46" / 30" / 19" widebody cabinet
chriz99
hey Planning on ordering some relays and relay timer wondering how many ill need to got with the same setup as you?
1X knocker - relay
1X Gear motor -relay
1X Shaker motor - relay timer
1X Strobe- ??? (what would i need to drive this)
I also notice on your spreadsheet you had shaker motor 2X???
My Cabs
My Pin Cab Attack of the PINZ cab
My Racing Cab OutRun Racing
  • Replies 1.5k
for my setup you need
knocker - 1x blue standard relay
gearmotor - 1x blue standard relay
shakermotor - 1x blue standard relay AND 1x grey timer relay (off-delay)
strobe: 1x blue standard relay AND 1x grey timer relay (off-delay)
at the moment you can only set S, L or W to an ledwiz output, but we are working on mixing S/L/W. so you need only 1 ledwiz output for shaker.
cheers
chris
[sIGPIC][/sIGPIC]
Hi Chris,
Would it not be a good idea to design some sort of standard switch board for the interface ?
What i am thinking of is this:
3 or 4 type of boards with 6 channels each.
- first board switches 6 channels of 12 volts up to 1 amp or so by transistor
- second board same as first board, but with build in adjustable electronic timers (555) an max 1 amp
- third and fourth board basic the same as first and second, but uses board relays for higher amp switching
Maybe the design of boards 1-2 and 3-4 could be basicly the same, only with or without the timer element. Board 3-4 would be capable of switching high voltage (110~220v).
[TABLE=width: 500]
[TR]
[TD][/TD]
[TD=align: center]New project homepage: http://blog.pixelmagic.nl/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]LED-Wiz utility: http://pinball.pixelmagic.nl/ledwiz/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]Anyone want to buy my LEDwiz ??
[/TD]
[TD][/TD]
[/TR]
[/TABLE]
yes, that sounds very interesting. can you make a proto-board for testing?
we talked also about realizing a timer/strobo function via ledwiz/code and klaus is working on a pwm-board either (to drive the shaker with various intensity). maybe it works, maybe not :D let's do some pioneering and we'll see what the future brings.
I think for the meantime the plug and play relays are a good and working opportunity.
Hi Chris,
cheers
chris
[sIGPIC][/sIGPIC]
Hey guys, can someone doing a full cab setup like this let me know what colors/lengths/spools of wire they bought for the project? I'm at that point to start wiring things to switches and wanted to get what's best.
Thanks!
Spencer
Be carefull with the using 555 timers. I built a board using 555 timers and had over sensing due to EM from the relays. The circuits needs to placed far from the relays. Perhaps in the top part of the cab.
little update
Is there no other way then using this very large resistors ??
BTW, i wil check for a prototype of the generic switch boards, but my electronics supplier is moving, so it will have to wait a bit.
[TABLE=width: 500]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TD]
[TD][/TD]
[/TR]
[/TABLE]
those aluminium heatsink resistors are really oversized for 12v power-led usage, but i got it for an excellent price at ebay ;) so no harm in using :D
you can also try 9-11watt resistors via 12v or 5watt resistors via 5v to drive the cree leds.
good news about the prototype. can't wait to see it finished :five:
cheers
chris
[sIGPIC][/sIGPIC]
Do i see this good, do you have a visible metal bracket of the lcd tv ??
Time to fix that then, i used black electical tape with my 17" monitor, worked like a charm !
[TABLE=width: 500]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TD]
[TD][/TD]
[/TR]
[/TABLE]
That's h4ck3r's cab. I've seen it in person (mine is based on his as he got me hooked! Bastard! :D) and no metal visible when the glass and rails are on.
995...
I may have missed it in the almost 1000 posts of this thread, but has anyone come up with a supplier for a similar affordable shaker motor in the US?
** Love the LED mod on the dog!! ;-)
Its called a "bumble ball" Thats what im going to use
My Cabs
