Help setting up Pinball Arcade
  • Replies 283
here u go.
Thanks Andy! Just tried it but still loads TPA but stops at the "press to start"
Running v139.7 what's yours?
mine is 1.39.7 aswell av u tryed changing the sleep b4 logo to a higher number or a lower number and is ur rocketlauncher.exe runing as admin.
I am using v139.7 and the newest module from RL. Pinball arcade runs in dx11 but no matter what game I select just stops at the main menu....query I have to press "1" to select stuff not "enter" does this matter?
Which/who's module are you using? (mine above? a different one?). It sounds like you have the DX11 version in the module options, but don't have the exe changed.
Here's the instructions I posted before:
1. To get Pinball Arcade to run in DX11 the .exe needs to be renamed (for me it's in Steam/steamapps/common/pinball arcade). I rename "PinballArcade.exe" to "PinballArcadeDX9.exe" then rename "PinballArcade11.exe" to "PinballArcade.exe"
2. After that make sure you have DX11 version selected in the module settings.
3. Make sure you have all of your tables listed, in alphabetical order and exactly matching your database names in "MyTable". Copying/pasting someone elses will not work if your database doesn't match exactly.
4. Like I mentioned in my notes above you may need to change lines 148 and 149 of the module depending on if you own all the tables or if you don't. Those lines are clearly marked with instructions in the module I customized, not in the official one.
I'm not sure what you mean you need to press 1 to start? Pinball Arcade uses the enter key.
@metal i have a question for u mate.
sometimes when i run it it goes to the my tables folder then it moves to exit game and i dont no y. then if i run it agin its ok.
Ok chaps...not renamed exe. Appear to be running same version as Andy so XML should work. Also had same results from new official and andys module...
Andy is your module 'metals' ?
I'll try renaming and report back
I got mine then update rockerlauncher I just added my tables from my old module and over written the ones in the new module.
Because you aren't using the module I fixed and posted above (in post #122, I also posted it way back on page 2, but use the newer #122 version), I made that module specifically to fix that problem. There's a glitch in TPA that causes the "What's New" screen to pop-up randomly over and over. When this pops up it breaks the flow of the script. The official module doesn't fix this (although djvj said he was going to add it into the newest version). I knew you weren't using mine because you mentioned you needed to change sleep to 7000 (which it already is in mine) and you needed to add Roadshow (which is already in mine)
EVERYONE: Use my fixed, custom module I posted in post #122, not the official one. Mine is the one that actually works, that's why I posted it. Oh, and read post #122!
Just don't forget to change your MyTables settings to match your table names, not mine.
EDIT: In fact I'll go delete my table names from the module I posted so it doesn't screw anyone up.
Ps I keep seeing the 'what's new' window too!
Because you're not using my fixed module. See my post above.
I find it funny that twice in this thread I've made a "I got it fixed, here's the module" posts and none of you are using it? Ha!
Cool let me know. If your names are right it should then all work perfect. The only thing that doesn't is the fade in screen, but that's because the DX11 version doesn't have a "windowed fullscreen" mode yet.
I changed from your tables to mine and it seem to b working ok. I did av it working b4 it were just that's wots new kept poping up some time lol .
Yep. The Whats New pop-up was the problem/glitch I'd been posting about now for weeks.
Mike a programmer at Farsight built that fix in for me after I kept bugging him about it here:
http://pinballarcadefans.com/showthread.php/10320-Mike-can-you-guys-please-fix-the-nag-screen
His fix then let me fix the module and now it all runs perfect other than fade (which will be fixed in an update or two). Glad you got it running mate (HA!)
I just looked over the latest module DJVJ released day before yesterday and it looks like he has included my fix for the nag screen, my fixes for the key inputs and my instructions for lines 148 & 149 in the official version. So from here on out official versions should actually work (until Farsight glitches something else, HA!). I'll test it to make sure right now then post it here.
EDIT: Has my fixes and changes in place and seems to work like a champ. It also has a new setting DJVJ added called "Start Game", leave it to false to have it start the game at the main table screen (or table history screen if you've never played the table before) just like my module does. Or set it to true to have the module actually start the table, skipping the main table menu, attract mode, options, multiplayer etc... Personally I prefer this to be false.
This is the latest official module that RocketLauncher is now auto-updating to.
I await your testing cheers
its not working now metal the whot new screen keep poping up evertime I run game.
Ah, I just rememberd you aren't using the Steam version and I only put my fix in for the Steam version (same with the official module).
...hold on.
ok  hope it can be sorted.
I can't test this myself. So you'll need to try it.
In your module change line 129 to this (spaces before and all):
	Run(executable, emuPath,"skipwhatsnew")
And see if that fixes it. The pop-up is random so you'll have to launch several tables to be sure. Say 10 launches with no What's New pop up.
