fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 The exe is an installer... Not the app. It'll generate a desktop shortcut. Use that to launch the app after the first time.Sent from my Pixel XL using Tapatalk Link to comment Share on other sites More sharing options...
jtb1987 Posted February 5, 2017 Share Posted February 5, 2017 9 hours ago, fr0stbyt3 said: That's my team, yes. I'll ask the guys if they're doing any maintenance. It's definitely not me. Did this just happen? Sent from my Pixel XL using Tapatalk It looks like Hyperlist is still down: http://hyperlist.hyperspin-fe.com/ Link to comment Share on other sites More sharing options...
jtb1987 Posted February 5, 2017 Share Posted February 5, 2017 To use the hyperbase live program...is the connection to emumovies down? I can login to emumovies fine from the emumovies website or from hypersync, but when I try to login to emumovies via hyperbase, it says incorrect username/password. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 To use the hyperbase live program...is the connection to emumovies down? I can login to emumovies fine from the emumovies website or from hypersync, but when I try to login to emumovies via hyperbase, it says incorrect username/password.I'm going to release 0.0.21 shortly. That should fix the issue for you.Sent from my Pixel XL using Tapatalk Link to comment Share on other sites More sharing options...
maabus Posted February 5, 2017 Share Posted February 5, 2017 8 hours ago, fr0stbyt3 said: The exe is an installer... Not the app. It'll generate a desktop shortcut. Use that to launch the app after the first time. Sent from my Pixel XL using Tapatalk I know its the installer, but my issue is it doesn't install anything. After running it the first time, and then closing the program, all that's in the folder that I ran the installer from is is the installer. Does it install to some default folder? I checked my hyperspin folder and it was not in there either. Unless it is installing somewhere that I don't know of, it just runs, and doesn't install for me. Link to comment Share on other sites More sharing options...
oldhag270 Posted February 5, 2017 Share Posted February 5, 2017 It should install to your default folder,which is usually on your C: drive.Program Files or Program Files (x86) Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 Just now, maabus said: I know its the installer, but my issue is it doesn't install anything. After running it the first time, and then closing the program, all that's in the folder that I ran the installer from is is the installer. Does it install to some default folder? I checked my hyperspin folder and it was not in there either. Unless it is installing somewhere that I don't know of, it just runs, and doesn't install for me. I am installing it somewhere you don't know about. You'll find the super secret hiding place at %LocalAppData%\HyperbaseLive Link to comment Share on other sites More sharing options...
gigapig Posted February 5, 2017 Share Posted February 5, 2017 2 hours ago, jtb1987 said: It looks like Hyperlist is still down: http://hyperlist.hyperspin-fe.com/ Yes correct, we are aware of the problem and looking into it. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 2 minutes ago, oldhag270 said: It should install to your default folder,which is usually on your C: drive.Program Files or Program Files (x86) I deprecated that as some users were having permissions based issues. Link to comment Share on other sites More sharing options...
oldhag270 Posted February 5, 2017 Share Posted February 5, 2017 Just now noticed that,keep up the good work. Link to comment Share on other sites More sharing options...
maabus Posted February 5, 2017 Share Posted February 5, 2017 Ok found it... Stupid me.. there was a desktop shortcut, but I never went to the desktop i was working out of my directories. In the root appdata\hyperbase folder there is a hyperbase live exe. I ran that one and it behaved like the installer. I ran the exe in the app-.20 and that one worked. What is the exe in the root for? Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 2 minutes ago, maabus said: Ok found it... Stupid me.. there was a desktop shortcut, but I never went to the desktop i was working out of my directories. In the root appdata\hyperbase folder there is a hyperbase live exe. I ran that one and it behaved like the installer. I ran the exe in the app-.20 and that one worked. What is the exe in the root for? It's a bootstrapper. It handles the updates and launch of the app. It also assures your shortcut doesn't have to change every time an update runs. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 So has sync been snappy for everyone? Have you got your intended data? Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 Also, there seems to be some style bugs in the latest build. I'll fix those in 22. (see version number placement) Link to comment Share on other sites More sharing options...
oldhag270 Posted February 5, 2017 Share Posted February 5, 2017 Seems to be syncing fine with me. Link to comment Share on other sites More sharing options...
oldhag270 Posted February 5, 2017 Share Posted February 5, 2017 One thing I did notice is when I add another system or console,I need to do it again for it to show up in the main window. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 Just now, oldhag270 said: One thing I did notice is when I add another system or console,I need to do it again for it to show up in the main window. Hmm, try this. Add a system, then hit sync. See if it pops up. I'll look at that on my end now. Link to comment Share on other sites More sharing options...
oldhag270 Posted February 5, 2017 Share Posted February 5, 2017 After I hit sync it shows up. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 1 minute ago, oldhag270 said: After I hit sync it shows up. Yeah... looks like I need to update the service that handles that. I'm refreshing it before the data is there. Nice catch! Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 BTW, you guys are saints for not complaining about the add console dialog. It's on the list of things to clean up. Link to comment Share on other sites More sharing options...
jtb1987 Posted February 5, 2017 Share Posted February 5, 2017 Hi @fr0stbyt3 I'm trying to install and use Hyperbase as it doesn't seem like Hypersync is working for me anymore and I get this far: 1. I install the 64bit version from your first page in this thread 2. I login to the first main screen 3. I set the path to my Hyperspin folder 4. I try to login to emumovies but it will not connect (says incorrect username/password) 5. I click view all, but it's just a blank screen 6. I click sync all, but it just hangs Hoping you can bounce me back in the right direction... I'm trying to setup my systems wheel for the first time, grouped by arcade manufacturer and having a hard time getting the wheel art and emumovies synced for certain systems (sega classics, nintendo classics) - where originally using Hypersync DID work for other systems, ex. SNK Classics. It also seemed to work fine for the full mame list (Hypersync). Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 9 minutes ago, jtb1987 said: Hi @fr0stbyt3 I'm trying to install and use Hyperbase as it doesn't seem like Hypersync is working for me anymore and I get this far: 1. I install the 64bit version from your first page in this thread 2. I login to the first main screen 3. I set the path to my Hyperspin folder 4. I try to login to emumovies but it will not connect (says incorrect username/password) 5. I click view all, but it's just a blank screen 6. I click sync all, but it just hangs Hoping you can bounce me back in the right direction... I'm trying to setup my systems wheel for the first time, grouped by arcade manufacturer and having a hard time getting the wheel art and emumovies synced for certain systems (sega classics, nintendo classics) - where originally using Hypersync DID work for other systems, ex. SNK Classics. It also seemed to work fine for the full mame list (Hypersync 7 So HBL 0.0.21 is released now, so switch to that. 32bit: http://hyperbase-live.com/updates/win32/Hyperbase Live Setup 0.0.21-ia32.exe 64bit: http://hyperbase-live.com/updates/win64/Hyperbase Live Setup 0.0.21.exe Emumovies is completely broken in 0.0.20 Link to comment Share on other sites More sharing options...
jtb1987 Posted February 5, 2017 Share Posted February 5, 2017 Hi @fr0stbyt3 It looks like the issue is still here - It now reads that it's version .21, but it says incorrect username and password when I try to login to the emumovies part. The same username/password works directly on the emumovies website (I double checked!) Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted February 5, 2017 Author Share Posted February 5, 2017 4 minutes ago, jtb1987 said: Hi @fr0stbyt3 It looks like the issue is still here - It now reads that it's version .21, but it says incorrect username and password when I try to login to the emumovies part. The same username/password works directly on the emumovies website (I double checked!) Hmm, it's working fine for my username. thats odd.... You might be locked out of the API for too many failed login attempts. I don't think that would stop you from being able to log into the site. (if that is the case, give it a few hours and it'll work) Can anyone else sync emumovies? Link to comment Share on other sites More sharing options...
JoeC3109 Posted February 5, 2017 Share Posted February 5, 2017 Emumovies isnt working for me either Link to comment Share on other sites More sharing options...
