Unknown50862 Posted February 28, 2014 Posted February 28, 2014 The static 16:9 themes do not have cart/boxart layers 3 and 4 set. I guess this is intentional as the Delux version does have the layers set correctly. So there will be a static version with wheel on the right and another version for outfading wheel and box/cartart displayed instead like in the 4:3 versions from gib? I don't have access to HyperSync, so I didn't have any artwork to work with when doing the system themes. I have some art that I manually grabbed from VSS, but only box sets for the systems on my setup. I figured it'd be best to leave it out, rather than halfass it by guessing where the artwork would fit. Plus I figured most people are going to tweak it a bit to match their gathered/preferred artwork anyway. Unifieid Megatheme - Themes, Extended (on-hold), Additional Systems, Wheels 1/Wheels 2, Fade, Bezels, Letter Packs, Pointers, Controller Icons My Hyperspin Setup
KlopjerO Posted February 28, 2014 Posted February 28, 2014 I don't have access to HyperSync, so I didn't have any artwork to work with when doing the system themes. I have some art that I manually grabbed from VSS, but only box sets for the systems on my setup. I figured it'd be best to leave it out, rather than halfass it by guessing where the artwork would fit. Plus I figured most people are going to tweak it a bit to match their gathered/preferred artwork anyway. Dude stop downplaying you're stuff. Its the shizzle Sent from my Nexus 7 using Tapatalk | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
PacMan7 Posted February 28, 2014 Posted February 28, 2014 Don't worry about it unknown because some people will have 2d or 3d boxes and your doing a great job.
jaZz_KCS Posted February 28, 2014 Posted February 28, 2014 Yeah let me rephrase that: Its good that you didn't include the artwork layers in the Static HD set. Because there will be as many ppl wanting to use it without art at all so that the wheel can stay fully visible (as discussed before). And the other half of the ppl who do want to use artworks will probably end up in using many different sets with diff. sizes and such so it wouldnt make sense to pre-set it. You did a good job because now everybody can choose how to use the "extra space" provided with 16:9 themselves.
bubsy54 Posted February 28, 2014 Posted February 28, 2014 Having artwork set in a theme doesn't really affect anything in terms of people wanting artwork or not. If artwork is included in the theme, it will only show if people place artwork in their folders. If they don't want artwork to show, they just don't put anything in their folder. As for different sizes of artwork I assume the problem would be size affecting placement.. I never had an issue with placement. I have had problems with the size of the artwork but once the artwork had been resized, I never had to change anything in the theme itself. sent from my galaxy s3 using tapatalk
ejfriis Posted March 11, 2014 Posted March 11, 2014 Any chance anybody has the background psd for NES in 1920x1080 that hasn't already been flattened? I'm looking for the tiled seals without the gradient background. All the psd files on the ftp I've found have been flattened, except one which is 1280x720. I want to darken the background a bit and add a little of that golden brown color that was in the original seal, for a more authentic 80s NES feel. I tried to tile the 1280x720 one, and I just couldn't get it right. My gimp skills are pretty terrible.
Unknown50862 Posted March 11, 2014 Posted March 11, 2014 Any chance anybody has the background psd for NES in 1920x1080 that hasn't already been flattened? I'm looking for the tiled seals without the gradient background. All the psd files on the ftp I've found have been flattened, except one which is 1280x720. I want to darken the background a bit and add a little of that golden brown color that was in the original seal, for a more authentic 80s NES feel. I tried to tile the 1280x720 one, and I just couldn't get it right. My gimp skills are pretty terrible. ~/Upload Here/gibbawho/--Unified Mega Theme--/Working/PSDs/nes-16x9.psd EDIT: Nevermind, that is the one you've already found. Sorry to say, but I don't believe there is one in a higher resolution. That one is the source. Unifieid Megatheme - Themes, Extended (on-hold), Additional Systems, Wheels 1/Wheels 2, Fade, Bezels, Letter Packs, Pointers, Controller Icons My Hyperspin Setup
dragon57 Posted March 11, 2014 Posted March 11, 2014 Ejfriis, check out the psd I just uploaded to my ftp directory. It seems to have all the layers intact.
ejfriis Posted March 11, 2014 Posted March 11, 2014 Ejfriis, check out the psd I just uploaded to my ftp directory. It seems to have all the layers intact. Thanks, but that is also the 1280x720 version. I realized today that the seal layer in that file actually is larger than the image anyways, so I was able to work off of that. I guess none of it matter anyways, because anything after 1024x768 is dropped, so those extra pixels I was after were for nothing. Oh well, live and learn.
Unknown50862 Posted March 11, 2014 Posted March 11, 2014 I guess none of it matter anyways, because anything after 1024x768 is dropped, so those extra pixels I was after were for nothing. Oh well, live and learn. Not exactly. If you use gibbawho's method of exporting through Flash, then the extra resolution will provide different results. Though the question is still up in the air on whether this provides an overall benefit. It seems, depending on your setup, will determine if things look better or worse. Unifieid Megatheme - Themes, Extended (on-hold), Additional Systems, Wheels 1/Wheels 2, Fade, Bezels, Letter Packs, Pointers, Controller Icons My Hyperspin Setup
gibbawho Posted March 18, 2014 Author Posted March 18, 2014 I've started a new thread for the Unified Mega Theme Extended (the new batch of themes with all the artwork options etc.) You can find it here. http://www.hyperspin-fe.com/forum/showthread.php?33008-Unified-Megatheme-Extended I'll still be watching this thread for non-extended chat.
gibbawho Posted March 18, 2014 Author Posted March 18, 2014 Does anyone have a Nintendo Famicom theme? Check my other thread
KlopjerO Posted May 16, 2014 Posted May 16, 2014 I recently animated your Famicom and super Famicom themes Gibbs, its in the approval section, | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
AshuraX Posted May 17, 2014 Posted May 17, 2014 Anyone to make animated background for ps2, and new gibbawho famicom? Thanks My WIP Projects :Bezel Project Mame Horizontal : https://imageshack.com/a/auM4/1 Mame Vertical : https://imageshack.com/a/jEM4/1 Cave full pack : https://imageshack.com/a/7eJ4/1 Capcom : https://imageshack.com/a/eIM4/1 Themes Neo Geo Full Theme Pack : https://imageshack.com/a/oeJ4/1Mega CD Boxart : new thread will come....My First Cab Build : http://www.hyperspin-fe.com/topic/1221-ashurax-mon-projet-ghouls-ghost-arcade-cab/
KlopjerO Posted May 17, 2014 Posted May 17, 2014 Anyone to make animated background for ps2, and new gibbawho famicom? Thanks I can do that, and mon amis did ou check the ftp ? I uploaded an animated super famicom theme. it's in the submission section of the unified megatheme folder. | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
teacworms Posted May 18, 2014 Posted May 18, 2014 Some of the wheel images seem to be corrupted on the FTP. Atari 2600 and Sega Saturn are the ones I noticed. I you look at their thumbnails, the images are getting clipped.
AshuraX Posted May 20, 2014 Posted May 20, 2014 Klopjero Hi, bro! I can't check your theme on the FTP but it's looks great, My computer is down ,but i was talking about nes gibbawho new background. Actually i have 3 missing animated background to have a fullset. pc engine, ps2 & this starnight nes background. ^^If you have the time to make them it could be perfectly. Thanks bro. My WIP Projects :Bezel Project Mame Horizontal : https://imageshack.com/a/auM4/1 Mame Vertical : https://imageshack.com/a/jEM4/1 Cave full pack : https://imageshack.com/a/7eJ4/1 Capcom : https://imageshack.com/a/eIM4/1 Themes Neo Geo Full Theme Pack : https://imageshack.com/a/oeJ4/1Mega CD Boxart : new thread will come....My First Cab Build : http://www.hyperspin-fe.com/topic/1221-ashurax-mon-projet-ghouls-ghost-arcade-cab/
KlopjerO Posted May 20, 2014 Posted May 20, 2014 KlopjeroHi, bro! I can't check your theme on the FTP but it's looks great, My computer is down ,but i was talking about nes gibbawho new background. Actually i have 3 missing animated background to have a fullset. pc engine, ps2 & this starnight nes background. ^^If you have the time to make them it could be perfectly. Thanks bro. Aww crap man, sorry to hear that Just got a brain wave for those starry nights, I could take the background, copy it.. flipt it and have it fade in and out so you get that starry twinkeling effect. I wonder how that will turn it.. will check that tonight. PC engine is done by the way.. PS2 is not.. and that starry night could be next | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
AshuraX Posted May 20, 2014 Posted May 20, 2014 Thanks very much bro! My WIP Projects :Bezel Project Mame Horizontal : https://imageshack.com/a/auM4/1 Mame Vertical : https://imageshack.com/a/jEM4/1 Cave full pack : https://imageshack.com/a/7eJ4/1 Capcom : https://imageshack.com/a/eIM4/1 Themes Neo Geo Full Theme Pack : https://imageshack.com/a/oeJ4/1Mega CD Boxart : new thread will come....My First Cab Build : http://www.hyperspin-fe.com/topic/1221-ashurax-mon-projet-ghouls-ghost-arcade-cab/
tmills Posted May 20, 2014 Posted May 20, 2014 Hi Guys im new to Hyperspin, been learning fast and have it all running except bezels, Fade and hyperpause. how do i set up the bezels from the megatheme pack? i place bezel folders in HyperLaunch\Media\Bezels and the ahk file in the corresponding module folder however when i run a game i get an error about BezelGUI() can anyone help or point me to some guides on bezels, fade and ahk code advice is much Appreciated!
rfancella Posted May 20, 2014 Posted May 20, 2014 Hi Guys im new to Hyperspin, been learning fast and have it all running except bezels, Fade and hyperpause.how do i set up the bezels from the megatheme pack? i place bezel folders in HyperLaunch\Media\Bezels and the ahk file in the corresponding module folder however when i run a game i get an error about BezelGUI() can anyone help or point me to some guides on bezels, fade and ahk code advice is much Appreciated! TMills, Hello and welcome to the Forums!!! Is the error this?? http://www.hyperspin-fe.com/forum/showthread.php?26394-Mess-Module&p=319725&viewfull=1#post319725 Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
tmills Posted May 20, 2014 Posted May 20, 2014 Hi Ron thanks for the quick reply, i will have a look into it and see if i can solve the issue. Tom
KlopjerO Posted May 20, 2014 Posted May 20, 2014 Thanks very much bro! PSSST | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
