  • 0
support multi sub wheels on main menu ?
relic
Question
hi is there a guide or something i could follow to do this in english as im very interested in this technique and it would be handy to have in the future maybe even possible to add onto hyperspin 2.0 release if we ever figure it out thanks regards relic.
salut est -il un guide ou quelque chose que je pourrais suivre pour le faire en anglais comme im très intéressé par cette technique et il serait utile d'avoir à l'avenir peut-être même possible d'ajouter sur Hyperspin version 2.0 si jamais nous le découvrir grâce Cordialement relique .
heres what im refering too if you dont know
sig.png 100%
  • Answers 98
"theres is just a rip off version of ours."
What do you mean by this? Are you saying there's a different working version of it?
i mean the french one is very simlar in  a way sept its using java but has hyper spin exe to run it
but if you guys want to try it out i found this page with links maybe this will work better http://www.arcadepunk.co.uk/****************-hyper-free-spin-something-french-dont-know/
recommended use jdownloader to grab all links in 1 go - http://jdownloader.org/
sig.png 100%
This would be great for adding tv shows and video game related internet videos to my emulator/media box under my t.v.
T.V/Internet>AVGN>Episode 1, 2, 3......
yeah when i
Did anyone get this to work?
I haven't been able to follow the instructions.
test
yeah when i tested it it was very buggy like the themes didnt fit in place for starters and i couldent get the multiwheel option or any of it to work i think the best thing to do is use the source and code into it for our own frotend which is the orginal theres is just a rip off version of ours.
sig.png 100%
Here's the link:
mega:///#F!lVoWjDYb!7IXPvCwDJ9HPblcMadytfg
Copy/paste it. I tried to create a link but it doesn't access the site.
For convenience...
Mega with the config that I created for Homayonahmade
https://Mega.co.nz/#F! lVoWjDYb! 7IXPvCwDJ9HPblcMadytfg
inside the folder you'll find
Start HyperSpin.exe program to launch at startup
multi wheels.exe program which fill has the fly the correct file in the right place
the folder setting
the databases folder
the configuration folder
in the configuration folder we find the Wheels folder that contains it the folder Box1
These in this box1 folder that we will find all the files sub Wheels
In this case we will create a folder for each wheel sub we created
Let's take as an example the AMIGA folder
Inside we find the Menu.xml hand that contains systems Commodore Amiga CDTV-Commodore Amiga CD32
We also find the file parametre.ini
If we edit the parametre.ini file we find inside
Consoles: these system parent
followed by a space and Box1: these folder or we sum
and still followed by a space and ecran1: is not used but a master, his served for a screen configuration
If we look into the Menu.xml hand of the parent wheel, therefore in the console folder
We find well our AMIGA entry
and in the parametre.ini file
We find wheels which is the first wheel of the system
then in the settings folder we find each created sub wheel name ini file
Let's take the example with the AMIGA system
We will edit the file AMIGA.ini
the line that interests us sound
exe = Multi Wheels.exe: my Multi Wheels program has run
parameters = AMIGA Box1 ecran1: la these every single one puts the name of the system
to do with all the system you want to add
However never master two identical system name
then by launching multi wheels.exe
You can activate multi wheel
by activating a backup of the main menu.xml of origin will be save
and replaced if deactivate you the function
for images of the wheel sub simply masters in media/hand wheel-images-menu
and the themes in media/main menu/Themes
good evening to all and good test
Thanks dude!
supermomo93
Connoisseur
Connaisseur
Can someone try my zip file? That's not the Spanish version of things, it's an exe I got from the ftp I think she I was helping identify useful apps
I believe knewlife made this application. For those wondering what it does :
it lets you change your main menu filtering the entries based on the year and genre (type of system)
Hi,
those guys are spanish, not french. I'm not sure french are using this method, even on the french site. You should contact a spanish guy on youtube to ask him. In europe, the hyperspin community is active but they don't work and share here. I don't understand that... United, we could be stronger... But now, we have to surf on many website to find stuffs. It's not centralized. Too bad :(
Really? Search which other sites? For what? Themes and other art things?
i didnt make it the spanish did and the french seem to have a diffrent method compared to the spanish type
but to find out there guide you have to go on the french site and i think you have to register as well ill post a link so you guys can check the diffrence between them -
http://forum.just follow the title of the vid to find the site.fr/tutos-pour-hyperlaunch/multi-wheel-hyperspin-est-possible-t3041.html
sig.png 100%
Hi,
well even the french know how to do it so there must be a more simple way to solve this perhaps a program could be made for doing this trick like an old switcharoo addon you could use some app which duplicates programs and links them in together
sig.png 100%
I never figured out how they did it but I know what they did. This is the case of opening multiple instances of hyperspin. It's like a hyperspin within a hyperspin. I'm following this thread cuz I never got to doing this and I too would like to get the steps
Okay, so your asking if a future release would allow a three layered wheel tree(System type list, Specific System list, Games) instead of the current two layer (Main Menu of Systems and Games).  This would be interesting.
Ya that would be great. I've always been looking for a way to have a main menu which has a console wheel, computer wheel, arcade wheel, handheld wheel etc. then once you click it, you would see all the systems and you could choose accordingly. Does the new app that you are working on account for this?
