  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
I finally got the game to load from the Arcade Loader RH file. here I a new problem though. I applied the sound fix, install LAV and FFDShow. if I run the game from the KHSG or KHSG no cursor, it is perfect, I just don't have a crosshair. Sound is great, cut scenes are great. However, if I run if from the Arcade Loader, I get the cursor and it runs fine, but the cutscenes are zoomed into the top left corner. So the first cutscene, where the guy is in bed, I see just the night stand. In the second, when they find their friend, I see a piece of his head. I went through the Config file but cannot figure out which setting to change, if any. Did this happen to anyone else and if so, how did you fix it?
I think I found it. If I run ForceDisplaySize=0 and DisplayMode=1, I run at the resolution I have set but cut scenes go like I described. If I run ForceDisplaySize=1 and DisplayMode=0, then I get the full window cut scenes but my resolution goes to something like 640X480. You can't set both to 1, it crashes and if you set them both to 0, that sets it to the worse resolution. I tried different loaders but no dice there.
Can I have both? Is there a setting I can change to allow me to force the resolution AND get the full size cut scenes? I guess if not, it is not too big a deal as I would only want to run the Arcade Loader RH file to get the crosshair. I'd rather have a better resolution though so if that is the case, I will just continue use the KHSG file.
Have you tried different loader modes ?
-1
2
3
4
5
Sent from my SM-N9005 using Tapatalk
sig2.png?raw=1sig.jpg?raw=1
Just curious...I thought my videos were working...but how long is the first video? Mine is like 3 seconds dude in bed then "Shoot, shoot!"
Sent from my SM-N900V using Tapatalk
I had that happen under certain conditions, I'm racking my brain as to what I did to cause it.
Was it something in the ttx.ini?
Was it those dodgy codec packs?
It may be a good idea to start over with a clean install and use the fix files that work for you.
Didn't those 2 channel video files get uploaded twice? The first time they were broken?
Sorry my memory sucks.
My videos do that too, I thought that was the norm lol
gig, do you not have Lav's pack installed? connorsdad, i need to have my coffee first, but I'll let you know if/once I make some progress.
It may have been that , but I've since dumped all the codecs and used the sound fix files from mediafire mentioned in the earlier post.
I will try that first. I'd rather not have codecs installed for just one game!
LAV has a tendency to pop up
In the system tray and with particular applications can start up the TTS service. This could be a possibility that causes crash issues. Perhaps looking at disabling the LAV system tray icons from showing notifications etc might help?
Just throwing ideas out there.
Did you grab and install the sound fix files? If not theres also the 2 channel files which I can Dropbox to you. But try the sound fix files.
Or even to the fix connersdad did
I have the sound fix from the post by Grad1us, where is the other fix? I would like to try that too. I noticed my cut scenes re very short. I have the LAV filters and did the ffddshow installed and still no have them real short.
-1
2
3
4
5
I did try them all. 2 of them work but they have the same outcome of a zoomed in cut scene. Is this happening to anyone else? Or am I the only lucky one?
Fyi, I'm in an arcade on Minehead seafront. It's full of fruities, pusher machines and grabber/ ufo catchers. All they have is Point Blank and a Marksman machine and a few driving games. :( I remember when it was full of the classics.
yes,I've been using the audio fix that grad1u5 provided which replaces the SE and EVENT folders in the .\Data\SOUND sub folder. It just won't get past any vid file without LAVs filters (bothx 86 and x64) installed. I'm using Win 7 Pro x64 and I can play fine with LAVs, i just wanted to get the videos perfect-ish without codecs, if possible.
I use Loader 5, but NOT all of the other ones crash (when LAVs filters are installed). (I'd have to test them again, if you really wanted to know)
Do you have DisplayWidth and DisplayHeight under DisplayMode? If so what's that set to?
You won't bloody believe it, I didn't and I walked straight past it the first time.
The screen needed adjusting as the colours were off, but there it is.
<a  href=ngK3XPi.jpg' alt='ngK3XPi.jpg'>
1280x1024, native for my 19" LCD. If I force it, cut scenes fill the screen and if I enable displaymode, they are zoomed to the top right corner.
Where can I find the full length cut scenes? I guess the other video files?
I figured out my issue with playing the full cut scenes. I went back and re-read the last couple pages and saw gigapig installed k-lite codes so I went and go the latest version (10.3), which uninstalled the LAV and ffdshow codecs I already had since it has newer ones. I went through and enabled the ffdshow like connorsdad did (I did this before but not all of them were supported - they all are now with the newer version) and now I get the full cut scenes to watch!
I still cannot figure out this screen resize deal and why forcing the screen to a higher resolution forces the cut scenes to be zoomed but no big deal. the game is supposed to run in 640X480 (from what I have read) so I will simply play it like that if I want crosshairs and I can always switch it if I don't want crosshairs.
Ok, So I was able to get Silent Hill playing with cross hair at full screen with full movies/intros minus LAV or ffdshow. I had to use the "2nd" audio files suggested by gigapig. From there I used gig's ttx.ini from his ftp (just as a control; I had messed with mines waaay too much), the only thing I had to mess with was I changed the [Window Size] to =1 then the resolution I changed to my native display 1920 x 1080. Dang, that was fun! Thanks for all that helped!
