HyperSearch
pietie
This app is terrific :)
Would be possible to add variable for alternate games wheel folder? I'm making a boxart theme and they look really bad in hypersearch...
[ATTACH=CONFIG]47432[/ATTACH]
This is actually a good idea.
Also, a fix for the keyboard for people on windows 8.
  • Replies 485
From pietie's profile last time he accessed hyperspin was 11-21-2014, just some days ago :)
Anyway I have a strange input issue even on windows seven... on my main rig everything works fine but on my htpc "left" go "up" so navigating trought systems is nearly impossibile (it works fine on the virtual keyboard). Pretty strange as basically i'm using the same software on both computers (w7 64bit on main rig and w7 32bit on htpc)...
  • 3 weeks later...
Is there a way to run the program as a sub wheel?basically it would have 3 searches by entering each wheel instead of using the keystroke. I finding it irritating to accidentally move the right shock stick to trigger the search. I'd prefer a wheel for hypersearch other then keystrokes. Is there a work around or how can I set this up?
The log window is supposed to pop up only the first time you launch hypersearch or when your hyperspin path in HyperSearch.exe.config is wrong
U trigger it by launch keys, open when pressing f1 or whatever it's set up by default. U just need to add the exe to the startup script. If u find a way to launch if via wheel, please let me know.
got it working but after I type say commando in and the click search it goes back to my main menu wheel and I don't no why anyone help please thanks.
It crashes for me every time I search it finds the game then says hyper search has stopped working and closes :(.
Hyper Helper Ready To Help
It works great for me. I just wish it was possible to have alternate wheelart locations similar to how it has alternate systemwheel images. Overall it is awesome.
Hi,i have just tried this for the 1st time,looks super duper but one thing i can't do is launch a game once i have searched and found the game i want to play,i have mashed the entire keyboard and the normal launching key doesn't work,it instead moves through the search to the letter Z as i have Z as my launch game key,i already have it set to arcade mode,any help would be great thank you.
to be sure .. i am getting ...
TriggerKey fired but HS is not the active window. in the log.
Can anyone tell me how to change the window size of hypersearch? I am using duel monitors which may be affecting it. It is just too big and I can only see about 75% of hypersearch. I imagine I need to change something in the styles file? Or perhaps the config. Any ideas would be greatly appreciated.
Hello thanks for this job, but I met a little probleme when I use Hypersearch, the logo of windows start is display when I use this app how can I hide this please?
Hello, anybody have met this problem?
any one know whats going on with this? still have the same problem with it crashing heres the log
23:29:03 Search trigger key from config: F3
23:29:03 Favourites trigger key from config: F4
23:29:03 Genre trigger key from config: F5
23:29:03 Hyperspin path: G:\Hyperspin
23:29:03 Hook installed succesfully
23:29:03 Hyperspin settings loaded from: G:\Hyperspin\Settings\Settings.ini
23:29:03 HL path: G:\Hyperspin\HyperLaunch\
23:29:03 CabMode: False
23:29:03 SearchDB: Parsing G:\Hyperspin\Databases\Main Menu\Main Menu.xml...
23:29:03 SearchDB: Found 59 entries in [Main Menu.xml]
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\HyperSearch\HyperSearch.xml
23:29:03 Found 1 entries
23:29:03 Removed: 0 (wheel filter), 0 (theme filter)
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\WoW Action Max\WoW Action Max.xml
23:29:03 Found 6 entries
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\Amstrad GX4000\Amstrad GX4000.xml
23:29:03 Found 25 entries
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\American Laser Games\American Laser Games.xml
23:29:03 Found 7 entries
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\Atari 2600\Atari 2600.xml
23:29:03 Found 608 entries
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\Atari 5200\Atari 5200.xml
23:29:03 Found 71 entries
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\Atari 7800\Atari 7800.xml
23:29:03 Found 59 entries
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\Atari Jaguar\Atari Jaguar.xml
23:29:03 Found 32 entries
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\Atari Lynx\Atari Lynx.xml
23:29:03 Found 74 entries
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\Bandai WonderSwan Color\Bandai WonderSwan Color.xml
23:29:03 Found 94 entries
23:29:03 SearchDB: Processing G:\Hyperspin\Databases\Bally Astrocade\Bally Astrocade.xml
23:29:04 Found 48 entries
23:29:04 Removed: 0 (wheel filter), 0 (theme filter)
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Commodore Amiga CD32\Commodore Amiga CD32.xml
23:29:04 Found 163 entries
23:29:04 Removed: 36 (wheel filter), 0 (theme filter)
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\ColecoVision\ColecoVision.xml
23:29:04 Found 140 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\DICE\DICE.xml
23:29:04 Found 14 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\GCE Vectrex\GCE Vectrex.xml
23:29:04 Found 23 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Nintendo Famicom\Nintendo Famicom.xml
23:29:04 Found 291 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Nintendo Famicom Disk System\Nintendo Famicom Disk System.xml
23:29:04 Found 67 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Nintendo Virtual Boy\Nintendo Virtual Boy.xml
23:29:04 Found 20 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Nintendo Entertainment System\Nintendo Entertainment System.xml
23:29:04 Found 791 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Super Nintendo Entertainment System\Super Nintendo Entertainment System.xml
23:29:04 Found 773 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Mattel Intellivision\Mattel Intellivision.xml
23:29:04 Found 141 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Magnavox Odyssey 2\Magnavox Odyssey 2.xml
23:29:04 Found 99 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Nintendo Wii\Nintendo Wii.xml
23:29:04 Found 6 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Nintendo 64\Nintendo 64.xml
23:29:04 Found 303 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Nintendo Game Boy\Nintendo Game Boy.xml
23:29:04 Found 532 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Nintendo Game Boy Color\Nintendo Game Boy Color.xml
23:29:04 Found 527 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\Nintendo Game Boy Advance\Nintendo Game Boy Advance.xml
23:29:04 Found 1037 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\NEC PC Engine\NEC PC Engine.xml
23:29:04 Found 159 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\NEC PC-FX\NEC PC-FX.xml
23:29:04 Found 62 entries
23:29:04 SearchDB: Processing G:\Hyperspin\Databases\NEC TurboGrafx-16\NEC TurboGrafx-16.xml
23:29:05 Found 104 entries
23:29:05 Removed: 0 (wheel filter), 0 (theme filter)
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Sega SG-1000\Sega SG-1000.xml
23:29:05 Found 73 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Sega Master System\Sega Master System.xml
23:29:05 Found 278 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Sega Genesis\Sega Genesis.xml
23:29:05 Found 781 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Sega CD\Sega CD.xml
23:29:05 Found 171 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Sega 32X\Sega 32X.xml
23:29:05 Found 33 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Sega Saturn\Sega Saturn.xml
23:29:05 Found 406 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Sega Dreamcast\Sega Dreamcast.xml
23:29:05 Found 347 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Sega Game Gear\Sega Game Gear.xml
23:29:05 Found 259 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Shooter Games\Shooter Games.xml
23:29:05 Found 25 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\NEC TurboGrafx-CD\NEC TurboGrafx-CD.xml
23:29:05 Found 46 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\NEC SuperGrafx\NEC SuperGrafx.xml
23:29:05 Found 5 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\SNK Neo Geo\SNK Neo Geo.xml
23:29:05 Found 144 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\SNK Neo Geo CD\SNK Neo Geo CD.xml
23:29:05 Found 90 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\SNK Neo Geo Pocket\SNK Neo Geo Pocket.xml
23:29:05 Found 10 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\SNK Neo Geo Pocket Color\SNK Neo Geo Pocket Color.xml
23:29:05 Found 42 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Taito Type X\Taito Type X.xml
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Zinc\Zinc.xml
23:29:05 Found 71 entries
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\PC Games\PC Games.xml
23:29:05 Found 16 entries
23:29:05 Removed: 8 (wheel filter), 0 (theme filter)
23:29:05 SearchDB: Processing G:\Hyperspin\Databases\Panasonic 3DO\Panasonic 3DO.xml
23:29:06 Found 216 entries
23:29:06 Removed: 0 (wheel filter), 0 (theme filter)
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\PopCap\PopCap.xml
23:29:06 Found 43 entries
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\Sony Playstation\Sony Playstation.xml
23:29:06 Found 1713 entries
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\Sony Playstation 2\Sony Playstation 2.xml
23:29:06 Found 28 entries
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\Sony PSP\Sony PSP.xml
23:29:06 Found 7 entries
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\Capcom Play System\Capcom Play System.xml
23:29:06 Found 24 entries
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\Capcom CPSIII\Capcom CPSIII.xml
23:29:06 Found 5 entries
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\Daphne\Daphne.xml
23:29:06 Found 17 entries
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\Sega Model 2\Sega Model 2.xml
23:29:06 Found 33 entries
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\Future Pinball\Future Pinball.xml
23:29:06 Found 0 entries
23:29:06 SearchDB: Processing G:\Hyperspin\Databases\VTech CreatiVision\VTech CreatiVision.xml
23:29:08 Search: full game list loaded in 4875ms. Game count: 11158
23:29:08 Favourites: Found 7 file(s).
23:29:08 Processing G:\Hyperspin\Databases\NEC TurboGrafx-16\favorites.txt...
23:29:08 Found 0 item(s)
23:29:08 Processing G:\Hyperspin\Databases\Nintendo Famicom Disk System\Famicom Disk System\favorites.txt...
23:29:08 Processing G:\Hyperspin\Databases\Nintendo Game Boy Advance\favorites.txt...
23:29:08 Processing G:\Hyperspin\Databases\Panasonic 3DO\favorites.txt...
23:29:08 Found 2 item(s)
23:29:08 Processing G:\Hyperspin\Databases\PopCap\favorites.txt...
23:29:08 Found 1 item(s)
23:29:08 Processing G:\Hyperspin\Databases\Sega Saturn\favorites.txt...
23:29:08 Search: Favourites list loaded in 47ms. Entry count: 2
23:29:08 Processing G:\Hyperspin\Databases\SNK Neo Geo CD\favorites.txt...
23:29:08 Search: Genere list loaded in 78ms. Genre count: 97
23:30:37 Using list: Normal
23:30:47 SearchMode: Contains
23:30:47 ERROR: System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
at HyperSearch.Util.StartProcess(String process, String args, Boolean log)
at HyperSearch.MainWindow.LEDBlinkGameSelected(String gameName)
at HyperSearch.Windows.GameSearchWindow.resultListView_SelectionChanged(Object sender, SelectionChangedEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Controls.ListBox.OnSelectionChanged(SelectionChangedEventArgs e)
at System.Windows.Controls.Primitives.Selector.SelectionChanger.End()
at System.Windows.Controls.Primitives.Selector.SelectionChanger.SelectJustThisItem(ItemInfo info, Boolean assumeInItemsCollection)
at System.Windows.Controls.Primitives.Selector.OnSelectedIndexChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at System.Windows.Controls.Primitives.Selector.set_SelectedIndex(Int32 value)
at HyperSearch.Windows.GameSearchWindow.systemSummaryListView_SelectionChanged(Object sender, SelectionChangedEventArgs e)
  • 3 weeks later...
  • 4 weeks later...
Regarding yout todo list, you asked if anyone had an idea how to constrain the search when in a wheel. My suggestion is to parse the LedBlinkey info. It should the wheel info when changing in and out of wheels.
Combine this with the EDS, you will be able to send info to HyperSearch and LEDBlinkey at the same time
Cheers.
http://www.hyperspin-fe.com/forum/showthread.php?t=39083
It takes searching to the next level.
Cheers
How is that better? Hypersearch looks like it belonged in hyperspin. This new tool looks like an add on. It might have better search functions but it doesn't feel like it belongs with the rest of hyperspin. Plus I really like the way hypersearch gives you a list of games with a video.
My only problem with hypersearch is that in Windows 8 the keyboard layout is messed up. If only there was a way to fix that.
I have to agree.
HyperSearch feels much more natural on a cab/big screen and integrates flawlessly with HyperSpin while HyperXMLSpin feels more like it's an external tool. Not to say it's useless, more like it's not for everyone, I think.
I use HyperSearch myself and am happy with it :)
It adds the option of searching and creating a wheel for that search. It's a feature that is missing...but I do miss the Hypersearch layout and video preview. Is there a reason you can't use both? Hypersearch for on the fly game search including video previews and hyperxmlspin for creating custom wheels?
