Min2001 Posted October 15, 2014 Posted October 15, 2014 Mame 0.155 is out today! Release: http://mamedev.org/release.html Whats New: http://mamedev.org/releases/whatsnew_0155.txt And by the looks of it theres a lot of fixed roms, including that of Raiden 2 and Raiden DX
rfancella Posted October 15, 2014 Posted October 15, 2014 Wow! Another big update! Wonder how many chd's? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Min2001 Posted October 15, 2014 Author Posted October 15, 2014 Quote Wonder how many chd's? Not many I hope those things take up way too much hdd space.
albert_c Posted October 15, 2014 Posted October 15, 2014 How soon after new MAME releases does MKChamp release his patch typically? When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
joe35car Posted October 15, 2014 Posted October 15, 2014 13 in total in new and renames. The big was in wontmuch chd. just under 3GB. 15.2 GB in new and renames.
dougan78 Posted October 16, 2014 Posted October 16, 2014 And gauntlet dark legacy looks like it is fixed!!
bandit721 Posted October 16, 2014 Posted October 16, 2014 Quote How soon after new MAME releases does MKChamp release his patch typically? Already posted... http://forum.arcadecontrols.com/index.php?topic=64298.0
albert_c Posted October 16, 2014 Posted October 16, 2014 Wasn't there earlier today but wow, that was fast. Now if the GroovyMAME guys follow suit, I'll compile away. When you find great deals on Craigslist for CRT based cabs, exuberance can be a bad thing! Current status of cabs: 0/5 working as desired :wallbash:
fifou Posted October 19, 2014 Posted October 19, 2014 Raiden 2 promoted from non working !!!! raaaaaaaaaaaaaaaaaaaaaaaat leaaaaast !!!!!
rdhanded2 Posted October 19, 2014 Posted October 19, 2014 Very cool My Tekken 3 pedestal conversionBasement Bar / Arcade
relic Posted October 20, 2014 Posted October 20, 2014 best news ever and zero team 2000 is another awesome game its liek cadlac and dinosaurs 100%
boot_sequence Posted October 20, 2014 Posted October 20, 2014 will this necessitate an xml for0.155? I see the .154 available in hyperlist
Polemicist Posted October 21, 2014 Posted October 21, 2014 boot_sequence said: will this necessitate an xml for0.155? I see the .154 available in hyperlist Shhh... Brolly will get to it. Doing them is very time consuming. And MESS was also updated. Dunno what you lot complain about with drive space. The MESS CHD and ROM set take up 1.4TB so a measly under 400 GB is chicken feed.
phulshof Posted October 21, 2014 Posted October 21, 2014 Polemicist said: Shhh... Brolly will get to it. Doing them is very time consuming. Creation of a new MAME XML file is time consuming? Does he create them by hand? I haven't taken a look at recent categorization used by HS, but if the catver.ini are still valid I could probably build them from the MAME output combined with the catver.ini. I'm just not sure if there's a new catver.ini file available yet. I've got a small Linux program to turn all MAME and MESS software lists into HS compatible XML files that I could update a bit to fit the needs of this community.
Polemicist Posted October 21, 2014 Posted October 21, 2014 Speak with Brolly. What goes in the XML is specific. What gets posted to HyperList is Brolly controlled. How it is made takes time and works perfectly every time. If you want the list instantly you can do whatever you like.
phulshof Posted October 21, 2014 Posted October 21, 2014 Polemicist said: Speak with Brolly. What goes in the XML is specific. What gets posted to HyperList is Brolly controlled. How it is made takes time and works perfectly every time. If you want the list instantly you can do whatever you like. I'm in no hurry. I was just wondering if he had to update everything by hand or not. If so, I'd happily lend a helping hand to automate some things. Edit: Just downloaded the 0.154 version. It appears there's more information in these XML files then there used to be, like the rating for instance. That's not information I have access to yet.
Polemicist Posted October 21, 2014 Posted October 21, 2014 catver.ini is part of it yes. Plus a bit of checking. I. Always look forward to the combination of a Brolly XML release and Jumpstile MameUIFX release combined. always puts a smile on my face. ?
brolly Posted October 21, 2014 Posted October 21, 2014 It's not a manual process, but does require some manual work because catver.ini genres don't match HS genres perfectly also ratings need to be added manually. There's no catver.ini for .155 yet so until then I probably won't be updating the XML since I don't have time to test the new games right now, if someone wants to do it I can try to put together a list of the games that need genres/ratings added. That's what requires more time on each database update.
