Howler Arcade Controller is now LIVE on Kickstarter!
engg100
Hello everyone,
The Howler Arcade controller is now live: Check it out on Kickstarter:
http://www.kickstarter.com/projects/2034467396/howler-arcade-controller
Here is the Video:
http://www.kickstarter.com/projects/2034467396/howler-arcade-controller/widget/video.html
Here are a few details:
The Howler Arcade Controller is a 4 joystick, 26 button, gamepad controller, keyboard controller, mouse controller, 96 channel LED driver USB composite device designed for interfacing to controls on a home arcade system.
Thanks,
Josh
  • Replies 59
Looks cool, but too bad I have 36 buttons (not including directionals) on my cpanel, which that thing only supports 26. I wonder why he stopped at 26?
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
I actually just emailed him asking if there would be other versions available with more buttons or a shift function or anything.
Heh, so did I :P
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Hey guys, the reason there is only 26 buttons is because the board would be HUGE with more than that. I am using spring pin connectors and in order to have an RGB LED for each button and joystick there are more than 150 connections!!! The good news is that you can have multiple boards in a system. I plan on supporting up to 4 boards. The test system I show in the picture is actually running 2 boards in it so I can ensure that multiple boards are working properly.
If you guys have any other questions or concerns let me know! and thanks for your support, the Hypersin community is GREAT!
Also, only up for 8 hours and already at 14% of funding! I hope I reach my goal so I can stock these controllers indefinitely!
Ok that's a little better then. I'd still rather see more buttons and a bigger board. But it's your design. I backed ya.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Done. I told you I would pay $100 for it when you first mentioned it, and now I have.
This Kind of work is essential to the hardware side of things moving forward.
Love the work so far :)
Nice! I want one, though..... I already have a box with two Mag-stick Plusses, buttons and an iPac gathering dust for a few years now. But this looks awesome, what buttons & sticks are you using in the video?
Over 50% there, the hyperspin-fe community is frickin awesome.
@THK I am using Happ Competition with these handles from paradise arcades:
http://www.paradisearcadeshop.com/paradise-arcade-custom-parts/586-iki-il-happ-rgb-shaft-kit-with-slip-ring.html
The buttons I am using are just the white spectralite that I modded and put in my own RGB LEDs because it was much cheaper:
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=343
I hope this gets new people excited about retro gaming and arcade cabinet building!
Once again, thanks everyone!
If you want you can help a guy out by sharing the link on twitter, Facebook, reddit or any other forums that may have interested people: http://www.kickstarter.com/projects/2034467396/howler-arcade-controller or use the bitly link for twitter: kck.st/HhLK0A
Also, if you wanna follow me on twitter @wolfmizzle or mention the controller #howlercontroller.
Josh
Whoa! All of the "Early Adopter" rewards are gone. I did not think that they would go this quickly so I added an "Early Procrastinator" reward for only $6 more. It includes the howler arcade controller, power supply, and USB A-B cable.
Thanks again guys!
Josh
Maybe a suggestion for ya? The beta "appears" to have a surface mount USB connector. I see in the video you were very careful to have your finger behind/ontop of that connector. I've spent a lot of time doing validation on Engineering Sample boards and these surface mount connectors are highly problematic and IMHO not the way to go. I highly suggest the USB connector be a through hole.
@Deadly
Thanks for pointing that out. I also noticed that the SMT micro USB connector was pretty crappy as well (and a biatch to solder). I have changed this connector on the Production boards to a normal USB type B through hole connector. You can see it on this pic of just the connectors:
I am just finishing up layout right now so if anyone has any other suggestions, let me know!
Josh
@zolta420
I have tested the buttons with Future Pinball and they work great. Once I get the Production version I will test out how the accelerometer works for tilt and bump functions. I will be mapping the accelerometer to an analog joystick axis which you can configure in Future Pinball.
In other news, my project has been featured as a kickstarter "Staff Pick" It is at the top of the list!
http://www.kickstarter.com/discover/categories/technology?ref=sidebar
Congrats dude. I have No doubt that you will get all the backing you need. Also, the people here, I think, would be more than happy to help you out if you need a hand software or firmware wise.
I'm excited :)
Sent from my GT-I9100T using Tapatalk
This is awesome! Might be a dumb question, but can I use this along side an Ipac4 (since it's only 28 buttons, would I be able to set the player buttons and joysticks to your controller for the LED control and then run all extra buttons that I wouldn't need colored LEDs in off of the ipac)?
Congrats! Must give you a good satisfying feeling :cool:
