Nexus23 Posted February 21, 2015 Posted February 21, 2015 Hi, tested Steem.SSE.3.6.4.Win32 works good, more Games run! But the focus problem is not survived. Some news about that? Does it woek for you without the problem? greets, Nexus23
craiganderson Posted February 21, 2015 Author Posted February 21, 2015 here is the module i am using dont think it does fullscreen...sorry but see the RED text .. that has to match the .exe of the steem version you are using....otherwise the module will just "close out" as if you exited the emulator that MIGHT be the problem! MEmu = MEmuV = MURL = MAuthor = craiganderson MVersion = 1.0 MCRC = iCRC = MID = MSystem = "Atari ST" ;---------------------------------------------------------------------------- ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() 7z(romPath, romName, romExtension, 7zExtractPath) settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) ; disableHideTitleBar := true ; disableHideToggleMenu := true ; disableHideBorder := true ; BezelStart("fixResMode") BezelStart() params := "db=""GBST v3.1d""" Run(executable . " " . params . " fn=""" . romName . """", emuPath) WinWait("ahk_class Steem Window") WinWaitActive("ahk_class Steem Window") WinMaximize, ahk_class Steem Window [b][color="#FF0000"]executable:="Steem SSE 3.4.1.exe"[/color][/b] BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("ahk_class Steem Window") Process, Close, SainT161.exe Process, Close, Steem.exe Process, Close, 7z.exe Process, Close, GameBase.exe FileRemoveDir, E:\Atari ST Temp, 1 Return http://craigandersonthemes.weebly.com/
Nexus23 Posted February 22, 2015 Posted February 22, 2015 Thanks, problem survived! I like to play in windowed screen with bezel, locks very nice! greets, Nexus23
craiganderson Posted February 22, 2015 Author Posted February 22, 2015 Its working? You meant problem SOLVED? http://craigandersonthemes.weebly.com/
Nexus23 Posted February 22, 2015 Posted February 22, 2015 Oh, bad Google translation problem SOLVED! now I can survived for the next time greets
nimpa Posted February 23, 2015 Posted February 23, 2015 Pretty awesome Craig! I might try setting it up once again. Last time it fuck'd up! Thank you !!
Nexus23 Posted February 24, 2015 Posted February 24, 2015 Losing focus comes again after second startup! Now setuped "Hatari" that works fine without boarder in Full screen. Uploaded via. FTP under my username! Only need to open the Hyperlauch (Settings) and match "all" to Gamebase roms folder "A-Z"! On HyperHQ set searching subfolders doesn`t work now edited the Setting.ini... Fake .txt files & Gamebase1.3 not needed anymore. greets
spotUP Posted February 25, 2015 Posted February 25, 2015 What's the status of this? Craig are you done with it? My Atari ST setup is in a miserable state both emu wize and media-wize.
craiganderson Posted February 25, 2015 Author Posted February 25, 2015 I am done. But apparently not working for some. Not sure why. Works for me. Sent from my iPad using Tapatalk http://craigandersonthemes.weebly.com/
showstopper Posted February 26, 2015 Posted February 26, 2015 I'm with spotup - what is the status with this? OP guide is steem, other people say they are using hatari. Craig is your OP the guide to follow? How to update HyperLaunch
Cybersnuff Posted February 26, 2015 Posted February 26, 2015 I use Craigs Setup and it works great but not in Fullscreen... I also had two times that Malware Checkers and ... deleted important parts of Gamebase... So can be a problem with some Virus Tools, Malware Tools... For me its working with a very nice Brezel . Haven`t tried Hatari yet. Maybe on Weekend... If this works Fullscreen and the games work then I will change to Hatari. If not I stay on Craigs very good and nice looking setup with Gamebase and a nice Bezel ....
craiganderson Posted February 26, 2015 Author Posted February 26, 2015 I will check full screen status when home Saturday. http://craigandersonthemes.weebly.com/
Nexus23 Posted February 27, 2015 Posted February 27, 2015 Hi, on Nvidia Card on my other PC no focusproblems! Ati Notebook losing focus! Hatari works good in fullscreen test it out! Files on FTP "Nexus23" folder.
Cybersnuff Posted February 28, 2015 Posted February 28, 2015 Yes Hatari works good in Fullscreen. Also Retroarch (with Hatari Module). Tested both yesterday but Craigs Gamebase / Steem solution plays far more games and also some games 100% working where Hatari misses something... But maybe someday Hatari gets better then Steem but today its not I think! But would be great if Craig can add Fullscreen to his solution... But thanks Nexus23 for your Files. So I can choose now which Game I play with Craigs Solution and which with Hatari.
craiganderson Posted February 28, 2015 Author Posted February 28, 2015 Yes Hatari works good in Fullscreen. Also Retroarch (with Hatari Module). Tested both yesterday but Craigs Gamebase / Steem solution plays far more games and also some games 100% working where Hatari misses something... But maybe someday Hatari gets better then Steem but today its not I think! But would be great if Craig can add Fullscreen to his solution...But thanks Nexus23 for your Files. So I can choose now which Game I play with Craigs Solution and which with Hatari. thanks for testing! I think gamebase plays more games as well. ill get back to u about fullscreen edit.......... if you want fullscreen with the setup i shared 1) turn off bezels in HLHQ 2) go into the emulator settings and set to fullscreen (video does not show this, but I had to set it from within a loaded game to get it to "stick", F12 frees up mouse to adjust setting from within a game) edit...and the emulator (steem) seems a little "finicky"....i had to change fullscreen on/off a couple of times get it to stick///...just fYI -Iy0u02CY3g http://craigandersonthemes.weebly.com/
Nexus23 Posted March 1, 2015 Posted March 1, 2015 Hi, on the Atari butten in the top left is also a funktion "stay on the Top" That changed nothing for me a few days ago also start in fullscreen wouldn`t work. Now did the same a few times at ones it work. I dont understand why It`s also a button top left says bigger Window! Click on it a few times bring you faster to fullscreen Crazy shit! Edit: Fake .txt files no needed if you setup rompath from A to Z! it looks like: [ROMS] Default_Emulator=Steem Rom_Path=..\..\Games\Atari\ST\Games\ST\0|..\..\Games\Atari\ST\Games\ST\A|..\..\Games\Atari\ST\Games\ST\B|..\..\Games\Atari\ST\Games\ST\C|..\..\Games\Atari\ST\Games\ST\D|..\..\Games\Atari\ST\Games\ST\E|..\..\Games\Atari\ST\Games\ST\F|..\..\Games\Atari\ST\Games\ST\G|..\..\Games\Atari\ST\Games\ST\H|..\..\Games\Atari\ST\Games\ST\I|..\..\Games\Atari\ST\Games\ST\J|..\..\Games\Atari\ST\Games\ST\K|..\..\Games\Atari\ST\Games\ST\L|..\..\Games\Atari\ST\Games\ST\M|..\..\Games\Atari\ST\Games\ST\N|..\..\Games\Atari\ST\Games\ST\O|..\..\Games\Atari\ST\Games\ST\P|..\..\Games\Atari\ST\Games\ST\Q|..\..\Games\Atari\ST\Games\ST\R|..\..\Games\Atari\ST\Games\ST\S|..\..\Games\Atari\ST\Games\ST\T|..\..\Games\Atari\ST\Games\ST\U|..\..\Games\Atari\ST\Games\ST\V|..\..\Games\Atari\ST\Games\ST\W|..\..\Games\Atari\ST\Games\ST\X|..\..\Games\Atari\ST\Games\ST\Y|..\..\Games\Atari\ST\Games\ST\Z|..\..\Games\Atari\ST\Games\STX\0|..\..\Games\Atari\ST\Games\STX\A|..\..\Games\Atari\ST\Games\STX\B|..\..\Games\Atari\ST\Games\STX\C|..\..\Games\Atari\ST\Games\STX\D|..\..\Games\Atari\ST\Games\STX\E|..\..\Games\Atari\ST\Games\STX\F|..\..\Games\Atari\ST\Games\STX\G|..\..\Games\Atari\ST\Games\STX\H|..\..\Games\Atari\ST\Games\STX\I|..\..\Games\Atari\ST\Games\STX\J|..\..\Games\Atari\ST\Games\STX\K|..\..\Games\Atari\ST\Games\STX\L|..\..\Games\Atari\ST\Games\STX\M|..\..\Games\Atari\ST\Games\STX\N|..\..\Games\Atari\ST\Games\STX\O|..\..\Games\Atari\ST\Games\STX\P|..\..\Games\Atari\ST\Games\STX\Q|..\..\Games\Atari\ST\Games\STX\R|..\..\Games\Atari\ST\Games\STX\S|..\..\Games\Atari\ST\Games\STX\T|..\..\Games\Atari\ST\Games\STX\U|..\..\Games\Atari\ST\Games\STX\V|..\..\Games\Atari\ST\Games\STX\W|..\..\Games\Atari\ST\Games\STX\X|..\..\Games\Atari\ST\Games\STX\Y|..\..\Games\Atari\ST\Games\STX\Z|..\..\Games\Atari\ST\Games\HD\0|..\..\Games\Atari\ST\Games\HD\A|..\..\Games\Atari\ST\Games\HD\B|..\..\Games\Atari\ST\Games\HD\C|..\..\Games\Atari\ST\Games\HD\D|..\..\Games\Atari\ST\Games\HD\E|..\..\Games\Atari\ST\Games\HD\F|..\..\Games\Atari\ST\Games\STX\Compilations\C|..\..\Games\Atari\ST\Games\STX\Compilations\L|..\..\Games\Atari\ST\Games\STX\Compilations\M|..\..\Games\Atari\ST\Games\STX\Compilations\T or put all Games in one folder should work to! You can use the newest version of Steem, Steem.SSE.3.6.4.Win32!
Cybersnuff Posted March 3, 2015 Posted March 3, 2015 Yes also have set it up since the weekend after downloading your files from the FTP. Thanks for them!! So it runs now with Gamebase/Steem, Hatari and Retroarch.... Steem SSE 3.6.4. the newest one I must still add...
wahoobrian Posted March 3, 2015 Posted March 3, 2015 Hey Guys, been watching this thread since I'm currently working on the official Atari ST database. Just wanted to let you know that I have yet to come across any game that doesn't run on Hatari. I think the reason you are getting better results on Steem/Gamebase is because Gamebase already has every game configured as far as what TOS version to use, memory allocations, machine type, etc... If you set up Hatari with those same config items you'll get good results. I'm also working on a new Hatari module that will allow all those settings and I will throw the associated ini in my upload folder when its completed. Hope this helps.
zerojay Posted March 26, 2015 Posted March 26, 2015 I'm working on a new version of the Steem SSE module that will support and include the proper settings that Gamebase sends to the emulators for better compatibility.
nathan1974au Posted May 15, 2015 Posted May 15, 2015 I'm thinking of Atari falcon, Atari STE, mega STE games that would be cool! (Midlife crisis) some have hot rods, some have gold chains, I have arcade machine with hyperspin.
SIMPLYAUSTIN Posted May 15, 2015 Posted May 15, 2015 So did we ever find which setup is the best route to go down with the Artari ST? EDIT: LOL... Artari... sounds like a great new Art app hehehe Simply Austin's YouTube
wahoobrian Posted May 15, 2015 Posted May 15, 2015 Official Atari ST XML released yesterday, check Downloads. Updated RL modules for Hatari/Steem SSE were released along with RL 1.0. Once FTP maintenance is complete, I can upload the matching module ini's to the FTP.
SIMPLYAUSTIN Posted May 15, 2015 Posted May 15, 2015 Great work and many thanks... form a personal standpoint... what Emu would people recommend in terms of reliability, controls and actual games working? Simply Austin's YouTube
