46" / 30" / 19" widebody cabinet
chriz99
A few questions:
- Can Solenoids and lamps be used on the same input? For example: ,S12,S14/L15,S21. I get an error
- Is it possible to get the LEDWiz to light up lights outside of the ROM? I would like the start/flipper buttons to be lit in the HyperPin menu too.
- How do I get different colors? For example, if I want the center light to be purple?
Edit: Reading manual now... :D
  • Replies 1.5k
A few questions:
not yet, at the moment only S or W or L input.
yes thats possible, check out the hyperpin-files inside the tutorial
via rgb led you have to set it as follows
Blue=0,0,ON
Green=0,ON,0
Cyan=0,ON,ON
Red=ON,0,0
Magenta=ON,0,ON
Yellow=ON,ON,0
White=ON,ON,ON
cheers
chris
[sIGPIC][/sIGPIC]
Thanks
Looking... Where in the files? FPLaunch.ahk?
Blue=0,0,ON
Green=0,ON,0
Cyan=0,ON,ON
Red=ON,0,0
Magenta=ON,0,ON
Yellow=ON,ON,0
White=ON,ON,ON
That I got, but we are limited to just these 7 colors?
Thanks
search for hpledcontrol exe/ini in the tutorial.
at the moment you can use pwm-colors only for flipperbuttons
for example (ON Orange)
Black=5,5,5
White=48,48,48
Red=48,0,0
Yellow=48,48,0
Orange=48,24,0
Lime=0,48,0
Green=0,24,0
Cyan=0,48,48
Blue=0,0,48
Purple=12,0,24
Violet=24,0,48
Magenta=48,0,48
Brown=24,12,0
pwm-flashercolor is a feature for the next version.
cheers
chris
[sIGPIC][/sIGPIC]
So I figured out that i need to launch HPLedControl.exe nit HyperPin.exe. That want clear in the tutorial.
now my flipper buttons flash white. Any way to change the color in hyperpin?
Compliments on the work done guys ! Need to order my led-wiz fast ;)
One small tip, maybe make 1 zip file with different dir's with all needed files in it and convert the .doc to a pdf ? If you want i can do that.
Erwin
[TABLE=width: 500]
[TR]
[TD][/TD]
[TD=align: center]New project homepage: http://blog.pixelmagic.nl/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]LED-Wiz utility: http://pinball.pixelmagic.nl/ledwiz/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]Anyone want to buy my LEDwiz ??
[/TD]
[TD][/TD]
[/TR]
[/TABLE]
I paid 60 euros for my stroboscope at ebay. it's a 230v/1500w strobe which can be manually adjusted in speed (via pot).
what type of input? the similar ones i have seen required a DMX input (3 pins) how does yours wire up?
CNC Work Here.....
I think I blew up my Power Supply... :(
I was testing the LEDs (9 of them; 3 on the top, 3 on the left, 3 on the right). Looked great! My kid loved them :D
I then switched from AFM to MM and none of the lights came up. Green LED on the Power Supply is off. Need to figure out what happened...
it's an analog (no dmx) stroboscope with a pot for manually adjusting the flasher speed. you need a timer-relay to drive it with your ledwiz. a friend of mine (electrician) did the strobe setup here, because I play not with high volt current.
cheers
chris
[sIGPIC][/sIGPIC]
I use these relays http://www.hyperspin-fe.com/forum/showthread.php?p=97319#post97319
in short: it's the same config like the shaker-motor. the ledwiz switches a (blue) standard 12vdc relay which switches a 12vdc timer relay (grey). the timer relay switches the 230v stroboscope for a predefined time.
for your own safety please let an electrician do this setup. my friend can not give a wiring diagram for high volt current.
cheers
chris
[sIGPIC][/sIGPIC]
ok. Did not blow up the Power Supply... :dancing2:
one of the +12v leads on one of the LEDs was ever so slightly sticking out beyond the bottom of the wood rail the are sitting in. That caused it to short against the frame of the PF LCD. Fixed now... :)
Hey Chris,
Having an issue that I am hoping you can help me with...
I have the Left slingshot mapped to input 9 and it works perfectly. I have the Right slingshot mapped to input 10 and it does the following.
In LEDBlinky (just as a test), when i turn input 10 on, it works perfectly... relay fires as does the solenoid.
In AFM, MB, & MM; shortly after the game initializes, the right slingshot activates and stays on. Does not turn off until I exit the table and reset it.
With CV; the Right slingshot never fires. Even in the test menu. Left slingshot works perfectly, right one does no.
Thoughts?
Now to decide UVP or not to UVP!...:(.. Seems like the LEDWIZ software and UVP dont like each other. there is considerable down and lag... Looks like Bye to UVP for now id rather have butter smooth gameplay and FF then just a blinking back glass.
and my system is rocking
Im running i5 760 Overclocked to 3.7hz
GTX 280
GTX 260
and all my software is optimze set affinity and ive gone into the system start up and turned off resources.
My Cabs
My Pin Cab Attack of the PINZ cab
My Racing Cab OutRun Racing
Yeah ive decided the LEDs are going to take over anyways. I would love a animated backglass but im not about to fork out $$$ for an i7 or faster :(
Besides the LEDWIZ is bringing VP to a new level anyways. I might just try and find some Backglass images. All i know is UVP and LEDWIZ code dont mix. Toss hyperpin into the mix and theres alot of stuff running at once.
My Cabs
