  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
Hi Guys,
a quick one.
I run Silent Hill from the folder of an separate emulator drive called E:, after going through config the game started to fail at startup and kept attempting to run the game in (was working before). Can someone please conform if the game has actually created local files on C: . The problem went away after I restored my C: from a backup image and as a result cleared anything that potentially was placed there.
cool i got xhair now...had to run it in windowed mode...which means bezel for it coming xD
thanks to all for all the input on this hread...specially gigapig for translating that ttx.ini for us :)
Thanks for your comments.
This is my public folder.
For more information speak don't know English.
Bad English, I'm sorry.
English doesn't matter. Your files helped many people. That is the important thing. Thank you.
Thanks for this. Can we get more info on what they contain?
Tested both sound fixes, the one from grad1u5 works fine but the sound is out of sync (most noticable is the guy yelling "NoooooO!" in the intro and appearing 2-3 seconds later)
The re-encoded movies from insertmorecoins doesn't seem to fix anything for me?
This must be hardware dependant as I don't have the same sync issues.
Anyone else notice the game runs quite slow? doesnt seem to get above 30fps on my i7 4770k, 16GB Ram, GeForce 770 GTX rig.
The enemies seems to move like they are in slow motion. Maybe it needs Triple Buffering to be forced on in the graphics driver to get 60fp? (Will test after work) or it's just not suited to my hardware. Pretty sure thats why the sound is out of sync.
I think the FPS must be locked at 30FPS, it lagged badly at the start of the game. dropping the res to 1280 x 1024 fixed that.
Great job, guy's!
Ok, done some more testing on this.
Silent Hill runs from either of my Hyperspin Drives (G:\ or Z:\)
The folders that it creates are:
'bemani_config' and 'Game Loader All RH'
located in:
Win7 C:\Users\<Username>\AppData\
WinXP C:\Documents and Settings\<Username>\Application Data\
Delete them if you are having problems and start agin.
People having problems with a missing crosshair - are you running this outside of Hyperspin or within Hyperspin? The crosshair is just a windows cursor replacement. If Hyperspin is set to hide the pointer, you prob won't be able to see it...
Are you running the KGSW.exe or the loader all RH file? I know for my, mine crashes at the exact same spot yours does if I run that RH file, but plays perfect when I use the KGSW.exe. Yeah, it has no crosshair, but I can deal with that. I am assuming you have already tried running from the KGSW file, but just in case you didn't, try that.
Not sure what OS you are on, but I am on Win7 64bit.
i have crosshair
using the loader all RH
works perfectly fine, my question was around local files created by the game on C: (which i know it does.. somewhere) which can stuff up the game, and this point was proven by me re-imaging my cab back from a image.
using win 7 x64
i think the local files CAN and ARE causing a large number of issues you guys are having by using me as an example.
Already tried that, no different.
Has anyone tried changing their Audio setup in windows to 5.1 or 7.1 and see if that fixed it? I have mine set to 7.1 as I use my laptop on my TV with full surround and when I use it with my Sennheiser HD590 headphones in Stereo or the Astro A50 in 7.1 it still works fine in stereo or surround. This is a general statement as I've not set the game up yet but will soon. :) Just seems odd that you have to re-encode a video to play it in stereo.
cant get crosshair to show on silent hill....also cant seem to be abole to set controls for it either via config file it came with....and apparently no player 2 atm?
the control config app doesn't seem to do anything. You have to run 'Game Loader All RS.exe' to get the crosshair to show.
RS or RH? mine came with "Game Loader All RH.exe"
which is what i use and no crosshair.
what about player2 controls?
Thanks
Controls can be changed with the Config.bat, although it's minimal, I only set Exit and Start.
Device is Keyboard.
From the "Control" section choose the key you want, So i choose "1" for start. Then click or double click 1P_START from the Action box. Do the same for the others.
You can check it's working by clicking the keys you've choosen from the control side and it should change on the Action side.
have you guys tried deleting the folder and starting fresh? It makes 2 folders in your C:\users\<<username>>\appdata\roaming\ folder, delete those too and try again (Sorry, would be helpful if I gave you the names of them, but im not in front of my Hyperspin PC atm...)
All I do is:
-install LAVFilters
-run the controller config batch, then close it without doing anything.
-install the sound fix (either one)
-run the "Game Loader All RH.exe"
Haven't had the problems you described on either PC's I use.
