46" / 30" / 19" widebody cabinet
chriz99
  • Replies 1.5k
Great stuff Chris! Sounds like you would need to modify the VPinmame table script. Is that how you are doing it now, or did you put a call to an external script?
Also, can you drive all of the cabinet lamps with just LED-wiz? I assume I need to wire in the switches to the ipac and bulb to the LED-wiz.
For START for example, I would need 2 wires to the ipac and 2 to the LED-wiz? Sorry, getting confused with the wiring. I have an ipac on order, but need to order the LED-wiz...
there is no need to modify the vpinmame table script. there is just a call to an external script.
you can drive everything in the lamp-, switch- and flasher/solenoid matrix with your ledwiz .
your example is right. 2 wires to ipac, 2 wires to ledwiz (to control the bulb)
cheers
chris
[sIGPIC][/sIGPIC]
Very, Very cool.
We should definitely set up a forum for this...
Once you know the button lights/topper lights, how much work is it to create the config?
Also,
I guess this is just something extra you added to Attack from Mars as I believe it does not have toppers?
the 3 topper lights are mainly for pinball flasher. every pinball has flasher, so you can emulate each color and viewing angle. they are so bright that it reflect to the playfield glass and to the whole room. amazing effect.
you have to see this in real.
cheers
chris
[sIGPIC][/sIGPIC]
I guess I dont fully understand what is meant by a pinball flasher...
shilmover, see this youtube video
look at 13 sec, 23 sec, 33 sec. You will see momentary red flashes for effect. This is a pinball flasher. All 90s pinballs to current day have flashers for effects.
Perfect! Got it... thx.
Great progress Chris !! Can't wait to see the details on how it works !
[TABLE=width: 500]
[TR]
[TD][/TD]
[TD=align: center]New project homepage: http://blog.pixelmagic.nl/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]LED-Wiz utility: http://pinball.pixelmagic.nl/ledwiz/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]Anyone want to buy my LEDwiz ??
[/TD]
[TD][/TD]
[/TR]
[/TABLE]
I only have solenoids for the flippers. I may just have to get some more for this.
Now you need my HyperDMD program...
BTW, did you get the replay solenoid working too?
yes, the original pinball replay knocker works! check out my second video at 1:56
your hyperdmd animation is awesome. I will try it :beer:
cheers
chris
[sIGPIC][/sIGPIC]
Nice! Missed that.
Thanks... Do you have access to the dropfolder?
I need to update it to the latest.
wow, very fast shipping! please post some pics and infos.
made just another short vid... to see the flasher illumination better...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/watch?v=wAGZvTXTPOc&hl=de_DE&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=wAGZvTXTPOc&hl=de_DE&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
cheers
chris
[sIGPIC][/sIGPIC]
No kidding. I figured 3+ weeks... :)
That video looks great!
Didnt get a spec sheet with them, so I need to figure out the voltages/pinouts/etc...
I think it was on the ebay page...
3W High Power RGB Led 6 Pins 1pcs
Red:Luminous Intensity: 40-50LM
Forward voltage: 2.0-2.5v
Forward current: 400mA
Green:Luminous Intensity: 50-60LM
Forward voltage: 3.2-3.6v
Forward current: 350mA
Blue:Luminous Intensity:15-20LM
Forward voltage: 3.2-3.8v
cheers
chris
[sIGPIC][/sIGPIC]
That's there, yes, but not the pinouts...
I am guessing that I need the following Resistors?
Red: 6.8 ohm, 2W
Green: 4.7 ohm, 2W
Blue: 3.9 ohm, 2W
at 5V?
Holy crap, those LEDs are bright... Not Chriz99-Rip-Your-Corneas-Out-Of-Your-Eyeballs bright, but bright.
Will wire something up tonight and see what it looks like...
