Help setting up Pinball Arcade
Lol ya. So it's not painful anymore maybe. What are the tips for the upgrade? Transition tool, read slowly, and somehow capture your custom modules? Say ta ta to hyperspeech system bios right? That's the only thing other then led blinky that I believe still needs worked out?
  • Replies 283
this is cra cra. Thanks for all the help on this folks
I just redownloaded the hyperhq version and I still get the error. Here are some other settings, is it like yours?
in hyperhq, under main settings, everything is left as is except for skip checks which has been set to rom and emulator
when I go to pinball arcade conf utility I hae it set to 1024x768 and fullscreen
the emulator itself is set up under global emulators. Its named pinball arcade and has a path. The module name is pinball arcade.ahk and virtual emulator is checked
when looking at the pinball arcade emulator tab I have default emulator set to pinball arcade. Nothing else is filled out here
When looking at hyperhq, its defaulted to hyperlaunch and pc game disabled. NOTHING else is filled in here
I'm guessing when you said "in hyperhq, under main settings, everything is left as is except for skip checks which has been set to rom and emulator" you were actually talking about the HyperLaunchHQ main settings (not HyperHQ)...
If you have a path set to the exe then you are using a standalone version and not the Steam version right?
Is it an "official" standalone version or no. If not that might be the problem. Did you rename your DX11 exe to be called "PinballArcade.exe?
What version of TPA do you have. It is the newest DX11 version (1.38.8 or newer I think) right?
The rest of that sounds right.
The module is coming up in yellow (not red) in the Pinball Arcade module tab in HLHQ?
In your HLHQ module folder you have a an Pinball Arcade.ini and a Pinball Arcade.isd. What is the text in the .ini?
So this is now basically say I have to upgrade don't it
Since it should be working in HLHQ for you I'm thinking you'll have the same problem in RocketLauncher.
Maybe upgrading would help, but I don't see why. These files, the module, the XML are basically the same in HLHQ and RLUI.
Yep the module is yellow. I can't run dx11 cuz my graphics card can't take it ha. I didn't do any renaming and just using dx9
here is my ini file
[settings]
Fullscreen=true
Sleep_Until_Logo=9000
Pinball_Version=DX9
I believe he has the same "acquired" version I have which is standalone and DX9 and 11 versions are completely split so there is no need for renaming the exes
That's what I thought. Is it working good for you?
here is my ini file
[settings]
Fullscreen=true
Pinball_Version=DX9
Hmmm... That all looks good, although I have my sleep set to 7000, but that shouldn't cause the trouble you're getting.
Do you have blockinput.exe in your HLHQ module extensions folder?
yup, other than the DX11 version not doing fullscreen properly.
Someone on the TPA forums had a similar issue. You have it set to fullscreen in the config and in RLUI and it doesn't go fullscreen for you?
Mine runs DX 11fullscreen just fine, but I have the most recent Steam updated version. Maybe that's the difference.
metal i think that its not working for me with the removeing of the nag screen is becouse im on version 1.39.7 and i think version 1.39.9 u can add that line in ahk to remove nag screen mate.
Yeah, I just responded to your post in the new topic.
That's why it didn't work yesterday. I totally forgot you had told me that. I spent hours trying to get it to work for you and it was never going to. Ha!
Oh well, it's all good because I did get it all figured out, module updated and it does work with the standalone exe, so long as you have the current version.
So as soon as you update it should work, unless there's something else weird about yours.
What version of TPA is yours? The current version is 1.39.9
thanks for trying. yes I still get the crc error. guess I have to upgrade
01:27:33:599 | HL | ERROR | +9111 | CRC Check - CRC does not match for this Library. Please re-download this file to continue using HyperLaunch: E:\x-PC\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk
I've not read all of the thread but if you turn fade off do you get the errors?
im on    1.39.7 and not 1.38.9 and it needs to be 1.39.9 that when they said u can remove the nag screen.
There would be nothing to change. The parameter to remove the nag screen would be exactly the same in the module so if it isn't working in your prior version it simply isn't going to. Sorry man.
  • 3 weeks later...
pinball arcade update to 1.40.7 with new safe cracker table. added new table to xml and to module and all ok and working sweet.
Yep. I posted the updated Databse, My Tables list and Wheel art yesterday in this topic: http://www.hyperspin-fe.com/topic/10648-pinball-arcade-version-1407-databasetable-list-in-here/
I also let DJVJ know what nneded to be fixed in the ltest module on the RLauncher forums.
Here's a copy of my poste, you'll have to follow the link for the wheel art though:
The Pinball Arcade was updated today to version 1.40.7.
The only important change was the new Safe Cracker table was added. Here's the fixed and updated database with all tables including Safe Cracker and the updated My Tables list for the module. I have also attached the Wheel Art for Safe Cracker already correctly named to the DB.
Here's my corrected My Tables list:
Addams Family, The (Bally)|Attack from Mars (Bally)|Big Shot (Gottlieb)|Black Hole (Gottlieb)|Black Knight 2000 (Williams)|Black Knight (Williams)|Black Rose (Bally)|Bram Stoker's Dracula (Williams)|Bride of Pin-Bot (Williams)|Cactus Canyon (Bally)|Centaur (Bally)|Central Park (Gottlieb)|Champion Pub, The (Bally)|Cirqus Voltaire (Bally)|Class of 1812 (Gottlieb)|Creature from the Black Lagoon (Bally)|Cue Ball Wizard (Gottlieb)|Cyclone (Williams)|Diner (Williams)|Dr. Dude & His Excellent Ray (Bally)|Earthshaker (Williams)|El Dorado - City Of Gold (Gottlieb)|Elvira and the Party Monsters (Bally)|Firepower (Williams)|Fish Tales (Williams)|Flight 2000 (Stern)|FunHouse (Williams)|Genie (Gottlieb)|Goin' Nuts (Gottlieb)|Gorgar (Williams)|Harley-Davidson, 3rd Edition (Stern)|Haunted House (Gottlieb)|High Roller Casino (Stern)|High Speed (Williams)|Jack-Bot (Williams)|Junk Yard (Williams)|Lights... Camera... Action! (Gottlieb)|Medieval Madness (Williams)|Monster Bash (Williams)|No Good Gofers (Williams)|Party Zone (Bally)|Phantom of the Opera, The (Data East)|Pin-Bot (Williams)|Red & Ted's Roadshow (Williams)|Ripley's Believe It or Not! (Stern)|Safe Cracker (Bally)|Scared Stiff (Bally)|Space Shuttle (Williams)|Star Trek - The Next Generation (Williams)|Starship Troopers (Sega)|Tales of the Arabian Nights (Williams)|Taxi (Williams)|Tee'd Off (Gottlieb)|Terminator 2 - Judgment Day (Williams)|Theatre of Magic (Bally)|Twilight Zone (Bally)|Victory (Gottlieb)|Whirlwind (Williams)|White Water (Williams)|WHO Dunnit (Bally)|Xenon (Bally)
Here is the corrected database.xml that matches the above My Tables list with all season 4 tables (including Safe Cracker) and Starship Troopers correctly credited to Sega:
<?xml version="1.0"?>
<menu>
  <header>
    <listname>Pinball Arcade</listname>
    <lastlistupdate>04/26/2015</lastlistupdate>
    <listversion>1.0 Final</listversion>
    <exporterversion>marxkemp</exporterversion>
  </header>
	<game name="Addams Family, The (Bally)" index="" image="">
		<description>Addams Family, The (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<manufacturer>Bally</manufacturer>
		<year>1992</year>
		<genre>Pinball</genre>
		<rating>ESRB - E (Everyone)</rating>
		<enabled>True</enabled>
	</game>
	<game name="Attack from Mars (Bally)">
		<description>Attack from Mars (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1995</year>
	</game>
	<game name="Big Shot (Gottlieb)">
		<description>Big Shot (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<manufacturer>Gottlieb</manufacturer>
		<year>1993</year>
	</game>
	<game name="Black Hole (Gottlieb)">
		<description>Black Hole Gottlieb</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1981</year>
	</game>
	<game name="Black Knight 2000 (Williams)">
		<description>Black Knight 2000 (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<manufacturer>Williams</manufacturer>
		<year>1989</year>
	</game>
	<game name="Black Knight (Williams)">
		<description>Black Knight (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1980</year>
	</game>
	<game name="Black Rose (Bally)">
		<description>Black Rose (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1992</year>
		<enabled>True</enabled>	</game>
	<game name="Bram Stoker's Dracula (Williams)">
		<description>Bram Stoker's Dracula (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1993</year>
	</game>
	<game name="Bride of Pin-Bot (Williams)">
		<description>Bride of Pin-Bot (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1991</year>
	</game>
	<game name="Cactus Canyon (Bally)">
		<description>Cactus Canyon (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1998</year>
	</game>
	<game name="Centaur (Bally)">
		<description>Centaur (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1981</year>
	</game>
	<game name="Central Park (Gottlieb)">
		<description>Central Park (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1966</year>
	</game>
	<game name="Champion Pub, The (Bally)">
		<description>Champion Pub, The (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1998</year>
	</game>
	<game name="Cirqus Voltaire (Bally)">
		<description>Cirqus Voltaire (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1997</year>
	</game>
	<game name="Class of 1812 (Gottlieb)">
		<description>Class of 1812 (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1991</year>
	</game>
	<game name="Creature from the Black Lagoon (Bally)">
		<description>Creature from the Black Lagoon (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1992</year>
	</game>
	<game name="Cue Ball Wizard (Gottlieb)">
		<description>Cue Ball Wizard (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1992</year>
	</game>
	<game name="Cyclone (Williams)">
		<description>Cyclone (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1988</year>
	</game>
	<game name="Diner (Williams)">
		<description>Diner (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1990</year>
	</game>
	<game name="Dr. Dude & His Excellent Ray (Bally)">
		<description>Dr. Dude & His Excellent Ray (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1990</year>
	</game>
	<game name="Earthshaker (Williams)">
		<description>Earthshaker (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1989</year>
	</game>
	<game name="El Dorado - City Of Gold (Gottlieb)">
		<description>El Dorado: City Of Gold (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1984</year>
	</game>
	<game name="Elvira and the Party Monsters (Bally)">
		<description>Elvira and the Party Monsters (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1989</year>
	</game>
	<game name="Firepower (Williams)">
		<description>Firepower (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1980</year>
	</game>
	<game name="Fish Tales (Williams)">
		<description>Fish Tales (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1992</year>
	</game>
	<game name="Flight 2000 (Stern)">
		<description>Flight 2000 (Stern)</description>
		<cloneof></cloneof>
		<crc></crc>
		<manufacturer>Stern</manufacturer>
		<year>1980</year>
	</game>
	<game name="FunHouse (Williams)">
		<description>FunHouse (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1990</year>
	</game>
	<game name="Genie (Gottlieb)">
		<description>Genie (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1979</year>
	</game>
	<game name="Goin' Nuts (Gottlieb)">
		<description>Goin' Nuts (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1983</year>
	</game>
	<game name="Gorgar (Williams)">
		<description>Gorgar (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1979</year>
	</game>
	<game name="Harley-Davidson, 3rd Edition (Stern)">
		<description>Harley-Davidson, 3rd Edition (Stern)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1999</year>
	</game>
	<game name="Haunted House (Gottlieb)">
		<description>Haunted House (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1982</year>
	</game>
	<game name="High Roller Casino (Stern)">
		<description>High Roller Casino (Stern)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>2001</year>
	</game>
	<game name="High Speed (Williams)">
		<description>High Speed (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1986</year>
	</game>
	<game name="Jack-Bot (Williams)">
		<description>Jack-Bot (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1995</year>
	</game>
	<game name="Junk Yard (Williams)">
		<description>Junk Yard (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1996</year>
	</game>
	<game name="Lights... Camera... Action! (Gottlieb)">
		<description>Lights... Camera... Action! (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1989</year>
	</game>
	<game name="Medieval Madness (Williams)">
		<description>Medieval Madness (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1997</year>
	</game>
	<game name="Monster Bash (Williams)">
		<description>Monster Bash (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1998</year>
	</game>
	<game name="No Good Gofers (Williams)">
		<description>No Good Gofers (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1997</year>
	</game>
	<game name="Party Zone (Bally)">
		<description>Party Zone (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1991</year>
	</game>
	<game name="Phantom of the Opera, The (Data East)">
		<description>Phantom of the Opera, The (Data East)</description>
		<cloneof></cloneof>
		<crc></crc>
		<manufacturer>Data East</manufacturer>
		<year>1993</year>
	</game>
	<game name="Pin-Bot (Williams)">
		<description>Pin-Bot (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1986</year>
	</game>
		<game name="Red & Ted's Roadshow (Williams)">
		<description>Red & Ted's Roadshow</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1994</year>
	</game>
	<game name="Ripley's Believe It or Not! (Stern)">
		<description>Ripley's Believe It or Not! (Stern)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>2004</year>
	</game>
	<game name="Safe Cracker (Bally)">
		<description>Safe Cracker (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1996</year>
	</game>
	<game name="Scared Stiff (Bally)">
		<description>Scared Stiff (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1996</year>
	</game>
	<game name="Space Shuttle (Williams)">
		<description>Space Shuttle (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1984</year>
	</game>
	<game name="Star Trek - The Next Generation (Williams)">
		<description>Star Trek: The Next Generation (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1993</year>
	</game>
	<game name="Starship Troopers (Sega)">
		<description>Starship Troopers (Sega)</description>
		<cloneof></cloneof>
		<crc></crc>
		<manufacturer>Sega</manufacturer>
		<year>1997</year>
	</game>
	<game name="Tales of the Arabian Nights (Williams)">
		<description>Tales of the Arabian Nights (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1996</year>
	</game>
	<game name="Taxi (Williams)">
		<description>Taxi (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1988</year>
	</game>
	<game name="Tee'd Off (Gottlieb)">
		<description>Tee'd Off (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1993</year>
	</game>
	<game name="Terminator 2 - Judgment Day (Williams)">
		<description>Terminator 2: Judgment Day (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1991</year>
	</game>
	<game name="Theatre of Magic (Bally)">
		<description>Theatre of Magic (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1995</year>
	</game>
	<game name="Twilight Zone (Bally)">
		<description>Twilight Zone (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1993</year>
	</game>
	<game name="Victory (Gottlieb)">
		<description>Victory (Gottlieb)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1987</year>
	</game>
	<game name="Whirlwind (Williams)">
		<description>Whirlwind (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1990</year>
	</game>
	<game name="White Water (Williams)">
		<description>White Water (Williams)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1993</year>
	</game>
	<game name="WHO Dunnit (Bally)">
		<description>WHO Dunnit (Bally)</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1995</year>
	</game>
		<game name="Xenon (Bally)">
		<description>Xenon</description>
		<cloneof></cloneof>
		<crc></crc>
		<year>1980</year>
	</game>
</menu>
