wahoobrian Posted May 15, 2015 Posted May 15, 2015 Great work and many thanks... form a personal standpoint... what Emu would people recommend in terms of reliability, controls and actual games working? I think I prefer Hatari, but honestly, you can't go wrong with either... Hatari or Steem SSE. They are both pretty good. There were a handful of games that I could only get to run on Steem. Once the FTP is taken out of read only mode, I'll upload my settings...
SIMPLYAUSTIN Posted May 15, 2015 Posted May 15, 2015 Thanks mate. But again, great work, I actually had one of these as a kid, but I had a MASTER SYSTEM at the same time so I never actually played it with any games hehehe what a waste! Simply Austin's YouTube
zerojay Posted May 15, 2015 Posted May 15, 2015 Official Atari ST XML released yesterday, check Downloads. Updated RL modules for Hatari/Steem SSE were released along with RL 1.0. Once FTP maintenance is complete, I can upload the matching module ini's to the FTP. This should be included with the module as Atari ST (Example).ini. Also I don't see a ROM set that matches up with your database...?
brolly Posted May 15, 2015 Posted May 15, 2015 When it comes to most systems apart from the mainstream ones (especially PC based systems) a single rom set will never include all the games available which is the point of the databases done within the project so you need to refer to several different sets. This is why making proper databases takes time and a lot of effort, creating them based on a single set only isn't that hard, but you'll be missing quite a few games normally.
dsync89 Posted June 13, 2015 Posted June 13, 2015 Give it a try. let me know if i forgot anything...which is quite possible 0) here is a video of it working for me kKnLkGIW1wA go here [[ http://craigandersonthemes.weebly.com/ ]] and click on "atari st" to find the files discussed below (NO ROMS, see below) This is whats working for me. I am not using STEEM directly because the gamebaseST setup is able to play games (in addition to the ones discussed above) that do not play via STEEM directly. Maybe someone can fix that but for now I am using this setup. I am not perfect. If you do not like my setup I am sorry........I will explain my little setup in more detail. But here are pics of My Settings. More explanation to come. 1) You will need to download the gamebaseST frontend from HERE ..... http://sourceforge.net/projects/gamebase/files/gamebase/v1.3/ ........ (thank you horseyhorsey) .....and then place the intact unzipped folder "GBST v3.1d" (from my download) into the gamebase 1.3 folder. just plop it on down inside there......use the "GBST v3.1d" from my download because some of the files have been modified to work. gamebaseST will be your "emulator" for the setup. And then this "emulator" will point to STEEM . 2) I am using "Steem SSE 3.4.1.exe".....its in my download as well. I think there are newer versions. I have not tested them. There are older versions in the gamebaseST download as well but so far the 3.4.1 has worked for me. 3) On this gamebaseST page (http://gbst.atomas.com/gamebase%20important%20README.php) there is a link for the games all organized the way they need to be organized for the gamebaseST frontend to work. It is (1598 MB). REMINDER: Do not use the "GBST v3.1d database" from this site (as mentioned in #1 above...use the one in my download. 4) Go inside gamebase.exe and set the paths to the emulator (steem) and the rom folder (Games). see video. lYzdz6fPztM 5) Here is my hyper hq settings. nothing to crazy here other that you will notice that the rom folder is not the same one that the gamebaseST is pointed towards in step 4 above. This is because (in my experience) the gamebaseST frontend only recognizes the roms/games when they are in the native folder setup as when downloaded from the gamebaseST site and this structure/setup includes subfolders (rom types followed by alphabet). 6) here is my HLHQ emulator settings. notice that GBLauncher.exe is the "emualtor". The rompath is pointing at dummy files (.txt) roms just to trick HLHQ into thinking we have them there. You cant point them at the gamebaseST "GAMES" folder because there are multiple subfolders. I have included my dummy files in the download. They are called "Roms for HLHQ" folder in the download. 7) Note the rompath for HLHQ is not the same as the path for the gamebaseST frontend. But it is the same as the one in step 6 above obviously. 8) If there is a game that just will not load via hyperspin/HLHQ, go into gamebase.exe and load it from there. It probably has a popup window that wants u to click something. But once you click it once, it remembers that choice and will open appropriately via hyperspin the next time. at least in my experience... . Really thanks for the elaborate explaination craig! Finally figured how GameBase and GameBase ST functioned and integrated them to my HyperSpin setup! Turned out that it's not really hard to setup once you know each of their role. P/S: I'm a fan of your work and downloaded almost all the artworks that you did on other obscure system not found on HyperSync.
walteric Posted June 20, 2015 Posted June 20, 2015 Hello, I setup Hatari 1.7 so that there're borders. All works fine (fullscreen + borders when I start the emulator). However, when I start from Hyperlaunch HQ (or Hyperspin), there's no border even if I set Emulators/Global Module Settings, Borders=true. In fact, I can modify all settings in Hyperlaunch (fullscreen or windowed, pointer, borders, etc..),, nothing will be. The emulator will always start in fullscreen, without border, without pointer... What happen with Hatari ? Thanks for your help
walteric Posted June 20, 2015 Posted June 20, 2015 Well, I tried modify all paramters, in all ini files but nothing can keep the borders... So I directly modified the ahk module file and now it works fine I think the problem comes from the incompatibility with the 1.7 version. The 2.0 ahk module seems for Hatari 1.6.2.
kenshutt97 Posted June 22, 2015 Posted June 22, 2015 I was having a focus issue. However, it seems when I opened the EMU solo, I could select the option for "always on top" but as soon as I launch out of RL, it would drop that setting. Read the update about fullscreen about having a game loaded first to fix the fullscreen. Seems the same thing applied to "always on top" Have to be in a game to get it to stick. Anyway, so it's focusing now, however, it drops the bezel for some reason. It drops it somewhere when the module seems to be controlling it. It loads initially with the bezel, then something happens and it drops. Any ideas?
nimpa Posted June 26, 2015 Posted June 26, 2015 I tried the "saint" atari st emulator.. And it has Xbox 360 support by auto.. Kinda messy configuring keys within steem for My Xbox 360 gamepad.. Atleast for me.. Maybe a silly, dumb and easy thing i have missed or something...
nathan1974au Posted August 12, 2015 Posted August 12, 2015 this is what i use! steem Ahk ------------------------------------------------------------------------------------------------------------------ MEmu = Steem MEmuV = v3.4.1 MURL = http://sourceforge.net/projects/steemsse/ MAuthor = rip from a hdd lol! MVersion = 2.0 MCRC = 4DB34981 iCRC = 1E716C97 MID = 635038268925531896 MSystem = "Atari ST" ;---------------------------------------------------------------------------- ; Notes: ; You must manually set a TOS using the emulator first. The UK version is preferred. ; If a game does not work properly check to see if there is a patch available. ; Be sure to read the controller options very carefully since sometimes your controls ; might only work if Scroll Lock is on or Num Lock is off. This needs to be set from ; within the emulator. ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) 7z(romPath, romName, romExtension, 7zExtractPath) Run(executable . " " . ((Fullscreen = "true") ? ("-fullscreen") : ("")) . " -nonotifyinit """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("ahk_class Steem Window") WinWaitActive("ahk_class Steem Window") FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() RestoreEmu: Send, {Pause} Return CloseProcess: FadeOutStart() WinClose("ahk_class Steem Window") Return ------------------------------------------------------------------------------------------------- ssd of steem ?xml version="1.0" encoding="UTF-8"?> <INISCHEMA> <INIFILES> <INIFILE name="%ModuleName%" required="false"> <INITYPE>Module</INITYPE> <SECTIONS> <SECTION name="Settings" required="false"> <SECTIONTYPE>Global</SECTIONTYPE> <KEYS> <KEY name="Fullscreen" required="false" nullable="false"> <KEYTYPE>Boolean</KEYTYPE> <DESCRIPTION>Enables/Disables Fullscreen</DESCRIPTION> </KEY> </KEYS> </SECTION> </SECTIONS> </INIFILE> </INIFILES> </INISCHEMA> (Midlife crisis) some have hot rods, some have gold chains, I have arcade machine with hyperspin.
spotUP Posted August 15, 2015 Posted August 15, 2015 So, most gamebase atari st games are set to autoboot? The problem with those is that they are IPF images and retroarch for windows is not built with IPF support, so retroarch can't launch them. I'd really like to run the games through retroarch with all the shaders and stuff.. hmm
wahoobrian Posted August 30, 2015 Posted August 30, 2015 Wahoobrian, any news on those ini files? =) They are now provided as the "example" ini files in the latest RL updates.
spotUP Posted September 1, 2015 Posted September 1, 2015 Cool! Only for the hatari module though? Retroarch uses Hatari as well so it should probably be there as well? I guess i can't just paste it in there?
brolly Posted September 2, 2015 Posted September 2, 2015 Nope that won't work, you need the Hatari module. Problem with using RetroArch is that while you can probably get away using it with console based systems when it comes to PC based ones they will always need a lot of settings and this would basically require every single module to be rewritten inside the RetroArch module which would soon become a huge mess. Just check the complexity of modules like WinVICE, WinUAE or Hatari and you can see how complex things would become if you merged them all together not to mention the nightmare that would be maintaining such a module, it would be basically returning to the HyperLaunch 1.0 days with a single huge script.
nathan1974au Posted September 25, 2015 Posted September 25, 2015 the best way to get wheels is to put every 8 bit and 16 bit wheels from all systems into a single folder and run dons renamer! saves making them! (Midlife crisis) some have hot rods, some have gold chains, I have arcade machine with hyperspin.
mccorkled Posted October 14, 2015 Posted October 14, 2015 Are there any tutorials on getting all ST games working through Hatari only? Aeon Nox XIII Themes Minted Cases w/ Reflection : Minted Cases : Minted XMLs
shitoken Posted October 20, 2015 Posted October 20, 2015 Hi Craig I have followed your post to setup Downloaded gamebase ST v.3.1d folder with 4 folders (emulator, games, music , screenshot) from this 4 folders only games one we will use am I right? Other folders any useful such Modplug, Jam , STsound? Inside game folder have 3 folders(HD,ST, STX) I have moved this game folder to H:\Games\Atari ST In this directory I have 2 folders now (Games & Roms for HLHQ) I did the setting in gamebase.exe for emulator path/filename But in the path it just like this H:\HyperSpin\Emulators\Atari ST (cannot select the exe) Under emulator name : Steem 3.4 Path for games :H:\Games\Atari ST\Games music/picture/extra (all left blank) When I try to run the game from gamebase directly receive error (7 zip failed unpack) If I use RL to launch the time after loaded nothing and with error to check the module Gamebase.ini [settings]Fullscreen=true Gamebase,ahk MEmu =MEmuV = MURL =MAuthor = craigandersonMVersion = 1.0MCRC =iCRC =MID =MSystem = "Atari ST";----------------------------------------------------------------------------;----------------------------------------------------------------------------StartModule()BezelGUI()FadeInStart()7z(romPath, romName, romExtension, 7zExtractPath)settingsFile := modulePath . "\" . moduleName . ".ini"Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1); disableHideTitleBar := true; disableHideToggleMenu := true; disableHideBorder := true; BezelStart("fixResMode")BezelStart()params := "db=""GBST v3.1d""" Run(executable . " " . params . " fn=""" . romName . """", emuPath)WinWait("ahk_class Steem Window")WinWaitActive("ahk_class Steem Window")executable:="Steem SSE 3.4.1.exe"BezelDraw()FadeInExit()Process("WaitClose", executable)7zCleanUp()BezelExit()FadeOutExit()ExitModule()CloseProcess: FadeOutStart() WinClose("ahk_class Steem Window") Process, Close, SainT161.exe Process, Close, Steem.exe Process, Close, 7z.exe Process, Close, GameBase.exeReturn --------------------------------------------------------------------------------------- What am I doing wrong here? Please help thanks
Guest Posted December 15, 2015 Posted December 15, 2015 Hi Craig I have followed your post to setup Downloaded gamebase ST v.3.1d folder with 4 folders (emulator, games, music , screenshot) from this 4 folders only games one we will use am I right? Other folders any useful such Modplug, Jam , STsound? Inside game folder have 3 folders(HD,ST, STX) I have moved this game folder to H:\Games\Atari ST In this directory I have 2 folders now (Games & Roms for HLHQ) I did the setting in gamebase.exe for emulator path/filename But in the path it just like this H:\HyperSpin\Emulators\Atari ST (cannot select the exe) Under emulator name : Steem 3.4 Path for games :H:\Games\Atari ST\Games music/picture/extra (all left blank) When I try to run the game from gamebase directly receive error (7 zip failed unpack) If I use RL to launch the time after loaded nothing and with error to check the module Gamebase.ini [settings] Fullscreen=true Gamebase,ahk MEmu = MEmuV = MURL = MAuthor = craiganderson MVersion = 1.0 MCRC = iCRC = MID = MSystem = "Atari ST" ;---------------------------------------------------------------------------- ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() 7z(romPath, romName, romExtension, 7zExtractPath) settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) ; disableHideTitleBar := true ; disableHideToggleMenu := true ; disableHideBorder := true ; BezelStart("fixResMode") BezelStart() params := "db=""GBST v3.1d""" Run(executable . " " . params . " fn=""" . romName . """", emuPath) WinWait("ahk_class Steem Window") WinWaitActive("ahk_class Steem Window") executable:="Steem SSE 3.4.1.exe" BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("ahk_class Steem Window") Process, Close, SainT161.exe Process, Close, Steem.exe Process, Close, 7z.exe Process, Close, GameBase.exe Return --------------------------------------------------------------------------------------- What am I doing wrong here? Please help thanks Use the official database, with that PMed link *wink*. Hitari is the way to go, works a treat with the official collection and RocketLauncher. Sent from my iPhone using Tapatalk
shitoken Posted December 16, 2015 Posted December 16, 2015 Use the official database, with that PMed link *wink*. Hitari is the way to go, works a treat with the official collection and RocketLauncher. Sent from my iPhone using Tapatalk Hi bro where can I get official database with pmed link? Sorry not much understandTapatalk を使用して私の A0001 から送信
Guest Posted December 16, 2015 Posted December 16, 2015 Hi bro where can I get official database with pmed link? Sorry not much understand Tapatalk を使用して私の A0001 から送信 The db is in the download section. Sent from my iPhone using Tapatalk
shitoken Posted December 27, 2015 Posted December 27, 2015 The db is in the download section. Sent from my iPhone using Tapatalk Hi Bro Some games run fine with Hitari and some just went to green screen with floppy 1 and 2 what should I do next ? How can I set to full screen instead?
Guest Posted December 27, 2015 Posted December 27, 2015 Hi Bro Some games run fine with Hitari and some just went to green screen with floppy 1 and 2 what should I do next ? How can I set to full screen instead? Post over at the RL forums and we will get you sorted. Sent from my iPhone using Tapatalk
Massimo76 Posted January 20, 2016 Posted January 20, 2016 hi guys, on my pc Windonws 7 64 bit gamebase wont start... it is only for 32 bit??
