@mydriaze
I consider the git install mandatory. If you ask for help on the forums others including me will ask you to update hyperlaunch and try again. When they say update they mean use git to update it. I never even directed you to get the hyperlaunch install from the download section in my guide. In fact I told you to get it using git. There is nothing difficult about it, I even consider the git install guide better than my guide (has more informative pictures).
@radiofrog
This sounds very specific to your setup, I suggest creating a new thread on your issue. In your new thread be sure to include the xml that you are using inside the forum code tags. If you have games that appear in your audit list (ignore the color) they should appear in the add list if they don't already appear in the list box above the green + and target buttons.
  ghutch92 said:
@mydriaze
Ok, I understand the point. What I don't understand is what GIT do (update?) exactly. I haven't done so much research to be honest at the moment about it. What I don't like, is the windows integration (yes, even with the "windows explorer" box unticked). But that's personal I guess. What's the difference between the HL install from the website and from the GIT software?
BTW, if you want me to do some screenshot in order to add it to your post on the first page, just let me know, I will be happy to help the others as you all did there with me.
Edited by Mydriaze
Excuse my English, i'm French. :) Razer Atrox Porn Pics
Hyperlaunch is made up of lots of small files, which get updated frequently. The updates are distributed through GIT as this is simpler than creating a new installer package every time.
HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/
The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/
HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php
Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/
Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
yes git is perfect if you have it setup right i had a problem in the past now i follow instructions properly i just reinstalled git and it now works perfectly
sig.png 100%
Please note:
This picture is not here anymore during the setup (I installed the 64bits version):
and the followiing step: "Now what we do is copy all the contents except the .git folder of the hyperlaunch-3 folder into the HyperLaunch directory "
There's no .git folder inside the hyperlaunch-3 folder.
There is a .git folder. It is a hidden folder.
I have a question. #16: when I went to Hyperlaunch => Settings - There was both a Global Emulators (Example).ini and a Global Emulators.ini existing. This is a first time setup. I am kind of stuck here. I also notice that the Hyperspin executable will not open to this point. Not sure if it should or shouldn't yet, but I am stuck because I don't know how to proceed on the Global Emulators.ini considering the duplication.
Check to see if the files are identical. If they are then SWEET. :)
Hola mucho no entiendo porque mi traductor no me traduce a mi idioma , quisiera saber porque no me funcionan los pinball me sale en el munitor un triangulo rojo y no puedo saber porque. Desde ya muchas gracias
Hi ghutch truely great post you did here.. i followed the installation guide and all went well for MAME, just on a sidenote even after following your guide to the T, i did end up getting some strange MAME Vadility error message upon running a game.... its only brief and does not stop me from playing the game but was a nag more than anything else...... there was no mention of a further step i needed to do to fix it which you might want to add to your instructions.
I had to rename the mame example.ini file in hyperlaunch/modules/mame directory
This resolved the error and all works fine now.... any idea's why this would of happened and why this fixed it ?
Cheers
Can I get help were do I find this section when tring to setup PcLauncher
"4.) Click on the Rom Settings tab in the module settings window. Click on the green plus sign and choose one of your games (this list is generated from your database, you must have 2 or more games in your database)."
I assume you don't know where the module settings are.
http://www.hyperspin-fe.com/forum/showthread.php?29481-How-to-install-HyperSpin&p=279513&viewfull=1#post279513
  Quote
26 ?) Oh wait I almost forgot, whenever any one says edit your module settings they usually mean open HLHQ click on your system, click on the big modules tab, highlight the module you are using, and then click on the Edit Global Settings button. A little bit more info can be found here & here.
  fr_303 said:
Thanks Heaps that helped ou alot, do I need to do anything special when installed Fix it Felix through this guide on PC Launcher
This question is specifically related to your setup and is therefore not a good question for this thread. I see you have already asked this question in another thread may I suggest continuing your question over there. http://www.hyperspin-fe.com/forum/showthread.php?33754-How-to-setup-Fix-it-Felix&p=314555#post314555
hi im a newbiie being following this guide to install hyperspin and totally stuck.
deleted my previous attempts and thought i was doing well until i got to the part where i was to edit the settings file in settings hyperspin its not there.
this all new to me and being scratching my head for days trying to figure what ive done wrong so if anybody could help would be greatly appreciated
meant to say couldnt find the settings ini file in settings hyperspin.
Edited by alexander64
missed out some info
  • 3 months later...
are you still having trouble with this? I can try and help you out.
Nice guide a suggestion to complete the text guide i also would se a step by step guide with pictures
A subforum for different emulators how installing would be nice instead of having all in one place go back forward
Like this
Forum: > How install emulators
Sub forum > Nintendo 8
Sub forum > nintendo 16
Sub forum > Nintendo 64
Edited by Zeaede
Like this
I'll be doing an install start to finish next week on a brand new win7 install, i can make a step by step video. anyone have any recommendations for software to record my live desktop while i do everything?
Camtasia.
I made a guide too for a from-the-ground-up installation of MAME and HyperSpin with joystick navigation. Check it out here:
When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing!
Current status of cabs:  0/5 working as desired :wallbash: :wallbash: :wallbash:
