  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
Hi guys, sorry to come to the party so late but I hope some of you might help an old-timer get this Taito thing sorted. At the moment I'm only trying to set up the vertical shooters (Raiden 3 etc.) I've read through every page of this forum and followed Gigapigs YouTube video and I've got the games working perfectly except for one thing - none of them have rotated EVER!
I've tried Display, I've tried Irotate and I've tried every tip in this thread but none of them have rotated at all.
Can anybody tell me where to look?
Thank you gentleman.
I just run them with "Game Loader All RH.exe". They rotate just fine here.
Thanks Dime333, I'll go and Google for that now and report back how it goes.
I have uploaded files for Raiden 3 and 4 to my FTP folder. When using the game loader, you will need to have a file called "TypexInput.bin" in a folder called "sv" in your game folder. This file is the input config file. I have no memory of how to configure this file, maby someone else can help out. I use several different versions of the game loader for different games. Let me know if you need any other ones.
Downloaded Game Loader All RH.exe and ran it on a fresh copy of Raiden 3, still no rotation. Config program is in a foreign language so I have no idea what it says. Does the rotation only happen in Hyperlaunch cos I'm just running it in a temp folder while testing?
No, it should still rotate. I Always has for me. I don't Think you need to use any config program. It's been a while since I set this up. Sorry. Did you use my files? exe and ini?
It should be automatic unless the the config is set to "0". Have a look near the bottom of the TTX.ini file, look for "Rotate=" -1 I think is Auto, 1 & 0 will be on & off.
Thank you Gigapig, doing grandsons birthday party at the minute, will have another go tonight
Have you guys had any success editing the hex values in the Samurai Showdown game.exe for a different button config? I tried once a couple days ago but broke the exe in the process. I'm trying to map the buttons to MAME/IPac default.
Is there a way to turn off 'low resolution' on Samurai Showdown? The config.exe settings don't seem to do much of anything.
Yes. I have done the button config thing. I can't remember what I used though.
So I've unzipped a fresh copy of Raiden III, copied over the files from Dime333's FTP folder and set Rotate=1 in TTX.ini. Game works fine but no rotation. I'm running on a HP laptop with an i3 processor and Intel HD4400 graphics if that makes any difference although the game plays really well if I lie on my side to play it. Tried one of the Blaze Blue horizontal games out of curiosity and that worked first time. I really love shmups but this thing is doing my napper.
Success! Using the files uploaded by Dime333 and setting Loader Mode=4 in TTX.ini I have gotten Raiden 3 and 4 working nicely. Thank you very much gentlemen.
Dime333: could you possibly upload the files for the other vertical games to your FTP?
Gigapig: I have no bezels showing, do they only appear in Hyperlaunch?
If your using Game Loader and have enable BGImage in the ini, you should automatically get a bg.jpg appear in a folder called "Images". That is just a black background but you can swap it out with some that are supplied in the Game Loader zip.
It can also play background movies, but I have not had that working so far.
Sure. Could you specify the games for me?
Homura
Giga Wings Generations
Shikigami no Shiro III
Thanks Dime
Homura
Thanks Dime
Uploading now. Did you figure out how to set up Controls when using the loader?
Hi Dime, yes the controls were no problem. Thanks for uploading the latest files but unfortunately they didn't work the same way the Raidens did. I can run the games easily but none of the Loader Modes rotate. I think the problem may be the Intel graphics in this laptop, perhaps it's time to build a more macho machine. Think I'll have to put this one on hold for the time being. Many thanks for all your help.
No problem. How did you configure the Controls? I don't remember how I did it. Too bad it didn't work for you.
Hi Gigapig!
First of all, I'd like to thank you to help us with your amazing guide!
I've downloaded your TTX at Hyperspin FTP, but i notice that some games doesn't work, and the files looks like different from your guide.
Could help me with that? Thanks!
Same... I think you may want to look around for another exe or config file to get the same as what we have here. That way your wouldnt have the issue to talk of?
I'm using the same one as you guys from giga's torrent, I'll make a video whe I get home today to show the problem. But again, if you just launch the game straight from the folder and go into the input test with the xbox 360 controller plugged in, xpadder not running, you will see that the controller is supported natively and the buttons trigger different inputs for each player.
Ok i have the latest Hyperspin, and RocketLauncher, GigaPig i have followed your very excellent Tutorial - but i am wondering why i can not Audit the games on Taito Type X? i can launch the games from Hyperspin without any problems it seems.
yardley, I understand your problem but I don't see a way around it other than mapping P2 start (num-enter) via xpadder. The reversed controls for player 2 you perhaps would have to live with unless the exe can be hacked to reverse them and add the start button. I don't know if that's what's needed or if someone has done it already.
I did download a different version but that had the same issue but included some higher res exe's.
Perhaps someone else knows more.
