Section Admin
    3,641
    9
Everything posted by thatman84
  1. Error persists in .28 For reference
  2. I run uninstaller for .34 in Program Files HQ install and my .33 on my custom x:\ drive install Installed the exe .34 that gets downloaded to C:\Users\thatman84\AppData\Local\hyperhq-updater\pending & select my custom path The same bug persists when updating from .34 to .35. Updates automatically get installed to C:\Program Files
  3. I will fix that when next at the PC but it’s was very similar if not the same as this report
  4. That’s your hyperHQ version The bug presents itself in the HyperSpin Core plugin (that’s the version I’m referring to)
  5. Note:- This may well be normal windows stuff but IDK If you close the program from the task bar some processes remain running/hanging in the background The only way I could see to close them was with Task Manager but you had to close the correct one
  6. While HS was opening I Right clicked on taskbar icon and hit close window This error was produced and the only way to close was by end task in Task Manager
  7. I have tested and in Hyperspin v2.0.27 The esc esc bug is fixed, for both my controller and keyboard. The ability to select NO on the "Are you sure" screen is not fixed
  8. Getting the same thing Just to confirm with the Bug report this should be Hyperspin Component v 2.0.26 or .27 Check on the plugins tab
  9. I have similar issues with controller/escape key Need to get the issues added to https://hyperspin-fe.com/development-bug-tracking/11_hyperspin-2-bug-reporting/
  10. Thats almost as cool as your cab!
  11. Wanted to spread a bit of positivity around. I am absolutely digging being able to login to HyperTheme on the move and check out themes etc What are you digging about the new tools?? PS:- issues or pointing out problems in this thread will be deleted. The Admins have provided all the space needed for that type of comment within the forum
  12. Believe I had this issue also.
  13. When browsing themes we can see the images from when the creator adds that info. I would love to see a preview of the theme playing when I’m on it’s download page. Maybe when publishing or saving a theme it could export a 5s clip. Just an idea for far down the road
  14. I believe this was spoken about and the java error was unrelated to controller?
  15. There is an option in HyperHQ to set EM video quality. It defaults to medium. moved to HyperHQ Support forum
  16. I would prefer to wipe out my install and test from scratch with new releases BUT avoid having to scrape media and videos every time. My workflow would be, update with HyperHQ options -> Test -> Wipe out install -> download from website -> test again please advise on a good way to do this. I have been blindly deleting and and transferring my media files and probably a bad idea happy to configure systems in HyperHQ etc just it takes to long to scrape every time Not sure how all the metadata files link everything together. I expect having a way to do this will speed up bug testing
  17. The 2 Plugins have different versions to the main HyperHQ app
  18. Adding your own media is not currently supported BUT there should be a build with that feature coming soon. As for the Mame main menu will have to check.
  19. Moved topic over to HyperTheme Support I had multiple clients after changing client names between HyperHQ installs. Although HT allowed me to delete those straight away. lets see if anyone else can reproduce the issue.
  20. Updated from .31 to .33 and after quitting via task bar and restarting HyperHQ the .33 installl is required again Has happened with other versions also Deleting .exe from pending folder seems to fix the issue C:\Users\thatman84\AppData\Local\hyperhq-updater\pending
  21. This is version .33 (not in the component selector) reordering systems in wheel manager is very sensitive and flickers IMG_7370.mov
  22. Added the System name of the media being synced EmuMoviesMedium - Arcade (MAME) for example
  23. Moved to HyperHQ Support forum
