  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
Sorry if this has been mentioned before, but Raiden 4 needs a pause command in the bat file to load up. Without it, you will get seemingly random results, with it, you'll get a command window asking you to press any key to continue. Neither option really works in the context of a front end. I do have an exe that i wrote in ahk that launches R4 and automatically sends a key to the command window. Im not sure its going to work with the new HL though.
here is my bat file:
typex_loader game.exe
title R4
pause
Hope it helps
Both Raiden games have given me sporadic results - sometimes they start up, sometimes they don't. In most instances with Raiden IV I end up with a white box in the upper left corner of the screen, and then nothing happens...
Raiden III has worked fine for me but I have yet to see IV load. I am more or less (I think) seeing the same as you. I do have a ATI video card and I know with some other TTX games that can be and issue so I am not sure if that is a factor at this point or not.
So for me I pretty much have all the TTX games running fine except...
BlazBlue Calamity Trigger (ATI Graphics card)
Otomedius (Works but only on my TV, higher resolution than 1024X768)
Matrimelee Matsuri (Power Instinct V) ^^^ Same
Raiden IV (More or less launches but does not work, game is rotating fine.)
Your power instinct and raiden 3 controls work ok for player 2?
sig2.png?raw=1sig.jpg?raw=1
Test this some more and I am getting the same as you. If I touch any keys when this happens the game crashes.
Yes.
Is your ipac setup as standard or have you altered the factory setup?
If standard how are you remapping the keys in PI5 and raiden?
Cheers
Cheers
They are mapped.
Do you have the files from djvj, on the ftp?
I notice an issue with pc launcher when you run battle fantasia and giga wing the pc launcher seems to stay open regardless even after you exit those games me and another freind of mine have tried many things to close it but it has not worked just wondering if anyone else is having this issue and if so is there a fix for it. We tried making a close.bat for it but seems to shut it manually when you double click the bat but when your in the game it hangs and stays on and i notice it only happens with those 2 games im not sure if any other taito type x games have this problem. As i havent set up all the games for taito type x yet but anyways if anyone knows what could be the issue please respond.
thx regards relic
the only way to close it is end task which is annoying
sig.png 100%
thx regards relic
If you use the launcherexe instead of the bat file, they all launch and rotate fine but they don't close, if anyone knows a way to make them close properly that would be fantasic, and i'd not even bother with dxwnd, anyone have an idea?
[sIGPIC][/sIGPIC]
I did a video tut for VisitorQ so he could get up to speed with DXWnd. I'm not sure all of it will be relevant but it may help. I'm still not able to get mine rotated unless I do it manually with irotate in the system tray.
I did set it to vertical but still no joy, but I didn't have a lot of testing time. I'm away from my pc till Monday.
I will PM you a dropbox link.
I'm starting work with the wheel and would be interested in taking a look at your tutorial video. :) Got most everything working in ArcadePC loader external to HLaunch but haven't messed with DXwind and the bat files.
PM'ed Sir :wavey:
I've yet to get SSFIVAE running through ArcadePC Launcher. Anyone else having probs with this one? On my system Game32.exe kicks in and the monitor resolution changes then it hangs and I have to "End task" on game32.exe to get PC launcher running again.
I am not using Arcade Loader for any of my games, either PC Launcher or DXWnd. I think Raiden IV is about the only game I am having trouble with at this point.
By "PC Launcher" do you mean the PClauncher in HL 3? I was trying to get everything working outside HL first. I'm only aware of DXwnd and ArcadePC Launcher to run them external from HL.
No matter how hard I hit the keyboard these $#@!ers just wont close.
Also remember, what kind of mess your desktop might be in if they did close. It would be nice if that did work.
don't see wjy a simple bat with the kill command wouldn't work i'll take a look later when the little ones gone to bed
something like this and set it in post exit
@echo off
taskkill /f /im notepad.exe /t
[sIGPIC][/sIGPIC]
Depending on which set of ssfivae you downloaded you should not have to use arcade pc launcher. The version i got from the internet already had everything setup and all i had to do was install it, setup controls, and click on "game.bat" to get it going. Try to run without arcade loader unless you need it for some reason
bat file?
I'm not at the moment. ArcadePC launcher creates a [Gamename]launcher.exe that I'm using at the moment. I've downloaded djvj's bats but haven't messed with them yet.
