Garion Posted May 27, 2013 Share Posted May 27, 2013 I am having an issue with HyperSync 3 not syncing. I recently moved to a new pc Win7 64bit, i was running hypersync 2 and just installed 3. BTW neither work. I was able to enter my username and password, heard the chime when hitting login. I setup a job for MAME only, when i hit sync it doesn't seem to do anything and doesn't log anything in the status window. .NET 4 is installed. exactly same problem here. W7-64 with net4 and no sync or error at all with base systems. Link to comment Share on other sites More sharing options...
Jdubbs Posted May 27, 2013 Share Posted May 27, 2013 Only issue I have right now is that commodore Amiga videos redownload every time. for me its Earthworm Jim and Earthworm Jim 2 for genesis that redownload everytime Link to comment Share on other sites More sharing options...
noshgar Posted May 28, 2013 Share Posted May 28, 2013 It was suggested to me to reinstall .net 4 and that didn't make any difference. Everyone i have talked to says this is more than likely a licensing issue and requires the Hyperspin team to reset something on their end. Link to comment Share on other sites More sharing options...
Garion Posted May 28, 2013 Share Posted May 28, 2013 exactly same problem here. W7-64 with net4 and no sync or error at all with base systems. I try again but with other system than mame and its works. NES, zinc, etc... download fine. I don't understand why mame don't. It is my best supported and config system. Standard mame folders name. 148u2 with romlister XML database. All games listed on XML works fine inside hyperspin. I continue testing. Enviado vía Tapatalk Link to comment Share on other sites More sharing options...
zxspecticle Posted May 28, 2013 Share Posted May 28, 2013 I feel a bit of idiot posting this as I should have known better but if it helps others then I'm happy. Up until yesterday I've been unable to use the latest version of Hypersync as the only thing that appeared to sync were the pointers. I tried everything to sort this out including re-installing .net 4 but nothing worked. I WRONGLY assumed that because I didn't require video downloads I didn't need to enter a emumovies username and password. This is incorrect, even if you are a non paying member of emumovies, still enter your username and password into Hypersync and everything will work perfectly! Oooops! Link to comment Share on other sites More sharing options...
noshgar Posted May 30, 2013 Share Posted May 30, 2013 I feel a bit of idiot posting this as I should have known better but if it helps others then I'm happy. Up until yesterday I've been unable to use the latest version of Hypersync as the only thing that appeared to sync were the pointers. I tried everything to sort this out including re-installing .net 4 but nothing worked. I WRONGLY assumed that because I didn't require video downloads I didn't need to enter a emumovies username and password. This is incorrect, even if you are a non paying member of emumovies, still enter your username and password into Hypersync and everything will work perfectly! Oooops! This fixed my issue as well. Even if you do not have an emumovies.com account you cannot leave the username as null, I just entered my hyperspin account username/password. After you hit login from the home screen, you should hear two chimes indicating that both accounts are authenticated. Link to comment Share on other sites More sharing options...
esmith13 Posted June 4, 2013 Share Posted June 4, 2013 I am having an issue getting HyperSync 3 (v3.0.0.4 I believe?) to download ANYTHING for Super Nintendo or Atari 2600. Everything else downloads fine. I have a platinum membership here and a lifetime membership at emumovies. I hear both beeps when I launch HyperSync. The proper .NET 4 installation has been done. I have made individual jobs for each system in HyperSync. Only SNES and Atari 2600 fail to sync anything. I get no letters, wheel images, carts, videos, etc... It doesn't even appear to be trying as it flickers from saying idle for a split second. Even if I try to sync a system I have all the art for it takes longer than that before it goes back to idle. I am not telling it to sync only for roms I have (I want everything) and irregardless of that I know my roms are correct since I had no issues with the same romsets in HyperSync 2.0/HS 1.2 and the roms load/play fine thru HyperSpin. Any suggestions? P.S.: If it helps, this is a clean install of Win7Ult. x64 SP1. I have made sure to run HyperSync as administrator, root folder is C:\HyperSpin and all users have full control/write access to that location and all sub directories and files. To eliminate the computer/windows itself I pushed forward and upgraded and older HyperSpin 1.2 setup on another system to 1.3 and could again sync all media except for Atari 2600 and SNES. Thanks in advance for any help. Link to comment Share on other sites More sharing options...
tastyratz Posted June 10, 2013 Share Posted June 10, 2013 I just noticed tonight that the latest hypersync public has "database update utility" - with all the activity in the databases as of late am I missing something? It's a gray selection on my screen and I noticed it wasn't something I could queue in the job builder. Is it's functionality missing from the latest or am I just missing the obvious in front of me? Link to comment Share on other sites More sharing options...
nikeymikey Posted June 15, 2013 Share Posted June 15, 2013 Hi new platinum member here, up until yesterday I was able to use the hypersync app with my free account, but now when I try to access the job editor I get an unhandled exception error. Is this because Hypersync is still down or is it an error at my end? I have paid up and become platinum now (was going to anyway, as this site has been a great help in getting ready for my cabinet installation) but still am getting the error. Here's the error report just in case anyone wants to see it, I am using Win 8 64bit, so already have .Net stuff installed See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.Exception: Error reading JArray from JsonReader. at Newtonsoft.Json.Linq.JArray.Load(JsonReader reader) at HyperSync_Mongoose.Forms.Slaves.JobDesigner.c37002 833431689c69531e150ac2975c2() at HyperSync_Mongoose.Forms.Slaves.JobDesigner.c79ec2 a12e0051e19ccff15baee981873(Object cedb86737f3ede5325e7e3e110798049f, EventArgs c0cf0b3b8bea2af6867e0a2a27339963c) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18033 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- HyperSync Mongoose Assembly Version: 3.0.0.8 Win32 Version: 3.0.0.8 CodeBase: file:///C:/Hyperspin/HyperSync%20Mongoose.exe ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18033 built by: FX45RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ResourceAssembly Assembly Version: 1.0.0.0 Win32 Version: 3.0.0.8 CodeBase: file:///C:/Hyperspin/HyperSync%20Mongoose.exe ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18037 built by: FX45RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18022 built by: FX45RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- Download Service API Assembly Version: 1.0.0.0 Win32 Version: 3.0.0.8 CodeBase: file:///C:/Hyperspin/HyperSync%20Mongoose.exe ---------------------------------------- ProgressODoom Assembly Version: 1.0.4725.657 Win32 Version: 3.0.0.8 CodeBase: file:///C:/Hyperspin/HyperSync%20Mongoose.exe ---------------------------------------- ControlLibrary Assembly Version: 1.0.0.0 Win32 Version: 3.0.0.8 CodeBase: file:///C:/Hyperspin/HyperSync%20Mongoose.exe ---------------------------------------- Controls Assembly Version: 1.0.0.0 Win32 Version: 3.0.0.8 CodeBase: file:///C:/Hyperspin/HyperSync%20Mongoose.exe ---------------------------------------- AutomaticUpdater Assembly Version: 2.6.16.0 Win32 Version: 3.0.0.8 CodeBase: file:///C:/Hyperspin/HyperSync%20Mongoose.exe ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18033 built by: FX45RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Web Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18033 built by: FX45RTMGDR CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll ---------------------------------------- Microsoft.VisualBasic Assembly Version: 10.0.0.0 Win32 Version: 11.0.50709.17929 built by: FX45RTMREL CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- Newtonsoft.Json Assembly Version: 3.5.0.0 Win32 Version: 3.0.0.8 CodeBase: file:///C:/Hyperspin/HyperSync%20Mongoose.exe ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. Thank you to anyone who helps Link to comment Share on other sites More sharing options...
Daghdha Posted June 15, 2013 Share Posted June 15, 2013 I have the same error as NikeyMikey. An unhandled exception.. stack trace is same. Win 8, Dual monitor I just installed a few minutes ago, for the 1st time. Login is ok. When i try to open job editor it throws an exception. PS: When i: - click 'Continue' - new job - enter 'job title' and click ok it also throws an exception. Link to comment Share on other sites More sharing options...
Circo Posted June 15, 2013 Share Posted June 15, 2013 Did you read the PSA? Link to comment Share on other sites More sharing options...
Daghdha Posted June 15, 2013 Share Posted June 15, 2013 From what i understand from that it should be up again. no? Link to comment Share on other sites More sharing options...
tastyratz Posted June 15, 2013 Share Posted June 15, 2013 too bad you didn't join up a few days earlier to get your initial sync in. down for updates, gotta be patient. Rain will update when it's back online. Keep an eye on the psa thread. Link to comment Share on other sites More sharing options...
evilash Posted June 17, 2013 Share Posted June 17, 2013 Just staring out with hyper-spin - thought I'd go ahead and donate - but getting Unhandled exception issue - tried update to net framework 4.0 and complete remove and reinstall and still get same error. Any ideas??? My other question - even though not related to this 'thread' is where do I get ftp login info - I'm platinum member.. Link to comment Share on other sites More sharing options...
epicrean Posted June 17, 2013 Share Posted June 17, 2013 Just staring out with hyper-spin - thought I'd go ahead and donate - but getting Unhandled exception issue - tried update to net framework 4.0 and complete remove and reinstall and still get same error. Any ideas??? My other question - even though not related to this 'thread' is where do I get ftp login info - I'm platinum member.. Hypersync is down... As far as ftplogin that would be BBB or rain, send them a quick message Link to comment Share on other sites More sharing options...
xagesz Posted August 11, 2013 Share Posted August 11, 2013 Is hypersync still down? Link to comment Share on other sites More sharing options...
manicshere Posted August 11, 2013 Share Posted August 11, 2013 Nope. It's running perfectly fine. Link to comment Share on other sites More sharing options...
philongames Posted August 11, 2013 Share Posted August 11, 2013 Help! HyperSync isn't actually downloading anything! I followed all the other instructions I could find, setting up the Super Nintendo directory to be recognized, with everything set to default. I choose to sync all for the SNES from the main menu, and the program shows that it runs through each directory looking for missing art, but then never downloads anything when the sync is complete. The Hyperspin directory is set up correctly, .net framework installed okay, HyperSync recognizes the SNES directory and lets me choose to sync it. Not sure what else to do Sort of bummed out after spending the $40, but I understand this is a constant WIP Thanks! Link to comment Share on other sites More sharing options...
Rain Posted August 11, 2013 Author Share Posted August 11, 2013 You have slow Internet? I see you have been getting a lot of these: RunSync_DoWork.GameWheels() Details: System.Net.WebException: The operation has timed out at System.Net.WebClient.UploadValues(Uri address, String method, NameValueCollectionData) which usually happens when the Internet is mildly slow. I will find a way to send the data to your machine in a way faster to compensate for your Internet connection. There has never been an error I could not fix, HyperSync does not have any errors at all; all the errors with HyperSync are user errors, in this case it is your ISP and their Internet whom is to blame, but I will work away around it for you bro. Stay tuned. Link to comment Share on other sites More sharing options...
philongames Posted August 11, 2013 Share Posted August 11, 2013 Rain, you are the shiznit! Yeah, my internet sucks butt. I moved out to the country and have to deal with this crappy satellite internet :-/ The download is okay, but upload is horrid, and I have some pretty major ping and packet loss to go with it. If you can work some magic for poor folk like myself who are living in the stone ages, that would be awesome. Link to comment Share on other sites More sharing options...
epicfatigue Posted August 12, 2013 Share Posted August 12, 2013 Hey i am having an issue when i try and start Hypersync. I downlaoded the newest version and ran the update, now i get Bootstrapper 1.0.0.0.0 Status Verifying Windows Media Player Version.. Thats all sat like this forever no matter how many reboots. Windows Xp 64 Fully updated .Framenet 4 is installed any ideas many thanks Link to comment Share on other sites More sharing options...
xagesz Posted August 12, 2013 Share Posted August 12, 2013 Rain you are the man. I hope that post was directed at me Link to comment Share on other sites More sharing options...
xagesz Posted August 12, 2013 Share Posted August 12, 2013 I went around my VPN and now it works fine... sigh. but through vpn is still an issue Rain. Thank Link to comment Share on other sites More sharing options...
philongames Posted August 12, 2013 Share Posted August 12, 2013 Hey Rain, I think you did some work on the issue with slow connections last night (?). I was able to sync my cart art and wheel art for the SNES, but now it's back to not actually downloading anything anymore like before (specifically, box art). Thanks for your continued help with working to support us users with less than fantastic internet connections. Link to comment Share on other sites More sharing options...
Rain Posted August 13, 2013 Author Share Posted August 13, 2013 I will have to patch this in the next release (scheduled for 8/14/2013) to resolve the issue. I am building into HyperSync an Internet speed tester verification utility that will automatically set all of the internal variables around a users Internet connection speed. Considering there are about 18 variables to change dynamically and 4 timers/watches to adjust I think it would be better, because if I change these variables for users with Fast Internet than HyperSync will be slow, vise versa. So to accommodate the broad user group I think a built in verification test sounds like the more stable and best option all the way around. Link to comment Share on other sites More sharing options...
