sysParams != ""  ? sysParams : ""
				romParams := If romParams != ""  ? romParams : ""
				StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1	; replace all instances of | to ; in the Rom_Path from Emulators.ini so mame knows where to find your roms
				mameRomPaths := "-rompath """ .  (If mameRomName ? romPath : mameRomPaths) . """"	; if using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom
				If InStr(romParams,"-rompath")
					ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
				If InStr(sysParams,"-rompath")
					ScriptError("""-rompath"" is defined as a parameter for " . systemName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
				If mameRomName {
					FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension%	; rename rom to match what mame needs
					originalRomName := romName	; store romName from database so we know what to rename it back to later
					romName := mameRomName
					If ErrorLevel
						ScriptError("There was a problem renaming " . romName . "  to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8)
					Else	; if rename was successful, set var so we know to move it back later
						fileRenamed = 1
				If cheatMode = true
				{	If cheatModeKey	; if user wants to use a key to enable CheatMode
						cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? "-cheat" : ""
					Else	; no cheat mode key defined
						cheatEnabled := "-cheat"
				If hideConsole = true
					SetTimer, HideConsole, 10
				Run(executable . A_Space . romName . A_Space . fullscreen . A_Space . cheatEnabled . A_Space . videomode . A_Space . useBezels . A_Space . useOverlays . A_Space . useBackdrops . A_Space . mameRomPaths . A_Space . sysParams . A_Space . romParams, emuPath, winstate)
				If(ErrorLevel != 0){
					If (ErrorLevel = 1)
						Error = Failed Validity
					Else If(ErrorLevel = 2)
						Error = Missing Files
					Else If(ErrorLevel = 3)
						Error = Fatal Error
					Else If(ErrorLevel = 4)
						Error = Device Error
					Else If(ErrorLevel = 5)
						Error = Game Does Not Exist
					Else If(ErrorLevel = 6)
						Error = Invalid Config
					Else If ErrorLevel in 7,8,9
						Error = Identification Error
					Else
						Error = MAME Error
					ScriptError("MAME Error - " . Error)
				WinWait("ahk_class MAME")
				WinWaitActive("ahk_class MAME")
				BezelDraw()
				FadeInExit()
				BezelExit()
				If fileRenamed {	; rename file back to alternate name for next launch
					FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension%
					If ErrorLevel	; if rename was successful, set var so we know to move it back later
						ScriptError("There was a problem renaming " . romName . " back to " . originalRomName)
				FadeOutExit()
				ExitModule()
				ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution
					Global emuFullPath, emuPath
					ListXMLtable := []
					RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide
					Fileread, ListxmlContents, %emuPath%\tempBezel.txt
					RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent)
					RegExMatch(parent,"cloneof=" . """" . ".*", parent)
					RegExMatch(parent,"""" . ".*", parent)
					StringTrimLeft, parent, parent, 1
					RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle)
					RegExMatch(angle,"[0-9]+", angle, "-6")
					RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width)
					RegExMatch(width,"[0-9]+", width, "-6")
					RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height)
					RegExMatch(Height,"[0-9]+", Height, "-6")
					ListXMLtable[1] := parent
					ListXMLtable[2] := angle
					If (ListXMLtable[2]<>0)
						ListXMLtable[3] := height
					Else
						ListXMLtable[3] := width
						ListXMLtable[4] := width
					Else
						ListXMLtable[4] := height
					FileDelete, %emuPath%\tempBezel.txt
					Return ListXMLtable
				HaltEmu:
					If pauseMethod = 1
					{	disableSuspendEmu = true
						disableRestoreEmu = true
						PostMessage,0x211, 1, , , ahk_class MAME
					} Else If pauseMethod = 2
					} Else If pauseMethod = 3
						PostMessage,% 0x0400+6, 1, , , ahk_class MAME
					} Else If pauseMethod = 4
					} Else If pauseMethod = 5
						Send, {P down}
						Sleep, 1000
						Send, {P up}
				Return
				RestoreEmu:
					If pauseMethod = 1
					{	PostMessage,0x212, 1, , , ahk_class MAME
						WinActivate, ahk_class MAME
					{	PostMessage,% 0x0400+6, 0, , , ahk_class MAME
						Send, {P down}
						Sleep, 1000
						Send, {P up}
					} Else If pauseMethod = 6
				Return
				HideConsole:
					hideConsoleTimer++
					IfWinExist, ahk_class ConsoleWindowClass
					{	Log("Module - HideConsole - Console window found, hiding it out of view.")
						WinSet, Transparent, 0, ahk_class ConsoleWindowClass
						SetTimer, HideConsole, Off
					} Else If hideConsoleTimer >= 200
				Return
				CloseProcess:
					FadeOutStart()
					WinClose("ahk_class MAME")
				Return
16:25:26:426 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
16:25:26:426 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
16:25:26:426 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
16:25:26:426 | HL |     INFO  | +0     | Main - Module is built
16:25:26:426 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\AutoHotkey.dll exists
16:25:26:457 | HL |   DEBUG1  | +32    | CheckFile - Attributes:
				File Size:			785408 bytes
				Created:			5/2/2014 - 8:38:54 PM
16:25:26:472 | HL |     INFO  | +15    | Main - Running module
16:25:26:472 | HL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
16:25:26:628 | MD |     INFO  | +N/A   | Module initialized
16:25:26:660 | MD |     INFO  | +31    | StartModule - Started
16:25:26:660 | MD |     INFO  | +0     | StartModule - MEmu: MAME
				MEmuV: v0.148
				MURL: http://www.mame.net/
				MAuthor: djvj
				MVersion: 2.0.6
				MCRC: D558F163
				iCRC: CD775A90
				MID:
				MSystem: "AAE","Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES"
16:25:26:660 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "MAME"
16:25:26:660 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to HyperLaunch:
16:25:26:660 | MD |     INFO  | +0     | StartModule - Ended
16:25:26:660 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
16:25:26:660 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
16:25:26:660 | MD |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Modules\MAME\MAME.ini exists
16:25:26:691 | MD |   DEBUG1  | +32    | CheckFile - Attributes:
				File Size:			2419 bytes
				Modified:			12/26/2014 - 1:11:17 PM
16:25:26:691 | MD |     INFO  | +0     | Module Setting - Fullscreen: true
16:25:26:691 | MD |     INFO  | +0     | Module Setting - Videomode: d3d
16:25:26:691 | MD |     INFO  | +0     | Module Setting - HideConsole: true
16:25:26:691 | MD |     INFO  | +0     | Module Setting - PauseMethod: 4
16:25:26:691 | MD |     INFO  | +0     | Module Setting - BezelMode: normal
16:25:26:691 | MD |     INFO  | +0     | Module Setting - CheatMode: true
16:25:26:691 | MD |     INFO  | +0     | Module Setting - CheatModeKey: Z&X
16:25:26:691 | MD |     INFO  | +0     | Module Setting - Use_Bezels: true
16:25:26:691 | MD |     INFO  | +0     | Module Setting - Use_Overlays: true
16:25:26:691 | MD |     INFO  | +0     | Module Setting - Use_Backdrops: true
16:25:29:569 | MD |     INFO  | +2870  | BezelStart - Started
16:25:29:569 | MD |  WARNING  | +0     | Bezel is enabled, however none of the bellow valid Bezel files exist:
16:25:29:569 | MD |     INFO  | +0     | BezelStart - Ended
16:25:29:569 | MD |     INFO  | +0     | Module Run - Running: C:\Hyperspin\Emulators\Mame\mame.exe 1941 -nowindow  -video d3d -nouse_bezels -nouse_overlays -nouse_backdrops -rompath "C:\Hyperspin\Emulators\Mame\roms"
16:25:29:788 | MD |   DEBUG1  | +218   | Module Run - "mame.exe 1941 -nowindow  -video d3d -nouse_bezels -nouse_overlays -nouse_backdrops -rompath "C:\Hyperspin\Emulators\Mame\roms"  " Process ID: 1876
16:25:29:788 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;b74605c5-3116-4ac0-9c27-6b9dd57d5012] | State: 0 | X: 524 | Y: 190 | Width: 1370 | Height: 772 | Window HWND: 0x500fa | Process ID: 3268 | Process Path: C:\Hyperspin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe
16:25:29:788 | MD |     INFO  | +0     | Module WinWait - Waiting for ahk_class MAME
16:25:29:881 | MD |     INFO  | +94    | Module - HideConsole - Console window found, hiding it out of view.
16:25:31:160 | MD |   DEBUG1  | +1279  | GetActiveWindowStatus - Title: MAME: 1941: Counter Attack (World 900227) [1941] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x70116 | Process ID: 1876 | Process Path: C:\Hyperspin\Emulators\Mame\mame.exe
16:25:31:160 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: MAME: 1941: Counter Attack (World 900227) [1941] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x70116 | Process ID: 1876 | Process Path: C:\Hyperspin\Emulators\Mame\mame.exe
16:25:31:160 | MD |     INFO  | +0     | Module WinWaitActive - Waiting for "ahk_class MAME"
16:25:31:363 | MD |   DEBUG1  | +203   | GetActiveWindowStatus - Title: MAME: 1941: Counter Attack (World 900227) [1941] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x70116 | Process ID: 1876 | Process Path: C:\Hyperspin\Emulators\Mame\mame.exe
16:25:31:363 | MD |     INFO  | +0     | BezelDraw - Started
16:25:31:363 | MD |     INFO  | +0     | BezelDraw - Ended
16:25:31:363 | MD |     INFO  | +0     | Module Process - WaitClose mame.exe
16:25:54:950 | MD |   DEBUG1  | +23587 | CloseProcess started, user requested to end launched application
16:25:54:951 | MD |     INFO  | +0     | Module WinClose - Closing: ahk_class MAME
16:25:55:695 | MD |   DEBUG1  | +749   | CloseProcess ended
16:25:55:695 | MD |     INFO  | +0     | BezelExit - Started
16:25:55:695 | MD |     INFO  | +0     | BezelExit - Ended
16:25:55:695 | MD |     INFO  | +0     | StopGlobalUserFeatures - Starting
16:25:55:695 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
16:25:55:695 | MD |     INFO  | +0     | ExitModule - Started
16:25:55:695 | MD |     INFO  | +0     | Starting Updating Statistics:
16:25:55:695 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
16:25:55:695 | MD |   DEBUG2  | +0     | gameSectionStartTime:205858
16:25:55:695 | MD |   DEBUG2  | +0     | ElapsedTime:29
16:25:55:695 | MD |     INFO  | +0     | CreateRomTable - Started
16:25:55:695 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1941" and "(Disc"
16:25:55:695 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1941" and "(Disk"
16:25:55:695 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1941" and "(Cart"
16:25:55:695 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1941" and "(Tape"
16:25:55:695 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1941" and "(Cassette"
16:25:55:695 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1941" and "(Part"
16:25:55:695 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1941" and "(Side"
16:25:55:695 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
16:25:55:695 | MD |   DEBUG2  | +0     | Statistics cleared game name: 1941
16:25:55:817 | MD |   DEBUG2  | +125   | Loaded game statistics from ini files:
				Number_of_Times_Played: 7
				Last_Time_Played: Friday December 26, 2014 02:02:11 PM
				Average_Time_Played: 18
				Total_Time_Played: 125
				System_Total_Played_Time: 85461
				Total_Global_Played_Time: 97192
16:25:55:817 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 8
				Last_Time_Played: Friday December 26, 2014 04:25:55 PM
				Average_Time_Played: 19
				Total_Time_Played: 154
				System_Total_Played_Time: 85490
				Total_Global_Played_Time: 97221
16:25:55:921 | MD |     INFO  | +94    | Game section statistics updated.
16:25:55:921 | MD |     INFO  | +0     | ExitModule - Ended
16:25:55:921 | MD |     INFO  | +0     | End of Module Logs
16:25:56:028 | HL |     INFO  | +29547 | Main - Module ended, exiting HyperLaunch normally
16:25:56:028 | HL |     INFO  | +0     | ExitScript - Started
16:25:56:043 | HL |   DEBUG1  | +15    | ExitScript - Putting HyperSpin.exe back in focus
16:25:56:059 | HL |     INFO  | +16    | SystemCursor - Restoring mouse cursor
16:25:56:090 | HL |     INFO  | +31    | ExitScript - Ended
