sonicboom88 Posted October 18, 2014 Posted October 18, 2014 I just used a rom renaming software for my ps1 games and its just screwed them up all named wrong is there a way to fix it? I have 387 GB worth of ps1 games made me feel sick. Hyper Helper Ready To Help
Roadrunner Posted October 19, 2014 Posted October 19, 2014 Hit the undo button? Sorry man, I don't have a clue. I wish you well on this though, that sucks. Atari 2600 Theme Pack - Now Uploaded! Marvel Exit Screens Jukebox Rock Star Album Themes MAME Widescreen Bezels Pinball FX2 Widescreen Theme Pack Pinball FX2 4x3 Theme Pack Pinball FX3 Themes
THK Posted October 19, 2014 Posted October 19, 2014 Auch ..........................back with a vengeance........................
Spawk Posted October 19, 2014 Posted October 19, 2014 It may be helpful to know the renaming software used, as someone may have used it as well. Most good ones have a "revert" option somewhere.
sonicboom88 Posted October 19, 2014 Author Posted October 19, 2014 It wasn't dons version I think it was a old one I downloaded when i first started I think i will start again had too many that I was not likely to use. Hyper Helper Ready To Help
sonicboom88 Posted October 19, 2014 Author Posted October 19, 2014 HyperSpin_RomManager_1.0-MK2k Hyper Helper Ready To Help
sonicboom88 Posted October 19, 2014 Author Posted October 19, 2014 Oh like what you said there is a txt file in my database folder any idea how to convert to xml? Hyper Helper Ready To Help
albert_c Posted October 19, 2014 Posted October 19, 2014 FUBAR bud, sorry. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
gixxerrider73 Posted October 22, 2014 Posted October 22, 2014 The program I wrote hypermedia uses the crc value to name the rim files to match the hyper list. It will only name the ones that match but it may give you a good start Sent from my iPhone using Tapatalk
DamnedRegistrations Posted October 23, 2014 Posted October 23, 2014 You really don't want to be automatically renaming CD-based games at all for any system unless you just have iso files. If you have proper PS1 dumps, they come in bin + cue format due to all the multitrack games. In which case, you'll also need to open every cue file up in a text editor and make sure it's pointing to the correctly named bin file. Sorry to say but you may need to redownload whatever set you grabbed.
majorspawn Posted October 23, 2014 Posted October 23, 2014 you will need to play them one by one... wowzers! My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
Emu54 Posted October 23, 2014 Posted October 23, 2014 If your artwork is named right run fatmatch but in the rom box have art work and in the artwork have roms
wesfranks Posted October 23, 2014 Posted October 23, 2014 From MK2K's original post on this renaming tool, "the HyperSpin Rommanager only copies and renames the files it finds, so if you scan a folder full of 7z'ed files, only the name of the packed files will get renamed and not their content (the files inside each 7z that is)." Assuming you just renamed the zip file, the files inside should still have their original name. If it wasn't renamed, the cue file should be the same name that the zip file needs to be. If it was renamed, opening the cue file in a text editor may give you the proper name for the zip file. Only a couple of renaming tools claimed to be able to properly rename cue files inside zip files (with varying results if the posts are any indication). That's two additional chances to get your file names back to the way they were. Then again you may have already deleted and are merrily downloading the files again. Jeez, 387 GB. As damnedregistrations said, be careful renaming CD based systems, especially those with multiple files in a zip. Also don't feel bad. I screwed up my PS1 renaming also at first (and I don't feel that I am alone in this). Wes
sonicboom88 Posted October 23, 2014 Author Posted October 23, 2014 they where bin and cue ended up deleting them all |I had too many that I wouldn't use any way so just only going to put on what I will use. Hyper Helper Ready To Help
BiLbOBaggins Posted October 23, 2014 Posted October 23, 2014 I just used a rom renaming software for my ps1 games and its just screwed them up all named wrong is there a way to fix it? I have 387 GB worth of ps1 games made me feel sick. Is there a reason you did not back up your data first? I always duplicate a couple of files and use them for a test before I run any type of software against the whole batch. Just my two cents..
sonicboom88 Posted October 23, 2014 Author Posted October 23, 2014 It was over 300gb of ps1 game's I was just too lazy to do a test run. Hyper Helper Ready To Help
eezetee Posted October 24, 2014 Posted October 24, 2014 Maybe you have an old backup that has the xml on it? I wonder if inside the cue files has the original file names, assuming your program only renamed the file name. ??
damageinc86 Posted October 24, 2014 Posted October 24, 2014 It was real tedious but using that rommanager renamer tool, I usually had to go through the whole list looking for less than 100% matches and make sure they were pointing to the right file, and if not, point them to the right file manually. If your set wasn't even close then that would be a lot of manual pointing. Probably easiest to just to download a new set.
