EZ Flasher (Simple Flash Loader)
  • 1 month later...
  • Replies 73
Can someone tell me what the keymapping term (in the controller setting) is for the spacebar in ezflasher.
w=up
c=space
that is what I would like to put but it's not working and there is nothing in the directions about the space bar. THANKS
Also - I set this up to run as pcgames and it works very well. Thanks Rain.
  • 2 months later...
What condition is required to run this?
I ran the app and nothing, I ran the flash file through the app (open app with) and nothing.
App sounds perfect!
~5thWolf~
It works flawlessly. I have flash games set up on my wheel the same way PC games are se set up using EZ Flasher. I just create a folder for each flash game, drop in a copy of Ez Flasher rename the swf to game.swf, and modify the settings to my scrreen and desired controls. I use pclauncher to launch the games in each folder. These games look great fullscreen. It's brilliant.
I tried putting it in same folder, and still nothing. I looks like it disappears as soon as I launch it. Should just clicking the EZ-Flasher bring up the app gui?
Or does this have to be run through Hyperspin? I am trying to test it before using HS.
~5thWolf~
Assuming you have flash player installed, it should work. There is no gui that I am aware of. There is a settings.ini file, the flasher.exe, and you must provide the swf file. For example, if you have Aether.swf, you would put it into a folder with flasher.exe, the settings.ini, and then rename aether.exe to game.exe. Before you open flasher.exe, open the settings.ini, and change the settings to what you would like them to be. Once that is done, double click flasher.exe, and your game should open with the variables you have set. If you are not able to get a flash game playing without EZ Flasher, then EZ Flasher will probably not work for you. If you take an SWF, can you play it through Adobe Flash, or Explorer? If not, you need to remedy that before EZ Flasher will work for you.
Separate folders for each game seems a bit excessive? I got it working with EZ flasher in my emulator folder and a roms folder for all .swf files.
I can post how I got it working, but I am a bit busy at the moment :)
  • 1 month later...
This looks awesome. I keep getting an invalid file id when clicking the links in the first post. Is this posted somewhere else?
i need e-z flasher.I'm trying to become a member platinium but I will take a few days recently I associate with paypal. and need the program to continue configuring everything you could pass me by pm. thanks
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
Good Morning....ill put a copy of Rain's program in my FTP folder
[sIGPIC][/sIGPIC]
Sega Saturn Japanese Wheel Project: COMPLETE!! If you have FTP access, find my name and grab the set now!!!
  • 4 weeks later...
  • 4 months later...
Just in case anyone has problems getting ez flasher to work with Win7 (Which I did), you may get a message saying windows is missing a needed file. The file is flash.ocx and it does not come with or work with Win7 I guess. After several forum visits and trying to fix the issue I found that if you install Windows Flash Player 11.2 ActiveX control content debugger (for IE) from http://www.adobe.com, then the issue stops and EZ flasher starts working again!
  • 2 years later...
I've no clue what this app is but once it is found and it's indeed useful can we put it in the downloads section? I can then fix the link on the OP.
