New Unified Megatheme
Actually, looks like emumovies has a pretty full collection of marquees but no bezels. Just having the marquees might be the way to go for system theme.
  • Replies 907
Epetti, I uploaded the wrong version to the ftp at first. If your Arcade Classics shows a transparent screen, please re-download...sorry...in a hurry to go to bed. I'll look into the marquees as long as they are free to download since I don't have an Emumovies membership. That's actually a really good idea. Thanks!
By the way, I like seeing the wheel too but with a 4:3 restriction it's a bit harder and gibbawho created such nice menus that I just make mine fade out now. Getting use to it and it's not bad. You can always shrink the video as well and try to adjust everything to fit. Whatever works for you.
Looks great. Thanks.
I was looking at the marquees and it looks like they very between a few different sizes. I'm not familiar with HyperTheme but unless it allows you to force an image to scale to fit a given size without losing aspect ratio I'm not sure that will end up looking quite as nice as I had pictured.
Not dead, but I've been busy. I have a few more to upload tomorrow. Spent whatever free time I had trying to get Neo Geo AES to work and looking for art work. Guess I'll upgrade to Platinum to make my life easier.
I can't believe you've survived without it.
+1
Once upon a time it was a hard task to get all the artwork and videos etc setup. Now it's a snap.
You might be able to do posters for the arcade system default theme. Marquees would be neat as well. Just include the arcade classics marquee with the theme for games that don't have a usable marquee. The bezel would be too hard imo and would look out of place.
@epetti, you have to manually resize the images, hyperspin does not resize boxes to fit a certain size. Size info of artwork isn't even stored in the theme.xml
Tried this, but is there a way to have a default Artwork3? I tried putting the arcade classics marquee in the Artwork3 folder named Default and that didn't seem to work.
Set 2 is here - check the FTP under my name - Unified Theme - Set 2
Sorry for the delay. It's not much but it's all i had time for. I'll look at the marquees issue with the MAME Theme. Marquees should be possible but I haven't had time to try them out yet. I'm working on a few more themes already.
Good job, Need Sega CD if you have?
@ relic - I know. I'll be releasing the system and the main together from now on. Otherwise I loose track of what's been done. I finally became a platinum member so it's easy to get the box and cart art work now for the system menus.
@ epetti - I got the Marquee to work for the arcade classics theme. I'll post the system theme for that in the next few days but you will have to resize the marquees to fit on your own just like you have to resize all the boxes and carts for all the systems for them to fit.
@ ashurax - I don't have Sega CD yet but I can create it easily.
much appreciated sty your doing a excellent job ive backed up the themes in my folder just in case i named it Radical baddass themes
sig.png 100%
Styphelus thanks buddy!
@Styphelus - These are great, after a hiatus from emulation I've started from scratch with my build but when I get around to the themes, I'll definitely be checking these out! Well done and thank you for picking up where Gibbawho left off.
@Gibbawho - I hope your absence is nothing more serious than just being busy. I love the design, thanks for making them available.
A big fat +1 from me. Some excellent work here!
hi styphelus, can you drop on FTP your cart & Boxart for turbografx, Master system & atari series systems? There are amazing! Thanks
i think this is a juniorunderground work you can found all in ftp
Thanks a lot!
