mapsking Posted January 13, 2013 Posted January 13, 2013 I didn't see it posted, so forgive me if it is, and I missed it. With 1.3 and 1.3.1 both, whenever I try to move up or down from any wheel, it spins for a long time, but appears random, as to how long it spins. I think it stops somewhere ahead of where I was randomly, but most times, I hit ESC to simply go back. Sometimes for I'm guessing 50-100 or more slots, when going backwards, it goes a long ways again, sometimes further, sometimes a shorter distance than where it began. I am using an xbox 360 wired controller on a regular computer (no cab), and it was working prior to the update. I remapped all the controls, tried with two different controllers, all to no avail. I am running Windows 7 Home Premium (x64). I also went into Windows Game Controller settings, and tried with MAMEUI64, MAME64, and Maximus Arcade, all of which worked fine, moving the joystick up or down one went just once. I'm not sure what is going on, but I'd be happy to provide any information needed. Does anyone know how to correct this? Is it something simple I've done? Thanks, Mapsking
Circo Posted January 13, 2013 Posted January 13, 2013 Search this thread for xpadder. Tons of posts on this ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
Manddrakke Posted January 13, 2013 Posted January 13, 2013 Wheel acts ultra sensitive, I can not pass with x360 controller system to system or game by game try to choose a game or a system, wheel moves a fifth or rotates no stop, i try 1.3 and 1.3.1 and no work, only 1.0 1.2 work 100%, solutions? Sorry my poor english.
Ptaz Posted January 13, 2013 Posted January 13, 2013 Hey Guys, After updating to 1.3 hyperspin has a really slow startup and now starts windowed and I can't get it to go full screen?!? also sound is not working. Hyperspin 1.2 ran like a dream....
nogarth Posted January 14, 2013 Posted January 14, 2013 I'm sure there is a 1.3.1 update to fix that mate. Sent from my HTC Sensation XE with Beats Audio using Tapatalk 2 [sIGPIC][/sIGPIC]
nuker43 Posted January 19, 2013 Posted January 19, 2013 djvj said: Bill, this is the same issue I had with HS2. There may be a similarity here that is causing it. jbsoum, does it happen only when using the same theme and going from game to game? My issue was only then. Videos always work the first time a theme loads, just not when going to another game using the same theme.For the record, this all works fine for me on HS 1.3. Not sure if people are still having this problem but my videos were not loading after the first video in a game subwheel unless the game had its own theme. I searched the forums for a fix and couldn't find one so hopefully if people are still having this problem the fix is this: In the optimizer tab in hyperHQ make sure "Themes Wait For Special" is unchecked. Once i did this the videos all loaded fine whether it was default theme or a custom game theme.
jbsoum Posted January 20, 2013 Posted January 20, 2013 You are correct nuker43! Unchecked that box and everything works again.
dark13 Posted January 21, 2013 Posted January 21, 2013 Finally I did some testing on new releases Testing machine: q6600 2.4ghz (quadcore) 2x2gb ddr2 800mhz 9800gtx+ seagate barracuda 7200rpm 1tb (HS folder, OS is on 2x samsung t166 raid0) 1.3 is MUCH smoother. Probably it's due to the fact it uses more than 1 cores, is it due to multithreading optimization in flash 11? Technically 1.3 will takes more watts to run and will get your system hotter but general performance will be better than 1.2 especially on multicores systems. The only downside is it does not read anymore .swf renamed to .png for wheel image as they freeeze hyperspin. Is there some chance to get .swf support for wheel images in 2.0? Mp4 video support is really cool, better quality in less space but please keep .flv support as alpha channel can be used for crazy effects in themes Launch time is not great (2-3 seconds) but it's not a huge problem. It CAN be a problem on weaker cpus. 1.3.1 has a serious performance problem... my neo geo theme Stutter as hell when changing games, basically you won't see animation on marquee and artbox. EDIT: Tested also on my htpc (p4 3ghz, 2x512mb ddr 400, x1550). 1.3 seems to be faster even on a single core machine. Launch time is around 4 seconds, better than I expected Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
THK Posted January 21, 2013 Posted January 21, 2013 dark13 said: Please keep .flv support as alpha channel can be used for crazy effects in themes This has already been stated to be the case. ..........................back with a vengeance........................
smcgarr Posted January 23, 2013 Posted January 23, 2013 It would be great if there was a fix for the Intel HD graphics video bug. I just built a new Hyperspin system this evening and it has an i5 proc with the Intel HD 2500 graphics (good enough for MAME). The video is all distorted on the mp4 and some of the system preview vids (which are flv??). What are the chances of a 1.3.2 release?
jackhammersalm Posted January 24, 2013 Posted January 24, 2013 has anyone fixed the issue with the asteroids theme yet The Hyperspin Report writer/editor <br />resident grouch, Hyperspin facebook modorator<br />for those who want to read my work <br /><a href='http://thehyperspinreport.blogspot.co.uk' class='bbc_url' title='External link' rel='nofollow external'>http://thehyperspinreport.blogspot.co.uk</a>
nuker43 Posted January 24, 2013 Posted January 24, 2013 I fixed it to the best of my ability however i am no flash user... so the asteroids might not look perfect but its something. (note this was not my theme i just removed the buggy particle.swf file and added my own) https://www.dropbox.com/s/4dkhtrq4kcsc7o7/asteroid.zip
Secret80'sMan Posted January 24, 2013 Posted January 24, 2013 nuker43 said: I fixed it to the best of my ability however i am no flash user... so the asteroids might not look perfect but its something.(note this was not my theme i just removed the buggy particle.swf file and added my own) https://www.dropbox.com/s/4dkhtrq4kcsc7o7/asteroid.zip Has the new theme been adopted as part of the minted set that works through HyperSync?
jackhammersalm Posted January 24, 2013 Posted January 24, 2013 not yet by the looks of it nuker43 nice but wheres the video screen The Hyperspin Report writer/editor <br />resident grouch, Hyperspin facebook modorator<br />for those who want to read my work <br /><a href='http://thehyperspinreport.blogspot.co.uk' class='bbc_url' title='External link' rel='nofollow external'>http://thehyperspinreport.blogspot.co.uk</a>
Jumpstile Posted January 24, 2013 Posted January 24, 2013 This really needs to get fixed in HyperSync... Also, has anyone figured out which theme(s) are responsible for giving the white screen with the exclamation mark? I'm getting tired of having to force quit HyperSpin because of this... - J* How to rebuild your MAME ROM set using CLRMAMEPRO - Walkthrough HERE!
nuker43 Posted January 24, 2013 Posted January 24, 2013 oops forgot the video screen because i haven't added videos in my HS yet. Here is the theme with the video .. also its just a quick fix for people to use until the original theme creator can fix it https://www.dropbox.com/s/4dkhtrq4kcsc7o7/asteroid.zip
jackhammersalm Posted January 26, 2013 Posted January 26, 2013 Jumpstile said: This really needs to get fixed in HyperSync... Also, has anyone figured out which theme(s) are responsible for giving the white screen with the exclamation mark? I'm getting tired of having to force quit HyperSpin because of this... - J* I need to go through all the themes that have any issues then report them to rain. only way to find out what is actually compatible with hyperspin 1.3.0 and 1.3.1 The Hyperspin Report writer/editor <br />resident grouch, Hyperspin facebook modorator<br />for those who want to read my work <br /><a href='http://thehyperspinreport.blogspot.co.uk' class='bbc_url' title='External link' rel='nofollow external'>http://thehyperspinreport.blogspot.co.uk</a>
goushen Posted January 26, 2013 Posted January 26, 2013 I found that real bout fatal fury 2 theme crashes as well.
nuker43 Posted January 26, 2013 Posted January 26, 2013 goushen said: I found that real bout fatal fury 2 theme crashes as well. i just tried that theme and it didn't crash me.. i'm on 1.3.1... are you able to upload your zip so i can see if it crashes me?
goushen Posted January 26, 2013 Posted January 26, 2013 its the one made by rao that crashes, the one by soph is fine.
goushen Posted January 26, 2013 Posted January 26, 2013 im on 1.3.1 as well and i just tried it and it crashed again i just switched themes, maybe something in it is corrupted?
nuker43 Posted January 27, 2013 Posted January 27, 2013 goushen said: im on 1.3.1 as well and i just tried it and it crashed again i just switched themes, maybe something in it is corrupted? Ok i found it and yep it was crashing HS.. fixed it up here ya go: https://www.dropbox.com/s/0wyvz5z26ld2zv6/rbff2.zip also fixed the asteroids theme so it is true to the original exactly: https://www.dropbox.com/s/4dkhtrq4kcsc7o7/asteroid.zip If anyone else finds any broken themes let me know and ill fix em up
alexr214 Posted January 27, 2013 Posted January 27, 2013 Anyone having the Windows 8 Trackball/Spinner issue? I was hoping that 1.3 or 1.3.1 would address this but my wheel continues to spin uncontrollably if I have the Trackball or spinner option selected in Hyper HQ. All worked fine when I was on windows 7. I posted a message in the support forums but thought I would see if anyone had the issue and was able to resolve it with HS 1.3 or 1.3.1. Also, I just want to say thanks to BBB, Circo, Rain, and all the members. I've been working on my cab and system setup on-and-off for months (A new baby girl has kept me a bit busy at the moment so its taking longer then I would like). These forums have been essential for getting me fairly well set up but I still got more work to do. I look forward to sharing my set-up and cab soon as I work to get it finished up.
loppydog Posted January 28, 2013 Posted January 28, 2013 So I am liking the new HS very much so far! But I had one request for the next release. I know I have asked for this before, and I don't know if this is an easy fix or not. I would owe you big time BBB if you could fix the resolution refreshing of HS...or the lack there of. It seems to do it to me almost any time the emu/game resolution does not match my desktop resolution. Here is a pic of what it should be vs what it is:
