ci2own Posted March 30, 2016 Share Posted March 30, 2016 Wish I could but seeing how this is my only PC makes it hard I use it on windows 10 with no problem. Maybe you could try it with windows xp compatibility mode (to try something different). I have no more ideas. Link to comment Share on other sites More sharing options...
lilg1983 Posted March 30, 2016 Share Posted March 30, 2016 I use it on windows 10 with no problem. Maybe you could try it with windows xp compatibility mode (to try something different). I have no more ideas. running the update for it now if it doesn't work then I will try in compatibility mode for xp or 7 Link to comment Share on other sites More sharing options...
JayC Posted March 30, 2016 Share Posted March 30, 2016 I wouldn't count on the XP compatibility mode since HBL isn't designed nor officially supported for XP. Something weird is shurely going on since most of us haven't had any problem with the program. Have you checked your firewall/ settings? Maybe you or your ISP are blocking the connection? Link to comment Share on other sites More sharing options...
lilg1983 Posted March 30, 2016 Share Posted March 30, 2016 I wouldn't count on the XP compatibility mode since HBL isn't designed nor officially supported for XP. Something weird is shurely going on since most of us haven't had any problem with the program. Have you checked your firewall/ settings? Maybe you or your ISP are blocking the connection? let me check I will add a exception to my firewall to allow the connection see if that helps thank you everyone for your help Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted March 30, 2016 Author Share Posted March 30, 2016 Here are a couple of debugging steps: with the app launched and the loading screen showing, go to your web browser and type "http://localhost:9000". It should respond with " Cannot GET /". if not, you either need to allow that port on your firewall or another app is using it in file explorer, go to "C:\Program Files (x86)\Hyperbase\Hyperbase Live\core\resources\app\server" and make sure there is a settings.json file. if not, create one with just "{}" without quotes. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted March 30, 2016 Author Share Posted March 30, 2016 I'm 100% sure that my settings file is there when this occurs as I've checked that. The next time it happens I'll check to see if another app I'm running is using that port. It happened this morning but a reboot solved it, which would make sense if there was indeed another process using the port. Also make sure the app didn't forget to close a process. AKA kill all hyperbaselive.exe in process monitor Link to comment Share on other sites More sharing options...
lilg1983 Posted March 30, 2016 Share Posted March 30, 2016 Here are a couple of debugging steps: with the app launched and the loading screen showing, go to your web browser and type "http://localhost:9000". It should respond with " Cannot GET /". if not, you either need to allow that port on your firewall or another app is using it in file explorer, go to "C:\Program Files (x86)\Hyperbase\Hyperbase Live\core\resources\app\server" and make sure there is a settings.json file. if not, create one with just "{}" without quotes. ok went to the address and got the message Cannot GET then went to hyperbase\hyperbaselive\core\app\server there is a file settings.json Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted March 30, 2016 Author Share Posted March 30, 2016 ok went to the address and got the message Cannot GET then went to hyperbase\hyperbaselive\core\app\server there is a file settings.json PM me. I need to take a look at the machine. Link to comment Share on other sites More sharing options...
lilg1983 Posted March 30, 2016 Share Posted March 30, 2016 PM me. I need to take a look at the machine. just messaged you hope I did it right Link to comment Share on other sites More sharing options...
nogarth Posted March 30, 2016 Share Posted March 30, 2016 only thing i have spotted a few times is when one completes syncing the others just die. took the basic Hypersync install 1.3.3 added the first 3 databases. Atari 5200, Lynx and Daphne once daphne had finished it just hung. Processes are still running. hbl.txt Link to comment Share on other sites More sharing options...
JSinn Posted March 30, 2016 Share Posted March 30, 2016 Hi All, we are looking to re-brand the HyperBase Live logo. Any one of the artists here specialize in logo design? If anyone is interested in tackling this please PM me. We are looking for it to be done with material design in mind. Something that looks good both in color and B&W. I would ask JayC but I know he is busy creating the banners for the app. I'd nominate THK, he's the best logo designer that I've seen. That's if you can motivate him. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted March 30, 2016 Author Share Posted March 30, 2016 only thing i have spotted a few times is when one completes syncing the others just die. took the basic Hypersync install 1.3.3 added the first 3 databases. Atari 5200, Lynx and Daphne once daphne had finished it just hung. Processes are still running. hbl.txt Screenshot 2016-03-30 18.54.10.png I'll add Daphne and check in a bit. Could be bad data. Sent from my SM-G935T using Tapatalk Link to comment Share on other sites More sharing options...
nogarth Posted March 31, 2016 Share Posted March 31, 2016 still same kicked off at 5 this morning and at 6:30 stopped left it all day thinking it might pick up with no update to log but front end looks likes its running still Link to comment Share on other sites More sharing options...
THK Posted March 31, 2016 Share Posted March 31, 2016 I'd nominate THK, he's the best logo designer that I've seen. That's if you can motivate him. That logo has been bothering me a bit from the beginning. I'll have s stab at it and hope I'll come up with something better. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted March 31, 2016 Author Share Posted March 31, 2016 still same kicked off at 5 this morning and at 6:30 stopped left it all day thinking it might pick up with no update to log but front end looks likes its running still Yeah if it doesn't work in the first few minutes, an hour and a half is not gonna fix that. Link to comment Share on other sites More sharing options...
THK Posted April 1, 2016 Share Posted April 1, 2016 If HyperBase Live was electronic music xD Link to comment Share on other sites More sharing options...
THK Posted April 1, 2016 Share Posted April 1, 2016 I know just started sketching a bit for a design and a bit of my good ol' graffiti drawing habits came bubblin' up Link to comment Share on other sites More sharing options...
THK Posted April 1, 2016 Share Posted April 1, 2016 just couldn't resist paying a bit in AI Link to comment Share on other sites More sharing options...
scooter1974 Posted April 1, 2016 Share Posted April 1, 2016 If HyperBase Live was electronic music xD So it's settled then. This is the official logo[emoji14]Sent from my SM-T210R using Tapatalk Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted April 1, 2016 Author Share Posted April 1, 2016 OMG. Well I have to say, that is an intense logo for sure. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted April 1, 2016 Author Share Posted April 1, 2016 As far as an app icon, what do you guys think about just using the Sync button from the app? Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted April 1, 2016 Author Share Posted April 1, 2016 something like this Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted April 1, 2016 Author Share Posted April 1, 2016 or maybe this Link to comment Share on other sites More sharing options...
JSinn Posted April 1, 2016 Share Posted April 1, 2016 My vote is the first one (post #261) Link to comment Share on other sites More sharing options...
ci2own Posted April 1, 2016 Share Posted April 1, 2016 Hi! I have to say my HyperBase Live doesn't sync good either. I have selected only MAME to sync and it stucks in cashquiz.png for more than 5 hours. Where can i look for to try to find the problem? Thanks in advance! Link to comment Share on other sites More sharing options...
