twmac Posted July 23, 2014 Posted July 23, 2014 Geez....Just when I thought I was all caught up with 153 If anyone compiles the new version post here! Whats New http://mamedev.org/releases/whatsnew_0154.txt MESS: Whats New http://mamedev.org/releases/messnew_0154.txt
BetaWolf Posted July 24, 2014 Posted July 24, 2014 MAMEUIFX is also updated to 0.154. http://mame32fx.altervista.org/home.htm
Jumpstile Posted July 24, 2014 Posted July 24, 2014 MAMEUIFX is also updated to 0.154.http://mame32fx.altervista.org/home.htm Noted. - J* How to rebuild your MAME ROM set using CLRMAMEPRO - Walkthrough HERE!
rfancella Posted July 24, 2014 Posted July 24, 2014 Wow... That is a pretty big update according to the changelog. Tons of work from the MAMEDevs! Thanks guys! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Agrajag Posted July 24, 2014 Posted July 24, 2014 It's a biggie alright. Got most of it sorted out last night and this morning but had to leave uT hashing the CHDs and go to work, so thank goodness for TeamViewer! HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
andy-andy Posted July 25, 2014 Posted July 25, 2014 So far it seems that the mame.ahk doesn't want to work with .154. Anyone else have that problem?
clownstyle Posted July 25, 2014 Posted July 25, 2014 So far it seems that the mame.ahk doesn't want to work with .154. Anyone else have that problem? I haven't tested as yet. Does anyone have a .154 xml file for hyperspin?
clownstyle Posted July 25, 2014 Posted July 25, 2014 Took 10 posts this time, not bad Hey, someone had to ask. Get on it !! I assume it can also be generated from the .dat file? Or do we loose some tags doing it this way?
marxkemp Posted July 25, 2014 Posted July 25, 2014 There it is! I was waiting on that xml question ? funny! Did somebody already asked for jumpstyle's magic? ?
brolly Posted July 25, 2014 Posted July 25, 2014 You'll loose tags plus the dat file alone won't tell you if a game is working or not. Anyway main problem is that catlist isn't updated since 0.152 so any new games need to be tested in order to get the genres right, this means an update to the XML might take a while this time unless someone volunteers to help checking them.
Jumpstile Posted July 25, 2014 Posted July 25, 2014 jumpstile is watching MAMEUIFX .154 builds have been uploaded. See thread here. - J* How to rebuild your MAME ROM set using CLRMAMEPRO - Walkthrough HERE!
Polemicist Posted July 26, 2014 Posted July 26, 2014 I haven't tested as yet. Does anyone have a .154 xml file for hyperspin? Took 10 posts this time, not bad Bahahaha... I managed to not say a word this time. Pretty funny. You'll loose tags plus the dat file alone won't tell you if a game is working or not. Anyway main problem is that catlist isn't updated since 0.152 so any new games need to be tested in order to get the genres right, this means an update to the XML might take a while this time unless someone volunteers to help checking them. Make a list of what you want checked... Share it with idiots like me, Gig, Ron etc. Sure we can sit down and play some games.
rfancella Posted July 26, 2014 Posted July 26, 2014 Here here! Would be glad to help out where I can! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
twmac Posted July 29, 2014 Author Posted July 29, 2014 Trying to compile mame 0.154 but cannot find no nag .154 diff anywhere? Help?
Malmanian Posted July 30, 2014 Posted July 30, 2014 Trying to compile mame 0.154 but cannot find no nag .154 diff anywhere? Help? Greetings! You can always find the latest hi-score/no-nag diff at the arcadecontrols forum (see direct url below), MKChamp keeps it up to date with the official MAME releaes. http://forum.arcadecontrols.com/index.php?topic=64298.0 ---- Note! For those of you that wish to manually ''remove the "nag-screens"/loading screens/rom-warning startup screens etc by editing the src\emu\ui\ui.c source, follow these simple instructions below: (this is useful for other versions of MAME that are not compatible with the diff above, for example MAME-Plus etc: *** STEP 1: EDIT (open with notepad): src\emu\ui\ui.c --->> Add the red line under the green lines as shown below: (I don't include line number since that sometime changes with each MAME version, use the search function and search for this exact spot) const int maxstate = 3; int str = machine().options().seconds_to_run(); bool show_gameinfo = !machine().options().skip_gameinfo(); bool show_warnings = !machine().options().skip_gameinfo(); int state; show_gameinfo = show_warnings = show_disclaimer = FALSE; // <--- this line removes error/warning screens *** STEP 2: EDIT (open with notepad): src\emu\ui\ui.c --->> REMOVES WHITE BOX & LOADING SCREENS DURING ROM STARTUP... In ui.c search for the red line below and delete all the 3 instances of the line machine().video().frame_update(); "AYBABTU" : All your base are belong to us!
Dime333 Posted August 3, 2014 Posted August 3, 2014 Catlist updated to 0.154. http://www.progettoemma.net/?catlist
brolly Posted August 3, 2014 Posted August 3, 2014 Ah, excellent! Thanks for the heads up, that will help.
Polemicist Posted August 3, 2014 Posted August 3, 2014 When ya ready give us a list. Heck I'm playing R-Type so why not catalog a list of other games.
brolly Posted August 3, 2014 Posted August 3, 2014 I will, but with the new catlist that list will probably be much smaller now!
