Mame 0.153
Min2001
  • Replies 108
Are you asking for a guide for CLRMamepro or setting Mame up for Hyperlaunch/Hyperspin?
Just how to set up mame in general, first with mame secondly with hyperspin, if i can't run it without hs i propably wouldn't do it with hs?
I have figured out i can run different mame roms depending on which emulators im running
But i havent found any decent step by step guide for this
With mame there is 3-4 releases where to put what in what folders etc
This info can all be found on PD. Look in the wiki and read the ROM and CHD release threads. The split set is recommended for HyperSpin.
I'm in the wiki and can't find the CHD release thread?
The new torrent release threads are in the forum, but there is also useful info in the wiki, so you need to look in both places.
Thanks, appreciate it
Your not a Gold or Platinum member so I can't recommend Mame builds from the ftp. There must be plenty of Mame setup guides on the web, basically unpack the archive, put the right things in the right folders and away you go; you just need to set your controls.
I personally now use this version but a compiled version from the ftp which has things added such as Hi score support, the nag screen removed. More details here.
Adding it to Hyperspin, there are plenty of guides here, there's a video guide in my signature or ghutch has done a written guide as well. http://www.hyperspin-fe.com/forum/showthread.php?29481-How-to-install-HyperSpin
There are setups on the web but the packages from PD is different when it's the whole package, the issue with those guides i have found mosthly contains only how to get a rom somewhere and set up that rom only. On PD there are 4-5 different leseases from same set
Otherwise thanks for the other info
Personally, I'm using MAME 0.153 ROMs (Torrentzipped-split) from PD and the same version Mame emulator from the ftp.
HELP!!! Clrmamepro has just massacred my mame set. I added the .153 update roms and chds to my folder, setup cmp as i have done before using the .153 mame exe, now cmp says im missing 436 roms and 1 chd... Any ideas anyone?
Delete and download it all again. So much easier.
Well I've finally got into PD and have run my existing set thru torrentzip, going to join the .153 split torrent now and see where that gets me :)
I bet it was the neogeo.zip bios. All the neogeo games would come up missing
Could of been exactly that, although would that have been that many roms missing? I didnt think there were that many NeoGeo games.
257 neogeo games which would of failed because of the new update of the neogeo bios. :) Which would of left 179 games that needed to be added renamed or whatever.
