  • 0
Taito Type X and Hyperlaunch 3.0
langersld
Question
I just wanted to get clarification that Taito Type X is working fine in the New RocketLauncher...
In the PC Launcher.ini...I am pointing the script to the bat files
eg:
[super Street Fighter IV]
Application=C:\Hyperspin\Games\Taito Type X\Super Street Fighter IV\Super Street Fighter IV.bat
AppWaitExe=game.exe
I seem to be getting an issue where the game starts fine but after 20 seconds closes and the Hyperlaunch "now loading page appears"
Any help appreciated
  • Answers 1.4k
Tanin... the files that are on the FTP are meant to be all copied across for the game and bezels to work.... Please dont complain about the game not booting if you are using your own AHK...
There is no need for you to custom irotate with the files provided....
I think he is running a vertical monitor Langers, that's why he has a custom ahk for rotating 270 degrees. He won't need our files, he would just need to run the game as it was intended.
Perhaps we need to amend something to make it clear the files are for a horizontal monitor.
Cheers :cheers:
Does anyone else have problems with using the PCLauncher fadetitles for the following games - KOFMIRA, TW and THG5? Hyperlaunch errors after a few mins of playing saying that it stopped waiting for the fadetitle app. I'm using gigapigs pclauncher.ini. If I remove the fadetitle line for those games, it works perfectly.
Also, why are people using USB drives for drive F:\ to have Otomedius work/save? You can just share a local folder and map to it as drive F:\
make a folder in the Otomedius folder called 'save'. Right click the folder and go to properties-sharing-advanced sharing. Tick the box for 'share this folder' and change the permissions for 'Everyone' so they have full read/write access. Then go to my computer and map a network drive to F. The path is \\pcname\foldername
I have repackaged Gigapigs files for TTX as there were far too much bloat and non required files and also missing important fixes like the dll that stops SF4 from crashing during the intro. There are other errors I have corrected including non existing games in the database (SSFIV - there are only SSFIVAE or version 2012) Will upload if anyone is interested?
Taito Type X working at last - thank you for all the help with this!
"You can fool some of the people all of the time, and all of the people some of the time, but you can not fool all of the people all of the time"
Abraham Lincoln, (attributed)
16th president of US (1809 - 1865)
Anyone have any idea why i can only get calamity trigger to run in windowed mode and not full screen?
You can change it with the loader but if you've used the Taito Type X files then hopefully you haven't used it.
In your Blazblue folder look for a file called setting.arc, open it in Notepadd++ and look for this line.
EnableProxyLibrary=1
Change the 1 to a 0 and that will give you full screen.
There a bunch of other settings as well, whether they make a difference or not I don't know; if you change anything back up the file first.
Shouldn't need additional DLL's or Config files for the BlazeBlue games. All you need is the modified game.exe, sv folder and .bat file to run it. (You need the files from the Typex_Loader_2009-12-29.zip but most games come pre packaged with this.) Should run Full Screen by default, never had a problem with this on AMD or NVIDIA cards.
Have you checked the FadeTitle and AppWait in the PCLauncher.ini, make sure they are correct or strange things be happenin'
hey guys i have a litlle problem with Trouble Witches
When I start the Game Afer 20 sec Hyperlaunche says canot found window : Trouble Witches
I have start Aktiv Window logger with Trouble Bitches and this ist the output
07:14:39 |  (¯·._.·´¯·._.·´¯·._.·´¯·._STARTING LOG_.·´¯·._.·´¯·._.·´¯·._.·´¯)
07:14:39 |  Title/Class: ƒgƒ‰ƒuƒ‹™ƒEƒBƒbƒ`[ƒY‚`‚b Version 1.00 ahk_class ƒgƒ‰ƒuƒ‹™ƒEƒBƒbƒ`[ƒY‚`‚b Version 1.00 is now active
07:15:00 |  Title/Class: ƒgƒ‰ƒuƒ‹™ƒEƒBƒbƒ`[ƒY‚`‚b Version 1.00 ahk_class ƒgƒ‰ƒuƒ‹™ƒEƒBƒbƒ`[ƒY‚`‚b Version 1.00 is no longer active
07:15:00 |  (¯·._.·´¯·._.·´¯·._.·´¯·._ENDING LOG_.·´¯·._.·´¯·._.·´¯·._.·´¯)
I have test to chage the PC LAuncher.ini to ƒgƒ‰ƒuƒ‹™ƒEƒBƒbƒ`[ƒY‚`‚b Version 1.00 as windowtitle but it didnt help
Urbangangsta suggested
"If I remove the fadetitle line for those games, it works perfectly."
So thanks to him for that.
I have also removed it and it seems to work fine without the fadetitle for that game. Why that has changed I don't know, or maybe it never needed it?
the problem is when i do this i didnt come back to hyperspin on exit
What control setup are you using? A game pad or iPac?
Setting an exit key in the pad config should return you fine if using a game pad. If you use ipac you may need to add the "Return Focus" AHK or EXE into the Post Exit window for that game.
This also works as a fadetitle on my system.
ƒgƒ‰ƒuƒ‹™ƒEƒBƒbƒ`[ƒY‚`‚b Version 1.00 ahk_class ƒgƒ‰ƒuƒ‹™ƒEƒBƒbƒ`[ƒY‚`‚b Version 1.00
so i have won the fight with the witches
i have put this as Fadetitle in the ini via the HLHQ editor not direct in the ini
the i had problems with the exit the game crashed on exit
i have found that the config from TW was the Exit Button on ESC change it to another Key
And Now its runs !
Does anyone with a ATI graphics card have BlazBlue Calamity Trigger running without strange graphical errors? (mostly black screen, red character, etc)
Hi Klizine.... i think your out of luck there mate... Ive had huge graphical errors with ATI cards and BCT( lots have been reported)... changed to Nvidia no more problems...
I think you will also have issues with Samourai Shodown Edge of Destiny
Thanks langersld. I was affraid of that. Sad that the only thing the 'ol girl can't handle is one game. (shodown was the 1st game I got working....somehow) BBCT even runs on my dinky laptop...
And I'm back :(
I'm in the process of building a bartop, having cloned the hdd most of my emus/roms work fine, apart from this evil soab. I need to setup the vertical shooters from scratch as this cab won't feature a rotating monitor, some of the horizontal roms don't work due to using a different resolution in this build. Let's see if the gigaguides help me :)
Sent from my SM-N9005 using Tapatalk
sig2.png?raw=1sig.jpg?raw=1
Give it a try, I did and it works. :)
And good to have you back bro.
And did you ever post a video of that behemoth working, I wanted to see that rotating screen, and what is that little remote all about?
The little remote is to control the led strip at the bottom of the cab and the control panel down lighting, it changes the colour/flash/fade speed etc. Never did get around to doing a full video although I did post 2 short clips.
I figured out a brilliant method to get Taito working perfectly. Once I build my cab PC I'm dragging the thing up to langersld's place with a case of beer. :D
That is a neat idea and one I'd love to be part of ( if invited of course) I'm sure he can afford my air fare :P
Gentlemen "Me Casa, Su Casa"..... :beer:
Does anyone have gigawing saving high scores ?
Yes, working fine.
It seems the game doesn't like the initials POT :canabis:
Never known a game to police the scoreboard before :secruity:
Thanks to Gigapig for his help with this, you're a top bloke :top:
