Ibanezmike Posted February 12, 2015 Posted February 12, 2015 Hey guys, I am currently building a hyperspin arcade machine that will be running MAME, NES, SNES, Sega, and a few other emulators. I was just wondering if anyone knows if you are able to make any emulators (other then MAME) require a coin to be able to play? I want to eventually put a real coin mech in my machine but at the moment I will only be putting a dedicated coin button. Thanks -Mike
Styphelus Posted February 12, 2015 Posted February 12, 2015 Why would you want to do that? Having such a machine in a public place would be highly illegal. Unless of course you like the hassle of having to look for coins every time you want to play.
strawdog Posted February 12, 2015 Posted February 12, 2015 I am considering this too, just get a stack of coins, unlock the door when you need more ;-) it will just make it feel more authentic I have yet to purchase this but i will once i have built my cabinet http://shop.xgaming.com/products/arcade-coin-door-with-coin-mech-ships
craiganderson Posted February 12, 2015 Posted February 12, 2015 Sounds cool.... We have a old authentic gumball machine in our house...takes real coins.....good stuff http://craigandersonthemes.weebly.com/
rfancella Posted February 12, 2015 Posted February 12, 2015 LOL... The way I have mine setup: Mounted a switch in conjunction to the coin eject button. Wired a three way switch into it and the coin trip switch. Flip the switch one way and you have to put a coin in. Flip it another way and you can just push the coin eject button to get a credit and flip it the third way and either works. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
stillcore Posted February 12, 2015 Posted February 12, 2015 Or easiest yet. Throw on Dragons Lair II and just dump a bag of quarters out the window.
HazzardActual Posted February 12, 2015 Posted February 12, 2015 stillcore said: Or easiest yet. Throw on Dragons Lair II and just dump a bag of quarters out the window. LOL, this all day long. I suggest doing it like Rfancella, other wise, just run the coin wire directly to your coin mech switch. Assuming you have one. Theres been a few threads about this in the past, its frowned upon if you're going to set this cab up in public. But its a pretty effective way of keeping your kids off of HS. Already spent your allowance? Too bad!
Styphelus Posted February 12, 2015 Posted February 12, 2015 Nothing like constantly rubbing coins that have passed through thousands of other people's hands, been on the floor, in people's pockets and who knows where else.
craiganderson Posted February 12, 2015 Posted February 12, 2015 If I had a cab....I would do the coin thing for sure..... http://craigandersonthemes.weebly.com/
Ibanezmike Posted February 13, 2015 Author Posted February 13, 2015 The arcade machine I am building is only for personal use, it will just be in my living room. I was asking weather you could set hyperspin up so the other emulators can take a coin before being able to play the game like MAME because I have 3 little kids who will be primarily using the machine and I wanted to make a kind of incentive for them to clean their room and all that fun stuff and get coins for the arcade machine in return. I have done a bit of research and I cant find anything that is going to work but it would be a good idea if the hyperspin guys could implement it in a future version of hyperspin.
32assassin Posted February 13, 2015 Posted February 13, 2015 you are actually asking for the rom to be modified, this is never going to happen. the only thing that is possible is the South American time limit arcade. Where you add a coin and you get X amount of time to play. Given that Hyperspin is intended for home use, A commercial version of hyperspin is probably never going to see the light of day.
maxxsinner Posted February 13, 2015 Posted February 13, 2015 If you go down the timer path which would be the easiest option, I would just feed the common of the Ipac or whatever through a time controlled relay. Coins buy your time on Hyperspin and games and when your time runs out, all controls stop working. Would be pretty easy to do with something like an Arduino or similar. Independent of the software that way too. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
maxxsinner Posted February 13, 2015 Posted February 13, 2015 Cheers HA. @Jeremy0203 I was only going off this - Ibanezmike said: I was asking weather you could set hyperspin up so the other emulators can take a coin before being able to play the game like MAME because I have 3 little kids who will be primarily using the machine and I wanted to make a kind of incentive for them to clean their room and all that fun stuff and get coins for the arcade machine in return. Sounds to me like he is looking for a way to lock the machine out without coins. Considering there is basically no other option.... Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
Ibanezmike Posted February 13, 2015 Author Posted February 13, 2015 I will have a look into the timing method because it seems thats about the only way to go, thanks for everyones input.
maxxsinner Posted February 13, 2015 Posted February 13, 2015 If you need a hand with the circuit to do the timing, just let me know and I will see what I can do. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
ghutch92 Posted February 13, 2015 Posted February 13, 2015 If you don't want to put a time limit on the play time once the start, you can stick a program between hyperspin and hyperlaunch that intercepts the communication between the two. This program could then ask for coins before starting hyperlaunch. It would honestly suck to be playing a game that can't save and be near the end and then have it suddenly quit because of the time limit thing. How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
rfancella Posted February 13, 2015 Posted February 13, 2015 ghutch92 said: If you don't want to put a time limit on the play time once the start, you can stick a program between hyperspin and hyperlaunch that intercepts the communication between the two. This program could then ask for coins before starting hyperlaunch. It would honestly suck to be playing a game that can't save and be near the end and then have it suddenly quit because of the time limit thing. Just a thought. Could you remap the start button to the coin switch? Or set the coin switch to pass a password and set the launch to be password protected? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Maggus Posted May 6, 2018 Posted May 6, 2018 I put two coin slectors (from hollandcomputers.com) in my arcade. HS Arcade Classics uses those slots. It is fun when we have a party. 25ct a game. Whoever has the highscore on pac-man and centipede get half each of all coins. I just wish I could program HS or Arcade classics that slot one is 1 game per 10ct coin and slot 2 is 3 games per 25ct coin.
