  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
Are you running with the bat file or the launcher.exe? Do the games actually start up? Or does hl hang up?
Sent from my SCH-I535 using Tapatalk 2
I'm runng with the bat file(s). Well loading up Raiden IV I get a black screen (this is with the dxwnd module) It runs just fine with the Pc Launcher module though no rotation takes place. Using the dxwnd module Raiden III loads up just fine but again no rotation lol.
Please post your dxwnd.ini file from the modules folder. And are you using the latest hl? And latest dxwnd module?
I'm having some trouble getting Raiden III and IV to rotate they just load it's normal vertical mode meaning I would love to flip my monitor lol. I'm using dxwnd though with Raiden IV I just get a black screen. (Raiden IV works via PC Launcher btw)
Have you read page 9 of the thread Hunk, Check out Boomslangz method. Got it all setup in a few hours.
No need for dxwnd, you just use the original launchers and the pclauncher module.
Yep just helped gigapig get Raiden IV up and running now
raiden 4 does nothing for me, well it loaded once then that was it, if you could do a tutorial that would be great :)
[sIGPIC][/sIGPIC]
Thank you Sir, your a star. Now I can sleep easy at night and start rebuilding my life.
:cheers:
# VerticalMethod - choices are display or irotate, use whatever works best for you
# System specifies whether the game is standard or vertical rotation, default being standard
# TitleClass - This is the Window Title & Class of your application. To find the Title/Class you can use the AutoIt3 Window Spy utility installed with AutoHotKey or my utility @ http://www.hyperspin-fe.com/forum/showthread.php?15014-Window-Logger
# Exe - The filename and extension of the game. This is used because sometimes an exe cannot be renamed to match the romName.
[settings]
[GigaWing Generations]
TitleClass = YOKUSHIN ahk_class TOPWINDOW
LaunchExe=GigaWing Generations.bat
AppExe=game.exe
[Homura]
TitleClass = HOMURA ahk_class BASE
LaunchExe=Homura.bat
AppExe=game.exe
[Raiden III]
TitleClass = ©2005 ahk_class JJ9X
LaunchExe=Raiden III.bat
AppExe=game.exe
system=vertical rotation
[Raiden IV]
TitleClass = RAIDEN 4 ahk_class JJ11X
LaunchExe=Raiden IV.bat
AppExe=game.exe
[shikigami no Shiro III]
TitleClass = SHIKIGAMI ahk_class BASE
LaunchExe=Shikigami no Shiro III.bat
AppExe=game.exe
I am using the latest HL though I did have to update dxwnd so now Raiden IV loads fine except for not rotating ha ha.
just add me as friend and speak over chat
yeah I just put a program on yesterday which hides stuff such as icons of desktop and taskbar etc so now I don't see any crap
Hi Mate
Which program you using to hide those things?
Ignore that just read post page 37... cheers
Just in case you decide to stick with DXWnd for a few games, the reason they are not rotating is the system value in the dxwnd.ini. Should be 'vertical', not 'vertical rotation'. This was a bug DJVJ fixed a few days ago....
I only want to use DXWnd for the vertical games like Raiden III unless there is another solution? I updated the ini Windows seems to rotate though the game doesn't LOL I don't know man.
Using the launchers is the easiest, but then you have to mess with the 'exit problem' - but we have a solution for that now too... (Boomslangz method). I'm only using DXWnd module for Gigawing and Raiden III, the rest i'm using the launchers. Do you have Arcade PC Loader 1.4? Try running the games through that, then worry about HS...
Let us know how you progress...
You just have to copy them into the right folder under Arcade PC Laucher - ie, copy your entire (for example) ...\HyperSpin\Games\Taito Type X\Raiden III folder into ...\ArcadePC Loader\Games\RIII. Run them there, change any configs, then copy them back. I spent the day doing that - worked well.
That worked at least inside the loader. I'm not sure what to do from there. I can't configure the video settings inside of the loader it's all grayed out though the game launches fine and even rotates launching from the loader. (I haven't done anything lol)
ok, assuming Raiden III here.... try running RIII_Launcher.exe directly... If that works now, boom! you're good. and set it up using PC Launcher!
Doing that it gets stuck on the fade screen with sounds in the background though without the fade screen it works just fine and rotates though after exiting the game I get this HL error "There was an error waiting for the window "ahk_pid 5720". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem."
Hunk_4th. Firstly turn fade off until you get all these games working.
Next up your I'm assuming your using PCLauncher again? The error is because you've either not entered the appwaitexe, which would be "game.exe" or the fade title. All the fade titles are on page 1 of this thread.
And now Here.
[Arcana Heart 3]
FadeTitle=AH3
[battle Fantasia]
FadeTitle=BattleFantasia
[blazBlue Calamity Trigger]
FadeTitle=Blaz Blue
[blazBlue Continuum Shift]
FadeTitle=Blaz Blue
[Chaos Breaker]
FadeTitle=GAME
FadeTitle=YOKUSHIN
[Homura]
FadeTitle=HOMURA for TypeX
[King of Fighters '98, The Ultimate Match]
FadeTitle=Kof98
[King of Fighters XII, The]
FadeTitle=ahk_class NGLU_CLASS
[King of Fighters XIII, The]
FadeTitle=KOF XIII
[KOF - Maximum Impact Regulation A]
FadeTitle=KOF@MAXIMUM@IMPACT@regulation gAh
[Power Instinct The Commemoration]
FadeTitle= ??????????????????????
[Raiden III]
FadeTitle=©2005 MOSS LTD ALL RIGHTS RESERVED.
[Raiden IV]
FadeTitle=RAIDEN 4 ©2007 MOSS LTD ALL RIGHTS RESERVED.
[samurai Shodown - Edge of Destiny]
FadeTitle=Samurai Shodown 3D Ver[Mar 31 2008 15:23:19]
FadeTitle=SHIKIGAMI NO SHIRO3
[spica Adventure]
FadeTitle=SpikaADV.
[street Fighter IV]
FadeTitle=Street Fighter 4
FadeTitle=SF41 - Sep 14 2010 17:42:49
[Taisen Hot Gimmick 5]
FadeTitle=MTS for PC
[Tetris The Grand Master 3 Terror Instinct]
FadeTitle=TGM3 - Copyright © Arika Co., Ltd - 2004-2005 (Jan 30 2005 17:52:56)
[Trouble Witches AC]
FadeTitle=Trouble Witches
So now if your game works and you can exit out to HS, all good.
If not please make your life a lot easier and look at post #342 for a bit of Boomslangz magic.
Here's a link to the vid.
Does your resolution return back to its original state when you exit AH3? if not I have a small bat file that you can use that returns res back to 1920 x1080 .... you can also adjust it to suit whatever res you run with...
Any idea how get this to work with dual monitors?
I have the first one returning to 1920 x 1080 using your bat file, how would I go about getting it to return my second monitor back to its original state?
The reason for this is some of these taito games cause my second monitor display to be pushed to the right, every time I re-load them they push the image even further to the right :confused:
sig2.png?raw=1sig.jpg?raw=1
And now Here.
Nice thanks man! That worked and I seem to loose no focus returning to HP. I haven't tried Raiden IV or the other vertical games yet but I'll keep you guys posted! And thanks for the link I'll keep that in mind.
