If somebody makes a nice program icon image for my startup script, I'll release the version I'm currently working on with built-in support for 360 controllers. No need for any more xpadder or joytokey to navigate the hyperspin frontend. Also added support for launching and closing things when the hyperspin process closes.
Not what I was looking for. Anyways it's a .jpg, it needs to be an .ico file
i know it was just an example
sig.png 100%
I can make an ICO file out of anything you want as long as it is pretty good quality and preferably on a transparent background. :)
Please could you give an example for this
<code>Program_To_Run_Target_1=
Program_To_Run_Working_Dir_1=
Program_To_Run_MaxMinHide_1=
Program_To_Run_Target_2=
Program_To_Run_Working_Dir_2=
Program_To_Run_MaxMinHide_2=
Program_To_Run_Target_3=
Program_To_Run_Working_Dir_3=
Program_To_Run_MaxMinHide_3=
Process_Name_To_Close_1=
Process_Name_To_Close_2=</code>
thanks
That sounds very exciting, thank you.
Just to sweeten the deal I've added a couple of things.
A volume bar that pops up along the bottom of the screen which allows you to change or mute the volume while hyperspin is playing in the background. Need suggestions on a good default key that does not interfere with default hyperspin controls and is common on cabs (It will be user changeable if you don't like the decision).
A roulette button that will spin the wheel in a random direction for a random amount of time between a user definable range of seconds. In other words set the range to 3000 and 8000 and it will randomly pick a value between 3000 and 8000 and spin the wheel for that many milliseconds. Need suggestions on a good default key that does not interfere with default hyperspin controls and is common on cabs (It will be user changeable if you don't like the decision). Also should I add the option of making it select the item when it is done spinning or should I let the user have a choice to spin again?
Could make it do either depending on users config file or similar?
Yes indeed! It's amazing how many features that were missing from HyperSpin are gradually being added by 3rd party programs. Adding X360 pad support is a master stroke.
Do any of these take your fancy Ghutch? I can change them around, just having a play for you
[ATTACH=CONFIG]42999[/ATTACH] [ATTACH=CONFIG]43000[/ATTACH] [ATTACH=CONFIG]43001[/ATTACH]
Edit : hehehe that sounds bad :D
I like the symmetrical one (#3) it's just too fancy, make it solid without the pinstripe and add the same thickness white border to the circle. And flatten it out a little bit more.
Something like this?
[ATTACH=CONFIG]43003[/ATTACH] [ATTACH=CONFIG]43004[/ATTACH]
I added some shadow and a hit of glow just to make it stand from the page, being white
Better... Can you lose the shadows and green gradient and the white outer border?
Then make it look like the letters are glowing on a somewhat darker green background.
We're making progress :)
I will have a play now, see what I can do
[ATTACH=CONFIG]43044[/ATTACH] [ATTACH=CONFIG]43045[/ATTACH] [ATTACH=CONFIG]43046[/ATTACH]
I like the background on numbers 2 and 3. I like the font for 1. Can we use the 2 from the sega font and the S from the font for 1. Then connect them at the bottom like you did on the first samples you made, still keeping the S bigger than the 2?
Create an account
Register a new account
Sign in
Sign In Now
